Dear all I'm struggling with the activation of the bluetooth functionality with the recent code. The sdkconfig.bluetooth.hw31 will not compile at all. I found three major problems here. 1. Mongoose SSL is needed 2. Support for the 8MB RAM version is needed (not included in sdkconfig.bluetooth.hw31!) 3. CONFIG_BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF is needed for our special esp-idf situation By doing a simple diff I could solve 1, but overlooked Nr. 2. And that was lethal. It brought my OVMS in a boot loop after I installed the fresh compiled ovms3.bin. But I got here great help from Thomas (Thanx!), who pointed to the problem and helped me out on the sdkconfig settings. For Nr. 3 I made a dirty workaround by adding config BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF int "Should be 0, can also be 1" default 0 depends on OVMS help Workaround to make bluetooth compile with our special esp-idf situation. to the KConfig. But all efforts didn't bring a postive result. The image compiles and boots now, but we can't activate bluetooth. We get the Error bt: init controller failed: ESP_ERR_NO_MEM So I would like to ask, if anybody has a working, recent, bluetooth image and if so what does it need? Any help on this is highly welcome. Here the diff of my bluetooth sdkconfig to the standard sdkconfig without bluetooth: 137,146c137,138 < CONFIG_BT_ENABLED=y < < # < # Bluetooth controller < # < CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y < CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY= < CONFIG_BTDM_CONTROLLER_MODE_BTDM= < CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=3 < CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=3 ---
CONFIG_BT_ENABLED= CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=0 149,150d140 < CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y < CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1= 152,365c142 < CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y < CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4= < < # < # MODEM SLEEP Options < # < CONFIG_BTDM_CONTROLLER_MODEM_SLEEP= < CONFIG_BLE_SCAN_DUPLICATE=y < CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y < CONFIG_SCAN_DUPLICATE_BY_ADV_DATA= < CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR= < CONFIG_SCAN_DUPLICATE_TYPE=0 < CONFIG_DUPLICATE_SCAN_CACHE_SIZE=20 < CONFIG_BLE_MESH_SCAN_DUPLICATE_EN= < CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED= < CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y < CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100 < CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20 < CONFIG_BLUEDROID_ENABLED=y < CONFIG_BLUEDROID_PINNED_TO_CORE_0=y < CONFIG_BLUEDROID_PINNED_TO_CORE_1= < CONFIG_BLUEDROID_PINNED_TO_CORE=0 < CONFIG_BTC_TASK_STACK_SIZE=6144 < CONFIG_BTU_TASK_STACK_SIZE=4096 < CONFIG_BLUEDROID_MEM_DEBUG= < CONFIG_CLASSIC_BT_ENABLED= < CONFIG_GATTS_ENABLE=y < CONFIG_GATTS_SEND_SERVICE_CHANGE_MANUAL= < CONFIG_GATTS_SEND_SERVICE_CHANGE_AUTO=y < CONFIG_GATTS_SEND_SERVICE_CHANGE_MODE=0 < CONFIG_GATTC_ENABLE= < CONFIG_BLE_SMP_ENABLE=y < CONFIG_SMP_SLAVE_CON_PARAMS_UPD_ENABLE= < CONFIG_BT_STACK_NO_LOG= < < # < # BT DEBUG LOG LEVEL < # < CONFIG_HCI_TRACE_LEVEL_NONE= < CONFIG_HCI_TRACE_LEVEL_ERROR= < CONFIG_HCI_TRACE_LEVEL_WARNING=y < CONFIG_HCI_TRACE_LEVEL_API= < CONFIG_HCI_TRACE_LEVEL_EVENT= < CONFIG_HCI_TRACE_LEVEL_DEBUG= < CONFIG_HCI_TRACE_LEVEL_VERBOSE= < CONFIG_HCI_INITIAL_TRACE_LEVEL=2 < CONFIG_BTM_TRACE_LEVEL_NONE= < CONFIG_BTM_TRACE_LEVEL_ERROR= < CONFIG_BTM_TRACE_LEVEL_WARNING=y < CONFIG_BTM_TRACE_LEVEL_API= < CONFIG_BTM_TRACE_LEVEL_EVENT= < CONFIG_BTM_TRACE_LEVEL_DEBUG= < CONFIG_BTM_TRACE_LEVEL_VERBOSE= < CONFIG_BTM_INITIAL_TRACE_LEVEL=2 < CONFIG_L2CAP_TRACE_LEVEL_NONE= < CONFIG_L2CAP_TRACE_LEVEL_ERROR= < CONFIG_L2CAP_TRACE_LEVEL_WARNING=y < CONFIG_L2CAP_TRACE_LEVEL_API= < CONFIG_L2CAP_TRACE_LEVEL_EVENT= < CONFIG_L2CAP_TRACE_LEVEL_DEBUG= < CONFIG_L2CAP_TRACE_LEVEL_VERBOSE= < CONFIG_L2CAP_INITIAL_TRACE_LEVEL=2 < CONFIG_RFCOMM_TRACE_LEVEL_NONE= < CONFIG_RFCOMM_TRACE_LEVEL_ERROR= < CONFIG_RFCOMM_TRACE_LEVEL_WARNING=y < CONFIG_RFCOMM_TRACE_LEVEL_API= < CONFIG_RFCOMM_TRACE_LEVEL_EVENT= < CONFIG_RFCOMM_TRACE_LEVEL_DEBUG= < CONFIG_RFCOMM_TRACE_LEVEL_VERBOSE= < CONFIG_RFCOMM_INITIAL_TRACE_LEVEL=2 < CONFIG_SDP_TRACE_LEVEL_NONE= < CONFIG_SDP_TRACE_LEVEL_ERROR= < CONFIG_SDP_TRACE_LEVEL_WARNING=y < CONFIG_SDP_TRACE_LEVEL_API= < CONFIG_SDP_TRACE_LEVEL_EVENT= < CONFIG_SDP_TRACE_LEVEL_DEBUG= < CONFIG_SDP_TRACE_LEVEL_VERBOSE= < CONFIG_SDP_INITIAL_TRACE_LEVEL=2 < CONFIG_GAP_TRACE_LEVEL_NONE= < CONFIG_GAP_TRACE_LEVEL_ERROR= < CONFIG_GAP_TRACE_LEVEL_WARNING=y < CONFIG_GAP_TRACE_LEVEL_API= < CONFIG_GAP_TRACE_LEVEL_EVENT= < CONFIG_GAP_TRACE_LEVEL_DEBUG= < CONFIG_GAP_TRACE_LEVEL_VERBOSE= < CONFIG_GAP_INITIAL_TRACE_LEVEL=2 < CONFIG_BNEP_TRACE_LEVEL_NONE= < CONFIG_BNEP_TRACE_LEVEL_ERROR= < CONFIG_BNEP_TRACE_LEVEL_WARNING=y < CONFIG_BNEP_TRACE_LEVEL_API= < CONFIG_BNEP_TRACE_LEVEL_EVENT= < CONFIG_BNEP_TRACE_LEVEL_DEBUG= < CONFIG_BNEP_TRACE_LEVEL_VERBOSE= < CONFIG_BNEP_INITIAL_TRACE_LEVEL=2 < CONFIG_PAN_TRACE_LEVEL_NONE= < CONFIG_PAN_TRACE_LEVEL_ERROR= < CONFIG_PAN_TRACE_LEVEL_WARNING=y < CONFIG_PAN_TRACE_LEVEL_API= < CONFIG_PAN_TRACE_LEVEL_EVENT= < CONFIG_PAN_TRACE_LEVEL_DEBUG= < CONFIG_PAN_TRACE_LEVEL_VERBOSE= < CONFIG_PAN_INITIAL_TRACE_LEVEL=2 < CONFIG_A2D_TRACE_LEVEL_NONE= < CONFIG_A2D_TRACE_LEVEL_ERROR= < CONFIG_A2D_TRACE_LEVEL_WARNING=y < CONFIG_A2D_TRACE_LEVEL_API= < CONFIG_A2D_TRACE_LEVEL_EVENT= < CONFIG_A2D_TRACE_LEVEL_DEBUG= < CONFIG_A2D_TRACE_LEVEL_VERBOSE= < CONFIG_A2D_INITIAL_TRACE_LEVEL=2 < CONFIG_AVDT_TRACE_LEVEL_NONE= < CONFIG_AVDT_TRACE_LEVEL_ERROR= < CONFIG_AVDT_TRACE_LEVEL_WARNING=y < CONFIG_AVDT_TRACE_LEVEL_API= < CONFIG_AVDT_TRACE_LEVEL_EVENT= < CONFIG_AVDT_TRACE_LEVEL_DEBUG= < CONFIG_AVDT_TRACE_LEVEL_VERBOSE= < CONFIG_AVDT_INITIAL_TRACE_LEVEL=2 < CONFIG_AVCT_TRACE_LEVEL_NONE= < CONFIG_AVCT_TRACE_LEVEL_ERROR= < CONFIG_AVCT_TRACE_LEVEL_WARNING=y < CONFIG_AVCT_TRACE_LEVEL_API= < CONFIG_AVCT_TRACE_LEVEL_EVENT= < CONFIG_AVCT_TRACE_LEVEL_DEBUG= < CONFIG_AVCT_TRACE_LEVEL_VERBOSE= < CONFIG_AVCT_INITIAL_TRACE_LEVEL=2 < CONFIG_AVRC_TRACE_LEVEL_NONE= < CONFIG_AVRC_TRACE_LEVEL_ERROR= < CONFIG_AVRC_TRACE_LEVEL_WARNING=y < CONFIG_AVRC_TRACE_LEVEL_API= < CONFIG_AVRC_TRACE_LEVEL_EVENT= < CONFIG_AVRC_TRACE_LEVEL_DEBUG= < CONFIG_AVRC_TRACE_LEVEL_VERBOSE= < CONFIG_AVRC_INITIAL_TRACE_LEVEL=2 < CONFIG_MCA_TRACE_LEVEL_NONE= < CONFIG_MCA_TRACE_LEVEL_ERROR= < CONFIG_MCA_TRACE_LEVEL_WARNING=y < CONFIG_MCA_TRACE_LEVEL_API= < CONFIG_MCA_TRACE_LEVEL_EVENT= < CONFIG_MCA_TRACE_LEVEL_DEBUG= < CONFIG_MCA_TRACE_LEVEL_VERBOSE= < CONFIG_MCA_INITIAL_TRACE_LEVEL=2 < CONFIG_HID_TRACE_LEVEL_NONE= < CONFIG_HID_TRACE_LEVEL_ERROR= < CONFIG_HID_TRACE_LEVEL_WARNING=y < CONFIG_HID_TRACE_LEVEL_API= < CONFIG_HID_TRACE_LEVEL_EVENT= < CONFIG_HID_TRACE_LEVEL_DEBUG= < CONFIG_HID_TRACE_LEVEL_VERBOSE= < CONFIG_HID_INITIAL_TRACE_LEVEL=2 < CONFIG_APPL_TRACE_LEVEL_NONE= < CONFIG_APPL_TRACE_LEVEL_ERROR= < CONFIG_APPL_TRACE_LEVEL_WARNING=y < CONFIG_APPL_TRACE_LEVEL_API= < CONFIG_APPL_TRACE_LEVEL_EVENT= < CONFIG_APPL_TRACE_LEVEL_DEBUG= < CONFIG_APPL_TRACE_LEVEL_VERBOSE= < CONFIG_APPL_INITIAL_TRACE_LEVEL=2 < CONFIG_GATT_TRACE_LEVEL_NONE= < CONFIG_GATT_TRACE_LEVEL_ERROR= < CONFIG_GATT_TRACE_LEVEL_WARNING=y < CONFIG_GATT_TRACE_LEVEL_API= < CONFIG_GATT_TRACE_LEVEL_EVENT= < CONFIG_GATT_TRACE_LEVEL_DEBUG= < CONFIG_GATT_TRACE_LEVEL_VERBOSE= < CONFIG_GATT_INITIAL_TRACE_LEVEL=2 < CONFIG_SMP_TRACE_LEVEL_NONE= < CONFIG_SMP_TRACE_LEVEL_ERROR= < CONFIG_SMP_TRACE_LEVEL_WARNING=y < CONFIG_SMP_TRACE_LEVEL_API= < CONFIG_SMP_TRACE_LEVEL_EVENT= < CONFIG_SMP_TRACE_LEVEL_DEBUG= < CONFIG_SMP_TRACE_LEVEL_VERBOSE= < CONFIG_SMP_INITIAL_TRACE_LEVEL=2 < CONFIG_BTIF_TRACE_LEVEL_NONE= < CONFIG_BTIF_TRACE_LEVEL_ERROR= < CONFIG_BTIF_TRACE_LEVEL_WARNING=y < CONFIG_BTIF_TRACE_LEVEL_API= < CONFIG_BTIF_TRACE_LEVEL_EVENT= < CONFIG_BTIF_TRACE_LEVEL_DEBUG= < CONFIG_BTIF_TRACE_LEVEL_VERBOSE= < CONFIG_BTIF_INITIAL_TRACE_LEVEL=2 < CONFIG_BTC_TRACE_LEVEL_NONE= < CONFIG_BTC_TRACE_LEVEL_ERROR= < CONFIG_BTC_TRACE_LEVEL_WARNING=y < CONFIG_BTC_TRACE_LEVEL_API= < CONFIG_BTC_TRACE_LEVEL_EVENT= < CONFIG_BTC_TRACE_LEVEL_DEBUG= < CONFIG_BTC_TRACE_LEVEL_VERBOSE= < CONFIG_BTC_INITIAL_TRACE_LEVEL=2 < CONFIG_OSI_TRACE_LEVEL_NONE= < CONFIG_OSI_TRACE_LEVEL_ERROR= < CONFIG_OSI_TRACE_LEVEL_WARNING=y < CONFIG_OSI_TRACE_LEVEL_API= < CONFIG_OSI_TRACE_LEVEL_EVENT= < CONFIG_OSI_TRACE_LEVEL_DEBUG= < CONFIG_OSI_TRACE_LEVEL_VERBOSE= < CONFIG_OSI_INITIAL_TRACE_LEVEL=2 < CONFIG_BLUFI_TRACE_LEVEL_NONE= < CONFIG_BLUFI_TRACE_LEVEL_ERROR= < CONFIG_BLUFI_TRACE_LEVEL_WARNING=y < CONFIG_BLUFI_TRACE_LEVEL_API= < CONFIG_BLUFI_TRACE_LEVEL_EVENT= < CONFIG_BLUFI_TRACE_LEVEL_DEBUG= < CONFIG_BLUFI_TRACE_LEVEL_VERBOSE= < CONFIG_BLUFI_INITIAL_TRACE_LEVEL=2 < CONFIG_BT_ACL_CONNECTIONS=2 < CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=y < CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=y < CONFIG_BLE_HOST_QUEUE_CONGESTION_CHECK= < CONFIG_SMP_ENABLE=y < CONFIG_BLE_ACTIVE_SCAN_REPORT_ADV_SCAN_RSP_INDIVIDUALLY= < CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30 < CONFIG_BT_RESERVE_DRAM=0xdb5c
CONFIG_BT_RESERVE_DRAM=0 506a284 CONFIG_NO_BLOBS= 514d291 < CONFIG_SW_COEXIST_ENABLE= 642c419 < CONFIG_FATFS_ALLOC_PREFER_EXTRAM=y
CONFIG_FATFS_ALLOC_PREFER_EXTRAM= 673c450 < CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_INTERRUPT_BACKTRACE= 683c460 < CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_PRIORITY=20 688,689c465,469 < CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS= < CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=
CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=y CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID= CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y CONFIG_FREERTOS_RUN_TIME_STATS_USING_ESP_TIMER=y CONFIG_FREERTOS_RUN_TIME_STATS_USING_CPU_CLK= 775c555 < CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY= 777,778c557,558 < CONFIG_TCPIP_TASK_AFFINITY_CPU1= < CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
CONFIG_TCPIP_TASK_AFFINITY_CPU1=y CONFIG_TCPIP_TASK_AFFINITY=0x1 810c590 < CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=30
CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=60 859,860c639,640 < CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144 < CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40
CONFIG_OVMS_VEHICLE_RXTASK_STACK=8192 CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=60 865d644 < CONFIG_OVMS_COMP_BLUETOOTH=y 900d678 < CONFIG_BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF=0 905,906c683,684 < CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y < CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC= CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=y 909c687 < CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384 929c707 < CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y 1104a883 #
Thanx in advance for your help. Regards Chris
Hi all To make my question a bit more "transparent" I put templates of my bluetooth Kconfig and sdkconfig here https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/tree/maste r/vehicle/OVMS.V3/support in my github. The templates both end on .devmarxx Good health to everyone and take care! Greetinx Chris Am Donnerstag, den 26.03.2020, 20:46 +0100 schrieb Chris van der Meijden:
Dear all
to the KConfig.
