I have downloaded and tested 3.2.012 The C-zero (MiEV clone) charge bug was not included. On 25.04.2020 20:24, Tamás Kovács wrote:
Thanks the log, now i modified the AC charge detection code.
If you want to try add the following to config / firmware / flash from web : kommykt-nas.ddns.net:22289/ovms3.bin <http://kommykt-nas.ddns.net:22289/ovms3.bin> This is my NAS, the internet speed is not very high.
The changes that Tamás did worked. It tould have been nice that this would be included in 3.2.012 before it goes in prod. As far as I can see, the code is not committed into master yet. A better range_est while fastcharing can worked on later.
i only now created a pull request with AC charge detection fix. Michael Eric Menk <mikeemenk@gmail.com> ezt írta (időpont: 2020. ápr. 28., K, 16:46):
If you want to try add the following to config / firmware / flash from web : kommykt-nas.ddns.net:22289/ovms3.bin This is my NAS, the internet speed is not very high.
A better range_est while fastcharing can worked on later. _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Üdvözlettel: Kovács Tamás
Michael Eric Menk -
Tamás Kovács
