Trying the new web setup, but not getting very far… I (503580) webserver: HTTP GET / I (503590) webserver: HTTP GET /cfg/init I (503590) webserver: CfgInit enter 2.test.connect I (503610) webserver: HTTP GET /apple-touch-icon.png I (503610) webserver: HTTP GET /assets/style.css I (503730) webserver: HTTP GET /assets/script.js I (503880) webserver: HTTP GET /cfg/init I (503880) webserver: CfgInit enter 2.test.connect I (513960) webserver: HTTP GET /cfg/init I (513960) webserver: CfgInit enter 2.test.connect I (513960) webserver: HTTP GET / I (514000) webserver: HTTP GET /apple-touch-icon.png I (514000) webserver: HTTP GET /assets/style.css I (514090) webserver: HTTP GET /assets/script.js I (514220) webserver: HTTP GET /cfg/init I (514220) webserver: CfgInit enter 2.test.connect I (524280) webserver: HTTP GET / I (524290) webserver: HTTP GET /cfg/init I (524290) webserver: CfgInit enter 2.test.connect I (524320) webserver: HTTP GET /apple-touch-icon.png I (524340) webserver: HTTP GET /assets/style.css I (524420) webserver: HTTP GET /assets/script.js I (524590) webserver: HTTP GET /cfg/init I (524590) webserver: CfgInit enter 2.test.connect I (534620) webserver: HTTP GET / I (534630) webserver: HTTP GET /cfg/init I (534630) webserver: CfgInit enter 2.test.connect I (534660) webserver: HTTP GET /apple-touch-icon.png I (534660) webserver: HTTP GET /assets/style.css I (534760) webserver: HTTP GET /assets/script.js I (534890) webserver: HTTP GET /cfg/init I (534890) webserver: CfgInit enter 2.test.connect I (544940) webserver: HTTP GET / I (544950) webserver: HTTP GET /cfg/init I (544950) webserver: CfgInit enter 2.test.connect I (544980) webserver: HTTP GET /assets/style.css I (544990) webserver: HTTP GET /apple-touch-icon.png I (545080) webserver: HTTP GET /assets/script.js I (545250) webserver: HTTP GET /cfg/init I (545250) webserver: CfgInit enter 2.test.connect OVMS# wifi status WiFi Power: on Mode: Access-Point + Client mode STA SSID: HIGHWAYS MAC: 30:ae:a4:43:92:c4 IP: 10.10.41.203/255.255.248.0 GW: 10.10.40.64 AP SSID: DEVBENCH MAC: 30:ae:a4:43:92:c5 IP: 192.168.4.1 AP Stations: 1 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 OVMS# ota status Running partition: ota_0 Boot partition: ota_0 Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) Server Available: 3.1.005 … I (1141850) webserver: HTTP GET / I (1141860) webserver: HTTP GET /cfg/init I (1141860) webserver: CfgInit enter 2.test.connect I (1141890) webserver: HTTP GET /apple-touch-icon.png I (1141890) webserver: HTTP GET /assets/style.css I (1141990) webserver: HTTP GET /assets/script.js I (1142120) webserver: HTTP GET /cfg/init I (1142120) webserver: CfgInit enter 2.test.connect Can’t get out of that 2.test.connect. Any ideas? Regards, Mark.
Do you have the earlier log, especially of the CfgInit ticker messages? Is the auto config correct and matching the "HIGHWAY" network? Please try a reboot. The ticker should take on step "2.test.connect" and proceed. Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson:
Any ideas?
I tried a restart. Here is what I get: Firmware: 3.1.005-72-g8cd4d07/ota_0/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (1465) webserver: Launching Web Server I (1465) ssh: Launching SSH Server I (4185) wifi: ap channel adjust o:1,1 n:6,2 I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 I (4945) wifi: state: init -> auth (b0) I (4945) wifi: state: auth -> assoc (0) I (4955) wifi: state: assoc -> run (10) I (5055) wifi: connected with HIGHWAYS, channel 6 I (5375) sdcard: SD CARD has been inserted I (5465) sdcard: mount done I (6025) wpa: PTK has been installed, it may be an attack, ignor it. I (6025) wpa: GTK has been installed, it may be an attack, ignor it. I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (9455) netmanager: Set DNS#0 10.10.40.64 I (9455) netmanager: Set DNS#1 0.0.0.0 I (9455) netmanager: Set DNS#2 0.0.0.0 I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (9455) time: Starting SNTP client I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) I (13565) webserver: HTTP GET / I (13575) webserver: HTTP GET /cfg/init I (14825) webserver: HTTP GET / I (15135) webserver: HTTP GET /cfg/init I (15375) simcom: State timeout, transition to 13 I (15375) simcom: State: Enter PoweredOff state I (15375) gsm-mux: Stop MUX I (16695) webserver: HTTP GET / I (16705) webserver: HTTP GET /cfg/init I (16735) webserver: HTTP GET /apple-touch-icon.png I (16905) webserver: HTTP GET /assets/style.css I (16905) webserver: HTTP GET /assets/script.js I (17345) webserver: HTTP GET /cfg/init I (28045) webserver: HTTP POST /cfg/init I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 I (28085) webserver: HTTP GET /cfg/init I (28085) webserver: CfgInit enter 2.test.connect I (28085) webserver: HTTP GET /menu I (40025) webserver: HTTP GET / I (40035) webserver: HTTP GET /cfg/init I (40035) webserver: CfgInit enter 2.test.connect I (40045) webserver: HTTP GET / I (40075) webserver: HTTP GET /apple-touch-icon.png I (40085) webserver: HTTP GET /assets/style.css I (40185) webserver: HTTP GET /assets/script.js I (40355) webserver: HTTP GET /cfg/init I (40355) webserver: CfgInit enter 2.test.connect OVMS> enable Password: Secure mode I (50425) webserver: HTTP GET / I (50425) webserver: HTTP GET /cfg/init I (50425) webserver: CfgInit enter 2.test.connect I (50465) webserver: HTTP GET /apple-touch-icon.png I (50475) webserver: HTTP GET /assets/style.css I (50555) webserver: HTTP GET /assets/script.js I (50675) webserver: HTTP GET /cfg/init I (50675) webserver: CfgInit enter 2.test.connect OVMS# ota status Running partition: ota_0 Boot partition: ota_0 Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) Server Available: 3.1.005 OTA release providing minor improvements and fixes. - Vehicle: 12V battery monitoring vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference - OTA: automatic daily firmware updates (wifi only) auto [ota] = yes Enable/disable ota [auto.hour] = 2 Hour for daily check - Logging: persistent configuration, file cycling, web config UI: log [file.enable] = no Enable/disable file logging log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling log [file.path] = "" Log path, if on /sd watches sd.mounted log [level] Default level log [level.<tag>] Component levels - Reverse Engineering Tools enhancements - Tesla Roadster CAC support - Miscellaneous bug fixes and enhancements I (61705) webserver: HTTP GET / I (61715) webserver: HTTP GET /cfg/init I (61715) webserver: CfgInit enter 2.test.connect I (61745) webserver: HTTP GET /apple-touch-icon.png I (61755) webserver: HTTP GET /assets/style.css I (61845) webserver: HTTP GET /assets/script.js I (61965) webserver: HTTP GET /cfg/init I (61965) webserver: CfgInit enter 2.test.connect I (72035) webserver: HTTP GET / I (72045) webserver: HTTP GET /cfg/init I (72045) webserver: CfgInit enter 2.test.connect I (72085) webserver: HTTP GET /apple-touch-icon.png I (72095) webserver: HTTP GET /assets/style.css I (72175) webserver: HTTP GET /assets/script.js I (73485) webserver: HTTP GET /cfg/init I (73495) webserver: CfgInit enter 2.test.connect OVMS# config list auto auto (readable writeable) wifi.mode: apclient wifi.ssid.ap: DEVBENCH wifi.ssid.client: HIGHWAYS OVMS# config list module module (readable writeable) init: 2.test.connect Regards, Mark
Any ideas?
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
OK. I really should wait for config.mounted before reading from MyConfig. Fix is pushed, please try. Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson:
On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Any ideas?
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Added another fix. Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the javascript code in that case. The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 seconds. Regards, Michael Am 11.05.2018 um 18:19 schrieb Michael Balzer:
Any ideas?
Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event delivery queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task? The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks. I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode (which is what I did with my alternative approach before). Regards, Mark.
On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de> wrote:
Added another fix.
Regards, Michael
Any ideas?
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson:
Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my tests…
Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some commit a few days before. CONFIG_LWIP_SO_REUSE=y CONFIG_LWIP_SO_REUSE_RXTOALL=y If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT. The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is fast enough to keep them on the AP. Regards, Michael
On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Added another fix.
Regards, Michael
Any ideas?
Just double-checked, and yes they are there. It seems that after connecting to SSID, the attempt to run ‘Ota status’ is immediate, but the wifi client hasn’t settled down yet. I’ve looked in web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect”)’, it just seems to try to MyOTA.GetStatus as soon as the ssid matches? But it doesn’t check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is connected, and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I’m missing something? Regards, Mark
Regards, Michael
Added another fix.
Regards, Michael
Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: > Trying the new web setup, but not getting very far… > > I (503580) webserver: HTTP GET / > I (503590) webserver: HTTP GET /cfg/init > I (503590) webserver: CfgInit enter 2.test.connect > I (503610) webserver: HTTP GET /apple-touch-icon.png > I (503610) webserver: HTTP GET /assets/style.css > I (503730) webserver: HTTP GET /assets/script.js > I (503880) webserver: HTTP GET /cfg/init > I (503880) webserver: CfgInit enter 2.test.connect > I (513960) webserver: HTTP GET /cfg/init > I (513960) webserver: CfgInit enter 2.test.connect > I (513960) webserver: HTTP GET / > I (514000) webserver: HTTP GET /apple-touch-icon.png > I (514000) webserver: HTTP GET /assets/style.css > I (514090) webserver: HTTP GET /assets/script.js > I (514220) webserver: HTTP GET /cfg/init > I (514220) webserver: CfgInit enter 2.test.connect > I (524280) webserver: HTTP GET / > I (524290) webserver: HTTP GET /cfg/init > I (524290) webserver: CfgInit enter 2.test.connect > I (524320) webserver: HTTP GET /apple-touch-icon.png > I (524340) webserver: HTTP GET /assets/style.css > I (524420) webserver: HTTP GET /assets/script.js > I (524590) webserver: HTTP GET /cfg/init > I (524590) webserver: CfgInit enter 2.test.connect > I (534620) webserver: HTTP GET / > I (534630) webserver: HTTP GET /cfg/init > I (534630) webserver: CfgInit enter 2.test.connect > I (534660) webserver: HTTP GET /apple-touch-icon.png > I (534660) webserver: HTTP GET /assets/style.css > I (534760) webserver: HTTP GET /assets/script.js > I (534890) webserver: HTTP GET /cfg/init > I (534890) webserver: CfgInit enter 2.test.connect > I (544940) webserver: HTTP GET / > I (544950) webserver: HTTP GET /cfg/init > I (544950) webserver: CfgInit enter 2.test.connect > I (544980) webserver: HTTP GET /assets/style.css > I (544990) webserver: HTTP GET /apple-touch-icon.png > I (545080) webserver: HTTP GET /assets/script.js > I (545250) webserver: HTTP GET /cfg/init > I (545250) webserver: CfgInit enter 2.test.connect > > OVMS# wifi status > WiFi > Power: on > Mode: Access-Point + Client mode > > STA SSID: HIGHWAYS > MAC: 30:ae:a4:43:92:c4 > IP: 10.10.41.203/255.255.248.0 > GW: 10.10.40.64 > > AP SSID: DEVBENCH > MAC: 30:ae:a4:43:92:c5 > IP: 192.168.4.1 > AP Stations: 1 > 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 > > OVMS# ota status > Running partition: ota_0 > Boot partition: ota_0 > Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) > Server Available: 3.1.005 > > … > > I (1141850) webserver: HTTP GET / > I (1141860) webserver: HTTP GET /cfg/init > I (1141860) webserver: CfgInit enter 2.test.connect > I (1141890) webserver: HTTP GET /apple-touch-icon.png > I (1141890) webserver: HTTP GET /assets/style.css > I (1141990) webserver: HTTP GET /assets/script.js > I (1142120) webserver: HTTP GET /cfg/init > I (1142120) webserver: CfgInit enter 2.test.connect > > Can’t get out of that 2.test.connect. > > Any ideas? > > Regards, Mark. > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson:
The state ticker does not check yet if it can abort a scheduled timeout. So it doesn't do the test as soon as GetSSID() returns the network. The test is done fixed 20 seconds after StartAccessPointClientMode(). That is normally plenty of time for everything to settle. In my runs, the client network was normally fully functional in ~10 seconds. How long does your APClient switch take? You can try raising the 20 second timeout in line 226. Regards, Michael
On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Added another fix.
