Mark, I've had lots of broken pipes on the car side yesterday and I've got the same for the app side today. Do you know of any change on the server side that could cause this? Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Uh... just after sending, I remembered my new Edimax plug script running as a cron job. And indeed: the app loses the connection each time the status.pl script checks the SOC (currently once per minute). It's not related to the router / NAT, as my phone loses the connection right at the same time. Seems to be some bug in the server code regarding multiple client connections to the same vehicle id... I'll have a look. Regards, Michael Am 21.08.2015 um 17:48 schrieb Michael Balzer:
Mark,
Regards, Michael
Mark, on line 485 sub io_terminate deletes all app_conns of the vehicleid: delete $app_conns{$vehicleid}; I changed that to delete only the $fn entry: delete $app_conns{$vehicleid}{$fn}; ...which seems to fix the bug, my local test server no longer closes all app connections as soon as one terminates. Do I miss something? Regards, Michael Am 21.08.2015 um 18:01 schrieb Michael Balzer:
Regards, Michael
Mark,
Regards, Michael
Yep, that looks correct. Nice find. Regards, Mark.
On 22 Aug, 2015, at 1:27 am, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
Regards, Michael
Mark,
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 <dexter.vcf>_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Thanks for installing the fix, all scripts now work without disconnecting the Apps. Btw: my Edimax smart plug script inspired another user to create a version for the Homematic system, he gave his OK to include that as well. It's now located under "client/homematic". It also checks the GPS location and automatically switches the charge plug on when the car comes home. Coupling the OVMS with home automation systems is really easy and adds a lot of geek value ;-) Regards, Michael Am 23.08.2015 um 14:36 schrieb Mark Webb-Johnson:
On 22 Aug, 2015, at 1:27 am, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Regards, Michael
Regards, Michael
Mark,
Regards, Michael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 <dexter.vcf>_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
