Hi All, I have just had a bit of a painful experience with my 12V being drained (twice). I'm guessing it's related to OVMS, but also something seems to have happened as it was running file for a week! For some reason, the 12V battery graphs aren't working in the (android) App.. which means I'm not quite sure of the timelines, however it was most likely overnight. This morning my 12V was severely depleted (like 6v!). (Oh, it could be because I don't have the app running in the background). I'm assuming it's likely not to be the direct drain of the device itself, but maybe something it is querying on the CAN busses or something that is then causing a consequential power drain? I got road-side assist out and they got me going, but then 20mins later it was flat again! (I did see an alert in the APP and so was quick to go out, but was unsuccessful in getting the car going before it died!). I'm going to unplug it and see if that stops the card from dying. Also, I might leave the car on for a bit longer.. but still I have concerns! Also I haven't started using 'write' commands yet. Any ideas? //.ichael
Michael, while the OVMS draws some power, unless you actually keep the car alive by polling, that's normally no issue. The 12V battery will be recharged automatically from the main battery by the car. The Ioniq 5 though has a history of issues with the 12V battery. According to Andrew Till, a BMS update has fixed his issues: https://www.youtube.com/watch?v=YmfkvL_O1IA Also see his previous posts on that topic. Regards, Michael Am 23.09.22 um 09:55 schrieb Michael Geddes:
Hi All,
//.ichael
Thanks Michael, I rang the Hyundai service centre, and apparently, my BMS should not need any updates (build date 2021 vs 2020 cars with the problem apparently), but I'm putting it in for a checkup of the battery. Apparently, the BMS update was the subject of a recall for those cars affected. I'm going to take it in anyway in case. It seems, according to the OVMS, that the 12V is going from 13v down to 12v over about 3hours before (generally) being recharged. Looking at that link you shared with me (and related https://www.youtube.com/watch?v=lr3Z_z1C0Uk&t=965s), it should be more like 24 hours. It still should be triggering a charge cycle - and obviously in this case it seems to miss one and then it just goes downhill from there - so maybe the BMS still has a bug; not helped by being forced to trigger about 4x more frequently than normal! Assuming nothing is wrong with the car (which unless I install some kind of external battery monitor like that youtube clip), I can only assume that the 3hr drain is because my Ioniq 5 module is polling too much (which, seeing I copied the vehicle_kianiroev/src/ as my base, would mean THAT polls too much as well). I still have the PollSetPidList() called with the same data (albeit a copy) as the Kia. So in drafting this email I think I've hit on the problem, which is when the car is off, but a V2 or V3 client is connected (like the android app in 'background' mode), then it uses the 'Charging' pollstate element. It has {OFF, Charging, ON} at the moment, which means there's space for a 4th which I will assign to 'off, not-charging and clients connected'. I'll see what I can do to drop that right down in polling frequency and the number of modules being addressed. At some point soon it might be worth me pushing up to a fork in case anybody else wants to jump in! For example, the Lock module that the kia has is not present in the Australian version, but I suspect US ones with key-card ability might have it. //.ichael On Fri, 23 Sept 2022 at 17:03, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
Hi All,
//.ichael
Michael, it's generally a bad idea to have polls running just based on the client connection status. Clients may be connected all the time, e.g. if users attach some API pollers or set the App to persistent background operation (which is necessary for widgets or tasker scripting for example). You should only enable polling when actually necessary to perform some user requested action, or to monitor a drive / charge session of course. We've got an explicit "wakeup" command users can call to tell the module to wake up the car. That needs to implement some timeout to put the car back to sleep if it doesn't do so by itself. Regards, Michael Am 27.09.22 um 09:41 schrieb Michael Geddes:
Thanks Michael,
It seems, according to the OVMS, that the 12V is going from 13v down to 12v over about 3hours before (generally) being recharged. Looking at that link you shared with me (and related https://www.youtube.com/watch?v=lr3Z_z1C0Uk&t=965s <https://www.youtube.com/watch?v=lr3Z_z1C0Uk&t=965s>), it should be more like 24 hours. It still should be triggering a charge cycle - and obviously in this case it seems to miss one and then it just goes downhill from there - so maybe the BMS still has a bug; not helped by being forced to trigger about 4x more frequently than normal!
//.ichael
Michael,
Regards, Michael
Am 23.09.22 um 09:55 schrieb Michael Geddes: > Hi All, > > I have just had a bit of a painful experience with my 12V being > drained (twice). I'm guessing it's related to OVMS, but also > something seems to have happened as it was running file for a week! > > For some reason, the 12V battery graphs aren't working in the > (android) App.. which means I'm not quite sure of the timelines, > however it was most likely overnight. This morning my 12V was > severely depleted (like 6v!). (Oh, it could be because I don't have > the app running in the background). > > I'm assuming it's likely not to be the direct drain of the device > itself, but maybe something it is querying on the CAN busses or > something that is then causing a consequential power drain? > > I got road-side assist out and they got me going, but then 20mins > later it was flat again! (I did see an alert in the APP and so was > quick to go out, but was unsuccessful in getting the car going before > it died!). > > I'm going to unplug it and see if that stops the card from dying. > Also, I might leave the car on for a bit longer.. but still I have > concerns! > > Also I haven't started using 'write' commands yet. Any ideas? > > //.ichael >
On 27 Sep 2022, at 08:55, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Sounds like a better idea IMHO. Tracking issue is https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/275 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/275> I’ve got a Kona and did contribute a little a while back … but I’ve yet to get back using OVMS due to the power issues, although I have replace the 12v battery with a better one. It might be time for a re-write for the kona/ionic/niro support.