Regards, Michael
> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Do you have the earlier log, especially of the CfgInit ticker messages? > > Is the auto config correct and matching the "HIGHWAY" network? > > Please try a reboot. The ticker should take on step "2.test.connect" and proceed. > > > > Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >> Trying the new web setup, but not getting very far… >> >> I (503580) webserver: HTTP GET / >> I (503590) webserver: HTTP GET /cfg/init >> I (503590) webserver: CfgInit enter 2.test.connect >> I (503610) webserver: HTTP GET /apple-touch-icon.png >> I (503610) webserver: HTTP GET /assets/style.css >> I (503730) webserver: HTTP GET /assets/script.js >> I (503880) webserver: HTTP GET /cfg/init >> I (503880) webserver: CfgInit enter 2.test.connect >> I (513960) webserver: HTTP GET /cfg/init >> I (513960) webserver: CfgInit enter 2.test.connect >> I (513960) webserver: HTTP GET / >> I (514000) webserver: HTTP GET /apple-touch-icon.png >> I (514000) webserver: HTTP GET /assets/style.css >> I (514090) webserver: HTTP GET /assets/script.js >> I (514220) webserver: HTTP GET /cfg/init >> I (514220) webserver: CfgInit enter 2.test.connect >> I (524280) webserver: HTTP GET / >> I (524290) webserver: HTTP GET /cfg/init >> I (524290) webserver: CfgInit enter 2.test.connect >> I (524320) webserver: HTTP GET /apple-touch-icon.png >> I (524340) webserver: HTTP GET /assets/style.css >> I (524420) webserver: HTTP GET /assets/script.js >> I (524590) webserver: HTTP GET /cfg/init >> I (524590) webserver: CfgInit enter 2.test.connect >> I (534620) webserver: HTTP GET / >> I (534630) webserver: HTTP GET /cfg/init >> I (534630) webserver: CfgInit enter 2.test.connect >> I (534660) webserver: HTTP GET /apple-touch-icon.png >> I (534660) webserver: HTTP GET /assets/style.css >> I (534760) webserver: HTTP GET /assets/script.js >> I (534890) webserver: HTTP GET /cfg/init >> I (534890) webserver: CfgInit enter 2.test.connect >> I (544940) webserver: HTTP GET / >> I (544950) webserver: HTTP GET /cfg/init >> I (544950) webserver: CfgInit enter 2.test.connect >> I (544980) webserver: HTTP GET /assets/style.css >> I (544990) webserver: HTTP GET /apple-touch-icon.png >> I (545080) webserver: HTTP GET /assets/script.js >> I (545250) webserver: HTTP GET /cfg/init >> I (545250) webserver: CfgInit enter 2.test.connect >> >> OVMS# wifi status >> WiFi >> Power: on >> Mode: Access-Point + Client mode >> >> STA SSID: HIGHWAYS >> MAC: 30:ae:a4:43:92:c4 >> IP: 10.10.41.203/255.255.248.0 >> GW: 10.10.40.64 >> >> AP SSID: DEVBENCH >> MAC: 30:ae:a4:43:92:c5 >> IP: 192.168.4.1 >> AP Stations: 1 >> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >> >> OVMS# ota status >> Running partition: ota_0 >> Boot partition: ota_0 >> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >> Server Available: 3.1.005 >> >> … >> >> I (1141850) webserver: HTTP GET / >> I (1141860) webserver: HTTP GET /cfg/init >> I (1141860) webserver: CfgInit enter 2.test.connect >> I (1141890) webserver: HTTP GET /apple-touch-icon.png >> I (1141890) webserver: HTTP GET /assets/style.css >> I (1141990) webserver: HTTP GET /assets/script.js >> I (1142120) webserver: HTTP GET /cfg/init >> I (1142120) webserver: CfgInit enter 2.test.connect >> >> >> Can’t get out of that 2.test.connect. >> >> Any ideas? >> >> Regards, Mark. >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
An annotated normal setup log: Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console I (2766) webserver: Launching Web Server Firmware: 3.1.005-74-g4a100f0-dirty/factory/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 I (2826) simcom: State: Enter CheckPowerOff state I (11826) housekeeping: System considered stable (RAM: 8b=106600-109352 32b=52008) I (16826) simcom: State timeout, transition to 13 I (16826) simcom: State: Enter PoweredOff state I (16826) gsm-mux: Stop MUX … (finding my tablet, connecting to AP "OVMS") … I (62026) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1 I (62026) wifi: station: 30:75:12:f5:71:c7 join, AID=1, bgn, 20 I (62036) esp32wifi: AP station connected: id: 1, MAC: 30:75:12:f5:71:c7 I (72176) webserver: HTTP GET / I (72636) webserver: HTTP GET /assets/style.css I (72636) webserver: HTTP GET /assets/script.js I (72646) webserver: HTTP GET /apple-touch-icon.png I (73506) webserver: HTTP GET /home I (81306) webserver: HTTP GET /cfg/init I (81306) webserver: CfgInit enter 1 … (entering data for step 1) … I (119606) webserver: HTTP POST /cfg/init I (119606) webserver: CfgInit enter 1 I (119606) webserver: CfgInit1: starting test: AP 'Test1' I (119666) webserver: CfgInitSetStep: step 1.test.start timeout 5 I (119826) webserver: CfgInitTicker: step 1.test.start timeout in 5 seconds I (123826) webserver: CfgInitTicker: step 1.test.start timeout I (123826) webserver: CfgInitTicker: step 1: starting wifi AP 'Test1' I (123826) esp32wifi: Stopping WIFI station I (123826) wifi: station: 30:75:12:f5:71:c7 leave, AID = 1 I (123826) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1 I (123846) wifi: flush txq I (123846) wifi: stop sw txq I (123846) wifi: lmac stop hw txq I (124516) wifi: mode : softAP (30:ae:a4:37:25:89) I (124516) webserver: CfgInitSetStep: step 1.test.connect timeout 300 I (124526) esp32wifi: AP station disconnected: id: 1, MAC: 30:75:12:f5:71:c7 I (124526) netmanager: WIFI access point is down I (124526) esp32wifi: AP stopped I (124536) netmanager: WIFI access point is up I (124736) esp32wifi: AP started with SSID: Test1, MAC: 30:ae:a4:37:25:89, IP: 192.168.4.1 I (124736) webserver: Stopping Web Server I (124746) webserver: Launching Web Server I (124826) webserver: CfgInitTicker: step 1.test.connect timeout in 300 seconds I (129826) webserver: CfgInitTicker: step 1.test.connect timeout in 295 seconds I (134826) webserver: CfgInitTicker: step 1.test.connect timeout in 290 seconds I (139826) webserver: CfgInitTicker: step 1.test.connect timeout in 285 seconds I (144826) webserver: CfgInitTicker: step 1.test.connect timeout in 280 seconds I (148176) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1 I (148176) wifi: station: 30:75:12:f5:71:c7 join, AID=1, bgn, 20 I (148186) esp32wifi: AP station connected: id: 1, MAC: 30:75:12:f5:71:c7 I (149826) webserver: CfgInitTicker: step 1.test.connect timeout in 275 seconds I (154826) webserver: CfgInitTicker: step 1.test.connect timeout in 270 seconds I (159826) webserver: CfgInitTicker: step 1.test.connect timeout in 265 seconds I (161786) webserver: HTTP GET / I (161976) webserver: HTTP GET /cfg/init I (164826) webserver: CfgInitTicker: step 1.test.connect timeout in 260 seconds I (169826) webserver: CfgInitTicker: step 1.test.connect timeout in 255 seconds I (171786) webserver: HTTP POST /cfg/init I (171786) webserver: HandleLogin: 'admin' logged in, sid 2cbdd8198308f453 I (171826) webserver: HTTP GET /menu I (171846) webserver: HTTP GET /cfg/init I (171846) webserver: CfgInit enter 1.test.connect I (171846) webserver: CfgInit1: AP test succeeded I (171846) webserver: CfgInitSetStep: step 2 timeout 0 I (171866) webserver: CfgInit next: 2 … (entering step 2 data) … I (216836) webserver: HTTP POST /cfg/init I (216836) webserver: CfgInit enter 2 I (216856) webserver: CfgInitSetStep: step 2.test.start timeout 5 I (217826) webserver: CfgInitTicker: step 2.test.start timeout in 5 seconds I (221826) webserver: CfgInitTicker: step 2.test.start timeout I (221826) webserver: CfgInitTicker: step 2: starting wifi APCLIENT 'Test1' / 'WLAN-214677' I (221826) esp32wifi: Stopping WIFI station I (221836) wifi: station: 30:75:12:f5:71:c7 leave, AID = 1 I (221836) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1 I (221856) wifi: flush txq I (221856) wifi: stop sw txq I (221856) wifi: lmac stop hw txq I (221866) wifi: mode : sta (30:ae:a4:37:25:88) + softAP (30:ae:a4:37:25:89) I (221876) webserver: CfgInitSetStep: step 2.test.connect timeout 20 I (221876) esp32wifi: AP station disconnected: id: 1, MAC: 30:75:12:f5:71:c7 I (221876) netmanager: WIFI access point is down I (221876) esp32wifi: AP stopped I (221886) netmanager: WIFI access point is up I (222136) esp32wifi: AP started with SSID: Test1, MAC: 30:ae:a4:37:25:89, IP: 192.168.4.1 I (222136) webserver: Stopping Web Server I (222136) webserver: Launching Web Server I (222826) webserver: CfgInitTicker: step 2.test.connect timeout in 20 seconds I (224586) wifi: ap channel adjust o:1,1 n:11,2 I (224586) wifi: n:11 0, o:1 0, ap:11 2, sta:11 0, prof:1 I (225246) wifi: state: init -> auth (b0) I (225246) wifi: state: auth -> assoc (0) I (225256) wifi: state: assoc -> run (10) I (225266) wifi: connected with WLAN-214677, channel 11 I (225266) wifi: pm start, type: 1 I (225616) event: sta ip: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (225626) netmanager: Interface priority is st3 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (225626) netmanager: Set DNS#0 192.168.2.1 I (225626) netmanager: Set DNS#1 192.168.2.1 I (225626) netmanager: Set DNS#2 0.0.0.0 I (225626) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (225626) esp32wifi: STA got IP with SSID: WLAN-214677, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (225626) time: Starting SNTP client I (227826) webserver: CfgInitTicker: step 2.test.connect timeout in 15 seconds I (232826) webserver: CfgInitTicker: step 2.test.connect timeout in 10 seconds I (233866) wifi: n:11 0, o:11 0, ap:11 2, sta:11 0, prof:11 I (233876) wifi: station: 30:75:12:f5:71:c7 join, AID=1, bgn, 20 I (233876) esp32wifi: AP station connected: id: 1, MAC: 30:75:12:f5:71:c7 I (235556) webserver: HTTP GET / I (235866) webserver: HTTP GET /cfg/init I (235866) webserver: CfgInit enter 2.test.connect I (237826) webserver: CfgInitTicker: step 2.test.connect timeout in 5 seconds I (241826) webserver: CfgInitTicker: step 2.test.connect timeout I (242616) webserver: CfgInitTicker: step 2: success, proceeding to step 3 I (242616) webserver: CfgInitSetStep: step 3 timeout 0 I (245386) webserver: HTTP GET / I (245556) webserver: HTTP GET /cfg/init I (245556) webserver: CfgInit enter 3 … (entering step 3 data) … I (258926) webserver: HTTP POST /cfg/init I (258926) webserver: CfgInit enter 3 I (258956) webserver: CfgInitSetStep: step 3.update timeout 0 … (no new hw3.0 firmware on my server) … I (259036) webserver: CfgInit3: firmware up to date, proceeding to step 4 I (259036) webserver: CfgInitSetStep: step 4 timeout 0 I (259036) webserver: CfgInit next: 4 I (301826) housekeeping: 2018-05-12 18:42:07 GMT (RAM: 8b=94144-97772 32b=52008) … (entering step 4 data) … I (304896) webserver: HTTP POST /cfg/init I (304896) webserver: CfgInit enter 4 I (304926) webserver: CfgInitSetStep: step 4.test.start timeout 3 I (305446) webserver: HTTP POST /api/execute I (305446) webcommand: HttpCommandStream[0x3ffe9018]: 88820 bytes free, executing: vehicle status I (305476) webserver: HTTP POST /api/execute I (305486) webcommand: HttpCommandStream[0x3ffead00]: 82884 bytes free, executing: server v2 status I (307826) webserver: CfgInitTicker: step 4.test.start timeout I (307826) webserver: CfgInitTicker: step 4: setting vehicle type 'RT' I (307826) v-twizy: Renault Twizy vehicle module I (307826) v-twizy: battmon subsystem init I (307836) v-twizy: pwrmon subsystem init I (307836) v-twizy: charge subsystem init I (307846) canopen: Worker started on can1 I (307846) v-twizy: sevcon subsystem init I (307846) webserver: CfgInitSetStep: step 4.test.start timeout 3 I (307856) simcom: State: Enter PoweringOn state I (307866) simcom: Power Cycle I (309106) webserver: HTTP POST /api/execute I (309116) webcommand: HttpCommandStream[0x3fff0a80]: 56176 bytes free, executing: vehicle status I (310826) webserver: CfgInitTicker: step 4.test.start timeout I (310826) webserver: CfgInitTicker: step 4: start server v2 for host 'ovms.dexters-web.de' I (310826) ovms-server-v2: OVMS Server V2 registered metric modifier is #3 I (310826) ovms-server-v2: Status: Server has been started I (310826) ovms-server-v2: OVMS Server v2 running I (310836) ovms-server-v2: Connection is ovms.dexters-web.de:6867 Test1 I (310836) ovms-server-v2: Status: Connecting... I (310856) webserver: CfgInitSetStep: step 4.test.connect timeout 0 I (310876) ovms-server-v2: Connection successful I (310876) ovms-server-v2: Status: Logging in... I (310886) ovms-server-v2: Sending server login: MP-C 0 yjAgaG2QpDQXhanp4QhrY5 VjNL56xFykAzPbs4HjLhAg== Test1 I (311066) ovms-server-v2: Got server response: MP-S 0 Wixs45Hmj0ovGeVGBiQChN cGdkD5TjFj4dEhNDxyvc5g== I (311066) ovms-server-v2: Server token is Wixs45Hmj0ovGeVGBiQChN and digest is cGdkD5TjFj4dEhNDxyvc5g== I (311076) ovms-server-v2: Status: Server authentication ok. Now priming crypto. I (311076) ovms-server-v2: Shared secret key is Wixs45Hmj0ovGeVGBiQChNyjAgaG2QpDQXhanp4QhrY5 (44 bytes) I (311076) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established I (311096) ovms-server-v2: Incoming Msg: MP-0 Z0 I (311616) webserver: HTTP POST /api/execute I (311616) webcommand: HttpCommandStream[0x3fff17b4]: 47544 bytes free, executing: server v2 status I (311646) webserver: HTTP POST /api/execute I (311656) webserver: HTTP POST /api/execute I (311666) webserver: HTTP POST /api/execute I (311676) webserver: HTTP POST /api/execute I (311676) webcommand: HttpCommandStream[0x3fff1e38]: 22360 bytes free, executing: server v2 status I (311676) webcommand: HttpCommandStream[0x3fff6dc0]: 20648 bytes free, executing: server v2 status I (311686) webcommand: HttpCommandStream[0x3fff8eb8]: 23952 bytes free, executing: server v2 status I (311646) webcommand: HttpCommandStream[0x3fff33a0]: 23952 bytes free, executing: server v2 status I (311826) ovms-server-v2: Send MP-0 S0,K,0,0,,standard,50,50,0,0,0,0,0,0,0,0,0,0,108.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0 I (311826) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,4,0,0,1,0,0,0,0,0,0,0 I (311836) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,10000,0,0.0,0.0 I (311846) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (311846) ovms-server-v2: Send MP-0 F3.1.005-74-g4a100f0-dirty/factory/main (build idf ovms-3.1.005-527-g9d8e44e0 May 11 2018 18:40:41),,0,1,RT,WLAN-214677 I (313366) webserver: HTTP POST /api/execute I (313376) webcommand: HttpCommandStream[0x3fff33a0]: 48176 bytes free, executing: vehicle status I (313826) simcom: State: Enter PoweredOn state I (317376) webserver: HTTP POST /api/execute I (317386) webcommand: HttpCommandStream[0x3fff33a0]: 47912 bytes free, executing: server v2 status I (318366) webserver: HTTP POST /api/execute I (318366) webcommand: HttpCommandStream[0x3fff33a0]: 47736 bytes free, executing: vehicle status I (322366) webserver: HTTP POST /api/execute I (322376) webcommand: HttpCommandStream[0x3fff33a0]: 47456 bytes free, executing: server v2 status I (323376) webserver: HTTP POST /api/execute I (323376) webcommand: HttpCommandStream[0x3fff33a0]: 47508 bytes free, executing: vehicle status … (click "Keep & proceed") … I (326266) webserver: HTTP POST /cfg/init I (326266) webserver: CfgInit enter 4.test.connect I (326276) webserver: CfgInitSetStep: step 5 timeout 0 I (326316) webserver: CfgInit next: 5 I (326326) webserver: HTTP POST /api/execute I (326336) webcommand: HttpCommandStream[0x3fff340c]: 45652 bytes free, executing: server v2 status … (entering step 5 data) … I (333606) webserver: HTTP POST /cfg/init I (333606) webserver: CfgInit enter 5 I (333626) webserver: CfgInit5: starting test I (333626) webserver: CfgInitSetStep: step 5.test.start timeout 3 I (333846) simcom: State: Enter MuxStart state I (333846) gsm-mux: Start MUX I (333856) gsm-mux: Channel #0 is open I (333866) gsm-mux: Channel #1 is open I (333866) gsm-mux: Channel #2 is open I (333876) gsm-mux: Channel #3 is open I (333886) gsm-mux: Channel #4 is open I (333916) webserver: HTTP POST /api/execute I (333926) webcommand: HttpCommandStream[0x3fff4278]: 43024 bytes free, executing: simcom status I (333936) webserver: HTTP POST /api/execute I (333946) webcommand: HttpCommandStream[0x3fff627c]: 34276 bytes free, executing: simcom status I (334826) simcom: State: Enter NetWait state I (334826) gsm-nmea: Startup I (334986) webserver: HTTP POST /api/execute I (334986) webcommand: HttpCommandStream[0x3fff32b4]: 43032 bytes free, executing: simcom status I (335826) webserver: CfgInitTicker: step 