OVMS App Charge Status
With my new RAV4 EV port, every time there is a charge status change, the OVMS App pops up a notification that Charging Stopped. Even when a charging session is starting, the notification says Stopped. What do I need to set so that the notification indicates the correct state change? Also the Vehicle status pane on the web server Status page always says "Not Charging", even when the ms_v_charge_state is "charging" and ms_v_charge_inprogress is TRUE. Also, where do I send my stock image so it can be included in the app? Thanks, - Mike
Mike, see here on how to set the standard charge state metrics: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master... Explanations of these can be found here: https://docs.openvehicles.com/en/latest/userguide/metrics.html#standard-metr... On adding images to the Android App: https://github.com/openvehicles/Open-Vehicle-Android/wiki/Adding-Vehicle-Ima... Regards, Michael Am 14.03.22 um 04:39 schrieb Michael Iimura:
Thanks,
- Mike
Michael Balzer -
Michael Iimura