Regards, Michael
Thanks Michael,
//.ichael
On Fri, 23 Sept 2022 at 17:03, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: Michael,
The Ioniq 5 though has a history of issues with the 12V battery. According to Andrew Till, a BMS update has fixed his issues: https://www.youtube.com/watch?v=YmfkvL_O1IA <https://www.youtube.com/watch?v=YmfkvL_O1IA>
Regards, Michael
Hi All,
//.ichael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Yeah, I'm beginning to see that continuous polls are Bad(tm). With my latest changes, the 2 polls that are always done are for detecting On and Unlock which are on different module addresses. Setting the Car Type to NONE (and rebooting) certainly confirms that the battery drain goes away. Crap. Is there a better way of detecting 'On', 'unlock' and possibly 'alarm'? Anything else could be checked much less frequently anyway. Maybe I could use internal battery test changes to trigger checks... A bit dodgy though. Should I expect to see _any_ messages floating around on the bus without being requested? I'm not seeing any.. Presumably if I send 'Tester Present' it will keep the module powered (and back to square 1), or is there some kind of bus switch that is not letting me see messages? I'm coming into Can messages as a complete noon. Maybe Peter could help me on this, and we could put some of my changes back to kia/Kona or the common class when I'm done. I'll certainly look at using the wakeup. BTW for updating images I have set a SSH pubkey and am using scp <<image>> admin@ovms.lan:/sd && ssh admin@ovms.lan "module reset" Which works like a charm! Michael On Tue, 27 Sept 2022, 3:55 pm Michael Balzer, <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
Thanks Michael,
//.ichael
Michael,
Regards, Michael
Hi All,
//.ichael
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi Michael. Back when I had a Kia Niro I did some measurements on power draw. It’s not the poll itself that causes the power drain, it prevents the car from going to deep sleep. So I don’t think polling less frequently will have much effect. I didn’t find any way on the Kia to detect if it’s on without additional hardware involved, e.g. to check if there was power on the radio fuse. https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/275 Best Regards TIMO PENTTILÄ From: OvmsDev <ovmsdev-bounces@lists.openvehicles.com> On Behalf Of Michael Geddes Sent: den 28 september 2022 04:31 To: OVMS Developers <ovmsdev@lists.openvehicles.com> Subject: Re: [Ovmsdev] OVMS Power Drain? Yeah, I'm beginning to see that continuous polls are Bad(tm). With my latest changes, the 2 polls that are always done are for detecting On and Unlock which are on different module addresses. Setting the Car Type to NONE (and rebooting) certainly confirms that the battery drain goes away. Crap. Is there a better way of detecting 'On', 'unlock' and possibly 'alarm'? Anything else could be checked much less frequently anyway. Maybe I could use internal battery test changes to trigger checks... A bit dodgy though. Should I expect to see _any_ messages floating around on the bus without being requested? I'm not seeing any.. Presumably if I send 'Tester Present' it will keep the module powered (and back to square 1), or is there some kind of bus switch that is not letting me see messages? I'm coming into Can messages as a complete noon. Maybe Peter could help me on this, and we could put some of my changes back to kia/Kona or the common class when I'm done. I'll certainly look at using the wakeup. BTW for updating images I have set a SSH pubkey and am using scp <<image>> admin@ovms.lan:/sd<mailto:admin@ovms.lan:/sd> && ssh admin@ovms.lan<mailto:admin@ovms.lan> "module reset" Which works like a charm! Michael On Tue, 27 Sept 2022, 3:55 pm Michael Balzer, <dexter@expeedo.de<mailto:dexter@expeedo.de>> wrote: Michael, it's generally a bad idea to have polls running just based on the client connection status. Clients may be connected all the time, e.g. if users attach some API pollers or set the App to persistent background operation (which is necessary for widgets or tasker scripting for example). You should only enable polling when actually necessary to perform some user requested action, or to monitor a drive / charge session of course. We've got an explicit "wakeup" command users can call to tell the module to wake up the car. That needs to implement some timeout to put the car back to sleep if it doesn't do so by itself. Regards, Michael Am 27.09.22 um 09:41 schrieb Michael Geddes: Thanks Michael, I rang the Hyundai service centre, and apparently, my BMS should not need any updates (build date 2021 vs 2020 cars with the problem apparently), but I'm putting it in for a checkup of the battery. Apparently, the BMS update was the subject of a recall for those cars affected. I'm going to take it in anyway in case. It seems, according to the OVMS, that the 12V is going from 13v down to 12v over about 3hours before (generally) being recharged. Looking at