5.test.start timeout I (335826) webserver: CfgInitTicker: step 5: modem enter state NetStart I (335826) simcom: State: Enter NetStart state I (336186) webserver: HTTP POST /api/execute I (336196) webcommand: HttpCommandStream[0x3fff32b4]: 43024 bytes free, executing: simcom status I (336866) simcom: PPP Connection is ready to start I (337826) simcom: State: Enter NetMode state I (337826) gsm-ppp: Initialising... I (338226) webserver: HTTP POST /api/execute I (338236) webcommand: HttpCommandStream[0x3fff32b4]: 37856 bytes free, executing: simcom status I (338826) simcom: Lost network connection (NetworkRegistration in NetMode) I (338826) simcom: State: Enter NetLoss state I (338826) gsm-ppp: Shutting down (hard)... I (338826) gsm-ppp: PPP is shutdown I (338836) netmanager: Interface priority is st3 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (338846) netmanager: Set DNS#0 192.168.2.1 I (338846) netmanager: Set DNS#1 192.168.2.1 I (338846) netmanager: Set DNS#2 0.0.0.0 I (339176) webserver: HTTP POST /api/execute I (339186) webserver: HTTP POST /api/execute I (339186) webcommand: HttpCommandStream[0x3fff5680]: 29184 bytes free, executing: simcom status I (339186) webcommand: HttpCommandStream[0x3fff51c0]: 29184 bytes free, executing: simcom status I (344726) webserver: HTTP POST /api/execute I (344736) webcommand: HttpCommandStream[0x3fff32b4]: 39512 bytes free, executing: simcom status I (347826) simcom: State timeout, transition to 5 I (347826) simcom: State: Enter NetWait state I (347826) gsm-nmea: Startup I (348096) webserver: HTTP POST /api/execute I (348106) webcommand: HttpCommandStream[0x3fff32b4]: 39316 bytes free, executing: simcom status I (349826) ovms-server-v2: Send MP-0 h1,0,RT-BAT-P,1,86400,1,1,5000,10000,0,0,1000,0,-40,200,-40,0,0,0,0 I (349826) ovms-server-v2: Send MP-0 h2,0,RT-BAT-C,1,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h3,0,RT-BAT-C,2,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h4,0,RT-BAT-C,3,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h5,0,RT-BAT-C,4,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h6,0,RT-BAT-C,5,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h7,0,RT-BAT-C,6,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349836) ovms-server-v2: Send MP-0 h8,0,RT-BAT-C,7,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h9,0,RT-BAT-C,8,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h10,0,RT-BAT-C,9,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h11,0,RT-BAT-C,10,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h12,0,RT-BAT-C,11,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h13,0,RT-BAT-C,12,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h14,0,RT-BAT-C,13,86400,1,1,0,10000,0,0,-40,200,-40,0 I (349846) ovms-server-v2: Send MP-0 h15,0,RT-BAT-C,14,86400,1,1,0,10000,0,0,-40,200,-40,0 I (350136) ovms-server-v2: Incoming Msg: MP-0 h1 I (350136) ovms-server-v2: Incoming Msg: MP-0 h2 I (350146) gsm-ppp: StatusCallBack: User Interrupt I (350146) gsm-ppp: PPP connection has been closed I (350146) netmanager: Interface priority is st3 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (350146) netmanager: Set DNS#0 192.168.2.1 I (350146) netmanager: Set DNS#1 192.168.2.1 I (350146) netmanager: Set DNS#2 0.0.0.0 I (350156) ovms-server-v2: Incoming Msg: MP-0 h3 I (350166) ovms-server-v2: Incoming Msg: MP-0 h4 I (350176) ovms-server-v2: Incoming Msg: MP-0 h5 I (350176) ovms-server-v2: Incoming Msg: MP-0 h6 I (350186) ovms-server-v2: Incoming Msg: MP-0 h7 I (350196) ovms-server-v2: Incoming Msg: MP-0 h8 I (350206) ovms-server-v2: Incoming Msg: MP-0 h9 I (350206) ovms-server-v2: Incoming Msg: MP-0 h10 I (350216) webserver: HTTP POST /api/execute I (350226) webcommand: HttpCommandStream[0x3fff55d4]: 35288 bytes free, executing: simcom status I (350386) ovms-server-v2: Incoming Msg: MP-0 h11 I (350386) ovms-server-v2: Incoming Msg: MP-0 h12 I (350386) ovms-server-v2: Incoming Msg: MP-0 h13 I (350386) ovms-server-v2: Incoming Msg: MP-0 h14 I (350396) ovms-server-v2: Incoming Msg: MP-0 h15 I (355736) webserver: HTTP POST /api/execute I (355736) webcommand: HttpCommandStream[0x3fff5fd0]: 37948 bytes free, executing: simcom status I (357846) simcom: CREG Network Registration: RegisteredRoaming I (358826) simcom: State: Enter NetStart state I (359166) webserver: HTTP POST /api/execute I (359176) webcommand: HttpCommandStream[0x3fff5fd0]: 37892 bytes free, executing: simcom status I (359846) simcom: PPP Connection is ready to start I (360826) simcom: State: Enter NetMode state I (360826) gsm-ppp: Initialising... I (361026) webserver: HTTP POST /api/execute I (361036) webcommand: HttpCommandStream[0x3fff5fd0]: 37448 bytes free, executing: simcom status I (363566) gsm-ppp: StatusCallBack: None I (363566) gsm-ppp: status_cb: Connected I (363566) gsm-ppp: our_ipaddr = 10.170.195.13 I (363566) gsm-ppp: his_ipaddr = 10.64.64.64 I (363566) gsm-ppp: netmask = 255.255.255.255 I (363566) gsm-ppp: our6_ipaddr = :: I (363576) netmanager: Interface priority is st3 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (363576) netmanager: Set DNS#0 192.168.2.1 I (363576) netmanager: Set DNS#1 192.168.2.1 I (363576) netmanager: Set DNS#2 0.0.0.0 I (363576) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority I (363916) webserver: HTTP POST /api/execute I (363926) webcommand: HttpCommandStream[0x3fff5fd0]: 37828 bytes free, executing: simcom status I (368726) webserver: HTTP POST /api/execute I (368726) webcommand: HttpCommandStream[0x3fff5fd0]: 37508 bytes free, executing: simcom status … (click "Keep & proceed") … I (371186) webserver: HTTP POST /cfg/init I (371186) webserver: CfgInit enter 5.test.start I (371316) webserver: CfgInitSetStep: step done timeout 0 I (371336) webserver: CfgInit next: done Regards, Michael Am 12.05.2018 um 20:18 schrieb Michael Balzer:
Regards, Michael
Regards, Michael
Added another fix.
Regards, Michael
Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: > I tried a restart. Here is what I get: > > Firmware: 3.1.005-72-g8cd4d07/ota_0/main > Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 > > I (1465) webserver: Launching Web Server > I (1465) ssh: Launching SSH Server > I (4185) wifi: ap channel adjust o:1,1 n:6,2 > I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 > I (4945) wifi: state: init -> auth (b0) > I (4945) wifi: state: auth -> assoc (0) > I (4955) wifi: state: assoc -> run (10) > I (5055) wifi: connected with HIGHWAYS, channel 6 > I (5375) sdcard: SD CARD has been inserted > I (5465) sdcard: mount done > I (6025) wpa: PTK has been installed, it may be an attack, ignor it. > I (6025) wpa: GTK has been installed, it may be an attack, ignor it. > I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 > I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 > I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 > I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 > I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) > I (9455) netmanager: Set DNS#0 10.10.40.64 > I (9455) netmanager: Set DNS#1 0.0.0.0 > I (9455) netmanager: Set DNS#2 0.0.0.0 > I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client > I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 > I (9455) time: Starting SNTP client > I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) > I (13565) webserver: HTTP GET / > I (13575) webserver: HTTP GET /cfg/init > I (14825) webserver: HTTP GET / > I (15135) webserver: HTTP GET /cfg/init > I (15375) simcom: State timeout, transition to 13 > I (15375) simcom: State: Enter PoweredOff state > I (15375) gsm-mux: Stop MUX > I (16695) webserver: HTTP GET / > I (16705) webserver: HTTP GET /cfg/init > I (16735) webserver: HTTP GET /apple-touch-icon.png > I (16905) webserver: HTTP GET /assets/style.css > I (16905) webserver: HTTP GET /assets/script.js > I (17345) webserver: HTTP GET /cfg/init > I (28045) webserver: HTTP POST /cfg/init > I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 > I (28085) webserver: HTTP GET /cfg/init > I (28085) webserver: CfgInit enter 2.test.connect > I (28085) webserver: HTTP GET /menu > I (40025) webserver: HTTP GET / > I (40035) webserver: HTTP GET /cfg/init > I (40035) webserver: CfgInit enter 2.test.connect > I (40045) webserver: HTTP GET / > I (40075) webserver: HTTP GET /apple-touch-icon.png > I (40085) webserver: HTTP GET /assets/style.css > I (40185) webserver: HTTP GET /assets/script.js > I (40355) webserver: HTTP GET /cfg/init > I (40355) webserver: CfgInit enter 2.test.connect > OVMS> enable > Password: > Secure mode > > I (50425) webserver: HTTP GET / > I (50425) webserver: HTTP GET /cfg/init > I (50425) webserver: CfgInit enter 2.test.connect > I (50465) webserver: HTTP GET /apple-touch-icon.png > I (50475) webserver: HTTP GET /assets/style.css > I (50555) webserver: HTTP GET /assets/script.js > I (50675) webserver: HTTP GET /cfg/init > I (50675) webserver: CfgInit enter 2.test.connect > OVMS# ota status > Running partition: ota_0 > Boot partition: ota_0 > Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) > Server Available: 3.1.005 > > OTA release providing minor improvements and fixes. > > - Vehicle: 12V battery monitoring > vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference > - OTA: automatic daily firmware updates (wifi only) > auto [ota] = yes Enable/disable > ota [auto.hour] = 2 Hour for daily check > - Logging: persistent configuration, file cycling, web config UI: > log [file.enable] = no Enable/disable file logging > log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling > log [file.path] = "" Log path, if on /sd watches sd.mounted > log [level] Default level > log [level.<tag>] Component levels > - Reverse Engineering Tools enhancements > - Tesla Roadster CAC support > - Miscellaneous bug fixes and enhancements > > I (61705) webserver: HTTP GET / > I (61715) webserver: HTTP GET /cfg/init > I (61715) webserver: CfgInit enter 2.test.connect > I (61745) webserver: HTTP GET /apple-touch-icon.png > I (61755) webserver: HTTP GET /assets/style.css > I (61845) webserver: HTTP GET /assets/script.js > I (61965) webserver: HTTP GET /cfg/init > I (61965) webserver: CfgInit enter 2.test.connect > I (72035) webserver: HTTP GET / > I (72045) webserver: HTTP GET /cfg/init > I (72045) webserver: CfgInit enter 2.test.connect > I (72085) webserver: HTTP GET /apple-touch-icon.png > I (72095) webserver: HTTP GET /assets/style.css > I (72175) webserver: HTTP GET /assets/script.js > I (73485) webserver: HTTP GET /cfg/init > I (73495) webserver: CfgInit enter 2.test.connect > > OVMS# config list auto > auto (readable writeable) > wifi.mode: apclient > wifi.ssid.ap: DEVBENCH > wifi.ssid.client: HIGHWAYS > > OVMS# config list module > module (readable writeable) > init: 2.test.connect > > > Regards, Mark > >> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Do you have the earlier log, especially of the CfgInit ticker messages? >> >> Is the auto config correct and matching the "HIGHWAY" network? >> >> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >> >> >> >> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>> Trying the new web setup, but not getting very far… >>> >>> I (503580) webserver: HTTP GET / >>> I (503590) webserver: HTTP GET /cfg/init >>> I (503590) webserver: CfgInit enter 2.test.connect >>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>> I (503610) webserver: HTTP GET /assets/style.css >>> I (503730) webserver: HTTP GET /assets/script.js >>> I (503880) webserver: HTTP GET /cfg/init >>> I (503880) webserver: CfgInit enter 2.test.connect >>> I (513960) webserver: HTTP GET /cfg/init >>> I (513960) webserver: CfgInit enter 2.test.connect >>> I (513960) webserver: HTTP GET / >>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>> I (514000) webserver: HTTP GET /assets/style.css >>> I (514090) webserver: HTTP GET /assets/script.js >>> I (514220) webserver: HTTP GET /cfg/init >>> I (514220) webserver: CfgInit enter 2.test.connect >>> I (524280) webserver: HTTP GET / >>> I (524290) webserver: HTTP GET /cfg/init >>> I (524290) webserver: CfgInit enter 2.test.connect >>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>> I (524340) webserver: HTTP GET /assets/style.css >>> I (524420) webserver: HTTP GET /assets/script.js >>> I (524590) webserver: HTTP GET /cfg/init >>> I (524590) webserver: CfgInit enter 2.test.connect >>> I (534620) webserver: HTTP GET / >>> I (534630) webserver: HTTP GET /cfg/init >>> I (534630) webserver: CfgInit enter 2.test.connect >>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>> I (534660) webserver: HTTP GET /assets/style.css >>> I (534760) webserver: HTTP GET /assets/script.js >>> I (534890) webserver: HTTP GET /cfg/init >>> I (534890) webserver: CfgInit enter 2.test.connect >>> I (544940) webserver: HTTP GET / >>> I (544950) webserver: HTTP GET /cfg/init >>> I (544950) webserver: CfgInit enter 2.test.connect >>> I (544980) webserver: HTTP GET /assets/style.css >>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>> I (545080) webserver: HTTP GET /assets/script.js >>> I (545250) webserver: HTTP GET /cfg/init >>> I (545250) webserver: CfgInit enter 2.test.connect >>> >>> OVMS# wifi status >>> WiFi >>> Power: on >>> Mode: Access-Point + Client mode >>> >>> STA SSID: HIGHWAYS >>> MAC: 30:ae:a4:43:92:c4 >>> IP: 10.10.41.203/255.255.248.0 >>> GW: 10.10.40.64 >>> >>> AP SSID: DEVBENCH >>> MAC: 30:ae:a4:43:92:c5 >>> IP: 192.168.4.1 >>> AP Stations: 1 >>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>> >>> OVMS# ota status >>> Running partition: ota_0 >>> Boot partition: ota_0 >>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>> Server Available: 3.1.005 >>> >>> … >>> >>> I (1141850) webserver: HTTP GET / >>> I (1141860) webserver: HTTP GET /cfg/init >>> I (1141860) webserver: CfgInit enter 2.test.connect >>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>> I (1141890) webserver: HTTP GET /assets/style.css >>> I (1141990) webserver: HTTP GET /assets/script.js >>> I (1142120) webserver: HTTP GET /cfg/init >>> I (1142120) webserver: CfgInit enter 2.test.connect >>> >>> >>> Can’t get out of that 2.test.connect. >>> >>> Any ideas? >>> >>> Regards, Mark. >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Definitely something timing related. Even with auto wifi.mode=client, the wifi client comes up on boot, but v2 server can’t connect on first try (but second try works). This is what I get: I (7316) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7326) netmanager: Set DNS#0 10.10.40.64 I (7326) netmanager: Set DNS#1 0.0.0.0 I (7326) netmanager: Set DNS#2 0.0.0.0 I (7326) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7326) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) time: Starting SNTP client I (7326) ovms-server-v2: Status: Network is up, so attempt network connection I (7336) webserver: Launching Web Server I (7376) ssh: Launching SSH Server I (7386) ovms-server-v2: Status: Network is up, so attempt network connection I (8396) ovms-server-v2: Connection is api.openvehicles.com:6867 DEVBENCH I (8396) ovms-server-v2: Status: Connecting... I (10396) housekeeping: System considered stable (RAM: 8b=94792-95652 32b=23608) W (25696) ovms-server-v2: Connection failed E (25696) ovms-server-v2: Status: Error: Connection failed I (25696) ovms-server-v2: Status: Disconnected But, if I config set network dns ‘8.8.8.8 1.1.1.1’, I get: I (7087) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7097) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7097) netmanager: Set DNS#0 8.8.8.8 I (7097) netmanager: Set DNS#1 1.1.1.1 I (7107) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7107) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7107) time: Starting SNTP client I (7107) ovms-server-v2: Status: Network is up, so attempt network connection I (7117) webserver: Launching Web Server I (7137) ssh: Launching SSH Server I (7157) ovms-server-v2: Status: Network is up, so attempt network connection I (8387) ovms-server-v2: Connection is api.openvehicles.com:6867 DEVBENCH I (8387) ovms-server-v2: Status: Connecting... I (8617) ovms-server-v2: Connection successful I (8617) ovms-server-v2: Status: Logging in... I’m guessing this new ‘stored dns’ is the root of the problem, but really not sure what is going on. The delay is long enough to allow your test to timeout. Regards, Mark.