149,150d140 < CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y < CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1= 152,365c142 < CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y < CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4= < < # < # MODEM SLEEP Options < # < CONFIG_BTDM_CONTROLLER_MODEM_SLEEP= < CONFIG_BLE_SCAN_DUPLICATE=y < CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y < CONFIG_SCAN_DUPLICATE_BY_ADV_DATA= < CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR= < CONFIG_SCAN_DUPLICATE_TYPE=0 < CONFIG_DUPLICATE_SCAN_CACHE_SIZE=20 < CONFIG_BLE_MESH_SCAN_DUPLICATE_EN= < CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED= < CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y < CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100 < CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20 < CONFIG_BLUEDROID_ENABLED=y < CONFIG_BLUEDROID_PINNED_TO_CORE_0=y < CONFIG_BLUEDROID_PINNED_TO_CORE_1= < CONFIG_BLUEDROID_PINNED_TO_CORE=0 < CONFIG_BTC_TASK_STACK_SIZE=6144 < CONFIG_BTU_TASK_STACK_SIZE=4096 < CONFIG_BLUEDROID_MEM_DEBUG= < CONFIG_CLASSIC_BT_ENABLED= < CONFIG_GATTS_ENABLE=y < CONFIG_GATTS_SEND_SERVICE_CHANGE_MANUAL= < CONFIG_GATTS_SEND_SERVICE_CHANGE_AUTO=y < CONFIG_GATTS_SEND_SERVICE_CHANGE_MODE=0 < CONFIG_GATTC_ENABLE= < CONFIG_BLE_SMP_ENABLE=y < CONFIG_SMP_SLAVE_CON_PARAMS_UPD_ENABLE= < CONFIG_BT_STACK_NO_LOG= < < # < # BT DEBUG LOG LEVEL < # < CONFIG_HCI_TRACE_LEVEL_NONE= < CONFIG_HCI_TRACE_LEVEL_ERROR= < CONFIG_HCI_TRACE_LEVEL_WARNING=y < CONFIG_HCI_TRACE_LEVEL_API= < CONFIG_HCI_TRACE_LEVEL_EVENT= < CONFIG_HCI_TRACE_LEVEL_DEBUG= < CONFIG_HCI_TRACE_LEVEL_VERBOSE= < CONFIG_HCI_INITIAL_TRACE_LEVEL=2 < CONFIG_BTM_TRACE_LEVEL_NONE= < CONFIG_BTM_TRACE_LEVEL_ERROR= < CONFIG_BTM_TRACE_LEVEL_WARNING=y < CONFIG_BTM_TRACE_LEVEL_API= < CONFIG_BTM_TRACE_LEVEL_EVENT= < CONFIG_BTM_TRACE_LEVEL_DEBUG= < CONFIG_BTM_TRACE_LEVEL_VERBOSE= < CONFIG_BTM_INITIAL_TRACE_LEVEL=2 < CONFIG_L2CAP_TRACE_LEVEL_NONE= < CONFIG_L2CAP_TRACE_LEVEL_ERROR= < CONFIG_L2CAP_TRACE_LEVEL_WARNING=y < CONFIG_L2CAP_TRACE_LEVEL_API= < CONFIG_L2CAP_TRACE_LEVEL_EVENT= < CONFIG_L2CAP_TRACE_LEVEL_DEBUG= < CONFIG_L2CAP_TRACE_LEVEL_VERBOSE= < CONFIG_L2CAP_INITIAL_TRACE_LEVEL=2 < CONFIG_RFCOMM_TRACE_LEVEL_NONE= < CONFIG_RFCOMM_TRACE_LEVEL_ERROR= < CONFIG_RFCOMM_TRACE_LEVEL_WARNING=y < CONFIG_RFCOMM_TRACE_LEVEL_API= < CONFIG_RFCOMM_TRACE_LEVEL_EVENT= < CONFIG_RFCOMM_TRACE_LEVEL_DEBUG= < CONFIG_RFCOMM_TRACE_LEVEL_VERBOSE= < CONFIG_RFCOMM_INITIAL_TRACE_LEVEL=2 < CONFIG_SDP_TRACE_LEVEL_NONE= < CONFIG_SDP_TRACE_LEVEL_ERROR= < CONFIG_SDP_TRACE_LEVEL_WARNING=y < CONFIG_SDP_TRACE_LEVEL_API= < CONFIG_SDP_TRACE_LEVEL_EVENT= < CONFIG_SDP_TRACE_LEVEL_DEBUG= < CONFIG_SDP_TRACE_LEVEL_VERBOSE= < CONFIG_SDP_INITIAL_TRACE_LEVEL=2 < CONFIG_GAP_TRACE_LEVEL_NONE= < CONFIG_GAP_TRACE_LEVEL_ERROR= < CONFIG_GAP_TRACE_LEVEL_WARNING=y < CONFIG_GAP_TRACE_LEVEL_API= < CONFIG_GAP_TRACE_LEVEL_EVENT= < CONFIG_GAP_TRACE_LEVEL_DEBUG= < CONFIG_GAP_TRACE_LEVEL_VERBOSE= < CONFIG_GAP_INITIAL_TRACE_LEVEL=2 < CONFIG_BNEP_TRACE_LEVEL_NONE= < CONFIG_BNEP_TRACE_LEVEL_ERROR= < CONFIG_BNEP_TRACE_LEVEL_WARNING=y < CONFIG_BNEP_TRACE_LEVEL_API= < CONFIG_BNEP_TRACE_LEVEL_EVENT= < CONFIG_BNEP_TRACE_LEVEL_DEBUG= < CONFIG_BNEP_TRACE_LEVEL_VERBOSE= < CONFIG_BNEP_INITIAL_TRACE_LEVEL=2 < CONFIG_PAN_TRACE_LEVEL_NONE= < CONFIG_PAN_TRACE_LEVEL_ERROR= < CONFIG_PAN_TRACE_LEVEL_WARNING=y < CONFIG_PAN_TRACE_LEVEL_API= < CONFIG_PAN_TRACE_LEVEL_EVENT= < CONFIG_PAN_TRACE_LEVEL_DEBUG= < CONFIG_PAN_TRACE_LEVEL_VERBOSE= < CONFIG_PAN_INITIAL_TRACE_LEVEL=2 < CONFIG_A2D_TRACE_LEVEL_NONE= < CONFIG_A2D_TRACE_LEVEL_ERROR= < CONFIG_A2D_TRACE_LEVEL_WARNING=y < CONFIG_A2D_TRACE_LEVEL_API= < CONFIG_A2D_TRACE_LEVEL_EVENT= < CONFIG_A2D_TRACE_LEVEL_DEBUG= < CONFIG_A2D_TRACE_LEVEL_VERBOSE= < CONFIG_A2D_INITIAL_TRACE_LEVEL=2 < CONFIG_AVDT_TRACE_LEVEL_NONE= < CONFIG_AVDT_TRACE_LEVEL_ERROR= < CONFIG_AVDT_TRACE_LEVEL_WARNING=y < CONFIG_AVDT_TRACE_LEVEL_API= < CONFIG_AVDT_TRACE_LEVEL_EVENT= < CONFIG_AVDT_TRACE_LEVEL_DEBUG= < CONFIG_AVDT_TRACE_LEVEL_VERBOSE= < CONFIG_AVDT_INITIAL_TRACE_LEVEL=2 < CONFIG_AVCT_TRACE_LEVEL_NONE= < CONFIG_AVCT_TRACE_LEVEL_ERROR= < CONFIG_AVCT_TRACE_LEVEL_WARNING=y < CONFIG_AVCT_TRACE_LEVEL_API= < CONFIG_AVCT_TRACE_LEVEL_EVENT= < CONFIG_AVCT_TRACE_LEVEL_DEBUG= < CONFIG_AVCT_TRACE_LEVEL_VERBOSE= < CONFIG_AVCT_INITIAL_TRACE_LEVEL=2 < CONFIG_AVRC_TRACE_LEVEL_NONE= < CONFIG_AVRC_TRACE_LEVEL_ERROR= < CONFIG_AVRC_TRACE_LEVEL_WARNING=y < CONFIG_AVRC_TRACE_LEVEL_API= < CONFIG_AVRC_TRACE_LEVEL_EVENT= < CONFIG_AVRC_TRACE_LEVEL_DEBUG= < CONFIG_AVRC_TRACE_LEVEL_VERBOSE= < CONFIG_AVRC_INITIAL_TRACE_LEVEL=2 < CONFIG_MCA_TRACE_LEVEL_NONE= < CONFIG_MCA_TRACE_LEVEL_ERROR= < CONFIG_MCA_TRACE_LEVEL_WARNING=y < CONFIG_MCA_TRACE_LEVEL_API= < CONFIG_MCA_TRACE_LEVEL_EVENT= < CONFIG_MCA_TRACE_LEVEL_DEBUG= < CONFIG_MCA_TRACE_LEVEL_VERBOSE= < CONFIG_MCA_INITIAL_TRACE_LEVEL=2 < CONFIG_HID_TRACE_LEVEL_NONE= < CONFIG_HID_TRACE_LEVEL_ERROR= < CONFIG_HID_TRACE_LEVEL_WARNING=y < CONFIG_HID_TRACE_LEVEL_API= < CONFIG_HID_TRACE_LEVEL_EVENT= < CONFIG_HID_TRACE_LEVEL_DEBUG= < CONFIG_HID_TRACE_LEVEL_VERBOSE= < CONFIG_HID_INITIAL_TRACE_LEVEL=2 < CONFIG_APPL_TRACE_LEVEL_NONE= < CONFIG_APPL_TRACE_LEVEL_ERROR= < CONFIG_APPL_TRACE_LEVEL_WARNING=y < CONFIG_APPL_TRACE_LEVEL_API= < CONFIG_APPL_TRACE_LEVEL_EVENT= < CONFIG_APPL_TRACE_LEVEL_DEBUG= < CONFIG_APPL_TRACE_LEVEL_VERBOSE= < CONFIG_APPL_INITIAL_TRACE_LEVEL=2 < CONFIG_GATT_TRACE_LEVEL_NONE= < CONFIG_GATT_TRACE_LEVEL_ERROR= < CONFIG_GATT_TRACE_LEVEL_WARNING=y < CONFIG_GATT_TRACE_LEVEL_API= < CONFIG_GATT_TRACE_LEVEL_EVENT= < CONFIG_GATT_TRACE_LEVEL_DEBUG= < CONFIG_GATT_TRACE_LEVEL_VERBOSE= < CONFIG_GATT_INITIAL_TRACE_LEVEL=2 < CONFIG_SMP_TRACE_LEVEL_NONE= < CONFIG_SMP_TRACE_LEVEL_ERROR= < CONFIG_SMP_TRACE_LEVEL_WARNING=y < CONFIG_SMP_TRACE_LEVEL_API= < CONFIG_SMP_TRACE_LEVEL_EVENT= < CONFIG_SMP_TRACE_LEVEL_DEBUG= < CONFIG_SMP_TRACE_LEVEL_VERBOSE= < CONFIG_SMP_INITIAL_TRACE_LEVEL=2 < CONFIG_BTIF_TRACE_LEVEL_NONE= < CONFIG_BTIF_TRACE_LEVEL_ERROR= < CONFIG_BTIF_TRACE_LEVEL_WARNING=y < CONFIG_BTIF_TRACE_LEVEL_API= < CONFIG_BTIF_TRACE_LEVEL_EVENT= < CONFIG_BTIF_TRACE_LEVEL_DEBUG= < CONFIG_BTIF_TRACE_LEVEL_VERBOSE= < CONFIG_BTIF_INITIAL_TRACE_LEVEL=2 < CONFIG_BTC_TRACE_LEVEL_NONE= < CONFIG_BTC_TRACE_LEVEL_ERROR= < CONFIG_BTC_TRACE_LEVEL_WARNING=y < CONFIG_BTC_TRACE_LEVEL_API= < CONFIG_BTC_TRACE_LEVEL_EVENT= < CONFIG_BTC_TRACE_LEVEL_DEBUG= < CONFIG_BTC_TRACE_LEVEL_VERBOSE= < CONFIG_BTC_INITIAL_TRACE_LEVEL=2 < CONFIG_OSI_TRACE_LEVEL_NONE= < CONFIG_OSI_TRACE_LEVEL_ERROR= < CONFIG_OSI_TRACE_LEVEL_WARNING=y < CONFIG_OSI_TRACE_LEVEL_API= < CONFIG_OSI_TRACE_LEVEL_EVENT= < CONFIG_OSI_TRACE_LEVEL_DEBUG= < CONFIG_OSI_TRACE_LEVEL_VERBOSE= < CONFIG_OSI_INITIAL_TRACE_LEVEL=2 < CONFIG_BLUFI_TRACE_LEVEL_NONE= < CONFIG_BLUFI_TRACE_LEVEL_ERROR= < CONFIG_BLUFI_TRACE_LEVEL_WARNING=y < CONFIG_BLUFI_TRACE_LEVEL_API= < CONFIG_BLUFI_TRACE_LEVEL_EVENT= < CONFIG_BLUFI_TRACE_LEVEL_DEBUG= < CONFIG_BLUFI_TRACE_LEVEL_VERBOSE= < CONFIG_BLUFI_INITIAL_TRACE_LEVEL=2 < CONFIG_BT_ACL_CONNECTIONS=2 < CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=y < CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=y < CONFIG_BLE_HOST_QUEUE_CONGESTION_CHECK= < CONFIG_SMP_ENABLE=y < CONFIG_BLE_ACTIVE_SCAN_REPORT_ADV_SCAN_RSP_INDIVIDUALLY= < CONFIG_BLE_ESTABLISH_LINK_CONNECTION_TIMEOUT=30 < CONFIG_BT_RESERVE_DRAM=0xdb5c ---
506a284
CONFIG_NO_BLOBS=
514d291 < CONFIG_SW_COEXIST_ENABLE= 642c419 < CONFIG_FATFS_ALLOC_PREFER_EXTRAM=y ---
673c450 < CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y ---
683c460 < CONFIG_TIMER_TASK_PRIORITY=1 ---
688,689c465,469 < CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS= < CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS= ---
775c555 < CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y ---
777,778c557,558 < CONFIG_TCPIP_TASK_AFFINITY_CPU1= < CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF ---
810c590 < CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=30 ---
859,860c639,640 < CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144 < CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40 ---
