Hi all, Hi Michael, Listen, first things first: Wow, what a f*cki’n crazy great job you’ve done there !!! Now: well, works as expected on my Twizy45, Tried these on a very short run: POWER 120 115 110 (I believe I feel a slight difference, but not that obvious) SPEED 60 75 (didn’t have any slope to go beyond, got up to 60 neat and fast, kind of surprising/scary at first) RECUP 27 42 Ok, Recup: 27 instead of the default 21 (on the T45) is sensible, at the limit of slowing down a bit to fast for the following cars without a brake light 42 on brake is scary: you’re already at 27, once you barely touch the brake, 42% recuperation kicks in after half a second, so you get your expected friction-brake slowdown and boom, an extra slow down from recuperation… 42 is really too agressive, making an in between/modulated foot controlled slowdown nearly impossible… Will try 25 35 (Delta of 10% instead of 15%) We’ll see… Again: w00t! in town the crazy parisians will be less tempted to push me over the road as long as I can keep up with their illegal speeds ! (note: This is to be done at your own risk, mostly legal) (sorry for the lack of mail quote, I deactivated the digest mode which is kind of a pita) -- Julien (JaXX) Banchet
Hi Julien, thanks :-) Great to read everything works as designed :-) Supplementing the POWER command, you should also try RAMPS 100 100 + SMOOTH 0 -- this sets start and acceleration ramps to maximum speed and disables smoothing. This makes the Twizy much more responsive to the throttle and can make more difference than the 11% torque increase (120% will be cut down internally to 111%). For RECUP, take a look at docs/Twizy-Torque-Speed-Profiles.ods: you can shape the braking recuperation strength per speed. Try: TSMAP B 80 100 60 40 -- this is from sheet 2 "Recup1" and will shift the braking recup max to ~39 kph. This works pretty well on the T80 with 40% braking recup level. Btw: the TSMAP speed points are at the same for the T45. Regards, Michael Am 26.01.2014 19:20, schrieb Julien (JaXX) Banchet:
Hi all,
Hi Michael,
We’ll see…
-- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
Sure will try tomorrow ! Maybe something like this CFG RECUP 25 35 CFG TSMAP N 100 100 80 50 CFG TSMAP B 75 100 80 60
39 will have a recup kick with breaks (urban situation anyways, barely ever over that speed, unless I leave early enough :-) ) the sub 33kmh will have near matching values between neutral and breaking, a no surprise zone in other words
Won’t be getting back much more juice in the end but well, it’s still that :) Will give a shoot to the RAMPS/SMOOTH combo as well, MfG, JaXX ------------------------------------------------------ De: Michael Balzer dexter@expeedo.de Répondre: Michael Balzer dexter@expeedo.de Date: 26 janvier 2014 at 19:58:38 À: Julien (JaXX) Banchet jaxx@jaxx.org, ovmsdev@lists.teslaclub.hk ovmsdev@lists.teslaclub.hk Sujet: Re: [Ovmsdev] Twizy45 testing needed
Hi Julien,
Regards, Michael
Hi all,
Hi Michael,
We’ll see…
The flexibility in the tuning of this is making me very jealous! Mark. On 27 Jan, 2014, at 3:14 am, Julien (JaXX) Banchet <jaxx@jaxx.org> wrote:
MfG,
JaXX
Hi Julien,
Regards, Michael
Hi all,
Hi Michael,
We’ll see…
-- Julien (JaXX) Banchet _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
:) Well, 11km run, with a few higher speed portions. Achieves illegal speeds swiftly ! (I'll put it back to normal) RAMPS/SMOOTHING combo kicks, literally. Actually, when putting the power on, you can hear a "knock" sound, like if the motor made a x° rotation to sync in some position, but I could be wrong. At low speeds, pushing or releasing the accelerator is immediate followed by the expected behavior, making the car rock a bit. Range seems affected, no massively but there is a difference, of course, will have to see that over time, plus it was freezing. see ya soon ! Le 27/01/2014 02:17, Mark Webb-Johnson a écrit :
Mark.
MfG,
JaXX
Hi Julien,
Regards, Michael
Hi all,
Hi Michael,
We’ll see…
(sorry for the lack of mail quote, I deactivated the digest mode which is kind of a pita) -- Julien (JaXX) Banchet -- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
The "knock" sound is due to the gear box being coupled a little bit loosely. This knock can also be heard on rapid load changes. That's why the "start" ramp is normally so slow (3% on the T45, 4% on the T80), SEVCON calls this parameter "oscillation damping for loose gear boxes". So 100% instead is of course a radical change ;-), experiment with this value (first RAMPS param) until it sounds ok. Range will be affected by "race modes", but you can also configure "eco" modes as well. You can also gain a little bit range through higher recuperation, if you carefully use the power plus. It's all in your foot :-) Regards, Michael Am 27.01.2014 09:14, schrieb Julien (JaXX) Banchet:
see ya soon !
Mark.