Regards, Michael
Regards, Michael
Added another fix.
Regards, Michael
Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: > I tried a restart. Here is what I get: > > Firmware: 3.1.005-72-g8cd4d07/ota_0/main > Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 > > I (1465) webserver: Launching Web Server > I (1465) ssh: Launching SSH Server > I (4185) wifi: ap channel adjust o:1,1 n:6,2 > I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 > I (4945) wifi: state: init -> auth (b0) > I (4945) wifi: state: auth -> assoc (0) > I (4955) wifi: state: assoc -> run (10) > I (5055) wifi: connected with HIGHWAYS, channel 6 > I (5375) sdcard: SD CARD has been inserted > I (5465) sdcard: mount done > I (6025) wpa: PTK has been installed, it may be an attack, ignor it. > I (6025) wpa: GTK has been installed, it may be an attack, ignor it. > I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 > I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 > I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 > I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 > I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) > I (9455) netmanager: Set DNS#0 10.10.40.64 > I (9455) netmanager: Set DNS#1 0.0.0.0 > I (9455) netmanager: Set DNS#2 0.0.0.0 > I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client > I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 > I (9455) time: Starting SNTP client > I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) > I (13565) webserver: HTTP GET / > I (13575) webserver: HTTP GET /cfg/init > I (14825) webserver: HTTP GET / > I (15135) webserver: HTTP GET /cfg/init > I (15375) simcom: State timeout, transition to 13 > I (15375) simcom: State: Enter PoweredOff state > I (15375) gsm-mux: Stop MUX > I (16695) webserver: HTTP GET / > I (16705) webserver: HTTP GET /cfg/init > I (16735) webserver: HTTP GET /apple-touch-icon.png > I (16905) webserver: HTTP GET /assets/style.css > I (16905) webserver: HTTP GET /assets/script.js > I (17345) webserver: HTTP GET /cfg/init > I (28045) webserver: HTTP POST /cfg/init > I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 > I (28085) webserver: HTTP GET /cfg/init > I (28085) webserver: CfgInit enter 2.test.connect > I (28085) webserver: HTTP GET /menu > I (40025) webserver: HTTP GET / > I (40035) webserver: HTTP GET /cfg/init > I (40035) webserver: CfgInit enter 2.test.connect > I (40045) webserver: HTTP GET / > I (40075) webserver: HTTP GET /apple-touch-icon.png > I (40085) webserver: HTTP GET /assets/style.css > I (40185) webserver: HTTP GET /assets/script.js > I (40355) webserver: HTTP GET /cfg/init > I (40355) webserver: CfgInit enter 2.test.connect > OVMS> enable > Password: > Secure mode > > I (50425) webserver: HTTP GET / > I (50425) webserver: HTTP GET /cfg/init > I (50425) webserver: CfgInit enter 2.test.connect > I (50465) webserver: HTTP GET /apple-touch-icon.png > I (50475) webserver: HTTP GET /assets/style.css > I (50555) webserver: HTTP GET /assets/script.js > I (50675) webserver: HTTP GET /cfg/init > I (50675) webserver: CfgInit enter 2.test.connect > OVMS# ota status > Running partition: ota_0 > Boot partition: ota_0 > Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) > Server Available: 3.1.005 > > OTA release providing minor improvements and fixes. > > - Vehicle: 12V battery monitoring > vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference > - OTA: automatic daily firmware updates (wifi only) > auto [ota] = yes Enable/disable > ota [auto.hour] = 2 Hour for daily check > - Logging: persistent configuration, file cycling, web config UI: > log [file.enable] = no Enable/disable file logging > log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling > log [file.path] = "" Log path, if on /sd watches sd.mounted > log [level] Default level > log [level.<tag>] Component levels > - Reverse Engineering Tools enhancements > - Tesla Roadster CAC support > - Miscellaneous bug fixes and enhancements > > I (61705) webserver: HTTP GET / > I (61715) webserver: HTTP GET /cfg/init > I (61715) webserver: CfgInit enter 2.test.connect > I (61745) webserver: HTTP GET /apple-touch-icon.png > I (61755) webserver: HTTP GET /assets/style.css > I (61845) webserver: HTTP GET /assets/script.js > I (61965) webserver: HTTP GET /cfg/init > I (61965) webserver: CfgInit enter 2.test.connect > I (72035) webserver: HTTP GET / > I (72045) webserver: HTTP GET /cfg/init > I (72045) webserver: CfgInit enter 2.test.connect > I (72085) webserver: HTTP GET /apple-touch-icon.png > I (72095) webserver: HTTP GET /assets/style.css > I (72175) webserver: HTTP GET /assets/script.js > I (73485) webserver: HTTP GET /cfg/init > I (73495) webserver: CfgInit enter 2.test.connect > > OVMS# config list auto > auto (readable writeable) > wifi.mode: apclient > wifi.ssid.ap: DEVBENCH > wifi.ssid.client: HIGHWAYS > > OVMS# config list module > module (readable writeable) > init: 2.test.connect > > Regards, Mark > >> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Do you have the earlier log, especially of the CfgInit ticker messages? >> >> Is the auto config correct and matching the "HIGHWAY" network? >> >> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >> >> >> >> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>> Trying the new web setup, but not getting very far… >>> >>> I (503580) webserver: HTTP GET / >>> I (503590) webserver: HTTP GET /cfg/init >>> I (503590) webserver: CfgInit enter 2.test.connect >>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>> I (503610) webserver: HTTP GET /assets/style.css >>> I (503730) webserver: HTTP GET /assets/script.js >>> I (503880) webserver: HTTP GET /cfg/init >>> I (503880) webserver: CfgInit enter 2.test.connect >>> I (513960) webserver: HTTP GET /cfg/init >>> I (513960) webserver: CfgInit enter 2.test.connect >>> I (513960) webserver: HTTP GET / >>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>> I (514000) webserver: HTTP GET /assets/style.css >>> I (514090) webserver: HTTP GET /assets/script.js >>> I (514220) webserver: HTTP GET /cfg/init >>> I (514220) webserver: CfgInit enter 2.test.connect >>> I (524280) webserver: HTTP GET / >>> I (524290) webserver: HTTP GET /cfg/init >>> I (524290) webserver: CfgInit enter 2.test.connect >>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>> I (524340) webserver: HTTP GET /assets/style.css >>> I (524420) webserver: HTTP GET /assets/script.js >>> I (524590) webserver: HTTP GET /cfg/init >>> I (524590) webserver: CfgInit enter 2.test.connect >>> I (534620) webserver: HTTP GET / >>> I (534630) webserver: HTTP GET /cfg/init >>> I (534630) webserver: CfgInit enter 2.test.connect >>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>> I (534660) webserver: HTTP GET /assets/style.css >>> I (534760) webserver: HTTP GET /assets/script.js >>> I (534890) webserver: HTTP GET /cfg/init >>> I (534890) webserver: CfgInit enter 2.test.connect >>> I (544940) webserver: HTTP GET / >>> I (544950) webserver: HTTP GET /cfg/init >>> I (544950) webserver: CfgInit enter 2.test.connect >>> I (544980) webserver: HTTP GET /assets/style.css >>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>> I (545080) webserver: HTTP GET /assets/script.js >>> I (545250) webserver: HTTP GET /cfg/init >>> I (545250) webserver: CfgInit enter 2.test.connect >>> >>> OVMS# wifi status >>> WiFi >>> Power: on >>> Mode: Access-Point + Client mode >>> >>> STA SSID: HIGHWAYS >>> MAC: 30:ae:a4:43:92:c4 >>> IP: 10.10.41.203/255.255.248.0 >>> GW: 10.10.40.64 >>> >>> AP SSID: DEVBENCH >>> MAC: 30:ae:a4:43:92:c5 >>> IP: 192.168.4.1 >>> AP Stations: 1 >>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>> >>> OVMS# ota status >>> Running partition: ota_0 >>> Boot partition: ota_0 >>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>> Server Available: 3.1.005 >>> >>> … >>> >>> I (1141850) webserver: HTTP GET / >>> I (1141860) webserver: HTTP GET /cfg/init >>> I (1141860) webserver: CfgInit enter 2.test.connect >>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>> I (1141890) webserver: HTTP GET /assets/style.css >>> I (1141990) webserver: HTTP GET /assets/script.js >>> I (1142120) webserver: HTTP GET /cfg/init >>> I (1142120) webserver: CfgInit enter 2.test.connect >>> >>> Can’t get out of that 2.test.connect. >>> >>> Any ideas? >>> >>> Regards, Mark. >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
My boot without a fixed DNS looks like yours with a fixed one: I (5066) event: sta ip: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (5066) netmanager: Interface priority is st1 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (5076) netmanager: Set DNS#0 192.168.2.1 I (5076) netmanager: Set DNS#1 192.168.2.1 I (5076) netmanager: Set DNS#2 0.0.0.0 I (5076) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (5076) esp32wifi: STA got IP with SSID: WLAN-214677, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (5076) time: Starting SNTP client I (5076) ovms-server-v2: Status: Network is up, so attempt network connection I (6286) ovms-server-v2: Connection is ovms.dexters-web.de:6867 Test1 I (6286) ovms-server-v2: Status: Connecting... I (6516) ovms-server-v2: Connection successful I (6516) ovms-server-v2: Status: Logging in... Is your DNS in the router or behind? The IP and masking looks like it's on another net. If it's on another net, is it possible the first query after the wifi connect is blocked or fails due to some firewall delay? Regards, Michael Am 13.05.2018 um 16:07 schrieb Mark Webb-Johnson:
This is what I get:
I (7316) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7326) netmanager: Set DNS#0 10.10.40.64 I (7326) netmanager: Set DNS#1 0.0.0.0 I (7326) netmanager: Set DNS#2 0.0.0.0 I (7326) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7326) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) time: Starting SNTP client I (7326) ovms-server-v2: Status: Network is up, so attempt network connection I (7336) webserver: Launching Web Server I (7376) ssh: Launching SSH Server I (7386) ovms-server-v2: Status: Network is up, so attempt network connection I (8396) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH I (8396) ovms-server-v2: Status: Connecting... I (10396) housekeeping: System considered stable (RAM: 8b=94792-95652 32b=23608) W (25696) ovms-server-v2: Connection failed E (25696) ovms-server-v2: Status: Error: Connection failed I (25696) ovms-server-v2: Status: Disconnected
I (7087) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7097) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7097) netmanager: Set DNS#0 8.8.8.8 I (7097) netmanager: Set DNS#1 1.1.1.1 I (7107) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7107) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7107) time: Starting SNTP client I (7107) ovms-server-v2: Status: Network is up, so attempt network connection I (7117) webserver: Launching Web Server I (7137) ssh: Launching SSH Server I (7157) ovms-server-v2: Status: Network is up, so attempt network connection I (8387) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH I (8387) ovms-server-v2: Status: Connecting... I (8617) ovms-server-v2: Connection successful I (8617) ovms-server-v2: Status: Logging in...
On 13 May 2018, at 2:18 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
Regards, Michael
Added another fix.
