Re: [Ovmsdev] crash when calling 12 V history
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/892 This one is one me, and not sure how I missed it. //.ichael On Thu, 4 May 2023 at 15:45, Simon Ehlen <ovms@highteq.de> wrote:
Hello Michael,
after Michael Balzer's hint that I should take a closer look at the JSON string, I noticed that the error is in vehicle.cpp, which was changed in November.
When concatting the string some elements (yAxis, comma, closing) were forgotten.
You can see it if you compare for example the version of the Ioniq5 against the one of the standard class.
vehicle.cpp: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master... hyundai_ioniq5: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master...
I would be grateful if you could create a PR, because I am currently not 100% sure whether in my vehicle.cpp not individual adjustments of me are in there, with which I would not like to "pollute" the official repo.
What I noticed is that the gauges sometimes show different values than the label would lead you to believe.
For example, instead of the engine temperature, the SOC is displayed.
I am not familiar with the dashboard coding and would be grateful if you could show me where the values are assigned to the various gauges.
Cheers,
Simon
Am 03.05.2023 um 02:10 schrieb Michael Geddes:
It's probably worth seeing if you can see the fresult that is being returned causing the issue.. Being logged in the vfs-fat debug stream :/.
On Wed, 3 May 2023, 1:38 am Simon Ehlen, <ovms@highteq.de> wrote:
Hello,
since a few days my OVMS crashes as soon as I call the 12 V history monitor from the webinterface. The crash happens right after the click in the menu even before the history web page is loaded. I have not made any changes to my firmware recently nor any changes to the 12 V history at all. Yesterday I compiled the current version as a test, but the error occurs there as well.
Attached is the information from a2l with the backtrace.
Cheers, Simon_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Yeah. The order is critical. I should probably have done it a slightly different way for the final putting together. Michael On Thu, 4 May 2023, 4:24 pm Michael Geddes, <frog@bunyip.wheelycreek.net> wrote:
//.ichael
Hello Michael,
Cheers,
Simon
Hello,
Michael Geddes
