I'm writing a little Android app with Cordova to do something similar as Tesla's "Romance mode". The app will turn climate control on or off and will show a burning log fire while the car is heating. As cordova uses HTML and Javascript you can see an online preview here: http://www.arachnon.de/fire/test.html When you click or tap on the fireplace the countdown for turning "climatecontrol" on ticks down for 17 seconds. After that the fire starts "moving" and on webkit browsers you will hear a tickling sound. When you click or tap again the tickling will stop and you will get a static image again. You will also get a red bar for 10 seconds, turning "climatecontrol" off and blocking any new commands for those 10 seconds. When you click or tap on the yellow bar you will be able to store your OVMS credentials (vehicle ID and password). Cave: this is done in plain text with window.localstorage so the password will be plain readable from the local storage within the browser on your device. The credentials are needed to communicate with the Android OVMS app, as I am planning to use the "SendCommand Broadcast Intent data" functionality of the OVMS app. I should be able to do that via this cordova plugin: https://github.com/cordova-misc/cordova-webintent I read the OVMS "SendCommand Broadcast Intent data" documentation here: https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendCommand-B roadcast-Intent-data but it is not clear to me, how I can initiate the "climatecontrol on" shell command over the broadcast. So would like to ask for help on that :-) Once the app is up and running it should be usable for any vehicle with OVMS climate control implemented. Just a little gimmick. But fun :-)) Regards Chris
Chris, TL;DR: simply add the command to execute after the "7," intro, e.g. "7,climatecontrol on". The SendCommand API was built around the V2 message protocol, so you need to send commands as MP commands, see https://docs.openvehicles.com/en/latest/protocol_v2/commands.html for a list. MP command code 7 passes standard text (former SMS) commands to the shell, that's what the Wiki example shows (for V2 command "STAT?"). You can get the command response by listening to the CommandResult intent and reading the "cmd_data" extra. Be aware all command result will be sent as intents, so you need to check if a result matches your command (could possibly be improved if needed). Regards, Michael Am 28.12.20 um 10:34 schrieb Chris van der Meijden:
Regards
Chris
Hey Michael, thanks! The "7" was not clear to me ... I will give it all a try and will post the results. Greetinx Chris Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer:
Chris,
Regards, Michael
https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma nd-B roadcast-Intent-data
Regards
Chris
The app is up and running. https://github.com/devmarxx/OVMS-Fireplace This is still very, very beta. It just does what it needs to do, without any checks on user entries or responses from the vehicle. But it works and makes me smile :-)) Regards Chris Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer:
Chris,
Regards, Michael
Regards
Chris
Chris, nice :-) Just checked: the App doesn't yet transmit the HVAC flag via the update intent, but that's really simple to add. I'll do that right now. Regards, Michael Am 28.12.20 um 14:53 schrieb Chris van der Meijden:
Regards
Chris
Chris,
Regards, Michael
Regards
Chris
Done. Am 28.12.20 um 16:26 schrieb Michael Balzer:
Chris,
nice :-)
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Regards
Chris
Cool ... Could you perhaps compile a 3.17.3 with that one? Would also give me the new images "officially" :-) Thanx Chris Am Montag, den 28.12.2020, 16:31 +0100 schrieb Michael Balzer:
Done.
Chris,
nice :-)
Regards
Chris
Chris,
https://docs.openvehicles.com/en/latest/protocol_v2/commands.ht ml for
a
to
"STAT?").
your
similar
off
here:
sound.
a
turning
seconds.
your
plain
readable
app, as
cordova plugin:
here:
https://github.com/openvehicles/Open-Vehicle-Android/wiki/Sen dComma
nd-B
on"
that
with
Regards
Chris
http://lists.openvehicles.com/mailman/listinfo/ov msdev
http://lists.openvehicles.com/mailman/listinfo/ovmsde v
Chris, I thought "of course, should be a matter of minutes"… and *zapp* came Google along. It doesn't let me upload the new APK, keeps telling me it needs to be targeted for API 29, which it is built for according to Android Studio, but apparently the APK manifest keeps API 28 despite all my config efforts. I'll need to spend some more hours investigating this… *sigh* Regards, Michael Am 28.12.20 um 16:54 schrieb Chris van der Meijden:
Cool ...