Regards, Michael
Am 11.05.2018 um 18:19 schrieb Michael Balzer: > OK. I really should wait for config.mounted before reading from MyConfig. > > Fix is pushed, please try. > > > Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >> I tried a restart. Here is what I get: >> >> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >> >> I (1465) webserver: Launching Web Server >> I (1465) ssh: Launching SSH Server >> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >> I (4945) wifi: state: init -> auth (b0) >> I (4945) wifi: state: auth -> assoc (0) >> I (4955) wifi: state: assoc -> run (10) >> I (5055) wifi: connected with HIGHWAYS, channel 6 >> I (5375) sdcard: SD CARD has been inserted >> I (5465) sdcard: mount done >> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >> I (9455) netmanager: Set DNS#0 10.10.40.64 >> I (9455) netmanager: Set DNS#1 0.0.0.0 >> I (9455) netmanager: Set DNS#2 0.0.0.0 >> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >> I (9455) time: Starting SNTP client >> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >> I (13565) webserver: HTTP GET / >> I (13575) webserver: HTTP GET /cfg/init >> I (14825) webserver: HTTP GET / >> I (15135) webserver: HTTP GET /cfg/init >> I (15375) simcom: State timeout, transition to 13 >> I (15375) simcom: State: Enter PoweredOff state >> I (15375) gsm-mux: Stop MUX >> I (16695) webserver: HTTP GET / >> I (16705) webserver: HTTP GET /cfg/init >> I (16735) webserver: HTTP GET /apple-touch-icon.png >> I (16905) webserver: HTTP GET /assets/style.css >> I (16905) webserver: HTTP GET /assets/script.js >> I (17345) webserver: HTTP GET /cfg/init >> I (28045) webserver: HTTP POST /cfg/init >> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >> I (28085) webserver: HTTP GET /cfg/init >> I (28085) webserver: CfgInit enter 2.test.connect >> I (28085) webserver: HTTP GET /menu >> I (40025) webserver: HTTP GET / >> I (40035) webserver: HTTP GET /cfg/init >> I (40035) webserver: CfgInit enter 2.test.connect >> I (40045) webserver: HTTP GET / >> I (40075) webserver: HTTP GET /apple-touch-icon.png >> I (40085) webserver: HTTP GET /assets/style.css >> I (40185) webserver: HTTP GET /assets/script.js >> I (40355) webserver: HTTP GET /cfg/init >> I (40355) webserver: CfgInit enter 2.test.connect >> OVMS> enable >> Password: >> Secure mode >> >> I (50425) webserver: HTTP GET / >> I (50425) webserver: HTTP GET /cfg/init >> I (50425) webserver: CfgInit enter 2.test.connect >> I (50465) webserver: HTTP GET /apple-touch-icon.png >> I (50475) webserver: HTTP GET /assets/style.css >> I (50555) webserver: HTTP GET /assets/script.js >> I (50675) webserver: HTTP GET /cfg/init >> I (50675) webserver: CfgInit enter 2.test.connect >> OVMS# ota status >> Running partition: ota_0 >> Boot partition: ota_0 >> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >> Server Available: 3.1.005 >> >> OTA release providing minor improvements and fixes. >> >> - Vehicle: 12V battery monitoring >> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >> - OTA: automatic daily firmware updates (wifi only) >> auto [ota] = yes Enable/disable >> ota [auto.hour] = 2 Hour for daily check >> - Logging: persistent configuration, file cycling, web config UI: >> log [file.enable] = no Enable/disable file logging >> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >> log [file.path] = "" Log path, if on /sd watches sd.mounted >> log [level] Default level >> log [level.<tag>] Component levels >> - Reverse Engineering Tools enhancements >> - Tesla Roadster CAC support >> - Miscellaneous bug fixes and enhancements >> >> I (61705) webserver: HTTP GET / >> I (61715) webserver: HTTP GET /cfg/init >> I (61715) webserver: CfgInit enter 2.test.connect >> I (61745) webserver: HTTP GET /apple-touch-icon.png >> I (61755) webserver: HTTP GET /assets/style.css >> I (61845) webserver: HTTP GET /assets/script.js >> I (61965) webserver: HTTP GET /cfg/init >> I (61965) webserver: CfgInit enter 2.test.connect >> I (72035) webserver: HTTP GET / >> I (72045) webserver: HTTP GET /cfg/init >> I (72045) webserver: CfgInit enter 2.test.connect >> I (72085) webserver: HTTP GET /apple-touch-icon.png >> I (72095) webserver: HTTP GET /assets/style.css >> I (72175) webserver: HTTP GET /assets/script.js >> I (73485) webserver: HTTP GET /cfg/init >> I (73495) webserver: CfgInit enter 2.test.connect >> >> OVMS# config list auto >> auto (readable writeable) >> wifi.mode: apclient >> wifi.ssid.ap: DEVBENCH >> wifi.ssid.client: HIGHWAYS >> >> OVMS# config list module >> module (readable writeable) >> init: 2.test.connect >> >> >> Regards, Mark >> >>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> Do you have the earlier log, especially of the CfgInit ticker messages? >>> >>> Is the auto config correct and matching the "HIGHWAY" network? >>> >>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>> >>> >>> >>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>> Trying the new web setup, but not getting very far… >>>> >>>> I (503580) webserver: HTTP GET / >>>> I (503590) webserver: HTTP GET /cfg/init >>>> I (503590) webserver: CfgInit enter 2.test.connect >>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>> I (503610) webserver: HTTP GET /assets/style.css >>>> I (503730) webserver: HTTP GET /assets/script.js >>>> I (503880) webserver: HTTP GET /cfg/init >>>> I (503880) webserver: CfgInit enter 2.test.connect >>>> I (513960) webserver: HTTP GET /cfg/init >>>> I (513960) webserver: CfgInit enter 2.test.connect >>>> I (513960) webserver: HTTP GET / >>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>> I (514000) webserver: HTTP GET /assets/style.css >>>> I (514090) webserver: HTTP GET /assets/script.js >>>> I (514220) webserver: HTTP GET /cfg/init >>>> I (514220) webserver: CfgInit enter 2.test.connect >>>> I (524280) webserver: HTTP GET / >>>> I (524290) webserver: HTTP GET /cfg/init >>>> I (524290) webserver: CfgInit enter 2.test.connect >>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>> I (524340) webserver: HTTP GET /assets/style.css >>>> I (524420) webserver: HTTP GET /assets/script.js >>>> I (524590) webserver: HTTP GET /cfg/init >>>> I (524590) webserver: CfgInit enter 2.test.connect >>>> I (534620) webserver: HTTP GET / >>>> I (534630) webserver: HTTP GET /cfg/init >>>> I (534630) webserver: CfgInit enter 2.test.connect >>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>> I (534660) webserver: HTTP GET /assets/style.css >>>> I (534760) webserver: HTTP GET /assets/script.js >>>> I (534890) webserver: HTTP GET /cfg/init >>>> I (534890) webserver: CfgInit enter 2.test.connect >>>> I (544940) webserver: HTTP GET / >>>> I (544950) webserver: HTTP GET /cfg/init >>>> I (544950) webserver: CfgInit enter 2.test.connect >>>> I (544980) webserver: HTTP GET /assets/style.css >>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>> I (545080) webserver: HTTP GET /assets/script.js >>>> I (545250) webserver: HTTP GET /cfg/init >>>> I (545250) webserver: CfgInit enter 2.test.connect >>>> >>>> OVMS# wifi status >>>> WiFi >>>> Power: on >>>> Mode: Access-Point + Client mode >>>> >>>> STA SSID: HIGHWAYS >>>> MAC: 30:ae:a4:43:92:c4 >>>> IP: 10.10.41.203/255.255.248.0 >>>> GW: 10.10.40.64 >>>> >>>> AP SSID: DEVBENCH >>>> MAC: 30:ae:a4:43:92:c5 >>>> IP: 192.168.4.1 >>>> AP Stations: 1 >>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>> >>>> OVMS# ota status >>>> Running partition: ota_0 >>>> Boot partition: ota_0 >>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>> Server Available: 3.1.005 >>>> >>>> … >>>> >>>> I (1141850) webserver: HTTP GET / >>>> I (1141860) webserver: HTTP GET /cfg/init >>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>> I (1141890) webserver: HTTP GET /assets/style.css >>>> I (1141990) webserver: HTTP GET /assets/script.js >>>> I (1142120) webserver: HTTP GET /cfg/init >>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>> >>>> >>>> Can’t get out of that 2.test.connect. >>>> >>>> Any ideas? >>>> >>>> Regards, Mark. >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
With the Google/Cloudflare DNS you can finish the setup? I was hoping we could omit the DNS question now from the setup, as users likely don't know what that is. I'll add it to step 2 for now, but with a fixed & labeled selection. Am 13.05.2018 um 16:36 schrieb Michael Balzer:
Regards, Michael
This is what I get:
Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some commit a few days before.
CONFIG_LWIP_SO_REUSE=y CONFIG_LWIP_SO_REUSE_RXTOALL=y
Just double-checked, and yes they are there.
It seems that after connecting to SSID, the attempt to run ‘Ota status’ is immediate, but the wifi client hasn’t settled down yet. I’ve looked in web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect”)’, it just seems to try to MyOTA.GetStatus as soon as the ssid matches? But it doesn’t check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is connected, and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I’m missing something?
The state ticker does not check yet if it can abort a scheduled timeout. So it doesn't do the test as soon as GetSSID() returns the network.
The test is done fixed 20 seconds after StartAccessPointClientMode(). That is normally plenty of time for everything to settle. In my runs, the client network was normally fully functional in ~10 seconds.
How long does your APClient switch take? You can try raising the 20 second timeout in line 226.
Regards, Michael
On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson:
Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event delivery queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task?
Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my tests…
The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks.
If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT.
The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is fast enough to keep them on the AP.
Regards, Michael
I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode (which is what I did with my alternative approach before).
> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > Added another fix. > > Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I > guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the > javascript code in that case. > > The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 seconds. > > Regards, > Michael > > > Am 11.05.2018 um 18:19 schrieb Michael Balzer: >> OK. I really should wait for config.mounted before reading from MyConfig. >> >> Fix is pushed, please try. >> >> >> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>> I tried a restart. Here is what I get: >>> >>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>> >>> I (1465) webserver: Launching Web Server >>> I (1465) ssh: Launching SSH Server >>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>> I (4945) wifi: state: init -> auth (b0) >>> I (4945) wifi: state: auth -> assoc (0) >>> I (4955) wifi: state: assoc -> run (10) >>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>> I (5375) sdcard: SD CARD has been inserted >>> I (5465) sdcard: mount done >>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>> I (9455) time: Starting SNTP client >>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>> I (13565) webserver: HTTP GET / >>> I (13575) webserver: HTTP GET /cfg/init >>> I (14825) webserver: HTTP GET / >>> I (15135) webserver: HTTP GET /cfg/init >>> I (15375) simcom: State timeout, transition to 13 >>> I (15375) simcom: State: Enter PoweredOff state >>> I (15375) gsm-mux: Stop MUX >>> I (16695) webserver: HTTP GET / >>> I (16705) webserver: HTTP GET /cfg/init >>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>> I (16905) webserver: HTTP GET /assets/style.css >>> I (16905) webserver: HTTP GET /assets/script.js >>> I (17345) webserver: HTTP GET /cfg/init >>> I (28045) webserver: HTTP POST /cfg/init >>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>> I (28085) webserver: HTTP GET /cfg/init >>> I (28085) webserver: CfgInit enter 2.test.connect >>> I (28085) webserver: HTTP GET /menu >>> I (40025) webserver: HTTP GET / >>> I (40035) webserver: HTTP GET /cfg/init >>> I (40035) webserver: CfgInit enter 2.test.connect >>> I (40045) webserver: HTTP GET / >>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>> I (40085) webserver: HTTP GET /assets/style.css >>> I (40185) webserver: HTTP GET /assets/script.js >>> I (40355) webserver: HTTP GET /cfg/init >>> I (40355) webserver: CfgInit enter 2.test.connect >>> OVMS> enable >>> Password: >>> Secure mode >>> >>> I (50425) webserver: HTTP GET / >>> I (50425) webserver: HTTP GET /cfg/init >>> I (50425) webserver: CfgInit enter 2.test.connect >>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>> I (50475) webserver: HTTP GET /assets/style.css >>> I (50555) webserver: HTTP GET /assets/script.js >>> I (50675) webserver: HTTP GET /cfg/init >>> I (50675) webserver: CfgInit enter 2.test.connect >>> OVMS# ota status >>> Running partition: ota_0 >>> Boot partition: ota_0 >>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>> Server Available: 3.1.005 >>> >>> OTA release providing minor improvements and fixes. >>> >>> - Vehicle: 12V battery monitoring >>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>> - OTA: automatic daily firmware updates (wifi only) >>> auto [ota] = yes Enable/disable >>> ota [auto.hour] = 2 Hour for daily check >>> - Logging: persistent configuration, file cycling, web config UI: >>> log [file.enable] = no Enable/disable file logging >>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>> log [level] Default level >>> log [level.<tag>] Component levels >>> - Reverse Engineering Tools enhancements >>> - Tesla Roadster CAC support >>> - Miscellaneous bug fixes and enhancements >>> >>> I (61705) webserver: HTTP GET / >>> I (61715) webserver: HTTP GET /cfg/init >>> I (61715) webserver: CfgInit enter 2.test.connect >>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>> I (61755) webserver: HTTP GET /assets/style.css >>> I (61845) webserver: HTTP GET /assets/script.js >>> I (61965) webserver: HTTP GET /cfg/init >>> I (61965) webserver: CfgInit enter 2.test.connect >>> I (72035) webserver: HTTP GET / >>> I (72045) webserver: HTTP GET /cfg/init >>> I (72045) webserver: CfgInit enter 2.test.connect >>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>> I (72095) webserver: HTTP GET /assets/style.css >>> I (72175) webserver: HTTP GET /assets/script.js >>> I (73485) webserver: HTTP GET /cfg/init >>> I (73495) webserver: CfgInit enter 2.test.connect >>> >>> OVMS# config list auto >>> auto (readable writeable) >>> wifi.mode: apclient >>> wifi.ssid.ap: DEVBENCH >>> wifi.ssid.client: HIGHWAYS >>> >>> OVMS# config list module >>> module (readable writeable) >>> init: 2.test.connect >>> >>> >>> Regards, Mark >>> >>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>> >>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>> >>>> Is the auto config correct and matching the "HIGHWAY" network? >>>> >>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>> >>>> >>>> >>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>> Trying the new web setup, but not getting very far… >>>>> >>>>> I (503580) webserver: HTTP GET / >>>>> I (503590) webserver: HTTP GET /cfg/init >>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>> I (503880) webserver: HTTP GET /cfg/init >>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>> I (513960) webserver: HTTP GET /cfg/init >>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>> I (513960) webserver: HTTP GET / >>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>> I (514220) webserver: HTTP GET /cfg/init >>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>> I (524280) webserver: HTTP GET / >>>>> I (524290) webserver: HTTP GET /cfg/init >>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>> I (524590) webserver: HTTP GET /cfg/init >>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>> I (534620) webserver: HTTP GET / >>>>> I (534630) webserver: HTTP GET /cfg/init >>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>> I (534890) webserver: HTTP GET /cfg/init >>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>> I (544940) webserver: HTTP GET / >>>>> I (544950) webserver: HTTP GET /cfg/init >>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>> I (545250) webserver: HTTP GET /cfg/init >>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>> >>>>> OVMS# wifi status >>>>> WiFi >>>>> Power: on >>>>> Mode: Access-Point + Client mode >>>>> >>>>> STA SSID: HIGHWAYS >>>>> MAC: 30:ae:a4:43:92:c4 >>>>> IP: 10.10.41.203/255.255.248.0 >>>>> GW: 10.10.40.64 >>>>> >>>>> AP SSID: DEVBENCH >>>>> MAC: 30:ae:a4:43:92:c5 >>>>> IP: 192.168.4.1 >>>>> AP Stations: 1 >>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>> >>>>> OVMS# ota status >>>>> Running partition: ota_0 >>>>> Boot partition: ota_0 >>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>> Server Available: 3.1.005 >>>>> >>>>> … >>>>> >>>>> I (1141850) webserver: HTTP GET / >>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>> >>>>> >>>>> Can’t get out of that 2.test.connect. >>>>> >>>>> Any ideas? >>>>> >>>>> Regards, Mark. >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> -- >>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Pushed. Strangely enough, during my tests I once had the same effect as you, but with the Cloudflare DNS. I couldn't reproduce it though. Please try again. I also captured screenshots of the process for the user guide -- is that necessary? I took care to add a lot of info to the process itself. Regards, Michael Am 13.05.2018 um 16:44 schrieb Michael Balzer:
Regards, Michael
This is what I get:
Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson:
Regards, Michael
Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson: > > Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event delivery > queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task?
> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my > iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks.
