As the subject says - what does CarOn mean? Is it key in position 3, or car in "Ready" state? Or something even more remote like shifter not in "P"? Nikolay
Nikolay, unsigned char car_doors1 [bit 7] A bit used to signal whether the car is turned on or off. Set to 1 if the car ignition switch is ON, otherwise 0. If the state of the ignition switch is not readable on the bus, the vehicle not being in 'P' gear or handbrake not appied (and not charging), would be acceptable. Regards, Mark. On 15 Jun, 2014, at 9:38 pm, Nikolay Shishkov <nshishkov@yahoo.com> wrote:
Nikolay _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
Nikolay Shishkov
