Hi Michael, The following is the content of my "dummy" script, so it shouldn't cause any looping issues: var history = { "test": [], "v.p.odometer": [], "v.p.altitude": [], "v.b.energy.used": [], "v.b.energy.recd": [], }; var lastOdo = 0; var saveOdo = 0; print(Duktape.enc('jc', history)); I deleted the script and folder before seeing your suggestion on task priority, but I could reinstate and try at some point. Since deleting the script and the events folder the module has been stable for over 10 hours. I see there is garbage collection every 60s which seems to match the crash timings to within a second or so, could this be the cause?? Kind regards Derek
Derek, what do you mean by "match the crash timings"? Did you see the crash happen at the GC run? If you checked your file log, be aware the log may be cut off by the crash. The WDT reboot isn't polite to our logging task or unflushed file buffers. If there's a bug in the DukTape GC, that could well block further JS processing and thus trigger the WDT. The last GC bugs fixed in DukTape have been in release 2.1.0 (2017-04-15): https://duktape.org/download.html Your test script doesn't allocate much memory, and as it was bound to the system.wifi.sta.disconnected event should have run at most 6 times per minute -- not much stress for the GC… I'll bind your test script to ticker.1 on my bench module. Regards, Michael Am 12.08.20 um 08:52 schrieb Derek Caudwell:
Hi Michael,
Kind regards Derek
The script has now been running on my ticker.1 for nearly 4 hours without any issues. Some other reports included a poor Wifi signal. Does that apply to your situation as well? I can't easily reproduce that on my bench. Regards, Michael Am 12.08.20 um 09:18 schrieb Michael Balzer:
Derek,
Regards, Michael
Hi Michael,
Kind regards Derek
By reducing my Wifi router signal strength and lowering the wifi sq configs I managed to put my module additionally under networking stress, with multiple network changes in/out Wifi. Sadly, still no issue turning up… So, if you can reproduce the exact circumstances in your setting and narrow down the cause, that could be very helpful. Regards, Michael Am 12.08.20 um 13:10 schrieb Michael Balzer:
Regards, Michael
Derek,
Regards, Michael
Hi Michael,
Kind regards Derek
Derek Caudwell -
