Looking at the git log and changes.txt I'd say it's time to head for the next main release. The current build with the latest changes and tiT on core 1 is working very smoothly here. No crashes, CAN RX overflows are down to 0.25 per mille and SIMCOM overflows around 0.3 per mille. Espressif have announced they're incorporating the PSRAM fix into the official toolchain now, but there is no schedule for the release. Are there any open issues that need to be fixed for 3.2.006? Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Nothing from me. Current build seems stable. Perhaps build and release 3.2.006 to EAP this weekend? Regards, Mark.
Regards, Michael
I am ok to build. Anything more before I do that? Regards, Mark.
Regards, Michael
Can you clarify what the status of this is now? What exactly do we need to switch to the fix. Last I checked, it was only working in UNICORE mode. Have they fixed that? I see some recent commits in Espressif code referencing this, but not sure of when they plan to release. Regards, Mark.
Regards, Michael
I've been building and releasing using the patch already on ovms.dexters-web.de. Toolkit -98 works perfectly in dual core mode. The last issue I had that let me suspect it still needs unicore mode was actually the CAN hardware flaw I reported and fixed later on. To switch to the fix: 1. Install toolkit -98 and the newlib binaries from here: https://github.com/espressif/esp-idf/issues/2892#issuecomment-525286663 Linux <https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-98-g4638c4f-5.2.0-20190827.tar.gz> MacOS <https://dl.espressif.com/dl/xtensa-esp32-elf-macos-1.22.0-98-g4638c4f-5.2.0-20190827.tar.gz> Windows <https://dl.espressif.com/dl/xtensa-esp32-elf-win32-1.22.0-98-g4638c4f-5.2.0-20190827.tar.gz> (note the Windows toolchain probably still has symlinks instead of copies) Also, a new set of Newlib <https://dl.espressif.com/dl/newlib-psram-fix-ldstld-14aug.zip> binaries, recompiled with the above toolchain and with some manual fixes to some assembly routines. 2. Install the newlib binaries into lib/esp32-psram, make sure they are used by symlinking or replacing the standard files: balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> ll ~/esp/xtensa-esp32-elf-1.22.0-98/xtensa-esp32-elf/lib/esp32-psram/ insgesamt 43168 -rw-r--r-- 1 balzer users 2228 13. Aug 12:52 crt0.o lrwxrwxrwx 1 balzer users 23 28. Aug 22:00 libc.a -> libc-psram-workaround.a -rw-r--r-- 1 balzer users 5975618 14. Aug 11:25 libc-psram-workaround.a -rw-r--r-- 2 balzer users 5230008 13. Aug 12:52 libc-std.a lrwxrwxrwx 1 balzer users 23 28. Aug 22:00 libg.a -> libg-psram-workaround.a -rw-r--r-- 1 balzer users 5985208 14. Aug 11:25 libg-psram-workaround.a -rw-r--r-- 2 balzer users 5230008 13. Aug 12:52 libg-std.a lrwxrwxrwx 1 balzer users 23 28. Aug 22:00 libm.a -> libm-psram-workaround.a -rw-r--r-- 1 balzer users 1940568 14. Aug 11:25 libm-psram-workaround.a -rw-r--r-- 1 balzer users 2119642 13. Aug 12:52 libm-std.a -rw-r--r-- 1 balzer users 16717576 13. Aug 13:01 libstdc++.a -rw-r--r-- 1 balzer users 2286 13. Aug 13:01 libstdc++.a-gdb.py -rw-r--r-- 1 balzer users 986574 13. Aug 13:01 libsupc++.a 3. Checkout branches "spiram-fix-test" on both OVMS and esp-idf. (The esp-idf branch has the fix from https://github.com/espressif/esp-idf/issues/2892#issuecomment-525697255) 4. Disable sdkconfig:CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST (meant to work around PSRAM issues in the wifi blob, which has no toolkit 98 build yet) 5. make clean && make There will be some warnings about the toolkit version not matching the idf version, these can be safely ignored. Regards, Michael Am 09.12.19 um 03:09 schrieb Mark Webb-Johnson:
Espressif have announced they're incorporating the PSRAM fix into the official toolchain now, but there is no schedule for the release. Can you clarify what the status of this is now? What exactly do we need to switch to the fix.
Regards, Michael
Mark Webb-Johnson -
