The Twizy code has finally reached release 1.0. With my recent additions, all V2 features I planned to include in V3 are now done. As we're also again >200 commits from 3.2.001, maybe it's time for 3.2.002? Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Hi Michael, I am currently testing a change that I would really like in there, as it is a follow-up to earlier changes in this version (making the Leaf code less dependent on the 'max_gids' setting) So far the tests gave no issues, so I think I will be ready to push my changes either tomorrow or Friday. Could you wait with the new release until then? OKidoki, Anko -----Original Message----- From: Michael Balzer <dexter@expeedo.de> Sent: Wednesday, 8 May 2019 6:58 AM To: ovmsdev@lists.openvehicles.com Subject: [Ovmsdev] Time for 3.2.002? The Twizy code has finally reached release 1.0. With my recent additions, all V2 features I planned to include in V3 are now done. As we're also again >200 commits from 3.2.001, maybe it's time for 3.2.002? Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Let’s cut-off at Friday night (UTC). Then, Saturday I will build a 3.2.002 and put it into ‘eap'. Then perhaps ‘main’ mid next week? I had hoped that Espressif would fix the PSRAM corruption issue, but they say still working on it - I think no point waiting longer for that. Regards, Mark
On 8 May 2019, at 1:23 PM, Anko Hanse <anko_hanse@hotmail.com> wrote:
Hi Michael,
OKidoki, Anko
Regards, Michael
There seems to be an issue with the latest OBD2 polling code changes (?) https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/221 …or maybe it's just a Volt/Ampera issue? We should try to clarify / resolve that for 3.2.002. It would be so nice if Espressif would at least communicate on the PSRAM fix progress… Regards, Michael Am 08.05.19 um 07:31 schrieb Mark Webb-Johnson:
Hi Michael,
OKidoki, Anko
Regards, Michael
It seems the change made in commit 4fa745190bac56a4501787590ee95bf644532dbf (Geir) was to VEHICLE_POLL_TYPE_OBDIIEXTENDED response, to add support for multi-frame extended responses. However, that change removed the support for single frame responses (as used by Volt/Ampera). The code is currently checking for: // Multi-frame initial response if (((frame->data.u8[0]>>4) == 0x1)&& (frame->data.u8[2] == 0x40+m_poll_type)&& ((frame->data.u8[4]+(((uint16_t) frame->data.u8[3]) << 8)) == m_poll_pid)) … // Multi-frame second response else if (((frame->data.u8[0]>>4)==0x2)&&(m_poll_ml_remain>0)) …. I have now added back: // Single frame response else if ((frame->data.u8[1] == 0x62)&& ((frame->data.u8[3]+(((uint16_t) frame->data.u8[2]) << 8)) == m_poll_pid)) Byte 0 should be the number of bytes in the response. Geir’s modification seems to look for a 1 in the high nibble, so that shouldn’t match for ’normal’ single frame responses. For a single frame response, m_poll_ml_remain should always be zero. So, I think my modification should not affect Geir’s usage, and should add back support for single frame extended responses (as used by Volt/Ampera). But, I don’t have any active polling dumps from volt/ampera, so no way to test it beyond the very rudimentary testing I have done (can can1 rx standard 7EC 05 62 83 34 12 34, at the appropriate time). Could someone with a volt/ampera please test this, and see if it works? I have built into edge as 3.2.001-206-g0f4c05b. If it doesn’t work, can we get a CRTD dump during the active poll (ignition on)? Regards, Mark
Regards, Michael
Hi Michael,
OKidoki, Anko
Regards, Michael
Thanks Mark! I think that should fix it. Sorry for making the bug! Best regards, Geir Sendt fra min iPhone
8. mai 2019 kl. 14:10 skrev Mark Webb-Johnson <mark@webb-johnson.net>:
Regards, Michael
Am 08.05.19 um 07:31 schrieb Mark Webb-Johnson: Let’s cut-off at Friday night (UTC). Then, Saturday I will build a 3.2.002 and put it into ‘eap'. Then perhaps ‘main’ mid next week?
Hi Michael,
OKidoki, Anko
Regards, Michael
The 3.2.002 has been built, and is in both edge and eap release level on api.openvehicles.com <http://api.openvehicles.com/>. Regards, Mark.
Hi Michael,
OKidoki, Anko
Regards, Michael
Anko Hanse -
Geir Øyvind Vælidalo -
Mark Webb-Johnson -