MfG,
JaXX
Hi Julien,
Regards, Michael
Hi all,
Hi Michael,
We’ll see…
Hi, Sorry for the late extra report. Well, it gave me time to try the setings with a bit more time. I bet some had a concern about the effect of these settings on range. Well after a few days of adapting, I can say that it has very little effect on range, less than a 10% cutback depending on driving habits, though achieving better and needless to say "Safer" performances. I'm mostly against vehicle modifications of such sort, that said, on a country to country basis, the 45kmh limitation on 50kmh limited roads is in the end a bit dangerous where people are aggressive to the least while driving (I've only had good surprises in most surrounding countries). Therefor, being able to reach 50kmh, or even a tad more to keep up with the flow, avoids being pushed (or bullied) too much. (I did try 60 (+2) on some 70kmh segments, but rarely ever went over 50 in general. The simple fact of having a bit extra watts in the wheel shows that the Twizy deserves respect, the bullying evaporates with it :-) But this can be a subject of much debate. So again, with all the subjectivity this post can have, I believe that Michael has done a tremendous job! Thanks ! Oh, be aware: despite the bitter cold and it's effect on the traction battery, I estimate I kept my previous average of 70km of range, and still have my usual 3 stars on the eco-meter, though it takes a sensibly softer foot on the pedal. But, these mods will drastically change the speed of variation of the range-meter. Extra power with extra recup makes the estimation less smooth, obviously :-) All I need now is a "Low Service Battery" alert, idiots managed to turn just about everything on (mainly the warning lights) and killed the service battery the other night :-) Hugs and drive Safe ! JaXX ( damn, despite being the coolest driver in town, I hope no cops are reading this, my name is on the car o_O ) Le 27/01/2014 12:44, Michael Balzer a écrit :
Regards, Michael
see ya soon !
Mark.
MfG,
JaXX
Hi Julien,
Regards, Michael
Hi all,
Hi Michael,
We’ll see…
Hi Julien, thanks for the extended feedback! Why there's the 45 kph class on vehicles while it's 50 kph on streets I will never understand. Some years ago it used to be 60 kph on this vehicle/license class. Some say the 45 kph nonsense is a result of lobby work of some international driving school conspiracy to sell more motorcycle licenses... For the "low service battery" alert: you already have this, it's the 12V alert feature I implemented some releases ago. The alert just needs a reference voltage from the last charge cycle. If you did not receive that alert despite having charged at least once since mounting the OVMS, check your notification configuration. Regards, Michael Am 04.02.2014 09:17, schrieb Julien (JaXX) Banchet:
Hi,
JaXX
Michael, Oh, I did have the impression I had it somehow when the OVMS was still home in my lab on a 10 year old power supply... Plus it IS written black on white in the user guide :): "If the car does not power up, that can be due to low voltage on the 12V battery: try charging! The OVMS will send an alert if it detects the voltage dropping below 11.5V reminding you to charge in time." Well, thanks, gonna dive back in it, might have knocked off the SMS alerts somehow :-) JaXX./. Le 04/02/2014 12:44, Michael Balzer a écrit :
I think you missed saying 'allegedly' or 'hypothetically' in the below post. As in 'allegedly doing 50kph' or 'hypothetically 60kph' ;-) Regards, Mark
On 4 Feb, 2014, at 4:17 pm, "Julien (JaXX) Banchet" <jaxx@jaxx.org> wrote:
Hi,
Regards, Michael
see ya soon !
Mark.
MfG,
JaXX
Hi Julien,
Regards, Michael
Am 26.01.2014 19:20, schrieb Julien (JaXX) Banchet: > Hi all, > > Hi Michael, > > Listen, first things first: > Wow, what a f*cki’n crazy great job you’ve done there !!! > > Now: well, works as expected on my Twizy45, > Tried these on a very short run: > POWER 120 115 110 (I believe I feel a slight difference, but not that obvious) > SPEED 60 75 (didn’t have any slope to go beyond, got up to 60 neat and fast, kind of surprising/scary at first) > RECUP 27 42 > > Ok, Recup: 27 instead of the default 21 (on the T45) is sensible, at the limit of slowing down a bit to fast for the following cars without a brake light > 42 on brake is scary: you’re already at 27, once you barely touch the brake, 42% recuperation kicks in after half a second, so you get your expected friction-brake slowdown and boom, an extra slow down from recuperation… 42 is really too agressive, making an in between/modulated foot controlled slowdown nearly impossible… > Will try 25 35 (Delta of 10% instead of 15%) > > We’ll see… > > Again: w00t! in town the crazy parisians will be less tempted to push me over the road as long as I can keep up with their illegal speeds ! > (note: This is to be done at your own risk, mostly legal) > > > > (sorry for the lack of mail quote, I deactivated the digest mode which is kind of a pita) > -- > Julien (JaXX) Banchet -- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
Mark, You are totally right in pointing this out, thank you by the way, you totally understood where I wanted to get to, and it is not so often that someone helps me in improving my english, ya'all know how French are with foreign languages :-) ;-) JaXX./. Le 04/02/2014 16:31, Mark Webb-Johnson a écrit :
Mark Webb-Johnson -
