Hi all, as I can't find the CAN-ID's for TPMS for the VW e-Up at the moment, I thought I just disable the feature, so the app won't display the TPMS boxes unnecessarily. In OVMS v2 this was possible by setting car_stale_tpms = -1 so the last number sent by the "W" message to the server was -1. With that -1 the app will not display the TMPS boxes. The code in ovms_server_v2.cpp for the message is now extram::ostringstream buffer; buffer << "MP-0 W" << StandardMetrics.ms_v_tpms_fr_p->AsString("0",PSI) << "," << StandardMetrics.ms_v_tpms_fr_t->AsString("0") << "," << StandardMetrics.ms_v_tpms_rr_p->AsString("0",PSI) << "," << StandardMetrics.ms_v_tpms_rr_t->AsString("0") << "," << StandardMetrics.ms_v_tpms_fl_p->AsString("0",PSI) << "," << StandardMetrics.ms_v_tpms_fl_t->AsString("0") << "," << StandardMetrics.ms_v_tpms_rl_p->AsString("0",PSI) << "," << StandardMetrics.ms_v_tpms_rl_t->AsString("0") << ((stale)?",0":",1") ; Transmit(buffer.str().c_str()); and that gives no room for sending a -1 as far as I understand it. Is this a bug, a feature, or am I missing something? Thanx for help Greetinx Chris
Looks like an oversight. The spec says:
Car TPMS message 0x57 “W” This message is sent <cartoserver> “C”, or <servertoapp> “s”, and transmits the last known TPMS values of the vehicle.
<data> is comma-separated list of:
front-right wheel pressure (psi) front-right wheel temperature (celcius) rear-right wheel pressure (psi) rear-right wheel temperature (celcius) front-left wheel pressure (psi) front-left wheel temperature (celcius) rear-left wheel pressure (psi) rear-left wheel temperature (celcius) Stale TPMS indicator (-1=none, 0=stale, >0 ok)
We can test the metrics to see if they are defined. If not, then set stale to -1. Should just be another line in the server v2 code. Can you create a github issue, and I will fix. Or make the fix yourself and pull request? Regards, Mark
On 6 Mar 2020, at 6:31 PM, Chris van der Meijden <chris@arachnon.de> wrote:
Hi all,
Thanx for help
Greetinx
Chris
Hi Mark, thank you for your quick response. I created an issue on github. I feel still a bit to unexperienced to start coding on the core elements of OVMS. Thank you for your help. Regards Chris Am Freitag, den 06.03.2020, 20:03 +0800 schrieb Mark Webb-Johnson:
Car TPMS message 0x57 “W” This message is sent <cartoserver> “C”, or <servertoapp> “s”, and transmits the last known TPMS values of the vehicle. <data> is comma-separated list of: front-right wheel pressure (psi)front-right wheel temperature (celcius)rear-right wheel pressure (psi)rear-right wheel temperature (celcius)front-left wheel pressure (psi)front-left wheel temperature (celcius)rear-left wheel pressure (psi)rear-left wheel temperature (celcius)Stale TPMS indicator (-1=none, 0=stale,
0 ok)
wrote:
Hi all,
Thanx for help
Greetinx
Chris
Hi Mark, I merged the new code, compiled and it works like charm. No more TPMS boxes for the VW e-Up within the app :-) Thank you very much. Greetinx Chris Am Freitag, den 06.03.2020, 14:47 +0100 schrieb Chris van der Meijden:
Hi Mark,
Regards
Chris
Car TPMS message 0x57 “W” This message is sent <cartoserver> “C”, or <servertoapp> “s”, and transmits the last known TPMS values of the vehicle. <data> is comma-separated list of: front-right wheel pressure (psi)front-right wheel temperature (celcius)rear-right wheel pressure (psi)rear-right wheel temperature (celcius)front-left wheel pressure (psi)front-left wheel temperature (celcius)rear-left wheel pressure (psi)rear- left wheel temperature (celcius)Stale TPMS indicator (-1=none, 0=stale, >0 ok)
On 6 Mar 2020, at 6:31 PM, Chris van der Meijden <chris@arachnon. de> wrote:
Hi all,
Thanx for help
Greetinx
Chris
Chris van der Meijden -
