Change to API for vehicle poll0 and poll1 functions
I just committed a change to all vehicle modules, to change the api for the poll0() and poll1() functions. 1aaa0a3 Move can bus low level register access to vehicle.c, out of individual vehicle modules The new API sets up: unsigned int can_id; // ID of can message unsigned char can_filter; // CAN filter unsigned char can_datalength; // The number of valid bytes in the can_databuffer unsigned char can_databuffer[8]; // CAN message bytes prior to the calls to poll0() and poll1(). So, the individual vehicle modules no longer need to (and no longer are able to) access the low-level CAN bus registers in any way. I tried to move all the vehicle modules to the new mechanism, but there seemed to be significant differences in the way each module did things. Hopefully the work I did was ok and hasn’t broken anything, but please check your respective modules to make sure they still work. Overall, we’ve saved about 500-to-600 bytes of flash doing this. I’ve labelled this 2.6.1, as it has the capacity to break things. Regards, Mark.
Hi mark, i did this in "vehicle_voltampera.c:" in 2.2.7 else if (id == 0x7e9) { switch (pid) { case 0x2487: //Distance Traveled on Battery Energy This Drive Cycle edrive_distance = KM2MI((can_databuffer[5] + ((unsigned int)can_databuffer[4] << 8)) / 100); // German Volt Report im KM if ((edrive_distance > va_drive_distance_bat_max) && (car_chargestate == 4)) va_drive_distance_bat_max = edrive_distance; break; } } cause the return value is placed on 2 Bytes. I think it is necessary to implement a parameter how much return byte expected. Bye Michael Am 02.11.2013 um 14:14 schrieb Mark Webb-Johnson <mark@webb-johnson.net>:
Mark Webb-Johnson -
Michael Jochum
