I’ve committed a rather large patch to the CAN LOG framework in master. Changes include: Move to a connection-based framework, to better support multi-connection loggers Support single connection loggers as a simple use case of multi-connection loggers Move some functionality to the base canlog class, to remove burden from individual loggers Re-work the formatter transmit callback mechanism to work off the connection objects (rather than the nasty transmit callback previously used) Add support for dynamic per-connection pausing Add support for dynamic per-connection filtering Add support for control commands via CAN LOG clients Implement control commands in CRTD formatter Improve documentation for the CRTD format Apart from the change in appearance to the ‘can log status’ command, this should be backwards compatible. It seems to work for me, but I will do a lot more testing over the coming few evenings. Trying to get ready for some other work that leverages this capability. Regards, Mark
