I'm seeking people's opinions for the ACC CHARGEBY / CHARGEAT timing behaviour. The problem I have is to decide what algorithm to use for the case that people plugin after the scheduled charge time (or in the case of CHARGEBY, plugging in with a charge predicted to take to long to complete by the scheduled charge time). For example, say I have CHARGEAT set to 19:00:00. I get home, and plugin, at 19:10:00. What should we do? Schedule the charge for 19:00:00 the next day, or charge immediately? The logical choice seems to be charge immediately, but how far do we allow that 'nice' behavior to go? 19:10:00? 20:00:00? 23:00:00? etc? I guess we need some threshold, but what do people think is a sensible value for that threshold? For CHARGEBY, it is slightly more complicated. Say I plugin at 18:00:00, with a CHARGEBY of 21:00:00, but the prediction says 4 hours is required? What to do? What if, for the same case, I plugin at 22:00:00? The current algorithm in ACC does not allow any safety threshold. If CHARGEAT is 19:00:00 and you plugin at 19:01:00, tough luck - the charge will start at 19:00:00 tomorrow. For CHARGEBY, we do check if there is enough time to complete the charge before the scheduled time in the same day - if not, we send a charge alert message and start charging immediately. What do people think? Remember that this is a small embedded processor without much ram/flash, so we need to keep things simple. Regards, Mark.
In the CHARGEAT case, can I manually start the charge and not have the ACC code stop it? If so, then I think the behavior you describe in both cases is correct. Tom On 10/17/13 6:00 PM, "Mark Webb-Johnson" <mark@webb-johnson.net> wrote:
Tom, Currently, no. If ACC is waiting for a charge, it will stop charges until the designated time. This is a side-effect of it having to stop the car's automatic charge start on plugin. It could be changed to work that way, but we would have to have a delay (perhaps 1 minute) for ACC to be in control, before it backed off and allowed the user to do their thing. Regards, Mark. On 18 Oct, 2013, at 1:50 pm, Tom Saxton <tom@idleloop.com> wrote:
Tom
Mark, I use the chargeat option as offered by the car itself mostly for starting the charge at a time that the electricity rate is lower which is typically around 9 pm. To support this a threshold of several hours would be useful. The build in software also uses a threshold which is at least 4 hours. Have never noticed to have gone beyond this threshold so do not know what it is. Can try it. Groet / Regards Wiro Zijlmans
Op 18 okt. 2013 om 03:00 heeft Mark Webb-Johnson <mark@webb-johnson.net> het volgende geschreven:
Utilities are discovering that eventually there's going to be a big problem with EVs starting their charging en masse right when the billing rate drops. The graphs are astounding; in San Diego a huge chunk of the vehicles participating in the EV Project start charging at exactly midnight causing a giant spike in the EV utility load. The only reason it isn't a problem now is because there are so few EVs. Now the preferred model is to use CHARGEBY instead of CHARGEAT. The advantage is that the start times get spread out by how much each person drove that day and even the end times will spread out some because the charge time prediction is always going to be at least a little bit off. Eventually, we may get a more sophisticated demand response model where we get an additional incentive to let the utility handle the CHARGEBY timing and also be able to start the charge early when there's excess power on the grid, as from wind turbines putting a bunch of power into the grid. Tom On 10/17/13 11:21 PM, "Wiro Zijlmans" <wirozijlmans@gmail.com> wrote:
Mark Webb-Johnson -
Tom Saxton -
Wiro Zijlmans
