Hi Pierre, never used that feature... I'll have a look at it. Regards, Michael Am 24.02.2015 um 12:06 schrieb Pierre Uhl:
How about the Social Groups? Since Version 3 this is disabled in Android (not iPhone). When it will come back?
Regards Pierre
-----Ursprüngliche Nachricht----- Von: ovmsdev-bounces@lists.teslaclub.hk [mailto:ovmsdev-bounces@lists.teslaclub.hk] Im Auftrag von Michael Balzer Gesendet: Montag, 23. Februar 2015 21:55 An: ovmsdev@lists.teslaclub.hk Betreff: [Ovmsdev] Android update 3.5.1
https://github.com/openvehicles/Open-Vehicle-Android/commit/c5146599045913db...
Version 3.5.1: - OCM infos added: UsageCost, AccessComments, RelatedURL, GeneralComments - OCM map markers: added OperatorInfo - OCM detail dialog: layout rework, added button "View in OCM" - Code cleanups
APK: http://dexters-web.de/f/tw/oVMS-release-3.5.1.apk
Regards, Michael
-- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
Hi Michael, I don't use the OVMS app but I tried your version on Android with the demo car selected. On the Location view should I see charge points or do I have to do something to make them appear by default? For me the Demo car is appearing near San Jose, Filtered Stations is Off, Only show Stations in range is Off. Chris On 24/02/2015 20:22, Michael Balzer wrote:
Hi Pierre,
Regards, Michael
Regards Pierre
Regards, Michael
Chris, 1. Check "Options > Settings > Enabled" 2. If the menu reads "Filtered Stations OFF" that means your filter is currently ON, selecting the menu will switch to OFF... not very clear IMO, changing that is on my list, the whole menu code is a little bit strange, depending on hard coded labels... Btw, same menu switching logic applies to the range filter. 3. For the filter you need to configure your connection types in the car menu: click on the edit pen of the car, then on the joystick icon in the top bar, then button "Connections". Regards, Michael Am 25.02.2015 um 03:11 schrieb Christopher Cook:
Hi Michael,
Chris
Thanks Michael, I've tried changing the settings as you've suggested but no luck so far, I possibly need to reinstall. I'd suggest that the default be to enable the feature and enable all connections (no connection filtering) then let the user decide which ones they're not interested in (which will be region specific). Regards, Chris On 25/02/2015 16:54, Michael Balzer wrote:
Chris,
Regards, Michael
Hi Michael,
Chris
Chris, following your report I found some more bugs especially regarding the car specific filter. Can you please try this version: |http://dexters-web.de/f/tw/oVMS-release-3.5.2.apk| Thanks, Michael Am 26.02.2015 um 13:21 schrieb Christopher Cook:
Regards, Chris
Chris,
Regards, Michael
Hi Michael,
Chris
Christopher Cook -
