I hesitate to touch anything outside the can module yet, but I would like to store range values in kilometers. Reason: my car uses km and I'm losing precision if converting them to integer (!) miles. 1 mi = 1.609 km Are there any thoughts on this? Could it be just a labeling switch or does the server/app protocol need miles? Regards, Michael -- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
Michael, I think that the protocol requires Miles for this, and the Apps convert as necessary. From a precision point of view, it would be best to store it in the user's chosen units, but we do try to minimise what is done in the can bus interrupt service routines. It is not so easy to change, but I'll see what is the best way. For the moment, best to leave it in miles? Regards, Mark. P.S. Miles -> Kilometer formula is (((miles << 4)+5)/10)) I am sure there is something equally efficient for kilometers -> miles Best to avoid using floating point - especially in the interrupt service routines On 3 Nov, 2012, at 4:08 AM, Michael Balzer <dexter@expeedo.de> wrote:
Regards, Michael
<dexter.vcf>_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark, as car_speed already is stored in the user's units (i.e. Tesla CAN interrupt eventually needs to convert mph to km/h), this also is a bit inconsistent now... The CAN module could store values in the car units and tell the net module about the unit(s) used. So conversions would only need to be done at the output/display level only if the user prefs differ from the car config, and the can interrupt can be kept simple + fast. Another solution could be to change to miles/10 for all mile/mph values, that would give enough precision to not lose in translation. Regards, Michael Am 03.11.2012 15:08, schrieb Mark Webb-Johnson:
Michael,
Regards, Michael
Mark Webb-Johnson -