865d644 < CONFIG_OVMS_COMP_BLUETOOTH=y 900d678 < CONFIG_BTDM_CONTROLLER_BR_EDR_SCO_DATA_PATH_EFF=0 905,906c683,684 < CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y < CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC= ---
909c687 < CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096 ---
929c707 < CONFIG_MBEDTLS_KEY_EXCHANGE_PSK= ---
1104a883
Regards
Chris
Chris, sorry for the outdated bluetooth sdkconfig and lack of info on this. The bluetooth component development was done by Mark. It's been stopped at an early stage without usable functionality IIRC. It was supposed to pair, but nothing else. It used up a lot of memory we needed for other tasks, and there was no real need for this, so we excluded it from the standard build. It's been stuck there since mid 2018, and the IDF API may have changed in the meantime. I think the IDF even introduced a whole new driver approach later on, so the component may need a complete rewrite. You're welcome to work on that, but maybe there are better options for what you'd like to do, or you can work with a simplified approach. If I understood you correctly, you would like to access the UpMiiGo's main CAN bus via a bluetooth OBD2 dongle, because the main CAN isn't available at your preferred OVMS mounting point. My own experiences with bluetooth OBD2 dongles were all bad, very slow and unreliable, unsuitable for live CAN data. That's been years ago, maybe the situation has changed, but I still would prefer a cable, also because I don't trust these cheap bluetooth (or wifi) devices to be secure. Isn't the CAN bus reachable somewhere near? Regards, Michael Am 27.03.20 um 19:57 schrieb Chris van der Meijden:
Hi all
Greetinx
Chris
Dear all
to the KConfig.
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y 1104a883 # Thanx in advance for your help.
Regards
Chris
Hey Michael thank you for your quick response. So it seems that I opened Pandoras box :-) As you wrote, I thought it would be a good idea to access the VW OBD gateway over bluetooth as I now just tap into the VW comfort CAN from under the passenger seat. But as bluetooth is in such an alpha state at the moment, I will focus now on the next step to get the remote climate control managed over the comfort CAN rather than over the OBD gateway. This is a big reverse engineering task, but seems still easier achievable than rewriting the OVMS bluetooth part. But I will keep bluetooth in mind for the future. It would be just great to have it working ... Greetinx and take care. Chris Am Freitag, den 27.03.2020, 21:22 +0100 schrieb Michael Balzer:
Chris,
Regards, Michael
Hi all
https://github.com/devmarxx/Open-Vehicle-Monitoring-System-3/tree/m aste r/vehicle/OVMS.V3/support
Greetinx
Chris
Dear all
to the KConfig.
506a284
CONFIG_NO_BLOBS=
1104a883
Regards
Chris
Chris van der Meijden -