Regards, Michael
> I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode (which > is what I did with my alternative approach before). > > Regards, Mark. > >> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> Added another fix. >> >> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I >> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the >> javascript code in that case. >> >> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 >> seconds. >> >> Regards, >> Michael >> >> >> Am 11.05.2018 um 18:19 schrieb Michael Balzer: >>> OK. I really should wait for config.mounted before reading from MyConfig. >>> >>> Fix is pushed, please try. >>> >>> >>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>>> I tried a restart. Here is what I get: >>>> >>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>>> >>>> I (1465) webserver: Launching Web Server >>>> I (1465) ssh: Launching SSH Server >>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>>> I (4945) wifi: state: init -> auth (b0) >>>> I (4945) wifi: state: auth -> assoc (0) >>>> I (4955) wifi: state: assoc -> run (10) >>>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>>> I (5375) sdcard: SD CARD has been inserted >>>> I (5465) sdcard: mount done >>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>> I (9455) time: Starting SNTP client >>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>>> I (13565) webserver: HTTP GET / >>>> I (13575) webserver: HTTP GET /cfg/init >>>> I (14825) webserver: HTTP GET / >>>> I (15135) webserver: HTTP GET /cfg/init >>>> I (15375) simcom: State timeout, transition to 13 >>>> I (15375) simcom: State: Enter PoweredOff state >>>> I (15375) gsm-mux: Stop MUX >>>> I (16695) webserver: HTTP GET / >>>> I (16705) webserver: HTTP GET /cfg/init >>>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>>> I (16905) webserver: HTTP GET /assets/style.css >>>> I (16905) webserver: HTTP GET /assets/script.js >>>> I (17345) webserver: HTTP GET /cfg/init >>>> I (28045) webserver: HTTP POST /cfg/init >>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>>> I (28085) webserver: HTTP GET /cfg/init >>>> I (28085) webserver: CfgInit enter 2.test.connect >>>> I (28085) webserver: HTTP GET /menu >>>> I (40025) webserver: HTTP GET / >>>> I (40035) webserver: HTTP GET /cfg/init >>>> I (40035) webserver: CfgInit enter 2.test.connect >>>> I (40045) webserver: HTTP GET / >>>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>>> I (40085) webserver: HTTP GET /assets/style.css >>>> I (40185) webserver: HTTP GET /assets/script.js >>>> I (40355) webserver: HTTP GET /cfg/init >>>> I (40355) webserver: CfgInit enter 2.test.connect >>>> OVMS> enable >>>> Password: >>>> Secure mode >>>> >>>> I (50425) webserver: HTTP GET / >>>> I (50425) webserver: HTTP GET /cfg/init >>>> I (50425) webserver: CfgInit enter 2.test.connect >>>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>>> I (50475) webserver: HTTP GET /assets/style.css >>>> I (50555) webserver: HTTP GET /assets/script.js >>>> I (50675) webserver: HTTP GET /cfg/init >>>> I (50675) webserver: CfgInit enter 2.test.connect >>>> OVMS# ota status >>>> Running partition: ota_0 >>>> Boot partition: ota_0 >>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>> Server Available: 3.1.005 >>>> >>>> OTA release providing minor improvements and fixes. >>>> >>>> - Vehicle: 12V battery monitoring >>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>>> - OTA: automatic daily firmware updates (wifi only) >>>> auto [ota] = yes Enable/disable >>>> ota [auto.hour] = 2 Hour for daily check >>>> - Logging: persistent configuration, file cycling, web config UI: >>>> log [file.enable] = no Enable/disable file logging >>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>>> log [level] Default level >>>> log [level.<tag>] Component levels >>>> - Reverse Engineering Tools enhancements >>>> - Tesla Roadster CAC support >>>> - Miscellaneous bug fixes and enhancements >>>> >>>> I (61705) webserver: HTTP GET / >>>> I (61715) webserver: HTTP GET /cfg/init >>>> I (61715) webserver: CfgInit enter 2.test.connect >>>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>>> I (61755) webserver: HTTP GET /assets/style.css >>>> I (61845) webserver: HTTP GET /assets/script.js >>>> I (61965) webserver: HTTP GET /cfg/init >>>> I (61965) webserver: CfgInit enter 2.test.connect >>>> I (72035) webserver: HTTP GET / >>>> I (72045) webserver: HTTP GET /cfg/init >>>> I (72045) webserver: CfgInit enter 2.test.connect >>>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>>> I (72095) webserver: HTTP GET /assets/style.css >>>> I (72175) webserver: HTTP GET /assets/script.js >>>> I (73485) webserver: HTTP GET /cfg/init >>>> I (73495) webserver: CfgInit enter 2.test.connect >>>> >>>> OVMS# config list auto >>>> auto (readable writeable) >>>> wifi.mode: apclient >>>> wifi.ssid.ap: DEVBENCH >>>> wifi.ssid.client: HIGHWAYS >>>> >>>> OVMS# config list module >>>> module (readable writeable) >>>> init: 2.test.connect >>>> >>>> >>>> Regards, Mark >>>> >>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>> >>>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>>> >>>>> Is the auto config correct and matching the "HIGHWAY" network? >>>>> >>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>>> >>>>> >>>>> >>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>>> Trying the new web setup, but not getting very far… >>>>>> >>>>>> I (503580) webserver: HTTP GET / >>>>>> I (503590) webserver: HTTP GET /cfg/init >>>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>>> I (503880) webserver: HTTP GET /cfg/init >>>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>>> I (513960) webserver: HTTP GET /cfg/init >>>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>>> I (513960) webserver: HTTP GET / >>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>>> I (514220) webserver: HTTP GET /cfg/init >>>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>>> I (524280) webserver: HTTP GET / >>>>>> I (524290) webserver: HTTP GET /cfg/init >>>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>>> I (524590) webserver: HTTP GET /cfg/init >>>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>>> I (534620) webserver: HTTP GET / >>>>>> I (534630) webserver: HTTP GET /cfg/init >>>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>>> I (534890) webserver: HTTP GET /cfg/init >>>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>>> I (544940) webserver: HTTP GET / >>>>>> I (544950) webserver: HTTP GET /cfg/init >>>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>>> I (545250) webserver: HTTP GET /cfg/init >>>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>>> >>>>>> OVMS# wifi status >>>>>> WiFi >>>>>> Power: on >>>>>> Mode: Access-Point + Client mode >>>>>> >>>>>> STA SSID: HIGHWAYS >>>>>> MAC: 30:ae:a4:43:92:c4 >>>>>> IP: 10.10.41.203/255.255.248.0 >>>>>> GW: 10.10.40.64 >>>>>> >>>>>> AP SSID: DEVBENCH >>>>>> MAC: 30:ae:a4:43:92:c5 >>>>>> IP: 192.168.4.1 >>>>>> AP Stations: 1 >>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>>> >>>>>> OVMS# ota status >>>>>> Running partition: ota_0 >>>>>> Boot partition: ota_0 >>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>> Server Available: 3.1.005 >>>>>> >>>>>> … >>>>>> >>>>>> I (1141850) webserver: HTTP GET / >>>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>>> >>>>>> >>>>>> Can’t get out of that 2.test.connect. >>>>>> >>>>>> Any ideas? >>>>>> >>>>>> Regards, Mark. >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> -- >>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I just did another setup run to also catch a firmware update screenshot. I got a stack overflow in the events task when starting the step 4 test (loading vehicle module and server v2). The crash persisted over reboot, so the setup wizard reverted to factory defaults (good to know that works). This may be because I'm testing on a 3.0 module, but I've just pushed a stack change to 8K just to be sure. Regards, Michael Am 13.05.2018 um 17:54 schrieb Michael Balzer:
Pushed.
Please try again.
Regards, Michael
Regards, Michael
This is what I get:
> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some > commit a few days before. > > CONFIG_LWIP_SO_REUSE=y > CONFIG_LWIP_SO_REUSE_RXTOALL=y
Regards, Michael
> On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > > Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson: >> >> Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event >> delivery queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task? > > Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my tests… > >> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my >> iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks. > > Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some > commit a few days before. > > CONFIG_LWIP_SO_REUSE=y > CONFIG_LWIP_SO_REUSE_RXTOALL=y > > If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT. > > The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is > fast enough to keep them on the AP. > > Regards, > Michael > > >> I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode >> (which is what I did with my alternative approach before). >> >> Regards, Mark. >> >>> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> Added another fix. >>> >>> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I >>> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the >>> javascript code in that case. >>> >>> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 >>> seconds. >>> >>> Regards, >>> Michael >>> >>> >>> Am 11.05.2018 um 18:19 schrieb Michael Balzer: >>>> OK. I really should wait for config.mounted before reading from MyConfig. >>>> >>>> Fix is pushed, please try. >>>> >>>> >>>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>>>> I tried a restart. Here is what I get: >>>>> >>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>>>> >>>>> I (1465) webserver: Launching Web Server >>>>> I (1465) ssh: Launching SSH Server >>>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>>>> I (4945) wifi: state: init -> auth (b0) >>>>> I (4945) wifi: state: auth -> assoc (0) >>>>> I (4955) wifi: state: assoc -> run (10) >>>>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>>>> I (5375) sdcard: SD CARD has been inserted >>>>> I (5465) sdcard: mount done >>>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>>>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>>>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>>>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>> I (9455) time: Starting SNTP client >>>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>>>> I (13565) webserver: HTTP GET / >>>>> I (13575) webserver: HTTP GET /cfg/init >>>>> I (14825) webserver: HTTP GET / >>>>> I (15135) webserver: HTTP GET /cfg/init >>>>> I (15375) simcom: State timeout, transition to 13 >>>>> I (15375) simcom: State: Enter PoweredOff state >>>>> I (15375) gsm-mux: Stop MUX >>>>> I (16695) webserver: HTTP GET / >>>>> I (16705) webserver: HTTP GET /cfg/init >>>>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>>>> I (16905) webserver: HTTP GET /assets/style.css >>>>> I (16905) webserver: HTTP GET /assets/script.js >>>>> I (17345) webserver: HTTP GET /cfg/init >>>>> I (28045) webserver: HTTP POST /cfg/init >>>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>>>> I (28085) webserver: HTTP GET /cfg/init >>>>> I (28085) webserver: CfgInit enter 2.test.connect >>>>> I (28085) webserver: HTTP GET /menu >>>>> I (40025) webserver: HTTP GET / >>>>> I (40035) webserver: HTTP GET /cfg/init >>>>> I (40035) webserver: CfgInit enter 2.test.connect >>>>> I (40045) webserver: HTTP GET / >>>>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>>>> I (40085) webserver: HTTP GET /assets/style.css >>>>> I (40185) webserver: HTTP GET /assets/script.js >>>>> I (40355) webserver: HTTP GET /cfg/init >>>>> I (40355) webserver: CfgInit enter 2.test.connect >>>>> OVMS> enable >>>>> Password: >>>>> Secure mode >>>>> >>>>> I (50425) webserver: HTTP GET / >>>>> I (50425) webserver: HTTP GET /cfg/init >>>>> I (50425) webserver: CfgInit enter 2.test.connect >>>>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>>>> I (50475) webserver: HTTP GET /assets/style.css >>>>> I (50555) webserver: HTTP GET /assets/script.js >>>>> I (50675) webserver: HTTP GET /cfg/init >>>>> I (50675) webserver: CfgInit enter 2.test.connect >>>>> OVMS# ota status >>>>> Running partition: ota_0 >>>>> Boot partition: ota_0 >>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>> Server Available: 3.1.005 >>>>> >>>>> OTA release providing minor improvements and fixes. >>>>> >>>>> - Vehicle: 12V battery monitoring >>>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>>>> - OTA: automatic daily firmware updates (wifi only) >>>>> auto [ota] = yes Enable/disable >>>>> ota [auto.hour] = 2 Hour for daily check >>>>> - Logging: persistent configuration, file cycling, web config UI: >>>>> log [file.enable] = no Enable/disable file logging >>>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>>>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>>>> log [level] Default level >>>>> log [level.<tag>] Component levels >>>>> - Reverse Engineering Tools enhancements >>>>> - Tesla Roadster CAC support >>>>> - Miscellaneous bug fixes and enhancements >>>>> >>>>> I (61705) webserver: HTTP GET / >>>>> I (61715) webserver: HTTP GET /cfg/init >>>>> I (61715) webserver: CfgInit enter 2.test.connect >>>>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>>>> I (61755) webserver: HTTP GET /assets/style.css >>>>> I (61845) webserver: HTTP GET /assets/script.js >>>>> I (61965) webserver: HTTP GET /cfg/init >>>>> I (61965) webserver: CfgInit enter 2.test.connect >>>>> I (72035) webserver: HTTP GET / >>>>> I (72045) webserver: HTTP GET /cfg/init >>>>> I (72045) webserver: CfgInit enter 2.test.connect >>>>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>>>> I (72095) webserver: HTTP GET /assets/style.css >>>>> I (72175) webserver: HTTP GET /assets/script.js >>>>> I (73485) webserver: HTTP GET /cfg/init >>>>> I (73495) webserver: CfgInit enter 2.test.connect >>>>> >>>>> OVMS# config list auto >>>>> auto (readable writeable) >>>>> wifi.mode: apclient >>>>> wifi.ssid.ap: DEVBENCH >>>>> wifi.ssid.client: HIGHWAYS >>>>> >>>>> OVMS# config list module >>>>> module (readable writeable) >>>>> init: 2.test.connect >>>>> >>>>> >>>>> Regards, Mark >>>>> >>>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>>> >>>>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>>>> >>>>>> Is the auto config correct and matching the "HIGHWAY" network? >>>>>> >>>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>>>> >>>>>> >>>>>> >>>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>>>> Trying the new web setup, but not getting very far… >>>>>>> >>>>>>> I (503580) webserver: HTTP GET / >>>>>>> I (503590) webserver: HTTP GET /cfg/init >>>>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>>>> I (503880) webserver: HTTP GET /cfg/init >>>>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>>>> I (513960) webserver: HTTP GET /cfg/init >>>>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>>>> I (513960) webserver: HTTP GET / >>>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>>>> I (514220) webserver: HTTP GET /cfg/init >>>>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>>>> I (524280) webserver: HTTP GET / >>>>>>> I (524290) webserver: HTTP GET /cfg/init >>>>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>>>> I (524590) webserver: HTTP GET /cfg/init >>>>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>>>> I (534620) webserver: HTTP GET / >>>>>>> I (534630) webserver: HTTP GET /cfg/init >>>>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>>>> I (534890) webserver: HTTP GET /cfg/init >>>>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>>>> I (544940) webserver: HTTP GET / >>>>>>> I (544950) webserver: HTTP GET /cfg/init >>>>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>>>> I (545250) webserver: HTTP GET /cfg/init >>>>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>>>> >>>>>>> OVMS# wifi status >>>>>>> WiFi >>>>>>> Power: on >>>>>>> Mode: Access-Point + Client mode >>>>>>> >>>>>>> STA SSID: HIGHWAYS >>>>>>> MAC: 30:ae:a4:43:92:c4 >>>>>>> IP: 10.10.41.203/255.255.248.0 >>>>>>> GW: 10.10.40.64 >>>>>>> >>>>>>> AP SSID: DEVBENCH >>>>>>> MAC: 30:ae:a4:43:92:c5 >>>>>>> IP: 192.168.4.1 >>>>>>> AP Stations: 1 >>>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>>>> >>>>>>> OVMS# ota status >>>>>>> Running partition: ota_0 >>>>>>> Boot partition: ota_0 >>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>>> Server Available: 3.1.005 >>>>>>> >>>>>>> … >>>>>>> >>>>>>> I (1141850) webserver: HTTP GET / >>>>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>>>> >>>>>>> >>>>>>> Can’t get out of that 2.test.connect. >>>>>>> >>>>>>> Any ideas? >>>>>>> >>>>>>> Regards, Mark. >>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> >>>>>> -- >>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> -- >>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Here are my screenshots, in case someone wants to have a look without actually running the wizard. https://drive.google.com/open?id=1MWnKPk78fZHOJfrXiCwe6-2EBltnI01T Regards, Michael Am 13.05.2018 um 18:25 schrieb Michael Balzer:
Regards, Michael
Pushed.
