Everyone please have a look at… https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... Please try to reproduce the bug on your modules. I'm open for explanations. I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. My remaining theories: * A task writing out of bounds (but only 0-bytes?) * A hardware issue only affecting some modules A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules especially often. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
For those not following the github discussion: I'm pretty sure I've nailed the bug down. I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this normally will not erase your OVMS config partition, but a backup is always recommended. Regards, Michael Am 24.01.19 um 21:19 schrieb Michael Balzer:
Regards, Michael
To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. Regards, Michael Am 28.01.19 um 20:43 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
→ https://github.com/espressif/esp-idf/issues/3006 Regards, Michael Am 28.01.19 um 20:46 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
Regards, Michael
Michael, Espressif’s response (and linking to that other issue) sounds like others are seeing this. Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until they can find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed. Regards, Mark.
On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de> wrote:
→ https://github.com/espressif/esp-idf/issues/3006 <https://github.com/espressif/esp-idf/issues/3006>
Regards, Michael
Regards, Michael
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435>
Regards, Michael
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248>
My remaining theories: A task writing out of bounds (but only 0-bytes?) A hardware issue only affecting some modules A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules especially often.
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark, issue #2892 mentions using only the lower 2 MB of SPI RAM as a workaround. Where are our allocations placed by the allocator? Does it fill from the middle or end? If not we don't use the upper half yet. A possible workaround for the most apparent issues with this (string assembly) could be to use char buffers instead of std::string. I was thinking about doing that at least for the websocket stream. But if this really is a hardware issue it can affect all objects in SPI RAM, appending to std::string then only triggers this more often. Another workaround could be to run everything on core 0. Regards, Michael Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson:
Michael,
On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Regards, Michael
Regards, Michael
Regards, Michael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
On 30 Jan 2019, at 4:41 PM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
I saw that, and had a look. I don’t see anything in makeconfig to limit to 2MB (not 4MB). I do see a CONFIG_SPIRAM_SIZE=4194304 in sdkconfig, but not sure how it gets there. Perhaps we can just change there to 2MB and try? I did see this in the documentation: During ESP-IDF startup, external RAM is mapped into the data address space starting at at address 0x3F800000 (byte-accessible). The length of this region is the same as the SPIRAM size (up to the limit of 4MiB). So, maybe we can look at the address our allocations come from to see their offset from 0x3F800000? If it is coming from the top 2MB, then perhaps we start with a big 2MB allocation that we never use?
It seems strange that we are only seeing it with std::string. Maybe that just stresses the system more, or does a lot of reallocations?
Urgh.
Regards, Michael
Michael,
Regards, Michael
Regards, Michael
Regards, Michael
Regards, Michael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
My test log shows the buffer address 0x3f802044, so allocations are done from the beginning and we're not touching the upper 2 MB. Maybe the 2 MB workaround doesn't apply in our case, or has a correlation with the core assignment. Reallocations as a source can be ruled out, as I reserve enough capacity on the std::string.
Urgh.
Indeed. Am 30.01.19 um 10:00 schrieb Mark Webb-Johnson:
On 30 Jan 2019, at 4:41 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Urgh.