that link you shared with me (and related https://www.youtube.com/watch?v=lr3Z_z1C0Uk&t=965s), it should be more like 24 hours. It still should be triggering a charge cycle - and obviously in this case it seems to miss one and then it just goes downhill from there - so maybe the BMS still has a bug; not helped by being forced to trigger about 4x more frequently than normal! Assuming nothing is wrong with the car (which unless I install some kind of external battery monitor like that youtube clip), I can only assume that the 3hr drain is because my Ioniq 5 module is polling too much (which, seeing I copied the vehicle_kianiroev/src/ as my base, would mean THAT polls too much as well). I still have the PollSetPidList() called with the same data (albeit a copy) as the Kia. So in drafting this email I think I've hit on the problem, which is when the car is off, but a V2 or V3 client is connected (like the android app in 'background' mode), then it uses the 'Charging' pollstate element. It has {OFF, Charging, ON} at the moment, which means there's space for a 4th which I will assign to 'off, not-charging and clients connected'. I'll see what I can do to drop that right down in polling frequency and the number of modules being addressed. At some point soon it might be worth me pushing up to a fork in case anybody else wants to jump in! For example, the Lock module that the kia has is not present in the Australian version, but I suspect US ones with key-card ability might have it. //.ichael On Fri, 23 Sept 2022 at 17:03, Michael Balzer <dexter@expeedo.de<mailto:dexter@expeedo.de>> wrote: Michael, while the OVMS draws some power, unless you actually keep the car alive by polling, that's normally no issue. The 12V battery will be recharged automatically from the main battery by the car. The Ioniq 5 though has a history of issues with the 12V battery. According to Andrew Till, a BMS update has fixed his issues: https://www.youtube.com/watch?v=YmfkvL_O1IA Also see his previous posts on that topic. Regards, Michael Am 23.09.22 um 09:55 schrieb Michael Geddes:
Hi All,
//.ichael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com<mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com<mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com<mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Cars now often do not provide live process data frames on the OBD port's primary CAN. You may have an auxiliary CAN bus there, e.g. for infotainment communication, that may provide live frames. But you may not be able to detect a charge session from these. A very simple approach is to monitor the 12V level. For example on the UpMiiGo, if it rises to around 13V the car is recharging the 12V battery, if it goes to 14V or higher, it's fully awake for a drive or charge session. We used that approach until I found PIDs we can poll without keeping the car awake. If you didn't do so yet, try polling without a tester presence or diag session. Also try polling low priority / auxiliary PIDs instead of the actual status PIDs, i.e. PIDs that do not carry crucial system state data. You may also need to keep the polling frequency below some threshold to avoid the keep-alive trigger. Regards, Michael Am 28.09.22 um 06:15 schrieb Timo Penttilä:
Hi Michael.
*Best Regards*
*TIMO PENTTILÄ*
*From:*OvmsDev <ovmsdev-bounces@lists.openvehicles.com> *On Behalf Of *Michael Geddes *Sent:* den 28 september 2022 04:31 *To:* OVMS Developers <ovmsdev@lists.openvehicles.com> *Subject:* Re: [Ovmsdev] OVMS Power Drain?
Michael,
Regards, Michael
Thanks Michael,
//.ichael
Michael,
Regards, Michael
Thankyou all! I have not been idle - I've not quite moved away from the polling for receiving information.. but at least now I can clamp right down on it being used while the car is off by looking at the 12v power! The only code in the original using tester present is the commands, which I am yet to try. I will have a look at the upmiigo code. I'm not seeing multiple high levels.. But once it spikes I can poll for a bit. There is a crash that happens periodically. It's not in my code I don't think as I have put a debug on all functions in the directory that logs if it isn't 'disarmed'. Not for production, but useful. I guess once I have a GPS aerial I can use that to make sure the polling is activated on movement! I'm guessing it has to be significant to avoid inaccuracies of GPS triggering it. Michael On Wed, 28 Sept 2022 at 14:21, Michael Balzer <dexter@expeedo.de> wrote:
Regards, Michael
Hi Michael.
*Best Regards*
*TIMO PENTTILÄ*
*From:* OvmsDev <ovmsdev-bounces@lists.openvehicles.com> <ovmsdev-bounces@lists.openvehicles.com> *On Behalf Of *Michael Geddes *Sent:* den 28 september 2022 04:31 *To:* OVMS Developers <ovmsdev@lists.openvehicles.com> <ovmsdev@lists.openvehicles.com> *Subject:* Re: [Ovmsdev] OVMS Power Drain?
Michael,
Regards, Michael
Thanks Michael,
//.ichael
Michael,
Regards, Michael
Hi All,
//.ichael
Michael Balzer -
Michael Geddes -
Peter Lord -
Timo Penttilä
