Although experienced with J1850/Class 2, ovms is completely new to me. I have a friend with a V1 module in his roadster and it's great that the V3 module is finally out! I've figured out a fair amount on my own but it's probably time for me to start asking questions (and providing some feedback). I got my module up on the bench without too much trouble. The V2 and V3 server config was confusing to me since I knew almost nothing. I think I had read that V2 was legacy and V3 was where new development effort was happening so I thought that's what I wanted. But I didn't find much info on io.adafruit.com vs. ovms so I ended up configuring the V2 server for starters. My canbus car is a second generation CTS-V. Once I plugged that in I could see my car with the iphone app. But the app didn't show much (I completely understand that most work so far as been on plugin vehicles). Once I turned the car on the battery percentage starting showing how full my gas tank was. I'm still a bit confused about how GPS works. I was expecting it to use the GPS periodically but what I've found is if I don't turn on the GPS at startup, I never see location info even when I'm driving. And if I enable GPS at startup, it seems to always be on even when the car is not. Maybe this is because my car isn't supported and the module doesn't know when it's running? I also found that trying to press any of the homelink options crashes the iphone app. Initially I could not get ssh to work. This wasn't surprising since my FreeBSD desktop runs openssh 7.7p1 and I know there is a push to disable or even remove less secure and insecure crypto. But after joining the ovmsdev list the solution was revealed (create a Host block with "Ciphers aes128-cbc") so that is working for me now. I like the way ssh.keys work (mapping the remote username) but I use hard tokens with ssh it sure would be nice if you could configure more than one ssh key. When learning about how ssh works I was using the google doc (15Mar18) and it says when you login you start in non-secure mode. I find ssh always puts me in secure mode. The section about SD cards in the google doc is empty; I made assumptions and got a couple class 10 64G cards. I don't know if this is a good size or way to big to be useful. Today I brought up a mqtt server (mosquitto). In verbose mode I can see my v3 module posting things to it but I don't know what tools I can use with my server. I'd like to get a build environment up. The only info I could find was: https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/master/d... which is geared towards v2 (which I saw is pic based). What do I need to be able to build for v3? I normally work/play on FreeBSD but I have an ubuntu system handy for when I need it. I noticed lists.openvehicles.com uses http; if I try to force https I end up on a different website. Looks like apache is in use; I have a lot of experience with apache and lets encrypt ssl certs and would be happy to share the setup I use. I'm also wondering about https support for the ovms module itself. Is that on the roadmap? I know the esp32 can do it; I have done a *lot* with atmega arduino clones but have recently started using esp8266 and esp32 modules because I can network them (and with https). Craig
On Sun, 22 Apr 2018, Craig Leres wrote: It is interesting to see names from past lives pop up in new contexts!
The purpose of the V2 server is to allow the v3 devices to replace v2 devices and be useful in the near term while the v3 capabilities are developed.
The CAN bus protocols seem to be unique for each EV and unrelated to any standard functionality on the OBD-II connector. So to have OVMS be useful for the CTS-V would require adding support specifically for that vehicle. There is work underway to simplify that process.
The algorithm support I have available in the WolfCrypt library is somewhat limited. As I mentioned, AES-GCM is possible but may be too expensive in memory and speed.
I'm not sure what "hard tokens" means here. Since the username has no function other than as an index to a key, you can install multiple keys with different usernames if that helps.
Since authentication is required to establish the ssh connection, it makes sense to be in secure mode automatically. That sounds like the doc being behind the times.
I'd like to get a build environment up. ... What do I need to be able to build for v3? I normally work/play on FreeBSD but I have an ubuntu system handy for when I need it.
The first step would be to get the ESP-IDF running, if you have not already (you mention working with esp32). Espressif provides documentation and example programs. If that works on FreeBSD then you're set for OVMS as well, but if not you may need to use linux. Then clone openvehicles/Open-Vehicle-Monitoring-System-3 with --recurse-submodules and set IDF_PATH as you would for any of the example projects, and you should be able to build. -- Steve
I’ve updated the documentation to clarify this.
Craig Leres -
Mark Webb-Johnson -
Stephen Casner
