Issues since latest update (3.2.0.14)
Hello, Anyone else is having connection issues since latest update? I’m constantly loosing contact with the device and haven’t been able to open a console with USB but this time, I can still access it with the Web interface and noticed it can’t connect to server. E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address E (72178423) ovms-server-v2: Status: Error: Connection failed W (72180093) simcom: UART hw fifo overflow W (72192873) gsm-mux: Frame overflow (2048 bytes) E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address E (72238423) ovms-server-v2: Status: Error: Connection failed E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870) failed: cannot parse address E (72298463) ovms-server-v2: Status: Error: Connection failed Address looks good though. Sebastien Darveau sebastien.darveau@synnoetic.com
What are your DNS servers set to? Can you try with 8.8.8.8, if you aren’t already, and don’t use ISP/cellular DNS servers. Regards, Mark.
On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau@synnoetic.com> wrote:
Hello,
Strangely, it is connected on my home wifi. DNS are 212.9.0.135 and 212.9.0.136 and I can resolve openvehicles.com <http://openvehicles.com> correctly with nslookup on my laptop. Since everything works perfectly after a reboot, it is not a dns issue but a degradation while the box is running. It seems to worsen when going out of wifi range and back but I’m still not sure about this. A new error appeared this morning but probably unrelated: E (140391333) can: can1: intr=14187292 rxpkt=14151479 txpkt=3057 errflags=0x8040d9 rxerr=0 txerr=131 rxovr=23 txovr=0 txdelay=0 wdgreset=0 errreset=0 Thanks, Sebastien On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net> > wrote: What are your DNS servers set to? Can you try with 8.8.8.8, if you aren’t already, and don’t use ISP/cellular DNS servers. Regards, Mark. On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com> > wrote: Hello, Anyone else is having connection issues since latest update? I’m constantly loosing contact with the device and haven’t been able to open a console with USB but this time, I can still access it with the Web interface and noticed it can’t connect to server. E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867> ) failed: cannot parse address E (72178423) ovms-server-v2: Status: Error: Connection failed W (72180093) simcom: UART hw fifo overflow W (72192873) gsm-mux: Frame overflow (2048 bytes) E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867> ) failed: cannot parse address E (72238423) ovms-server-v2: Status: Error: Connection failed E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870 <http://api.openvehicles.com:6870> ) failed: cannot parse address E (72298463) ovms-server-v2: Status: Error: Connection failed Address looks good though. Sebastien Darveau sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Please try with 8.8.8.8, to rule out a dns issue. The reason I suggest this is because I have seen that ‘parse error’ before resulting from failed dns lookups. Regards, ?Mark
On 19 Aug 2020, at 9:08 PM, Sébastien Darveau <sebastien.darveau@synnoetic.com> wrote:
Strangely, it is connected on my home wifi. DNS are 212.9.0.135 and 212.9.0.136 and I can resolve openvehicles.com correctly with nslookup on my laptop. Since everything works perfectly after a reboot, it is not a dns issue but a degradation while the box is running. It seems to worsen when going out of wifi range and back but I’m still not sure about this.
Thanks, Sebastien
On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Hello,
Hi Mark, I did change the DNS but it didn’t fix the problem so I reverted to previous version. It looks like it is Leaf 2015 specific as reported here by someone else: https://www.openvehicles.com/node/2587 I suspect the new wifi feature because it seems to happen when leaving the wifi range. Thanks, Sebastien On Aug 19, 2020, at 10:50 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net> > wrote: Please try with 8.8.8.8, to rule out a dns issue. The reason I suggest this is because I have seen that ‘parse error’ before resulting from failed dns lookups. Regards, ?Mark On 19 Aug 2020, at 9:08 PM, Sébastien Darveau <sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com> > wrote: Strangely, it is connected on my home wifi. DNS are 212.9.0.135 and 212.9.0.136 and I can resolve openvehicles.com <http://openvehicles.com/> correctly with nslookup on my laptop. Since everything works perfectly after a reboot, it is not a dns issue but a degradation while the box is running. It seems to worsen when going out of wifi range and back but I’m still not sure about this. A new error appeared this morning but probably unrelated: E (140391333) can: can1: intr=14187292 rxpkt=14151479 txpkt=3057 errflags=0x8040d9 rxerr=0 txerr=131 rxovr=23 txovr=0 txdelay=0 wdgreset=0 errreset=0 Thanks, Sebastien On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net> > wrote: What are your DNS servers set to? Can you try with 8.8.8.8, if you aren’t already, and don’t use ISP/cellular DNS servers. Regards, Mark. On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com> > wrote: Hello, Anyone else is having connection issues since latest update? I’m constantly loosing contact with the device and haven’t been able to open a console with USB but this time, I can still access it with the Web interface and noticed it can’t connect to server. E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/> ) failed: cannot parse address E (72178423) ovms-server-v2: Status: Error: Connection failed W (72180093) simcom: UART hw fifo overflow W (72192873) gsm-mux: Frame overflow (2048 bytes) E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/> ) failed: cannot parse address E (72238423) ovms-server-v2: Status: Error: Connection failed E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870 <http://api.openvehicles.com:6870/> ) failed: cannot parse address E (72298463) ovms-server-v2: Status: Error: Connection failed Address looks good though. Sebastien Darveau sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
FYI: I also had a crash report from a guy with a 2018 Nissan eNV-200 40KW using the Leaf adaption. He wrote the last working OVMS version was 3.2.013-223-g7c41d3a6, all versions after that crash as soon as he starts the car. I pointed him to the Leaf developers, but it seems he didn't manage to file an issue. Regards, Michael Am 31.08.20 um 14:48 schrieb Sébastien Darveau:
Hi Mark,
Thanks, Sebastien
On Aug 19, 2020, at 10:50 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
Regards, ?Mark
On 19 Aug 2020, at 9:08 PM, Sébastien Darveau <sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com>> wrote:
Thanks, Sebastien
On Aug 19, 2020, at 2:25 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
On 19 Aug 2020, at 2:02 AM, Sébastien Darveau <sebastien.darveau@synnoetic.com <mailto:sebastien.darveau@synnoetic.com>> wrote:
Hello,
E (72178423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/>) failed: cannot parse address E (72178423) ovms-server-v2: Status: Error: Connection failed W (72180093) simcom: UART hw fifo overflow W (72192873) gsm-mux: Frame overflow (2048 bytes) E (72238423) ovms-server-v2: mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/>) failed: cannot parse address E (72238423) ovms-server-v2: Status: Error: Connection failed E (72298463) ovms-server-v2: mg_connect(api.openvehicles.com:6870 <http://api.openvehicles.com:6870/>) failed: cannot parse address E (72298463) ovms-server-v2: Status: Error: Connection failed
I’ve asked the guy with issue on the support ticket to try 3.2.013. Regards, Mark.
Regards, Michael
Hi Mark,
https://www.openvehicles.com/node/2587 <https://www.openvehicles.com/node/2587>
Thanks, Sebastien
Regards, ?Mark
Thanks, Sebastien
Hello,
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
Michael Balzer -
Sébastien Darveau