Please try again.
Regards, Michael
Regards, Michael
Definitely something timing related. Even with auto wifi.mode=client, the wifi client comes up on boot, but v2 server can’t connect on first try (but second try works).
This is what I get:
But, if I config set network dns ‘8.8.8.8 1.1.1.1’, I get:
I’m guessing this new ‘stored dns’ is the root of the problem, but really not sure what is going on. The delay is long enough to allow your test to timeout.
Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson: >> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >> commit a few days before. >> >> CONFIG_LWIP_SO_REUSE=y >> CONFIG_LWIP_SO_REUSE_RXTOALL=y > > Just double-checked, and yes they are there. > > It seems that after connecting to SSID, the attempt to run ‘Ota status’ is immediate, but the wifi client hasn’t settled down yet. I’ve looked in > web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect”)’, it just seems to try to MyOTA.GetStatus as soon as > the ssid matches? But it doesn’t check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is > connected, and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I’m missing something?
Regards, Michael
> Regards, Mark > >> On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> >> Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson: >>> >>> Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event >>> delivery queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task? >> >> Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my >> tests… >> >>> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my >>> iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks. >> >> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >> commit a few days before. >> >> CONFIG_LWIP_SO_REUSE=y >> CONFIG_LWIP_SO_REUSE_RXTOALL=y >> >> If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT. >> >> The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is >> fast enough to keep them on the AP. >> >> Regards, >> Michael >> >> >>> I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode >>> (which is what I did with my alternative approach before). >>> >>> Regards, Mark. >>> >>>> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>> >>>> Added another fix. >>>> >>>> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I >>>> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the >>>> javascript code in that case. >>>> >>>> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 >>>> seconds. >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 11.05.2018 um 18:19 schrieb Michael Balzer: >>>>> OK. I really should wait for config.mounted before reading from MyConfig. >>>>> >>>>> Fix is pushed, please try. >>>>> >>>>> >>>>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>>>>> I tried a restart. Here is what I get: >>>>>> >>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>>>>> >>>>>> I (1465) webserver: Launching Web Server >>>>>> I (1465) ssh: Launching SSH Server >>>>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>>>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>>>>> I (4945) wifi: state: init -> auth (b0) >>>>>> I (4945) wifi: state: auth -> assoc (0) >>>>>> I (4955) wifi: state: assoc -> run (10) >>>>>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>>>>> I (5375) sdcard: SD CARD has been inserted >>>>>> I (5465) sdcard: mount done >>>>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>>>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>>>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>>>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>>>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>>>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>>>>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>>>>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>>>>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>>>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>>>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>> I (9455) time: Starting SNTP client >>>>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>>>>> I (13565) webserver: HTTP GET / >>>>>> I (13575) webserver: HTTP GET /cfg/init >>>>>> I (14825) webserver: HTTP GET / >>>>>> I (15135) webserver: HTTP GET /cfg/init >>>>>> I (15375) simcom: State timeout, transition to 13 >>>>>> I (15375) simcom: State: Enter PoweredOff state >>>>>> I (15375) gsm-mux: Stop MUX >>>>>> I (16695) webserver: HTTP GET / >>>>>> I (16705) webserver: HTTP GET /cfg/init >>>>>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (16905) webserver: HTTP GET /assets/style.css >>>>>> I (16905) webserver: HTTP GET /assets/script.js >>>>>> I (17345) webserver: HTTP GET /cfg/init >>>>>> I (28045) webserver: HTTP POST /cfg/init >>>>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>>>>> I (28085) webserver: HTTP GET /cfg/init >>>>>> I (28085) webserver: CfgInit enter 2.test.connect >>>>>> I (28085) webserver: HTTP GET /menu >>>>>> I (40025) webserver: HTTP GET / >>>>>> I (40035) webserver: HTTP GET /cfg/init >>>>>> I (40035) webserver: CfgInit enter 2.test.connect >>>>>> I (40045) webserver: HTTP GET / >>>>>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (40085) webserver: HTTP GET /assets/style.css >>>>>> I (40185) webserver: HTTP GET /assets/script.js >>>>>> I (40355) webserver: HTTP GET /cfg/init >>>>>> I (40355) webserver: CfgInit enter 2.test.connect >>>>>> OVMS> enable >>>>>> Password: >>>>>> Secure mode >>>>>> >>>>>> I (50425) webserver: HTTP GET / >>>>>> I (50425) webserver: HTTP GET /cfg/init >>>>>> I (50425) webserver: CfgInit enter 2.test.connect >>>>>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (50475) webserver: HTTP GET /assets/style.css >>>>>> I (50555) webserver: HTTP GET /assets/script.js >>>>>> I (50675) webserver: HTTP GET /cfg/init >>>>>> I (50675) webserver: CfgInit enter 2.test.connect >>>>>> OVMS# ota status >>>>>> Running partition: ota_0 >>>>>> Boot partition: ota_0 >>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>> Server Available: 3.1.005 >>>>>> >>>>>> OTA release providing minor improvements and fixes. >>>>>> >>>>>> - Vehicle: 12V battery monitoring >>>>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>>>>> - OTA: automatic daily firmware updates (wifi only) >>>>>> auto [ota] = yes Enable/disable >>>>>> ota [auto.hour] = 2 Hour for daily check >>>>>> - Logging: persistent configuration, file cycling, web config UI: >>>>>> log [file.enable] = no Enable/disable file logging >>>>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>>>>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>>>>> log [level] Default level >>>>>> log [level.<tag>] Component levels >>>>>> - Reverse Engineering Tools enhancements >>>>>> - Tesla Roadster CAC support >>>>>> - Miscellaneous bug fixes and enhancements >>>>>> >>>>>> I (61705) webserver: HTTP GET / >>>>>> I (61715) webserver: HTTP GET /cfg/init >>>>>> I (61715) webserver: CfgInit enter 2.test.connect >>>>>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (61755) webserver: HTTP GET /assets/style.css >>>>>> I (61845) webserver: HTTP GET /assets/script.js >>>>>> I (61965) webserver: HTTP GET /cfg/init >>>>>> I (61965) webserver: CfgInit enter 2.test.connect >>>>>> I (72035) webserver: HTTP GET / >>>>>> I (72045) webserver: HTTP GET /cfg/init >>>>>> I (72045) webserver: CfgInit enter 2.test.connect >>>>>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (72095) webserver: HTTP GET /assets/style.css >>>>>> I (72175) webserver: HTTP GET /assets/script.js >>>>>> I (73485) webserver: HTTP GET /cfg/init >>>>>> I (73495) webserver: CfgInit enter 2.test.connect >>>>>> >>>>>> OVMS# config list auto >>>>>> auto (readable writeable) >>>>>> wifi.mode: apclient >>>>>> wifi.ssid.ap: DEVBENCH >>>>>> wifi.ssid.client: HIGHWAYS >>>>>> >>>>>> OVMS# config list module >>>>>> module (readable writeable) >>>>>> init: 2.test.connect >>>>>> >>>>>> >>>>>> Regards, Mark >>>>>> >>>>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>>>> >>>>>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>>>>> >>>>>>> Is the auto config correct and matching the "HIGHWAY" network? >>>>>>> >>>>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>>>>> >>>>>>> >>>>>>> >>>>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>>>>> Trying the new web setup, but not getting very far… >>>>>>>> >>>>>>>> I (503580) webserver: HTTP GET / >>>>>>>> I (503590) webserver: HTTP GET /cfg/init >>>>>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>>>>> I (503880) webserver: HTTP GET /cfg/init >>>>>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>>>>> I (513960) webserver: HTTP GET /cfg/init >>>>>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>>>>> I (513960) webserver: HTTP GET / >>>>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>>>>> I (514220) webserver: HTTP GET /cfg/init >>>>>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>>>>> I (524280) webserver: HTTP GET / >>>>>>>> I (524290) webserver: HTTP GET /cfg/init >>>>>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>>>>> I (524590) webserver: HTTP GET /cfg/init >>>>>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>>>>> I (534620) webserver: HTTP GET / >>>>>>>> I (534630) webserver: HTTP GET /cfg/init >>>>>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>>>>> I (534890) webserver: HTTP GET /cfg/init >>>>>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>>>>> I (544940) webserver: HTTP GET / >>>>>>>> I (544950) webserver: HTTP GET /cfg/init >>>>>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>>>>> I (545250) webserver: HTTP GET /cfg/init >>>>>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>>>>> >>>>>>>> OVMS# wifi status >>>>>>>> WiFi >>>>>>>> Power: on >>>>>>>> Mode: Access-Point + Client mode >>>>>>>> >>>>>>>> STA SSID: HIGHWAYS >>>>>>>> MAC: 30:ae:a4:43:92:c4 >>>>>>>> IP: 10.10.41.203/255.255.248.0 >>>>>>>> GW: 10.10.40.64 >>>>>>>> >>>>>>>> AP SSID: DEVBENCH >>>>>>>> MAC: 30:ae:a4:43:92:c5 >>>>>>>> IP: 192.168.4.1 >>>>>>>> AP Stations: 1 >>>>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>>>>> >>>>>>>> OVMS# ota status >>>>>>>> Running partition: ota_0 >>>>>>>> Boot partition: ota_0 >>>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>>>> Server Available: 3.1.005 >>>>>>>> >>>>>>>> … >>>>>>>> >>>>>>>> I (1141850) webserver: HTTP GET / >>>>>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>>>>> >>>>>>>> >>>>>>>> Can’t get out of that 2.test.connect. >>>>>>>> >>>>>>>> Any ideas? >>>>>>>> >>>>>>>> Regards, Mark. >>>>>>>> >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OvmsDev mailing list >>>>>>>> OvmsDev@lists.openvehicles.com >>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>> >>>>>>> -- >>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> -- >>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> -- >>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
This setup wizard is very impressive considering where we were with the v1 and v2 modules. This is like a real product! :-) Here are a few comments: Step 1: I would say "e.g. your vehicle license plate number" rather than "i.e.". I understand these to translate to English as "such as" versus "that is,". The vehicle license plate number is just one way to choose the ID. I followed the suggestion in the v2 documentation to use "US" plus my USA VIN number. Also, underscore '_' is allowed (gregd mentioned he's using that). Step 2: Might the phrase "unrestricted internet access" cause the user to incorrectly think an open Wifi network is required? Granted, the next line asks for the Wifi password, but perhaps "unrestricted" is not really necessary. What happens now?: This screen suggests that the latest firmware will be fetched while the user is waiting on this page, but that won't happen, right? Step 3 will come up to select the update server. Also, since we are now talking about two Wifi networks, I suggest to be more explicit; change "The access point remains unchanged" to something like "The OVMS Wifi access point will continue serving network Test1". Step 3: What will happen if the user follows "Alternatively, you may simply unplug the module and start again."? Will the module automatically try to update when it boots up? Step 4: If the setup steps have been followed normally, on't we know the vehicle ID already at this point? It is the AP SSID. It could be shown as the default when left empty. -- Steve On Sun, 13 May 2018, Michael Balzer wrote:
Regards, Michael
Steve, Am 13.05.2018 um 20:32 schrieb Stephen Casner:
You're right, I've changed that to "e.g.". We agreed on not allowing the "_" as the ID is also used for the mDNS hostname.
I've changed that to "Please enter a Wifi network that provides access to the internet".
Right, I changed the text to "… then tries to contact the OpenVehicles server to check the internet access".
Done.
No, it will return to the form, so you can choose another server or skip the step as necessary. I've extended the text to: "<p><strong>Don't panic</strong> if something goes wrong and the module gets stuck in the update.</p>" "<p>You can simply unplug and restart the module, it will show the update form again so you can choose to" " retry, try another server or skip the update.</p>"
It does so, I just erased the field for the screenshot. Thanks for the review! Regards, Michael
Regards, Michael
OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi Michael, A couple of comments on the setup screens: 1. Step 1/5. The Module ID suggestion to use the vehicle's license plate number may be a bit intimidating to some. You use "i.e." where I think you mean "e.g.". "I.e." is usually considered to be "in other words", as a clarification of a requirement, not a suggestion. I would suggest changing the first sentence text to be "Enter a unique personal module/vehicle ID, e.g. vehicle brand or nickname + last 5 digits of VIN, or other unique string (max xx characters)." (Please fill in the max length - 20 characters, I think?) Did we decide that the Module ID can include lower case characters? 2. If the vehicle ID is used for the Wifi AP name, there should be an additional warning that it will be visible to others within wifi range. I think this use of the AP name is probably a bad idea, from a security perspective. I don't want to draw attention to my car via WiFi beacons! This really should be a user-entered field; perhaps default of "OVMS" + 4 digit random value if you are worried about collisions. 3. Overall, the help text explaining each step of the process is very helpful and well written! Nicely done. Greg Michael Balzer wrote:
Regards, Michael
Greg, Am 13.05.2018 um 22:04 schrieb Greg D.:
Hi Michael,
I've added the nickname suggestion, the VIN isn't something a normal user will know. And yes on the lower case characters.
I labeled it module ID because it's primary use is for the module wifi AP. You can enter a different vehicle ID in step 4. Both are user-entered fields. Regarding the visibility of the AP, that's the way an AP is meant to be. There is no special security issue arising from that (other than running an AP), and there is no security benefit from hiding the AP. If users are concerned about running an AP, they can choose to disable the AP mode after finishing the wizard.
Thanks, and thanks for the review! Regards, Michael
Greg
Regards, Michael
It's hard to see how running on a 3.0 module would affect the stack usage unless some configuration difference caused an activity into the events task that would otherwise have been in a different task. If you're right on the hairy edge, perhaps the timing of an interrupt could be the difference between crash or not, but I think the interrupts switch to a separate stack. If there is some conditional activity that can be invoked either from a higher level function or from a lower level function, then timing of that condition might affect stack usage. -- Steve On Sun, 13 May 2018, Michael Balzer wrote:
Regards, Michael
Pushed.
Please try again.
Regards, Michael
With the Google/Cloudflare DNS you can finish the setup?
I was hoping we could omit the DNS question now from the setup, as users likely don't know what that is.
I'll add it to step 2 for now, but with a fixed & labeled selection.