Regards, Michael
Michael,
Regards, Michael
Regards, Michael
Regards, Michael
Am 24.01.19 um 21:19 schrieb Michael Balzer: > Everyone please have a look at… > > https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... > > Please try to reproduce the bug on your modules. > > I'm open for explanations. > > I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation > (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation > as well. > > My remaining theories: > > * A task writing out of bounds (but only 0-bytes?) > * A hardware issue only affecting some modules > > A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect > some modules especially often. > > Regards, > Michael
I tried changing CONFIG_SPIRAM_SIZE in sdkconfig directly, but it just reset back to the default 4MB. So changed esp-idf itself, components/esp32/Kconfig, and added a prompt for that config option. I could then change it in menuconfig and the change persisted. I then tested: I (0) cpu_start: App cpu up. I (715) spiram: SPI SRAM memory test OK I (716) heap_init: Initializing. RAM available for dynamic allocation: I (716) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (723) heap_init: At 3FFBA920 len 000256E0 (149 KiB): DRAM I (728) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM I (735) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (742) heap_init: At 400953CC len 0000AC34 (43 KiB): IRAM I (747) cpu_start: Pro cpu start user code I (752) spiram: Adding pool of 2048K of external SPI memory to heap allocator I (158) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 16MB external flash … I (9566) test_task: testing mode 1 loopcnt 1000 E (9576) test_task: loop #1: corruption detected at pos=497 size=498 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 #1: size=498, data @0x3f901ca0 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 E (9806) test_task: loop #5: corruption detected at pos=497 size=498 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 E (10036) test_task: loop #9: corruption detected at pos=829 size=830 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 which looks like a FAIL to me? So, then I tried something a little funky: Go back to normal CONFIG_SPIRAM_SIZE 4MB Add this to main/test_memory_corruption.cpp app_main(): void* big2mb = heap_caps_malloc(1024*1024*2, MALLOC_CAP_SPIRAM); printf("Big 2MB spi memory allocation is at %p\n",big2mb); Rebuild and run... Here is what I get: I (0) cpu_start: App cpu up. I (1151) spiram: SPI SRAM memory test OK I (1152) heap_init: Initializing. RAM available for dynamic allocation: I (1152) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (1159) heap_init: At 3FFBA920 len 000256E0 (149 KiB): DRAM I (1164) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM I (1171) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1179) heap_init: At 400953CC len 0000AC34 (43 KiB): IRAM I (1184) cpu_start: Pro cpu start user code I (1188) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (206) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. ... This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 16MB external flash Big 2MB spi memory allocation is at 0x3f800028 ... I (291) wifi station: ESP_WIFI_MODE_APSTA I (291) wifi: wifi driver task: 3ffc25c4, prio:23, stack:3584, core=0 ... I (3281) wifi station: retry to connect to the AP I (3281) wifi station: connect to the AP fail I (6111) wifi station: retry to connect to the AP I (6111) wifi station: connect to the AP fail I (8461) mem_stresser: started on core 0 mem @0x3fa01b98 I (8461) mem_stresser: started on core 1 mem @0x3fa81bac I (8951) wifi station: retry to connect to the AP I (8951) wifi station: connect to the AP fail I (9461) test_task: running on core 1 I (9561) test_task: testing mode 1 loopcnt 1000 #1: size=1039, data @0x3fb01ca4 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (11781) wifi station: retry to connect to the AP I (11781) wifi station: connect to the AP fail I (14621) wifi station: retry to connect to the AP I (14621) wifi station: connect to the AP fail I (17451) wifi station: connect to the AP fail I left it running for a few minutes, but no faults shown. Modes 1 through 4 all clean. So, to take the funkiness to the next level, I added the same to ovms_main, right at the start (actually in the log level setter, as that seemed to be the first thing that initialises). Somebody else gets in for 28bytes of SPIRAM (or maybe that is a structure header), but anyway... I (1742) spiram: SPI SRAM memory test OK I (1743) heap_init: Initializing. RAM available for dynamic allocation: I (1743) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM I (1750) heap_init: At 3FFCEDE8 len 00011218 (68 KiB): DRAM I (1755) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM I (1762) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (1768) heap_init: At 4009F530 len 00000AD0 (2 KiB): IRAM I (1775) cpu_start: Pro cpu start user code I (1779) spiram: Adding pool of 4096K of external SPI memory to heap allocator I (125) ovms_main: Set default logging level for * to INFO I (126) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug) ... I (17783) webserver: Launching Web Server I (17823) ssh: Launching SSH Server OVMS# test string 500 2 #1: stdlen = 1027 1985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504 finished OVMS# OVMS# module memory Free 8-bit 76160/230212, 32-bit 812/2720, SPIRAM 1886108/4194252 --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM main* 8368 0 0 8456 +8368 +0 +0 +8456 no task* 5376 0 0 0 +5376 +0 +0 +0 esp_timer 34808 0 6442123100 +34808 +0 +644+2123100 OVMS Events 36352 41040 0 35120 +36352 +41040 +0 +35120 OVMS DukTape 188 0 0 34668 +188 +0 +0 +34668 OVMS CanRx 3124 0 0 26168 +3124 +0 +0 +26168 ipc0 7776 0 0 0 +7776 +0 +0 +0 ipc1 12 0 0 0 +12 +0 +0 +0 Tmr Svc 0 88 0 0 +0 +88 +0 +0 tiT 232 468 0 664 +232 +468 +0 +664 wifi 600 8896 0 3324 +600 +8896 +0 +3324 OVMS Console 0 200 1180 26332 +0 +200 +1180 +26332 mdns 0 104 0 4 +0 +104 +0 +4 OVMS NetMan 0 216 0 84 +0 +216 +0 +84 I think that wins as the most ugly kludge to date. Shall I commit? Regards, Mark.
