Mark, I've pushed the change to include the README.md as the introduction page into the user guide. This change needs the sphinx plugin "m2r", which seems to require a change to the RTD configuration -- the build currently fails: https://readthedocs.org/projects/ovms/builds/9887081/ It seems you need to add the plugin manually in the RTD web interface. To avoid that, the RTD systems supports build configurations in the source tree, maybe that's a better option: https://docs.readthedocs.io/en/latest/config-file/index.html Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Michael, Fought with the readthedocs.yaml file for a while, but gave up. In the end, I added a requirements.txt file to list pip requirements, and added that to the readthedocs config (web interface). That seems to build now: Collecting m2r (from -r docs/source/requirements.txt (line 1)) Downloading https://files.pythonhosted.org/packages/39/e7/9fae11a45f5e1a3a21d8a98d02948e... Collecting mistune (from m2r->-r docs/source/requirements.txt (line 1)) Downloading https://files.pythonhosted.org/packages/09/ec/4b43dae793655b7d8a25f761196243... Requirement already satisfied: docutils in /home/docs/checkouts/readthedocs.org/user_builds/ovms/envs/latest/lib/python3.7/site-packages (from m2r->-r docs/source/requirements.txt (line 1)) (0.14) Building wheels for collected packages: m2r Building wheel for m2r (setup.py): started Building wheel for m2r (setup.py): finished with status 'done' Stored in directory: /home/docs/checkouts/readthedocs.org/user_builds/ovms/.cache/pip/wheels/47/f8/dc/80f56bc4abf785834d422c2f5c864a14bf34576612aeb03492 Successfully built m2r Installing collected packages: mistune, m2r Successfully installed m2r-0.2.1 mistune-0.8.4 Regards, Mark.
On 31 Oct 2019, at 6:31 AM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
Regards, Michael
Mark Webb-Johnson -
