Hi, I want my distances in miles, but temperatures in Celsius. Is this possible in the app, or can it be added? It would really help in the UK. Matt Beard
In the system settings app, find Open Vehicles in the listed apps, and you can find the configuration settings for this. Regards, Mark
On 26 Sep, 2013, at 5:55 am, Matt Beard <matt@beard.tv> wrote:
Hi,
Matt Beard
Ok, very cool, thanks! I notice that the chargers shown on the map are only those "within range" but there seems to be some sort of fudge-factor. My range I showing as 68mi, but I know there is a charger 60mi away and it does not show up. The inner red circle seems to be the limit and it is quite a lot less than 68mi. Is the fudge-factor adjustable? Matt On Wednesday, September 25, 2013, Mark Webb-Johnson wrote:
On 26 Sep, 2013, at 5:55 am, Matt Beard <matt@beard.tv <javascript:;>> wrote:
Hi,
Matt Beard
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <javascript:;> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Matt, Should be all stations within the car's estimated range (at the moment). On the map screen, you can tap the top-left station icon and turn off the "Only show stations in range", but I am really not sure how effective that is. Regards, Mark. On 26 Sep, 2013, at 3:39 PM, Matt Beard <matt@beard.tv> wrote:
Matt
Hi,
Matt Beard
OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
A couple of comments on this - first, the filter setting seems the wrong way in the menu! Second, it doesn't do what it says on the tin - please see attached pics. Matt On 26 September 2013 08:48, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Matt,
Matt
Hi,
Matt Beard
Mark Webb-Johnson -
Matt Beard -
Matt Beard OVMS