Thanx
Chris
Done.
Chris,
nice :-)
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Regards
Chris
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
bad news for some might be good news for others... maybe that way my recent pull request has a chance of making it into the next version? :) Thanks, sharkcow Am 28.12.20 um 18:13 schrieb Michael Balzer:
Chris,
Regards, Michael
Cool ...
Thanx
Chris
Done.
Chris,
nice :-)
Regards, Michael
Regards
Chris
Chris,
Regards, Michael
Am 28.12.20 um 10:34 schrieb Chris van der Meijden: > I'm writing a little Android app with Cordova to do something > similar > as Tesla's "Romance mode". The app will turn climate control on or > off > and will show a burning log fire while the car is heating. > > As cordova uses HTML and Javascript you can see an online preview > here: > > http://www.arachnon.de/fire/test.html > > When you click or tap on the fireplace the countdown for turning > "climatecontrol" on ticks down for 17 seconds. After that the fire > starts "moving" and on webkit browsers you will hear a tickling > sound. > When you click or tap again the tickling will stop and you will get > a > static image again. You will also get a red bar for 10 seconds, > turning > "climatecontrol" off and blocking any new commands for those 10 > seconds. > > When you click or tap on the yellow bar you will be able to store > your > OVMS credentials (vehicle ID and password). Cave: this is done in > plain > text with window.localstorage so the password will be plain > readable > from the local storage within the browser on your device. > > The credentials are needed to communicate with the Android OVMS > app, as > I am planning to use the "SendCommand Broadcast Intent data" > functionality of the OVMS app. I should be able to do that via this > cordova plugin: > > https://github.com/cordova-misc/cordova-webintent > > I read the OVMS "SendCommand Broadcast Intent data" documentation > here: > > https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma > nd-B > roadcast-Intent-data > > but it is not clear to me, how I can initiate the "climatecontrol > on" > shell command over the broadcast. So would like to ask for help on > that > :-) > > Once the app is up and running it should be usable for any vehicle > with > OVMS climate control implemented. > > Just a little gimmick. But fun :-)) > > Regards > > Chris > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Sharkcow, according to your PR you want to add the service interval info to the "S" (status) message. IMO that's not the most appropriate place. I'd rather add this to the "F" message, as that's already carrying the VIN, and also is meant to be updated less frequently. Also, we should pass through new fields to the Intent broadcast by default, to avoid stumbling upon missing fields as with the HVAC. So please add the respective puts to getBroadcastData(). Can you do these changes short term? Regards, Michael Am 28.12.20 um 18:36 schrieb sharkcow:
Thanks,
sharkcow
Chris,
Regards, Michael
Cool ...
Thanx
Chris
Done.
