Thanks Michael, I'm not that advanced to create such a feature for the Roadster... but maybe it's easier to have to server poll the car every x-minutes, and log the last 100 SOC entries or something like that. It could provide the data needed to create such a graph. Also, thanks for the source code update :) I'm planning to do some more work on the user interface this weekend, and I just did a succesful test with more advanced notifications on my smartwatch (android wear), I'll see if I can turn this into something useful. Message: 2
Date: Fri, 03 Apr 2015 12:13:57 +0200 From: Michael Balzer <dexter@expeedo.de> Subject: Re: [Ovmsdev] Android beta 3.9.0 To: ovmsdev@lists.teslaclub.hk Message-ID: <551E67E5.3050409@expeedo.de> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Here's the source status for version 3.9.1:
https://github.com/openvehicles/Open-Vehicle-Android/commit/8444f06335a54e1b...
The new tools are based on the -currently- Twizy specific historical records, in this case
RT-PWR-BattPack RT-PWR-BattCell
...plus the -currently- Twizy specific command code 206 "BatteryStatus".
As no other car currently can deliver this data and also as I'm lazy, the data model & chart layout is currently tailored to the Twizy battery pack layout. But that's easy to extend if other cars start providing the necessary data. Btw: if the proposed record format is OK for other cars, we should rename the records from "RT-" to "*-".
Same applies to the diag logs tool, which is currently only implemented for SEVCON diag data but can be extended for others.
I guess the charge alerts control can be adopted for other cars most easily. As far as I know the roadster module already provides charge time estimations, but it seems the charge alerts and max range cannot yet be set by the user. Maybe we can move the Twizy commands for this into the framework.
Regards, Michael
Am 03.04.2015 um 11:05 schrieb Jille Berends:
Testing 3.9.1 :) I guess I should get a Twizzy because of all the coolness coming to the app. Loving the graphs. Do you think this could be used on the Roadster too, or does it need specific features in the car itself?
Also, can you update Github?
2015-04-03 6:00 GMT+02:00 <ovmsdev-request@lists.teslaclub.hk <mailto:ovmsdev-request@lists.teslaclub.hk>>:
Send OvmsDev mailing list submissions to ovmsdev@lists.teslaclub.hk <mailto:ovmsdev@lists.teslaclub.hk>
To subscribe or unsubscribe via the World Wide Web, visit http://lists.teslaclub.hk/mailman/listinfo/ovmsdev or, via email, send a message with subject or body 'help' to ovmsdev-request@lists.teslaclub.hk <mailto:ovmsdev-request@lists.teslaclub.hk>
You can reach the person managing the list at ovmsdev-owner@lists.teslaclub.hk <mailto:ovmsdev-owner@lists.teslaclub.hk>
When replying, please edit your Subject line so it is more specific than "Re: Contents of OvmsDev digest..."
Today's Topics:
1. Re: Android beta 3.9.0 (Julien (JaXX) Banchet) 2. Re: Android beta 3.9.0 (Michael Balzer)
Message: 1 Date: Thu, 02 Apr 2015 20:48:38 +0200 From: "Julien (JaXX) Banchet" <jaxx@jaxx.org <mailto:jaxx@jaxx.org>> Subject: Re: [Ovmsdev] Android beta 3.9.0 To: OVMS Developers <ovmsdev@lists.teslaclub.hk <mailto:ovmsdev@lists.teslaclub.hk>> Message-ID: <551D8F06.9000801@jaxx.org <mailto:551D8F06.9000801@jaxx.org>> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Mark, Micheal,
Could this be eventually published to the Google Web Store using the recently pushed ARC-Welder ?
I tried it out, and it's kinda cool having it on the desktop! https://dl.dropboxusercontent.com/u/684235/arc_ovms_crop.jpg
Getting Started with ARC: https://developer.chrome.com/apps/getstarted_arc
MfG
JaXX./.
Le 01/04/2015 19:33, Michael Balzer a ?crit : > Hi Julien, > > thanks for reporting. Not sure how 3.9.0 could cause that, there
was
> no db/file structure change. > > Last db update was in 3.8.2 with a bug that lead to wrong database > creation on new installs or wiped data -- 3.8.3 fixed that, but should > only have needed a wipe if 3.8.2 was installed from scratch... > > I'm waiting for some more reports to see if there's a pattern. > > Regards, > Michael > > > Am 01.04.2015 um 16:41 schrieb Julien (JaXX) Banchet: >> Hi Michael, >> >> FYI, a plain update didn't make it, crashes on start (even after a >> fully reboot), without a crashlog... First time an apk update on OVMS >> does that. >> >> Had to wipe it >> >> JaXX./. >> >> >> Le 31/03/2015 22:50, Michael Balzer a ?crit : >>> Hi everyone, >>> >>> this is a beta test release mainly for Twizy users, there's just an >>> updated charger plug image (created by jilleberends) for other cars. >>> >>> dexters-web.de/f/tw/oVMS-release-3.9.0.apk <http://dexters-web.de/f/tw/oVMS-release-3.9.0.apk> >>> <http://dexters-web.de/f/tw/oVMS-release-3.9.0.apk> >>> >>> New function is the graphical battery monitor using the Twizy >>> specific history records. Access by the options icon on the battery tab. >>> >>> It concentrates on the data display for now, suggestions for
later
>>> analysis functions are welcome. >>> >>> Data download takes up to 20 seconds depending on the data amount >>> and phone capabilities, I'll add a sub progress bar for this. >>> >>> The chart engine was not suitable for this kind of chart, so I >>> switched to github.com/PhilJay/MPAndroidChart <http://github.com/PhilJay/MPAndroidChart> >>> <https://github.com/PhilJay/MPAndroidChart> for this. >>> >>> Please test & report. >>> >>> Regards, >>> Michael >>> >>> -- >>> Michael Balzer * Paradestr. 8 * D-42107 Wuppertal >>> Fon 0202 / 272 2201 * Handy 0176 / 206 989 26 >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> >>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev >> >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Paradestr. 8 * D-42107 Wuppertal > Fon 0202 / 272 2201 * Handy 0176 / 206 989 26 > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Jille Berends
