I now update (create a fresh install) my Mac (Macbok air 2017) to macOS Monterey and developing not working. I get a following when compile a code, this a main repo, without modification, fresh install. Any suggestions? Go back to BigSur?
Wel im running it all fine with Monterey so its not the OS, but im not a clean install so at a guess its esp or Xcode issue Regards Shane
On 28 Dec 2021, at 16:26, Tamás Kovács <kommykt@gmail.com> wrote:
I now update (create a fresh install) my Mac (Macbok air 2017) to macOS Monterey and developing not working. I get a following when compile a code, this a main repo, without modification, fresh install. Any suggestions? Go back to BigSur? <Terminalerror>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I build on Monterey ok. Perhaps double check the sdkconfig vs support/sdkconfig.default.hw31? And a ‘make clean’? Regards, Mark.
On 29 Dec 2021, at 12:26 AM, Tamás Kovács <kommykt@gmail.com> wrote:
I now update (create a fresh install) my Mac (Macbok air 2017) to macOS Monterey and developing not working. I get a following when compile a code, this a main repo, without modification, fresh install. Any suggestions? Go back to BigSur? <Terminal>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I think my main problem with the python, because esp first step is: sudo easy_install pip and get the following: Password: Searching for pip Reading https://pypi.org/simple/pip/ Downloading https://files.pythonhosted.org/packages/da/f6/c83229dcc3635cdeb51874184241a9... Best match: pip 21.3.1 Processing pip-21.3.1.tar.gz Writing /tmp/easy_install-_tOHJQ/pip-21.3.1/setup.cfg Running pip-21.3.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-_tOHJQ/pip-21.3.1/egg-dist-tmp-nFLUCL Traceback (most recent call last): File "/usr/bin/easy_install", line 13, in <module> load_entry_point('setuptools==41.0.1', 'console_scripts', 'easy_install')() File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 2319, in main **kw File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/__init__.py", line 145, in setup return distutils.core.setup(**attrs) File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/core.py", line 151, in setup dist.run_commands() File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/dist.py", line 953, in run_commands self.run_command(cmd) File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/distutils/dist.py", line 972, in run_command cmd_obj.run() File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 418, in run self.easy_install(spec, not self.no_deps) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 679, in easy_install return self.install_item(spec, dist.location, tmpdir, deps) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 705, in install_item dists = self.install_eggs(spec, download, tmpdir) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 890, in install_eggs return self.build_and_install(setup_script, setup_base) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 1158, in build_and_install self.run_setup(setup_script, setup_base, args) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/command/easy_install.py", line 1144, in run_setup run_setup(setup_script, args) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 253, in run_setup raise File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/contextlib.py", line 35, in __exit__ self.gen.throw(type, value, traceback) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 195, in setup_context yield File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/contextlib.py", line 35, in __exit__ self.gen.throw(type, value, traceback) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 166, in save_modules saved_exc.resume() File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 141, in resume six.reraise(type, exc, self._tb) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 154, in save_modules yield saved File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 195, in setup_context yield File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 250, in run_setup _execfile(setup_script, ns) File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/setuptools/sandbox.py", line 44, in _execfile code = compile(script, filename, 'exec') File "/tmp/easy_install-_tOHJQ/pip-21.3.1/setup.py", line 7 def read(rel_path: str) -> str: ^ SyntaxError: invalid syntax Monterey defaul python is: kommykt@Tamass-Air esp % python --version Python 2.7.18 kommykt@Tamass-Air esp % Now i create a new fresh install. Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2021. dec. 29., Sze, 0:44):
-- Üdvözlettel: Kovács Tamás
Now working all fine. I installed Homebrew with a following: /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)" After that installed python2.7 with the following command: python2.7 -m ensurepip --default-pip --user After tha install requirement.txt but i can install tornado, and nose packages as well, because this dependencies: python -m pip install --user tornado python -m pip install --user nose Now everythings compile fine. Tamás Kovács <kommykt@gmail.com> ezt írta (időpont: 2021. dec. 29., Sze, 9:11):
Password:
Searching for pip
**kw
dist.run_commands()
cmd_obj.run()
raise
yield
saved_exc.resume()
yield saved
yield
Python 2.7.18
Mark Webb-Johnson -
Shane @ Kilve Engineering -
Tamás Kovács