Chris,
nice :-)
Regards, Michael
Regards
Chris
Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer: > Chris, > > TL;DR: simply add the command to execute after the "7," intro, e.g. > "7,climatecontrol on". > > The SendCommand API was built around the V2 message protocol, so > you > need to send commands as MP commands, see > https://docs.openvehicles.com/en/latest/protocol_v2/commands.html > for > a > list. MP command code 7 passes standard text (former SMS) commands > to > the shell, that's what the Wiki example shows (for V2 command > "STAT?"). > > You can get the command response by listening to the CommandResult > intent and reading the "cmd_data" extra. Be aware all command > result > will be sent as intents, so you need to check if a result matches > your > command (could possibly be improved if needed). > > Regards, > Michael > > > Am 28.12.20 um 10:34 schrieb Chris van der Meijden: >> I'm writing a little Android app with Cordova to do something >> similar >> as Tesla's "Romance mode". The app will turn climate control on or >> off >> and will show a burning log fire while the car is heating. >> >> As cordova uses HTML and Javascript you can see an online preview >> here: >> >> http://www.arachnon.de/fire/test.html >> >> When you click or tap on the fireplace the countdown for turning >> "climatecontrol" on ticks down for 17 seconds. After that the fire >> starts "moving" and on webkit browsers you will hear a tickling >> sound. >> When you click or tap again the tickling will stop and you will >> get >> a >> static image again. You will also get a red bar for 10 seconds, >> turning >> "climatecontrol" off and blocking any new commands for those 10 >> seconds. >> >> When you click or tap on the yellow bar you will be able to store >> your >> OVMS credentials (vehicle ID and password). Cave: this is done in >> plain >> text with window.localstorage so the password will be plain >> readable >> from the local storage within the browser on your device. >> >> The credentials are needed to communicate with the Android OVMS >> app, as >> I am planning to use the "SendCommand Broadcast Intent data" >> functionality of the OVMS app. I should be able to do that via >> this >> cordova plugin: >> >> https://github.com/cordova-misc/cordova-webintent >> >> I read the OVMS "SendCommand Broadcast Intent data" documentation >> here: >> >> https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma >> >> nd-B >> roadcast-Intent-data >> >> but it is not clear to me, how I can initiate the "climatecontrol >> on" >> shell command over the broadcast. So would like to ask for help on >> that >> :-) >> >> Once the app is up and running it should be usable for any vehicle >> with >> OVMS climate control implemented. >> >> Just a little gimmick. But fun :-)) >> >> Regards >> >> Chris >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I've found the issue: gradle build variables don't work correctly anymore. I need to set the target SDK version manually on both modules. Sharkcow, I'll merge your PR and do the changes I suggested. Am 28.12.20 um 19:57 schrieb Michael Balzer:
Sharkcow,
Regards, Michael
Thanks,
sharkcow
Chris,
Regards, Michael
Cool ...
Thanx
Chris
Done.
Chris,
nice :-)
Regards, Michael
Am 28.12.20 um 14:53 schrieb Chris van der Meijden: > The app is up and running. > > https://github.com/devmarxx/OVMS-Fireplace > > This is still very, very beta. It just does what it needs to do, > without any checks on user entries or responses from the vehicle. > > But it works and makes me smile :-)) > > Regards > > Chris > > > Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer: >> Chris, >> >> TL;DR: simply add the command to execute after the "7," intro, >> e.g. >> "7,climatecontrol on". >> >> The SendCommand API was built around the V2 message protocol, >> so you >> need to send commands as MP commands, see >> https://docs.openvehicles.com/en/latest/protocol_v2/commands.html >> for >> a >> list. MP command code 7 passes standard text (former SMS) commands >> to >> the shell, that's what the Wiki example shows (for V2 command >> "STAT?"). >> >> You can get the command response by listening to the CommandResult >> intent and reading the "cmd_data" extra. Be aware all command >> result >> will be sent as intents, so you need to check if a result matches >> your >> command (could possibly be improved if needed). >> >> Regards, >> Michael >> >> >> Am 28.12.20 um 10:34 schrieb Chris van der Meijden: >>> I'm writing a little Android app with Cordova to do something >>> similar >>> as Tesla's "Romance mode". The app will turn climate control >>> on or >>> off >>> and will show a burning log fire while the car is heating. >>> >>> As cordova uses HTML and Javascript you can see an online preview >>> here: >>> >>> http://www.arachnon.de/fire/test.html >>> >>> When you click or tap on the fireplace the countdown for turning >>> "climatecontrol" on ticks down for 17 seconds. After that the >>> fire >>> starts "moving" and on webkit browsers you will hear a tickling >>> sound. >>> When you click or tap again the tickling will stop and you >>> will get >>> a >>> static image again. You will also get a red bar for 10 seconds, >>> turning >>> "climatecontrol" off and blocking any new commands for those 10 >>> seconds. >>> >>> When you click or tap on the yellow bar you will be able to store >>> your >>> OVMS credentials (vehicle ID and password). Cave: this is done in >>> plain >>> text with window.localstorage so the password will be plain >>> readable >>> from the local storage within the browser on your device. >>> >>> The credentials are needed to communicate with the Android OVMS >>> app, as >>> I am planning to use the "SendCommand Broadcast Intent data" >>> functionality of the OVMS app. I should be able to do that via >>> this >>> cordova plugin: >>> >>> https://github.com/cordova-misc/cordova-webintent >>> >>> I read the OVMS "SendCommand Broadcast Intent data" documentation >>> here: >>> >>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma >>> >>> nd-B >>> roadcast-Intent-data >>> >>> but it is not clear to me, how I can initiate the "climatecontrol >>> on" >>> shell command over the broadcast. So would like to ask for >>> help on >>> that >>> :-) >>> >>> Once the app is up and running it should be usable for any >>> vehicle >>> with >>> OVMS climate control implemented. >>> >>> Just a little gimmick. But fun :-)) >>> >>> Regards >>> >>> Chris >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Thanks, I was just trying to get started on them... but then I had to update android studio :-/ And thanks for your comments which help me to learn how things should be done :) sharkcow Am 28.12.20 um 20:12 schrieb Michael Balzer:
Sharkcow,
Regards, Michael
Thanks,
sharkcow
Chris,
Regards, Michael
Cool ...
Thanx
Chris
Done.
Am 28.12.20 um 16:26 schrieb Michael Balzer: > Chris, > > nice :-) > > Just checked: the App doesn't yet transmit the HVAC flag via the > update intent, but that's really simple to add. I'll do that > right now. > > Regards, > Michael > > > Am 28.12.20 um 14:53 schrieb Chris van der Meijden: >> The app is up and running. >> >> https://github.com/devmarxx/OVMS-Fireplace >> >> This is still very, very beta. It just does what it needs to do, >> without any checks on user entries or responses from the vehicle. >> >> But it works and makes me smile :-)) >> >> Regards >> >> Chris >> >> >> Am Montag, den 28.12.2020, 11:15 +0100 schrieb Michael Balzer: >>> Chris, >>> >>> TL;DR: simply add the command to execute after the "7," intro, >>> e.g. >>> "7,climatecontrol on". >>> >>> The SendCommand API was built around the V2 message protocol, >>> so you >>> need to send commands as MP commands, see >>> https://docs.openvehicles.com/en/latest/protocol_v2/commands.html >>> for >>> a >>> list. MP command code 7 passes standard text (former SMS) commands >>> to >>> the shell, that's what the Wiki example shows (for V2 command >>> "STAT?"). >>> >>> You can get the command response by listening to the CommandResult >>> intent and reading the "cmd_data" extra. Be aware all command >>> result >>> will be sent as intents, so you need to check if a result matches >>> your >>> command (could possibly be improved if needed). >>> >>> Regards, >>> Michael >>> >>> >>> Am 28.12.20 um 10:34 schrieb Chris van der Meijden: >>>> I'm writing a little Android app with Cordova to do something >>>> similar >>>> as Tesla's "Romance mode". The app will turn climate control >>>> on or >>>> off >>>> and will show a burning log fire while the car is heating. >>>> >>>> As cordova uses HTML and Javascript you can see an online preview >>>> here: >>>> >>>> http://www.arachnon.de/fire/test.html >>>> >>>> When you click or tap on the fireplace the countdown for turning >>>> "climatecontrol" on