Re: [Ovmsdev] OvmsDev Digest, Vol 31, Issue 1
Mark, Fair point on the diag port being more of a 'power user' input. Regarding the SIM card, I was not able to get the card to register on the AT&T or T-mobile networks using my unlocked quad band phone. The registration timed out. It may in fact be my SIM. And no, the GSM lock is not set on the module. I was able to get some output using the 'diag' command. The signal strength bounces between 0 and 24 every few minutes. Also, the VIN is reported is random characters, plus part of the SIM's serial. This is on a 2014 LEAF S trim (US). Thanks, -Jeff On 08/01/2014 09:00 PM, ovmsdev-request@lists.teslaclub.hk wrote:
Message: 2 Date: Fri, 01 Aug 2014 10:54:52 +0200 From: Michael Balzer <dexter@expeedo.de> Subject: Re: [Ovmsdev] OvmsDev Digest, Vol 30, Issue 12 To: ovmsdev@lists.teslaclub.hk Message-ID: <53DB55DC.9070706@expeedo.de> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
Jeff,
I think the diag port is not something a normal user should be confronted with. The OVMS setup and troubleshooting is already quite complex for a simple user. If you're able to use a serial port, you're able to find and read the tech docs -- just my 2 cents.
Now for your trace: is a GSM lock configured (parameter #13)? If so, try without.
Also, does the SIM work correctly in a mobile phone?
Regards, Michael
Am 01.08.2014 06:46, schrieb Aatheus:
Mark,
Thank you for the info. Can the serial port parameters get added to the helpme page? The info is not findable anywhere on the page. I did find it in the development PDF, but it was hard to find!
I managed to get serial access to the OVMS board, and it looks like the data call is repeatedly failing. I verified that my GeoSIM card has $15 balance on it. Is my SIM card screwed up? I activated the SIM on the GeoSIM site, and I think it's set up ok.
RDY
+CFUN: 1
+CPIN: READY
+PACSP: 1
+CREG: 0
+CREG: 2
Call Ready
GPS Ready AT
OK AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
+CSMINS: 0,1
OK AT+CCID;+CPBF="O-";+CPIN?
(SERIAL OBSCURED)
+CPIN: READY
OK AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;+CLTS=1;E0
+IPR: 9600
OK
ERROR
+CREG: 3
+CREG: 0
OK
+CSMINS: 0,1
OK
(SERIAL OBSCURED) +CPIN: READY
OK
+IPR: 9600
OK
ERROR
+CREG: 3
OK
+CSMINS: 0,1
OK
(SERIAL OBSCURED)
+CPIN: READY
OK
+IPR: 9600
OK
ERROR
Aatheus