Mark,
Urgh.
Regards, Michael
Michael,
Regards, Michael
Regards, Michael
Regards, Michael
Am 24.01.19 um 21:19 schrieb Michael Balzer: > Everyone please have a look at… > > https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248> > > Please try to reproduce the bug on your modules. > > I'm open for explanations. > > I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. > > My remaining theories: > A task writing out of bounds (but only 0-bytes?) > A hardware issue only affecting some modules > A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules especially often. > > Regards, > Michael > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Oh my… Can it be the first 2 MB are taboo for core 1 and the second 2 MB for core 0? Anyway, we won't need those 2 MB for now, and hopefully this will be fixed by Espressif soon. So I'd say yes, commit. Regards, Michael Am 30.01.19 um 12:26 schrieb Mark Webb-Johnson:
I then tested:
1. Go back to normal CONFIG_SPIRAM_SIZE 4MB
2. Add this to main/test_memory_corruption.cpp app_main():
3. Rebuild and run...
Here is what I get:
finished OVMS#
Shall I commit?
On 30 Jan 2019, at 5:00 PM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
Mark,
Urgh.
Regards, Michael
Michael,
Regards, Michael
Regards, Michael
Am 28.01.19 um 20:43 schrieb Michael Balzer: > For those not following the github discussion: I'm pretty sure I've nailed the bug down. > > I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. > > https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... > > If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is > small, this normally will not erase your OVMS config partition, but a backup is always recommended. > > Regards, > Michael > > > Am 24.01.19 um 21:19 schrieb Michael Balzer: >> Everyone please have a look at… >> >> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >> >> Please try to reproduce the bug on your modules. >> >> I'm open for explanations. >> >> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation >> (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this >> explanation as well. >> >> My remaining theories: >> >> * A task writing out of bounds (but only 0-bytes?) >> * A hardware issue only affecting some modules >> >> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect >> some modules especially often. >> >> Regards, >> Michael >>
Yes, I suspect there is something in there related to the core. I worry that (a) it is not as simple as 2MB/2MB, and (b) we run code on both cores anyway. We may have just fixed the test case (which runs on core #1), but not code running on core #0. Anyway, it is worth a try in the wild to see if it reduces the volume of errors, while Espressif continue to work on it. Kludgy wonderfulness is in commit 3.2.001-29-g311307cd. Regards, Mark.
On 30 Jan 2019, at 7:39 PM, Michael Balzer <dexter@expeedo.de> wrote:
Oh my…
Regards, Michael
I then tested:
Rebuild and run...
Here is what I get:
finished OVMS#
Shall I commit?
Mark,
Urgh.
Regards, Michael
Michael,
Regards, Michael
Am 28.01.19 um 20:46 schrieb Michael Balzer: > To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. > > Regards, > Michael > > > Am 28.01.19 um 20:43 schrieb Michael Balzer: >> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >> >> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >> >> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435> >> >> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this normally will not erase your OVMS config partition, but a backup is always recommended. >> >> Regards, >> Michael >> >> >> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>> Everyone please have a look at… >>> >>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248> >>> >>> Please try to reproduce the bug on your modules. >>> >>> I'm open for explanations. >>> >>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>> >>> My remaining theories: >>> A task writing out of bounds (but only 0-bytes?) >>> A hardware issue only affecting some modules >>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules especially often. >>> >>> Regards, >>> Michael >>>
Rolled out to "my" edgers. I'll watch crash counters during the next days and report. Regards, Michael Am 30.01.19 um 12:44 schrieb Mark Webb-Johnson:
On 30 Jan 2019, at 7:39 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Oh my…
Regards, Michael
I then tested:
Here is what I get:
finished OVMS#
Shall I commit?
Mark,
Urgh.