ticks down for 17 seconds. After that the >>>> fire >>>> starts "moving" and on webkit browsers you will hear a tickling >>>> sound. >>>> When you click or tap again the tickling will stop and you >>>> will get >>>> a >>>> static image again. You will also get a red bar for 10 seconds, >>>> turning >>>> "climatecontrol" off and blocking any new commands for those 10 >>>> seconds. >>>> >>>> When you click or tap on the yellow bar you will be able to store >>>> your >>>> OVMS credentials (vehicle ID and password). Cave: this is done in >>>> plain >>>> text with window.localstorage so the password will be plain >>>> readable >>>> from the local storage within the browser on your device. >>>> >>>> The credentials are needed to communicate with the Android OVMS >>>> app, as >>>> I am planning to use the "SendCommand Broadcast Intent data" >>>> functionality of the OVMS app. I should be able to do that via >>>> this >>>> cordova plugin: >>>> >>>> https://github.com/cordova-misc/cordova-webintent >>>> >>>> I read the OVMS "SendCommand Broadcast Intent data" documentation >>>> here: >>>> >>>> https://github.com/openvehicles/Open-Vehicle-Android/wiki/SendComma >>>> >>>> nd-B >>>> roadcast-Intent-data >>>> >>>> but it is not clear to me, how I can initiate the "climatecontrol >>>> on" >>>> shell command over the broadcast. So would like to ask for >>>> help on >>>> that >>>> :-) >>>> >>>> Once the app is up and running it should be usable for any >>>> vehicle >>>> with >>>> OVMS climate control implemented. >>>> >>>> Just a little gimmick. But fun :-)) >>>> >>>> Regards >>>> >>>> Chris >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Auweia ... Sorry, to read that ... Take your time, enjoy the holidays. Turn on the log burner :-) Chris Am Montag, den 28.12.2020, 18:13 +0100 schrieb Michael Balzer:
Chris,
Cool ...
Thanx
Chris
Done.
Chris,
nice :-)
Regards
Chris
Chris,
https://docs.openvehicles.com/en/latest/proto col_v2/commands.html for
a
to
"STAT?").
your
> I'm writing a little Android app > with Cordova to do something > > similar > > as Tesla's "Romance mode". The app will > turn climate > control on or > > off > > and will show a burning log fire while > the car is > heating. > > > > As cordova uses HTML and Javascript you > can see an > online preview > > here: > > > > http://www.arachnon.de/fire/test.html > > > > > When you click or tap on the fireplace > the countdown for > turning > > "climatecontrol" on ticks down for 17 > seconds. After > that the fire > > starts "moving" and on webkit browsers > you will hear a > tickling > > sound. > > When you click or tap again the tickling > will stop and > you will get > > a > > static image again. You will also get a > red bar for 10 > seconds, > > turning > > "climatecontrol" off and blocking any new > commands for > those 10 > > seconds. > > > > When you click or tap on the yellow bar > you will be able > to store > > your > > OVMS credentials (vehicle ID and > password). Cave: this > is done in > > plain > > text with window.localstorage so the > password will be > plain > > readable > > from the local storage within the browser > on your > device. > > > > The credentials are needed to communicate > with the > Android OVMS > > app, as > > I am planning to use the "SendCommand > Broadcast Intent > data" > > functionality of the OVMS app. I should > be able to do > that via this > > cordova plugin: > > > > https://github.com/cordova-misc/cordova-w > ebintent > > > > > I read the OVMS "SendCommand Broadcast > Intent data" > documentation > > here: > > > > https://github.com/openvehicles/Open-Vehi > cle-Android/wiki/SendComma > > > nd-B > > roadcast-Intent-data > > > > but it is not clear to me, how I can > initiate the > "climatecontrol > > on" > > shell command over the broadcast. So > would like to ask > for help on > > that > > :-) > > > > Once the app is up and running it should > be usable for > any vehicle > > with > > OVMS climate control implemented. > > > > Just a little gimmick. But fun :-)) > > > > Regards > > > > Chris > > > > > _______________________________________________ > > OvmsDev mailing list > > OvmsDev@lists.openvehicles.com > > > http://lists.openvehicles.com/mailman/lis > tinfo/ovmsdev > > >
_____________________________________________ __
http://lists.openvehicles.com/mailman/listinf o/ovmsdev
Chris van der Meijden -
Michael Balzer -
sharkcow
