I’m doing some work on optimising RAM usage in OVMS v3.1. This is to try to make space for bluetooth, etc. First step is fixing the (broken) SPIMEM_AGGRESSIVE option to work better. Saving is worthwhile: Without aggressive: Free 8-bit 113116/281672, 32-bit 8020/24276, SPIRAM 4140964/4194252 With aggressive: Free 8-bit 137380/281640, 32-bit 8020/24276, SPIRAM 4108616/4194252 That is the first step only. We are still using far too much internal RAM, and almost the whole 4MB of external RAM is sitting idle. The reason for this eMail: Hopefully I didn’t break anything. If I did, let me know. Regards, Mark.
Begin forwarded message:
From: GitHub <noreply@github.com> Subject: [openvehicles/Open-Vehicle-Monitoring-System-3] 2816b9: Support minimal build (all components disabled) - ... Date: 16 May 2018 at 10:13:49 AM HKT To: mark@webb-johnson.net Reply-To: GitHub <noreply@github.com>
Commit: 23f307757abb6411f77500182b72b11417019317 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/23f3... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/23f307757abb6411f77500182b72b11417019317> Author: Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> Date: 2018-05-16 (Wed, 16 May 2018)
Changed paths: M vehicle/OVMS.V3/main/ovms.cpp M vehicle/OVMS.V3/main/ovms.h
Log Message: ----------- Correct implementation of CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE.
Looks good, no problems up to now. I've been building with SPIMEM_AGGRESSIVE before using the 3.1 defaults. With the two new bluetooth memory options enabled… CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=y CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=y …I now get this bluetooth memory footprint: OVMS# power bluetooth status Power for bluetooth is off OVMS# module memory Free 8-bit 66336/230084, 32-bit 232/376, SPIRAM 4045440/4194252 OVMS# power bluetooth on Power mode of bluetooth is now on I (140846) bluetooth: Powering bluetooth on... I (140906) BTDM_INIT: BT controller compile version [a4252a2]| I (140956) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE E (141186) BT: bta_gattc_co_cache_addr_init, Line = 334, nvs flash get blob data fail, err_code = 1102 I (141236) bluetooth: Reg app succeeded with inteface ID 3 D (141286) bluetooth: event = 0| D (141336) bluetooth: GAP_EVT, event 22| D (141386) bluetooth: GAP_EVT, event 0| D (141446) bluetooth: GAP_EVT, event 1| D (141506) bluetooth: GAP_EVT, event 6| I (141546) bluetooth: advertising start success OVMS# module memory Free 8-bit 37824/230084, 32-bit 232/376, SPIRAM 4018840/4194252 --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM tiT 464 664 0 7980 +0 +0 +0 +4 OVMS NetMan 4 14712 100 32248 +0 +9968 +0 +20 btController 0 88 0 0 +0 +88 +0 +0 Btc_task 0 14924 0 1304 +0 +14924 +0 +1304 btuT 0 2252 0 23492 +0 +2252 +0 +23492 OVMS# module memory Free 8-bit 37556/230084, 32-bit 232/376, SPIRAM 4017244/4194252 --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM tiT 464 912 0 7980 +0 +248 +0 +0 wifi 1568 64 0 3748 +0 +0 +0 -1732 OVMS# power bluetooth off Power mode of bluetooth is now off I (184576) bluetooth: Powering bluetooth off... E (184626) BT: bta_dm_disable BTA_DISABLE_DELAY set to 200 ms D (184626) bluetooth: event = 6| I (191606) ovms-server-v2: Send MP-0 S0,K,0,0,,storage,29,50,0,0,0,0,0,0,1,0,0,0,96.59,124,91,0,95,-1,0,0,0,-1,91,58,0,0.00,0.00,0 I (191656) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,191,0,0,1,0,12.9,0,13.14,0,0,0 I (191706) ovms-server-v2: Send MP-0 L51.302567,7.390008,223.4,339.7,1,1,0,10002,0,0.0,0.0 D (192626) simcom: rx line ch=3 len=10 : +CREG: 1,1 D (192676) simcom: rx line ch=3 len=26 : +CCLK: "80/01/23,09:12:28" D (192736) simcom: rx line ch=3 len=10 : +CSQ: 5,99 D (192786) simcom: rx line ch=3 len=23 : +COPS: 0,0,"congstar",2 D (192836) simcom: rx line ch=3 len=2 : OK OVMS# module memory Free 8-bit 61684/230084, 32-bit 232/376, SPIRAM 4045296/4194252 --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM main* 12516 0 0 6348 -128 +0 +0 +0 Btc_task* 0 128 0 0 +0 -14796 +0 -1304 btuT* 0 20 0 0 +0 -2232 +0 -23492 tiT 464 664 0 6420 +0 -248 +0 -1560 wifi 1568 64 0 3788 +0 +0 +0 +40 OVMS NetMan 4 9296 100 32248 +0 -5416 +0 +0 btController 0 0 0 0 +0 -88 +0 +0 Better, but it still needs a lot (too much) of internal RAM. Btw, I needed to change the signature of the xt_error_handler_callback to build with bluetooth enabled on the current esp-idf. I'll push that change to our esp-idf. Regards, Michael Am 16.05.2018 um 05:10 schrieb Mark Webb-Johnson:
*From: *GitHub <noreply@github.com <mailto:noreply@github.com>> *Subject: **[openvehicles/Open-Vehicle-Monitoring-System-3] 2816b9: Support minimal build (all components disabled) - ...* *Date: *16 May 2018 at 10:13:49 AM HKT *To: *mark@webb-johnson.net <mailto:mark@webb-johnson.net> *Reply-To: *GitHub <noreply@github.com <mailto:noreply@github.com>>
Commit: 23f307757abb6411f77500182b72b11417019317 https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/23f3... Author: Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> Date: 2018-05-16 (Wed, 16 May 2018)
Mark Webb-Johnson -