Regards, Michael
Michael,
> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > → https://github.com/espressif/esp-idf/issues/3006 > > Regards, > Michael > > > Am 28.01.19 um 20:46 schrieb Michael Balzer: >> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, >> so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. >> >> Regards, >> Michael >> >> >> Am 28.01.19 um 20:43 schrieb Michael Balzer: >>> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >>> >>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >>> >>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>> >>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this >>> normally will not erase your OVMS config partition, but a backup is always recommended. >>> >>> Regards, >>> Michael >>> >>> >>> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>>> Everyone please have a look at… >>>> >>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>> >>>> Please try to reproduce the bug on your modules. >>>> >>>> I'm open for explanations. >>>> >>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 >>>> compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>>> >>>> My remaining theories: >>>> >>>> * A task writing out of bounds (but only 0-bytes?) >>>> * A hardware issue only affecting some modules >>>> >>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules >>>> especially often. >>>> >>>> Regards, >>>> Michael >>>>
Is it just my impression or has the wifi speed decreased with that workaround? It's especially apparent on the firmware version info. That's just 23K, but takes some seconds to load. It was slow before though, I need to make a comparison. I hope the workaround doesn't shift the issue to core 0 (running the wifi stack)… Regards, Michael Am 30.01.19 um 19:19 schrieb Michael Balzer:
Regards, Michael
Oh my…
Regards, Michael
I then tested:
Here is what I get:
finished OVMS#
Shall I commit?
Mark,
Urgh.
Regards, Michael
Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson: > Michael, > > Espressif’s response (and linking to that other issue) sounds like others are seeing this. > > Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until they can > find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed. > > Regards, Mark. > >> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> → https://github.com/espressif/esp-idf/issues/3006 >> >> Regards, >> Michael >> >> >> Am 28.01.19 um 20:46 schrieb Michael Balzer: >>> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, >>> so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. >>> >>> Regards, >>> Michael >>> >>> >>> Am 28.01.19 um 20:43 schrieb Michael Balzer: >>>> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >>>> >>>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >>>> >>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>> >>>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this >>>> normally will not erase your OVMS config partition, but a backup is always recommended. >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>>>> Everyone please have a look at… >>>>> >>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>>> >>>>> Please try to reproduce the bug on your modules. >>>>> >>>>> I'm open for explanations. >>>>> >>>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 >>>>> compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>>>> >>>>> My remaining theories: >>>>> >>>>> * A task writing out of bounds (but only 0-bytes?) >>>>> * A hardware issue only affecting some modules >>>>> >>>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules >>>>> especially often. >>>>> >>>>> Regards, >>>>> Michael >>>>>
Comparison made, difference confirmed. Load times: *Pre-Workaround: * firmware 32.7 KB 5.08 s firmware 32.7 KB 4.96 s firmware 32.7 KB 5.08 s firmware 32.7 KB 5.06 s firmware 32.7 KB 5.09 s firmware 32.7 KB 5.17 s firmware 32.7 KB 5.00 s firmware 32.7 KB 5.06 s firmware 32.7 KB 5.04 s firmware 32.7 KB 4.96 s *Post-Workaround: * firmware 32.7 KB 6.99 s firmware 32.7 KB 5.05 s firmware 32.7 KB 4.83 s firmware 32.7 KB 6.42 s firmware 32.7 KB 6.50 s firmware 32.7 KB 6.49 s firmware 32.7 KB 6.40 s firmware 32.7 KB 4.94 s firmware 32.7 KB 5.17 s firmware 32.7 KB 6.54 s This looks like the bug hits the wifi or lwip stack now, causing frequent retransmits of corrupted packets. I just also tried running the test project with that 2 MB allocation and starting the test task on core 0: the corruptions show again. So it's reasonable to assume core 0 can only work with the lower 2 MB and core 1 only with the higher 2 MB. Would it be an option to split the SPI RAM into two heaps and use each depending on the core requesting memory? Regards, Michael Am 30.01.19 um 21:01 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
Oh my…
Regards, Michael
I then tested:
Here is what I get:
finished OVMS#
Shall I commit?
> On 30 Jan 2019, at 4:41 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Mark, > > issue #2892 mentions using only the lower 2 MB of SPI RAM as a workaround. Where are our allocations placed by the allocator? Does it fill from the > middle or end? If not we don't use the upper half yet.
So, maybe we can look at the address our allocations come from to see their offset from 0x3F800000? If it is coming from the top 2MB, then perhaps we start with a big 2MB allocation that we never use? > A possible workaround for the most apparent issues with this (string assembly) could be to use char buffers instead of std::string. I was thinking about > doing that at least for the websocket stream.
> But if this really is a hardware issue it can affect all objects in SPI RAM, appending to std::string then only triggers this more often. > > Another workaround could be to run everything on core 0.
Urgh.
