Hi, In order to help new users access the power of the OVMS I have pulled together some of the scripting documentation. It is mainly from http://bit.ly/2FcqnyS and is in a draft section in a http://bit.ly/2sdkgmh that will later be integrated into User Manual once reviewed. I don't have an OVMS unit at the moment so cant test myself. So it would be great if those with experience of using the scripting feature could review/add to the above document as necessary. You will need to request access, mainly so that I can come back to specific people if I need to clarify anything (rather than pinging the entire group). Also happy to take known issues not in the http://bit.ly/2CUS8KX and capture in github. Thanks, Rob
It looks like Google no longer presents an option to request access to a Google Doc. I have therefore made it available to only those with the link. If you tried to view the draft document please try again and once visible make sure you SignIn. Rob --- On Mon, 07 Jan 2019 11:08:49 +0000 Robert Sharpe (Electric Vehicle Consultant) <mailto:robert.sharpe@evergreen-consulting.co.uk> wrote ---- Hi, In order to help new users access the power of the OVMS I have pulled together some of the scripting documentation. It is mainly from http://bit.ly/2FcqnyS and is in a draft section in a http://bit.ly/2sdkgmh that will later be integrated into User Manual once reviewed. I don't have an OVMS unit at the moment so cant test myself. So it would be great if those with experience of using the scripting feature could review/add to the above document as necessary. You will need to request access, mainly so that I can come back to specific people if I need to clarify anything (rather than pinging the entire group). Also happy to take known issues not in the http://bit.ly/2CUS8KX and capture in github. Thanks, Rob _______________________________________________ OvmsDev mailing list mailto:OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
