Hi all, For my project I have changed the Nissan Leaf code to support connection with normal OBD cable. There are still some bugs to sort out but the code seems to function. This is a breaking change for those that use the special OBD cable for Nissan Leaf, and I am wondering if I should branch this off as a separate vehicle file? A "CAR CAN Nissan Leaf" instead of the "EV CAN Nissan Leaf"? Is anyone using the current Nissan Leaf code? Nikolay
There are a handful of people I have heard from using the Leaf code, but I don’t know of anyone developing for it at the moment. There was a lot of discussion a year or so ago about which can bus to work from on the Leaf. Consensus was the EV bus. From my memory, the reasons were: We can use passive listening to see if the car is charging, driving or sleeping. Active polling is bi-directional, but if car is sleeping, polling causes vehicle to use a 12V solenoid to power up a controller each time, and we are worried about wear-and-tear as well as 12V battery consumption for those components. The EV bus has lots of stuff available on it. A search for Nissan Leaf in the archives would probably bring up all the gory details. Regards, Mark.
On 22 Jun, 2015, at 4:20 pm, Nikolay Shishkov <nshishkov@yahoo.com> wrote:
Hi all,
Nikolay _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Thanks for the answer Mark, I was not able to "wake-up" the car with polling on the CAR CAN bus. It was late though, so I need to repeat that test to be sure. Or maybe I am mixing it up with the E-UP... I think the reason for this was that I did not find a way to request the odometer. So if I want to keep and submit my code - should I make a new vehicle? Nikolay On Monday, June 22, 2015 3:15 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote: There are a handful of people I have heard from using the Leaf code, but I don’t know of anyone developing for it at the moment. There was a lot of discussion a year or so ago about which can bus to work from on the Leaf. Consensus was the EV bus. From my memory, the reasons were: - We can use passive listening to see if the car is charging, driving or sleeping. - Active polling is bi-directional, but if car is sleeping, polling causes vehicle to use a 12V solenoid to power up a controller each time, and we are worried about wear-and-tear as well as 12V battery consumption for those components. - The EV bus has lots of stuff available on it. A search for Nissan Leaf in the archives would probably bring up all the gory details. Regards, Mark. On 22 Jun, 2015, at 4:20 pm, Nikolay Shishkov <nshishkov@yahoo.com> wrote: Hi all, For my project I have changed the Nissan Leaf code to support connection with normal OBD cable. There are still some bugs to sort out but the code seems to function. This is a breaking change for those that use the special OBD cable for Nissan Leaf, and I am wondering if I should branch this off as a separate vehicle file? A "CAR CAN Nissan Leaf" instead of the "EV CAN Nissan Leaf"? Is anyone using the current Nissan Leaf code? Nikolay_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Try listening for a clicking noise from the front motor compartment while you are polling the EV bus and the car is asleep. If you really want to use the CAR can bus, then I suggest you use a different vehicle type. Regards, Mark.
Nikolay
On 22 Jun, 2015, at 4:20 pm, Nikolay Shishkov <nshishkov@yahoo.com <mailto:nshishkov@yahoo.com>> wrote:
Hi all,
Nikolay _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
Mark Webb-Johnson -
Nikolay Shishkov