> Regards, > Michael > > > Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson: >> Michael, >> >> Espressif’s response (and linking to that other issue) sounds like others are seeing this. >> >> Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until they can >> find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed. >> >> Regards, Mark. >> >>> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> → https://github.com/espressif/esp-idf/issues/3006 >>> >>> Regards, >>> Michael >>> >>> >>> Am 28.01.19 um 20:46 schrieb Michael Balzer: >>>> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM >>>> section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 28.01.19 um 20:43 schrieb Michael Balzer: >>>>> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >>>>> >>>>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >>>>> >>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>>> >>>>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this >>>>> normally will not erase your OVMS config partition, but a backup is always recommended. >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> >>>>> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>>>>> Everyone please have a look at… >>>>>> >>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>>>> >>>>>> Please try to reproduce the bug on your modules. >>>>>> >>>>>> I'm open for explanations. >>>>>> >>>>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be >>>>>> C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>>>>> >>>>>> My remaining theories: >>>>>> >>>>>> * A task writing out of bounds (but only 0-bytes?) >>>>>> * A hardware issue only affecting some modules >>>>>> >>>>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some >>>>>> modules especially often. >>>>>> >>>>>> Regards, >>>>>> Michael >>>>>>
Yep, I agree. It looks like core #0 is using the top 2MB and core #1 the bottom 2MB. The question is will we see more problems with this workaround than without it? I doubt if anything will come out of Espressif China for several weeks. Chinese New Year is here now and everything is shutting down for the break. Factories will be down for a month - businesses perhaps a fortnight. At least we have confirmed that it is the same issue as: [TW#28180] PSRAM Cache Issue stills exist #2892 Regards, Mark
On 31 Jan 2019, at 5:36 AM, Michael Balzer <dexter@expeedo.de> wrote:
Comparison made, difference confirmed. Load times: Pre-Workaround: firmware 32.7 KB 5.08 s firmware 32.7 KB 4.96 s firmware 32.7 KB 5.08 s firmware 32.7 KB 5.06 s firmware 32.7 KB 5.09 s firmware 32.7 KB 5.17 s firmware 32.7 KB 5.00 s firmware 32.7 KB 5.06 s firmware 32.7 KB 5.04 s firmware 32.7 KB 4.96 s
Post-Workaround: firmware 32.7 KB 6.99 s firmware 32.7 KB 5.05 s firmware 32.7 KB 4.83 s firmware 32.7 KB 6.42 s firmware 32.7 KB 6.50 s firmware 32.7 KB 6.49 s firmware 32.7 KB 6.40 s firmware 32.7 KB 4.94 s firmware 32.7 KB 5.17 s firmware 32.7 KB 6.54 s
Regards, Michael
Regards, Michael
Regards, Michael
Oh my…
Regards, Michael
I then tested:
Rebuild and run...
Here is what I get:
finished OVMS#
Shall I commit?
> On 30 Jan 2019, at 5:00 PM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote: > > > >> On 30 Jan 2019, at 4:41 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Mark, >> >> issue #2892 mentions using only the lower 2 MB of SPI RAM as a workaround. Where are our allocations placed by the allocator? Does it fill from the middle or end? If not we don't use the upper half yet. > > I saw that, and had a look. I don’t see anything in makeconfig to limit to 2MB (not 4MB). > > I do see a CONFIG_SPIRAM_SIZE=4194304 in sdkconfig, but not sure how it gets there. Perhaps we can just change there to 2MB and try? > > I did see this in the documentation: > > During ESP-IDF startup, external RAM is mapped into the data address space starting at at address 0x3F800000 (byte-accessible). The length of this region is the same as the SPIRAM size (up to the limit of 4MiB). > > So, maybe we can look at the address our allocations come from to see their offset from 0x3F800000? If it is coming from the top 2MB, then perhaps we start with a big 2MB allocation that we never use? > >> A possible workaround for the most apparent issues with this (string assembly) could be to use char buffers instead of std::string. I was thinking about doing that at least for the websocket stream. > > It seems strange that we are only seeing it with std::string. Maybe that just stresses the system more, or does a lot of reallocations? > >> But if this really is a hardware issue it can affect all objects in SPI RAM, appending to std::string then only triggers this more often. >> >> Another workaround could be to run everything on core 0. > > Urgh. > >> Regards, >> Michael >> >> >> Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson: >>> Michael, >>> >>> Espressif’s response (and linking to that other issue) sounds like others are seeing this. >>> >>> Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until they can find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed. >>> >>> Regards, Mark. >>> >>>> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>> >>>> → https://github.com/espressif/esp-idf/issues/3006 <https://github.com/espressif/esp-idf/issues/3006> >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 28.01.19 um 20:46 schrieb Michael Balzer: >>>>> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> >>>>> Am 28.01.19 um 20:43 schrieb Michael Balzer: >>>>>> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >>>>>> >>>>>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >>>>>> >>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457965435> >>>>>> >>>>>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, this normally will not erase your OVMS config partition, but a backup is always recommended. >>>>>> >>>>>> Regards, >>>>>> Michael >>>>>> >>>>>> >>>>>> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>>>>>> Everyone please have a look at… >>>>>>> >>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#issuecomment-457334248> >>>>>>> >>>>>>> Please try to reproduce the bug on your modules. >>>>>>> >>>>>>> I'm open for explanations. >>>>>>> >>>>>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>>>>>> >>>>>>> My remaining theories: >>>>>>> A task writing out of bounds (but only 0-bytes?) >>>>>>> A hardware issue only affecting some modules >>>>>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some modules especially often. >>>>>>> >>>>>>> Regards, >>>>>>> Michael >>>>>>>
A slight improvement in terms of stability. Crash numbers have decreased a bit, but better yet, the crash "quality" has improved. Backtraces make sense again. Some new backtraces let me check the notification concurrency handling again, and I have found and resolved two more issues. I haven't seen any websocket data corruptions with the new version, but the overall wifi performance has clearly degraded. One user reported wifi connections previously working very reliably now sometimes drop without apparent reason. Overall I think we should keep the workaround and hope Espressif will solve this asap. Regards, Michael Am 31.01.19 um 01:50 schrieb Mark Webb-Johnson:
On 31 Jan 2019, at 5:36 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Regards, Michael
Regards, Michael
Oh my…
Regards, Michael
Am 30.01.19 um 12:26 schrieb Mark Webb-Johnson: > I tried changing CONFIG_SPIRAM_SIZE in sdkconfig directly, but it just reset back to the default 4MB. > > So changed esp-idf itself, components/esp32/Kconfig, and added a prompt for that config option. I could then change it in menuconfig and the change > persisted. > > I then tested: > > I (0) cpu_start: App cpu up. > I (715) spiram: SPI SRAM memory test OK > I (716) heap_init: Initializing. RAM available for dynamic allocation: > I (716) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM > I (723) heap_init: At 3FFBA920 len 000256E0 (149 KiB): DRAM > I (728) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM > I (735) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM > I (742) heap_init: At 400953CC len 0000AC34 (43 KiB): IRAM > I (747) cpu_start: Pro cpu start user code > I (752) spiram: Adding pool of 2048K of external SPI memory to heap allocator > I (158) cpu_start: Starting scheduler on PRO CPU. > I (0) cpu_start: Starting scheduler on APP CPU. > This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 16MB external flash > … > I (9566) test_task: testing mode 1 loopcnt 1000 > E (9576) test_task: loop #1: corruption detected at pos=497 size=498 > 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan > 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 > > #1: size=498, data @0x3f901ca0 > 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan > 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 > > E (9806) test_task: loop #5: corruption detected at pos=497 size=498 > 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan > 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 > > E (10036) test_task: loop #9: corruption detected at pos=829 size=830 > 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan > 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS > WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 > 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23 > > > which looks like a FAIL to me? > > So, then I tried something a little funky: > > 1. Go back to normal CONFIG_SPIRAM_SIZE 4MB > > 2. Add this to