Currently the documentation says: https://docs.openvehicles.com/en/latest/userguide/console.html With OpenSSH version 6.6 (or later), cipher aes128-cbc has been disabled by default and needs to be enabled manually but this does not appear to be needed with the version of wolfssh we're currently using. My FreeBSD desktop has OpenSSH 7.9p1 in the base system and "/usr/bin/ssh -F /dev/null ovms-z.alameda.xse.com" (i.e. no config file) works fine. Meanwhile, OpenSSH 8.8 (which I've been using via the ports system since October) disables ssh-rsa by default so I had to add something simlar to: Host ovmsname.local HostkeyAlgorithms +ssh-rsa PubkeyAcceptedAlgorithms +ssh-rsa to my .ssh/config. If someone would confirm my understanding of the current state is correct, I'd be happy to generate a PR to update the doc. Craig
Craig,
You're right, this was a case of documentation not being updated to match the code. The update to WolfSSH 1.4.5 and WolfSSL 4.6.0 removed this restriction. That occurred a year ago (January 2021).
That is also correct. I believe the code as currently configured requires an RSA key. I see "NO_DSA" included in the user_settings.h that might be OK to remove. Some of the configuration trimming was to save space and some was to avoid the need for the slow calculations. Thanks for updating documentation. -- Steve
Perfect, thanks for the details.
I suspect RSA is the "best" WolfSSL 4.6.0 supports. And I'm ok with NO_DSA staying in effect: http://www.openssh.com/legacy.html OpenSSH 7.0 and greater similarly disable the ssh-dss (DSA) public key algorithm. It too is weak and we recommend against its use. PR #700 created. Craig
Craig Leres -
Stephen Casner
