I believe I have finally resolved the issue with the GSM daughter board and/or antenna interfering with my GPS. I replaced both and it seems to be all good now. Interestingly, I found this nice Antenna that has GSM and GPS (with 2 well-labeled tails that are compatible with the OVMS connections). https://www.amazon.com.au/dp/B07V9HRF65 It seems to be working well and is much neater to replace (I snaked it up through to the speaker+air cover on the front dash area). //.ichael
It would be nice to know which component was responsible for the interference, and what was broken to cause this, but you'd probably need an EM laboratory to find out. A broad range of combined GSM/GPS antenna are available now, also some nice shark fin shaped ones for roof mounting. Unfortunately they are all much higher priced than the combination of the single purpose ones. Regards, Michael Am 05.10.23 um 06:46 schrieb Michael Geddes:
//.ichael
Indeed, it would be good.. unless somebody in Perth happens to have such a Lab... yeah, might be a bit hard. I guess I could try ruling out the antennas.. Michael On Fri, 6 Oct 2023, 18:54 Michael Balzer, <dexter@expeedo.de> wrote:
Regards, Michael
//.ichael
Michael Balzer -
Michael Geddes
