Anyone know the correct apn, username and password for this? Begin forwarded message:
Parameter command I used: PARAMS K SMS,IP 64.111.70.40 http://pda.t-mobile.nl - - ... Any idea what to check?
Name: T-Mobile NL APN: smartsites.t-mobile Proxy: <not set=""> Port: <not set=""> Username: * Password: * Server: * MMSC: http://t-mobilemms<http://t-mobilemms/> MMS proxy: 010.010.010.011 MMS port: 8080 MCC: 204 MNC: 16 APN type: default From: Mark Webb-Johnson <mark@webb-johnson.net<mailto:mark@webb-johnson.net>> Reply-To: OVMS Developers <ovmsdev@lists.teslaclub.hk<mailto:ovmsdev@lists.teslaclub.hk>> Date: woensdag 9 mei 2012 12:43 To: "ovmsdev@lists.teslaclub.hk<mailto:ovmsdev@lists.teslaclub.hk>" <ovmsdev@lists.teslaclub.hk<mailto:ovmsdev@lists.teslaclub.hk>> Subject: [Ovmsdev] NL t-mobile apn Anyone know the correct apn, username and password for this? Begin forwarded message: Parameter command I used: PARAMS K SMS,IP 64.111.70.40 http://pda.t-mobile.nl - - ... Any idea what to check? Mark Ramakers CFO Talpa Holding N.V. Zevenend 45 - 1251 RL Laren P.O. Box 154 - 1250 AD Laren The Netherlands T +31 35 53 33 553 E MRamakers@talpa.tv W http://www.talpa.tv Chamber of commerce registration number 32083875 Talpa Holding is part of the Talpa Group -------------------------------------------------------------------------- The information contained in this communication is confidential and may be legally privileged. It is intended solely for the use of the individual or entity to whom it is addressed and others authorised to receive it. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or taking any action in relation to the contents of this information is strictly prohibited and may be unlawful. Neither the sender nor the represented institution are liable for the correct and complete transmission of the contents of an e-mail, or for its timely receipt. --------------------------------------------------------------------------
Mark Ramakers -