main/test_memory_corruption.cpp app_main(): > > void* big2mb = heap_caps_malloc(1024*1024*2, MALLOC_CAP_SPIRAM); > printf("Big 2MB spi memory allocation is at %p\n",big2mb); > > 3. Rebuild and run... > > > Here is what I get: > > I (0) cpu_start: App cpu up. > I (1151) spiram: SPI SRAM memory test OK > I (1152) heap_init: Initializing. RAM available for dynamic allocation: > I (1152) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM > I (1159) heap_init: At 3FFBA920 len 000256E0 (149 KiB): DRAM > I (1164) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM > I (1171) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM > I (1179) heap_init: At 400953CC len 0000AC34 (43 KiB): IRAM > I (1184) cpu_start: Pro cpu start user code > I (1188) spiram: Adding pool of 4096K of external SPI memory to heap allocator > I (206) cpu_start: Starting scheduler on PRO CPU. > I (0) cpu_start: Starting scheduler on APP CPU. > ... > This is ESP32 chip with 2 CPU cores, WiFi/BT/BLE, silicon revision 1, 16MB external flash > Big 2MB spi memory allocation is at 0x3f800028 > ... > I (291) wifi station: ESP_WIFI_MODE_APSTA > I (291) wifi: wifi driver task: 3ffc25c4, prio:23, stack:3584, core=0 > ... > I (3281) wifi station: retry to connect to the AP > I (3281) wifi station: connect to the AP fail > > I (6111) wifi station: retry to connect to the AP > I (6111) wifi station: connect to the AP fail > > I (8461) mem_stresser: started on core 0 mem @0x3fa01b98 > I (8461) mem_stresser: started on core 1 mem @0x3fa81bac > I (8951) wifi station: retry to connect to the AP > I (8951) wifi station: connect to the AP fail > > I (9461) test_task: running on core 1 > > I (9561) test_task: testing mode 1 loopcnt 1000 > #1: size=1039, data @0x3fb01ca4 > 4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan > 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS > WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 > 15:08:23)4348864OVMS WIFI BLE BT cores=2 rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS WIFI BLE BT cores=2 > rev=ESP32/1WLAN-214677-52wifi103.2.001-22-g14d16854-dirty/factory/edge (build idf v3.2-dev-1419-g5afc1b0cb-dirty Jan 27 2019 15:08:23)4348864OVMS > WIFI BLE BT cores=2 rev=ESP32/1 > > I (11781) wifi station: retry to connect to the AP > I (11781) wifi station: connect to the AP fail > > I (14621) wifi station: retry to connect to the AP > I (14621) wifi station: connect to the AP fail > > I (17451) wifi station: connect to the AP fail > > > I left it running for a few minutes, but no faults shown. Modes 1 through 4 all clean. > > So, to take the funkiness to the next level, I added the same to ovms_main, right at the start (actually in the log level setter, as that seemed to be > the first thing that initialises). Somebody else gets in for 28bytes of SPIRAM (or maybe that is a structure header), but anyway... > > I (1742) spiram: SPI SRAM memory test OK > I (1743) heap_init: Initializing. RAM available for dynamic allocation: > I (1743) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM > I (1750) heap_init: At 3FFCEDE8 len 00011218 (68 KiB): DRAM > I (1755) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM > I (1762) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM > I (1768) heap_init: At 4009F530 len 00000AD0 (2 KiB): IRAM > I (1775) cpu_start: Pro cpu start user code > I (1779) spiram: Adding pool of 4096K of external SPI memory to heap allocator > I (125) ovms_main: Set default logging level for * to INFO > I (126) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug) > ... > I (17783) webserver: Launching Web Server > I (17823) ssh: Launching SSH Server > OVMS# test string 500 2 > #1: stdlen = 1027 > 1985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan > 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 > rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 > 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 > rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf v3.1-dev-2835-g151269458-dirty Jan 30 2019 > 19:17:20)012.61985504OVMS WIFI BLE BT cores=2 rev=ESP32/168HIGHWAYS-29wifi163.2.001-22-g14d16854-dirty/factory/edge (build idf > v3.1-dev-2835-g151269458-dirty Jan 30 2019 19:17:20)012.61985504 > > finished > OVMS# > > OVMS# module memory > Free 8-bit 76160/230212, 32-bit 812/2720, SPIRAM 1886108/4194252 > --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM > main* 8368 0 0 8456 +8368 +0 +0 +8456 > no task* 5376 0 0 0 +5376 +0 +0 +0 > esp_timer 34808 0 6442123100 +34808 +0 +644+2123100 > OVMS Events 36352 41040 0 35120 +36352 +41040 +0 +35120 > OVMS DukTape 188 0 0 34668 +188 +0 +0 +34668 > OVMS CanRx 3124 0 0 26168 +3124 +0 +0 +26168 > ipc0 7776 0 0 0 +7776 +0 +0 +0 > ipc1 12 0 0 0 +12 +0 +0 +0 > Tmr Svc 0 88 0 0 +0 +88 +0 +0 > tiT 232 468 0 664 +232 +468 +0 +664 > wifi 600 8896 0 3324 +600 +8896 +0 +3324 > OVMS Console 0 200 1180 26332 +0 +200 +1180 +26332 > mdns 0 104 0 4 +0 +104 +0 +4 > OVMS NetMan 0 216 0 84 +0 +216 +0 +84 > > > I think that wins as the most ugly kludge to date. > > Shall I commit? > > Regards, Mark. > >> On 30 Jan 2019, at 5:00 PM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote: >> >> >> >>> On 30 Jan 2019, at 4:41 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> Mark, >>> >>> issue #2892 mentions using only the lower 2 MB of SPI RAM as a workaround. Where are our allocations placed by the allocator? Does it fill from the >>> middle or end? If not we don't use the upper half yet. >> >> I saw that, and had a look. I don’t see anything in makeconfig to limit to 2MB (not 4MB). >> >> I do see a CONFIG_SPIRAM_SIZE=4194304 in sdkconfig, but not sure how it gets there. Perhaps we can just change there to 2MB and try? >> >> I did see this in the documentation: >> >> During ESP-IDF startup, external RAM is mapped into the data address space starting at at address 0x3F800000 (byte-accessible). The length of this >> region is the same as the SPIRAM size (up to the limit of 4MiB). >> >> >> So, maybe we can look at the address our allocations come from to see their offset from 0x3F800000? If it is coming from the top 2MB, then perhaps we >> start with a big 2MB allocation that we never use? >> >>> A possible workaround for the most apparent issues with this (string assembly) could be to use char buffers instead of std::string. I was thinking >>> about doing that at least for the websocket stream. >> >> It seems strange that we are only seeing it with std::string. Maybe that just stresses the system more, or does a lot of reallocations? >> >>> But if this really is a hardware issue it can affect all objects in SPI RAM, appending to std::string then only triggers this more often. >>> >>> Another workaround could be to run everything on core 0. >> >> Urgh. >> >>> Regards, >>> Michael >>> >>> >>> Am 30.01.19 um 03:33 schrieb Mark Webb-Johnson: >>>> Michael, >>>> >>>> Espressif’s response (and linking to that other issue) sounds like others are seeing this. >>>> >>>> Lousy timing (with Chinese New Year next week), so don’t expect anything quick from Espressif. I guess we’ll just have to live with it until they can >>>> find a workaround. It sounds like the issue is at the hardware level and a compiler patch will be needed. >>>> >>>> Regards, Mark. >>>> >>>>> On 30 Jan 2019, at 3:07 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>> >>>>> → https://github.com/espressif/esp-idf/issues/3006 >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> >>>>> Am 28.01.19 um 20:46 schrieb Michael Balzer: >>>>>> To clarify: the bug is most likely not restricted to the case of building a message in a buffer. It can possibly cause corruptions in any RAM >>>>>> section, so can well be responsible for many/most of the unidentified crashes and stack/heap corruptions we're experiencing. >>>>>> >>>>>> Regards, >>>>>> Michael >>>>>> >>>>>> >>>>>> Am 28.01.19 um 20:43 schrieb Michael Balzer: >>>>>>> For those not following the github discussion: I'm pretty sure I've nailed the bug down. >>>>>>> >>>>>>> I have reproduced the bug in a simple test project and intend to raise an issue with Espressif on this. >>>>>>> >>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>>>>> >>>>>>> If you'd like to test this on your module, configure the project to your wifi credentials, then use "make flash". As the test project is small, >>>>>>> this normally will not erase your OVMS config partition, but a backup is always recommended. >>>>>>> >>>>>>> Regards, >>>>>>> Michael >>>>>>> >>>>>>> >>>>>>> Am 24.01.19 um 21:19 schrieb Michael Balzer: >>>>>>>> Everyone please have a look at… >>>>>>>> >>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/189#... >>>>>>>> >>>>>>>> Please try to reproduce the bug on your modules. >>>>>>>> >>>>>>>> I'm open for explanations. >>>>>>>> >>>>>>>> I thought this might be some copy-on-write bug with std::string, but the gcc 5.x libstdc++ does no longer use that implementation (wouldn't be >>>>>>>> C++11 compliant as well). I also tried moving all strings to temporary buffers, but modes 5 & 6 eliminated this explanation as well. >>>>>>>> >>>>>>>> My remaining theories: >>>>>>>> >>>>>>>> * A task writing out of bounds (but only 0-bytes?) >>>>>>>> * A hardware issue only affecting some modules >>>>>>>> >>>>>>>> A hardware issue only affecting some percentage of ESP32 could explain this as well as the strange heap corruptions that seem to affect some >>>>>>>> modules especially often. >>>>>>>> >>>>>>>> Regards, >>>>>>>> Michael >>>>>>>>
Mark Webb-Johnson -
