Everyone, I've managed to extend the persistent metrics storage structure to support 100 instead of the former 30 metrics with even a slight reduction in memory usage: OVMS# metrics persist version 3, serial 2, 820 bytes, and 77 of 100 slots used This is achieved by replacing the metric names as 24 byte keys by their 4 byte hash keys. There's a potential disadvantage from this to be noted: hash collisions may occur. I've tested a full persistent metrics set including the new TPMS arrays, no collisions with the current hash function. If a collision occurs, the metric won't get added to the persistent set (or will be removed, see below), and an error log message is generated. If you add new persistences for standard or custom metrics, check the log. A special case are vector metrics. These are implemented by allocating one slot to the vector size using the metric's base name, and one slot for each element using the base name extended by the index. If the vector grows, it will try to allocate new persistent slots as needed. If that fails, persistence is dropped for the whole vector. So if you add a new persistent vector, be sure to check for element hash collisions by setting it manually to a full expected element set at least once. You can do so easily by the "metrics set" command. If we run into hash collisions, there are some options, e.g. using another hash function. Extending the storage structure to support chained chunks of values is another option. Persistence is currently limited to values fitting into 4 bytes. OvmsMetricFloat, Int and Bool work, and vectors fitting that element size. String, Set, BitSet are todo. I've added persistence to a number of state and counter metrics formerly lacking persistence. The new set of persistent metrics is: OVMS# metrics list -p v.b.12v.voltage.ref 12.6V v.b.cac 160Ah v.b.coulomb.recd v.b.coulomb.recd.total v.b.coulomb.used v.b.coulomb.used.total v.b.energy.recd v.b.energy.recd.total v.b.energy.used v.b.energy.used.total v.b.range.est 160km v.b.range.ideal 200km v.b.soc 50% v.b.soh 100% v.b.temp 25°C v.c.12v.temp v.c.charging v.c.climit v.c.kwh v.c.kwh.grid v.c.kwh.grid.total v.c.limit.range v.c.limit.soc v.c.temp 22°C v.c.time 0Sec v.c.timermode v.c.timerstart v.d.cp v.e.aux12v v.e.awake v.e.cabintemp v.e.charging12v v.e.drivemode v.e.drivetime 0Sec v.e.locked v.e.on v.e.parktime 275Sec v.e.temp 22°C v.e.valet v.g.climit v.g.generating v.g.kwh v.g.kwh.grid v.g.kwh.grid.total v.g.limit.range v.g.limit.soc v.g.temp v.g.time v.g.timermode v.g.timerstart v.i.temp 22°C v.m.temp 30°C v.p.altitude 329.3m v.p.latitude 51.3024 v.p.longitude 7.38979 v.p.odometer 100000km v.p.trip v.t.alert 0,0,0,1 v.t.health 95,93,96,74% v.t.pressure 206.843,216.483,275.79,175.79kPa v.t.temp 33,33,34,38°C If you still miss something here, let me know. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Fantastic, thanks!
-- Stephen Davies Chief Technical Officer, Telviva (PTY) Ltd (previously Connection Telecom (PTY) Ltd Direct: 0878200262 / Reception: 0878200200 Written on the go, please excuse brevity/typos.
Steve, Chris brought to my attention one of your last changes collided with one of mine. I removed the persist argument from the OvmsMetricString constructor, as that class doesn't support persistence yet. I've pushed the fix already. Regards, Michael Am 17.01.21 um 22:09 schrieb Steve Davies:
On Sun, 17 Jan 2021 at 20:17, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Fantastic, thanks! -- Stephen Davies Chief Technical Officer, Telviva (PTY) Ltd (previously Connection Telecom (PTY) Ltd Direct: 0878200262 / Reception: 0878200200 Written on the go, please excuse brevity/typos.
Thanks - I think the 2 PRs crossed in the queue.
Michael Balzer -
Steve Davies
