Enjoy
Begin forwarded message:
From: mark@openvehicles.com Subject: OVMS Nightly Firmware Build 3.1.009 Date: 15 August 2018 at 8:11:30 PM HKT To: mark@openvehicles.com
3.1.009 Wed Aug 15 12:11:30 UTC 2018 Automated build (markhk8)
Total sizes: DRAM .data size: 16452 bytes DRAM .bss size: 32864 bytes Used static DRAM: 49316 bytes ( 131420 available, 27.3% used) Used static IRAM: 107932 bytes ( 23140 available, 82.3% used) Flash code: 1328694 bytes Flash rodata: 612052 bytes Total image size:~2065130 bytes (.bin may be padded larger)
* 92d8501 (HEAD, tag: 3.1.009, origin/master, origin/HEAD, master) Known Issues, ready for 3.1.009 * 9dd6131 Changes and TODO, ready for 3.1.009 * 8724c1d Merge pull request #152 from caederus-ovms/units |\ | * e0aa195 Use correct SI unit abbreviations for distance (km), speed (km/h), acceleration (km/h/s - as an alternative to the usual m/s²). | * 51ce2a2 If converting value to different unit, AsUnitString() should also convert unit name. |/ * 3c05772 TeslaModelS: Add support for CAN2 and CAN3, and decode MCU GPS lat, lon, heading, and HDOP * 0e3c6d4 Twizy: fix missing charge records in RT-PWR-Log * 7192be1 Minor command description changes to sync with user guide * 3704933 Wifi: add RSSI level to status output * 4cf3dba Merge pull request #150 from bobbo3/master |\