Am 13.05.2018 um 16:36 schrieb Michael Balzer:
My boot without a fixed DNS looks like yours with a fixed one:
I (5066) event: sta ip: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (5066) netmanager: Interface priority is st1 (192.168.2.109/255.255.255.0 gateway 192.168.2.1) I (5076) netmanager: Set DNS#0 192.168.2.1 I (5076) netmanager: Set DNS#1 192.168.2.1 I (5076) netmanager: Set DNS#2 0.0.0.0 I (5076) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (5076) esp32wifi: STA got IP with SSID: WLAN-214677, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1 I (5076) time: Starting SNTP client I (5076) ovms-server-v2: Status: Network is up, so attempt network connection I (6286) ovms-server-v2: Connection is ovms.dexters-web.de:6867 Test1 I (6286) ovms-server-v2: Status: Connecting... I (6516) ovms-server-v2: Connection successful I (6516) ovms-server-v2: Status: Logging in...
Is your DNS in the router or behind? The IP and masking looks like it's on another net. If it's on another net, is it possible the first query after the wifi connect is blocked or fails due to some firewall delay?
Regards, Michael
Am 13.05.2018 um 16:07 schrieb Mark Webb-Johnson:
Definitely something timing related. Even with auto wifi.mode=client, the wifi client comes up on boot, but v2 server can't connect on first try (but second try works).
This is what I get:
I (7316) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7326) netmanager: Set DNS#0 10.10.40.64 I (7326) netmanager: Set DNS#1 0.0.0.0 I (7326) netmanager: Set DNS#2 0.0.0.0 I (7326) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7326) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7326) time: Starting SNTP client I (7326) ovms-server-v2: Status: Network is up, so attempt network connection I (7336) webserver: Launching Web Server I (7376) ssh: Launching SSH Server I (7386) ovms-server-v2: Status: Network is up, so attempt network connection I (8396) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH I (8396) ovms-server-v2: Status: Connecting... I (10396) housekeeping: System considered stable (RAM: 8b=94792-95652 32b=23608) W (25696) ovms-server-v2: Connection failed E (25696) ovms-server-v2: Status: Error: Connection failed I (25696) ovms-server-v2: Status: Disconnected
But, if I config set network dns '8.8.8.8 1.1.1.1', I get:
I (7087) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7097) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) I (7097) netmanager: Set DNS#0 8.8.8.8 I (7097) netmanager: Set DNS#1 1.1.1.1 I (7107) netmanager: WIFI client up (with MODEM down): starting network with WIFI client I (7107) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 I (7107) time: Starting SNTP client I (7107) ovms-server-v2: Status: Network is up, so attempt network connection I (7117) webserver: Launching Web Server I (7137) ssh: Launching SSH Server I (7157) ovms-server-v2: Status: Network is up, so attempt network connection I (8387) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH I (8387) ovms-server-v2: Status: Connecting... I (8617) ovms-server-v2: Connection successful I (8617) ovms-server-v2: Status: Logging in...
I'm guessing this new 'stored dns' is the root of the problem, but really not sure what is going on. The delay is long enough to allow your test to timeout.
On 13 May 2018, at 2:18 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson: >> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >> commit a few days before. >> >> CONFIG_LWIP_SO_REUSE=y >> CONFIG_LWIP_SO_REUSE_RXTOALL=y > > Just double-checked, and yes they are there. > > It seems that after connecting to SSID, the attempt to run 'Ota status' is immediate, but the wifi client hasn't settled down yet. I've looked in > web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect")', it just seems to try to MyOTA.GetStatus as soon as the > ssid matches? But it doesn't check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is connected, > and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I'm missing something?
The state ticker does not check yet if it can abort a scheduled timeout. So it doesn't do the test as soon as GetSSID() returns the network.
The test is done fixed 20 seconds after StartAccessPointClientMode(). That is normally plenty of time for everything to settle. In my runs, the client network was normally fully functional in ~10 seconds.
How long does your APClient switch take? You can try raising the 20 second timeout in line 226.
Regards, Michael
> Regards, Mark > >> On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >> >> >> Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson: >>> >>> Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event >>> delivery queue was full so ticker.1 messages couldn't be delivered). I guess it is doing the wifi connectivity test in the main event task? >> >> Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my tests... >> >>> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn't seem to work properly, so I lose connection to the station. Also, my >>> iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks. >> >> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >> commit a few days before. >> >> CONFIG_LWIP_SO_REUSE=y >> CONFIG_LWIP_SO_REUSE_RXTOALL=y >> >> If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT. >> >> The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is >> fast enough to keep them on the AP. >> >> Regards, >> Michael >> >> >>> I'll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode >>> (which is what I did with my alternative approach before). >>> >>> Regards, Mark. >>> >>>> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>> >>>> Added another fix. >>>> >>>> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I >>>> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the >>>> javascript code in that case. >>>> >>>> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 >>>> seconds. >>>> >>>> Regards, >>>> Michael >>>> >>>> >>>> Am 11.05.2018 um 18:19 schrieb Michael Balzer: >>>>> OK. I really should wait for config.mounted before reading from MyConfig. >>>>> >>>>> Fix is pushed, please try. >>>>> >>>>> >>>>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>>>>> I tried a restart. Here is what I get: >>>>>> >>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>>>>> >>>>>> I (1465) webserver: Launching Web Server >>>>>> I (1465) ssh: Launching SSH Server >>>>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>>>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>>>>> I (4945) wifi: state: init -> auth (b0) >>>>>> I (4945) wifi: state: auth -> assoc (0) >>>>>> I (4955) wifi: state: assoc -> run (10) >>>>>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>>>>> I (5375) sdcard: SD CARD has been inserted >>>>>> I (5465) sdcard: mount done >>>>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>>>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>>>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>>>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>>>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>>>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>>>>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>>>>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>>>>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>>>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>>>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>> I (9455) time: Starting SNTP client >>>>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>>>>> I (13565) webserver: HTTP GET / >>>>>> I (13575) webserver: HTTP GET /cfg/init >>>>>> I (14825) webserver: HTTP GET / >>>>>> I (15135) webserver: HTTP GET /cfg/init >>>>>> I (15375) simcom: State timeout, transition to 13 >>>>>> I (15375) simcom: State: Enter PoweredOff state >>>>>> I (15375) gsm-mux: Stop MUX >>>>>> I (16695) webserver: HTTP GET / >>>>>> I (16705) webserver: HTTP GET /cfg/init >>>>>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (16905) webserver: HTTP GET /assets/style.css >>>>>> I (16905) webserver: HTTP GET /assets/script.js >>>>>> I (17345) webserver: HTTP GET /cfg/init >>>>>> I (28045) webserver: HTTP POST /cfg/init >>>>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>>>>> I (28085) webserver: HTTP GET /cfg/init >>>>>> I (28085) webserver: CfgInit enter 2.test.connect >>>>>> I (28085) webserver: HTTP GET /menu >>>>>> I (40025) webserver: HTTP GET / >>>>>> I (40035) webserver: HTTP GET /cfg/init >>>>>> I (40035) webserver: CfgInit enter 2.test.connect >>>>>> I (40045) webserver: HTTP GET / >>>>>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (40085) webserver: HTTP GET /assets/style.css >>>>>> I (40185) webserver: HTTP GET /assets/script.js >>>>>> I (40355) webserver: HTTP GET /cfg/init >>>>>> I (40355) webserver: CfgInit enter 2.test.connect >>>>>> OVMS> enable >>>>>> Password: >>>>>> Secure mode >>>>>> >>>>>> I (50425) webserver: HTTP GET / >>>>>> I (50425) webserver: HTTP GET /cfg/init >>>>>> I (50425) webserver: CfgInit enter 2.test.connect >>>>>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (50475) webserver: HTTP GET /assets/style.css >>>>>> I (50555) webserver: HTTP GET /assets/script.js >>>>>> I (50675) webserver: HTTP GET /cfg/init >>>>>> I (50675) webserver: CfgInit enter 2.test.connect >>>>>> OVMS# ota status >>>>>> Running partition: ota_0 >>>>>> Boot partition: ota_0 >>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>> Server Available: 3.1.005 >>>>>> >>>>>> OTA release providing minor improvements and fixes. >>>>>> >>>>>> - Vehicle: 12V battery monitoring >>>>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>>>>> - OTA: automatic daily firmware updates (wifi only) >>>>>> auto [ota] = yes Enable/disable >>>>>> ota [auto.hour] = 2 Hour for daily check >>>>>> - Logging: persistent configuration, file cycling, web config UI: >>>>>> log [file.enable] = no Enable/disable file logging >>>>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>>>>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>>>>> log [level] Default level >>>>>> log [level.<tag>] Component levels >>>>>> - Reverse Engineering Tools enhancements >>>>>> - Tesla Roadster CAC support >>>>>> - Miscellaneous bug fixes and enhancements >>>>>> >>>>>> I (61705) webserver: HTTP GET / >>>>>> I (61715) webserver: HTTP GET /cfg/init >>>>>> I (61715) webserver: CfgInit enter 2.test.connect >>>>>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (61755) webserver: HTTP GET /assets/style.css >>>>>> I (61845) webserver: HTTP GET /assets/script.js >>>>>> I (61965) webserver: HTTP GET /cfg/init >>>>>> I (61965) webserver: CfgInit enter 2.test.connect >>>>>> I (72035) webserver: HTTP GET / >>>>>> I (72045) webserver: HTTP GET /cfg/init >>>>>> I (72045) webserver: CfgInit enter 2.test.connect >>>>>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>>>>> I (72095) webserver: HTTP GET /assets/style.css >>>>>> I (72175) webserver: HTTP GET /assets/script.js >>>>>> I (73485) webserver: HTTP GET /cfg/init >>>>>> I (73495) webserver: CfgInit enter 2.test.connect >>>>>> >>>>>> OVMS# config list auto >>>>>> auto (readable writeable) >>>>>> wifi.mode: apclient >>>>>> wifi.ssid.ap: DEVBENCH >>>>>> wifi.ssid.client: HIGHWAYS >>>>>> >>>>>> OVMS# config list module >>>>>> module (readable writeable) >>>>>> init: 2.test.connect >>>>>> >>>>>> >>>>>> Regards, Mark >>>>>> >>>>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>>>> >>>>>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>>>>> >>>>>>> Is the auto config correct and matching the "HIGHWAY" network? >>>>>>> >>>>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>>>>> >>>>>>> >>>>>>> >>>>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>>>>> Trying the new web setup, but not getting very far... >>>>>>>> >>>>>>>> I (503580) webserver: HTTP GET / >>>>>>>> I (503590) webserver: HTTP GET /cfg/init >>>>>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>>>>> I (503880) webserver: HTTP GET /cfg/init >>>>>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>>>>> I (513960) webserver: HTTP GET /cfg/init >>>>>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>>>>> I (513960) webserver: HTTP GET / >>>>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>>>>> I (514220) webserver: HTTP GET /cfg/init >>>>>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>>>>> I (524280) webserver: HTTP GET / >>>>>>>> I (524290) webserver: HTTP GET /cfg/init >>>>>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>>>>> I (524590) webserver: HTTP GET /cfg/init >>>>>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>>>>> I (534620) webserver: HTTP GET / >>>>>>>> I (534630) webserver: HTTP GET /cfg/init >>>>>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>>>>> I (534890) webserver: HTTP GET /cfg/init >>>>>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>>>>> I (544940) webserver: HTTP GET / >>>>>>>> I (544950) webserver: HTTP GET /cfg/init >>>>>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>>>>> I (545250) webserver: HTTP GET /cfg/init >>>>>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>>>>> >>>>>>>> OVMS# wifi status >>>>>>>> WiFi >>>>>>>> Power: on >>>>>>>> Mode: Access-Point + Client mode >>>>>>>> >>>>>>>> STA SSID: HIGHWAYS >>>>>>>> MAC: 30:ae:a4:43:92:c4 >>>>>>>> IP: 10.10.41.203/255.255.248.0 >>>>>>>> GW: 10.10.40.64 >>>>>>>> >>>>>>>> AP SSID: DEVBENCH >>>>>>>> MAC: 30:ae:a4:43:92:c5 >>>>>>>> IP: 192.168.4.1 >>>>>>>> AP Stations: 1 >>>>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>>>>> >>>>>>>> OVMS# ota status >>>>>>>> Running partition: ota_0 >>>>>>>> Boot partition: ota_0 >>>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>>>> Server Available: 3.1.005 >>>>>>>> >>>>>>>> ... >>>>>>>> >>>>>>>> I (1141850) webserver: HTTP GET / >>>>>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>>>>> >>>>>>>> >>>>>>>> Can't get out of that 2.test.connect. >>>>>>>> >>>>>>>> Any ideas? >>>>>>>> >>>>>>>> Regards, Mark. >>>>>>>> >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OvmsDev mailing list >>>>>>>> OvmsDev@lists.openvehicles.com >>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>> >>>>>>> -- >>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> >>>>> -- >>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>> >>>>> >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> -- >>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> -- >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I also doubt it's related to the hardware version, and as the crash was consistent during the run and over two reboots I also don't think it's an interrupt timing issue. The crash occured on starting server v2 from the events task: I (5287) webserver: CfgInitTicker: step 4: start server v2 for host 'ovms.***ERROR*** A stack overflow in task OVMS Events has been detected. abort() was called at PC 0x4009045c on core 1 0x4009045c: vApplicationStackOverflowHook at /home/balzer/esp/esp-idf/components/esp32/panic.c:669 Backtrace: 0x4009026c:0x3ffbe030 0x40090443:0x3ffbe050 0x4009045c:0x3ffbe070 0x4008cd54:0x3ffbe090 0x4008e734:0x3ffbe0b0 0x4008e6ea:0x01010101 0x4009026c: invoke_abort at /home/balzer/esp/esp-idf/components/esp32/panic.c:669 0x40090443: abort at /home/balzer/esp/esp-idf/components/esp32/panic.c:669 0x4009045c: vApplicationStackOverflowHook at /home/balzer/esp/esp-idf/components/esp32/panic.c:669 0x4008cd54: vTaskSwitchContext at /home/balzer/esp/esp-idf/components/freertos/tasks.c:4840 0x4008e734: _frxt_dispatch at /home/balzer/esp/esp-idf/components/freertos/portasm.S:406 0x4008e6ea: _frxt_int_exit at /home/balzer/esp/esp-idf/components/freertos/portasm.S:206 Rebooting... With 8K stack, the crash disappeared. Maybe we can reduce the stack usage of the server v2 start or move the start to another context, but I think we can afford the extra 1K for the events task. Regards, Michael Am 13.05.2018 um 19:21 schrieb Stephen Casner:
Regards, Michael
Pushed.
Strangely enough, during my tests I once had the same effect as you, but with the Cloudflare DNS.
I couldn't reproduce it though.
Please try again.
I also captured screenshots of the process for the user guide -- is that necessary? I took care to add a lot of info to the process itself.
Regards, Michael
Am 13.05.2018 um 16:44 schrieb Michael Balzer:
Regards, Michael
This is what I get:
> On 13 May 2018, at 2:18 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: > > > Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson: >>> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >>> commit a few days before. >>> >>> CONFIG_LWIP_SO_REUSE=y >>> CONFIG_LWIP_SO_REUSE_RXTOALL=y >> Just double-checked, and yes they are there. >> >> It seems that after connecting to SSID, the attempt to run 'Ota status' is immediate, but the wifi client hasn't settled down yet. I've looked in >> web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect")', it just seems to try to MyOTA.GetStatus as soon as the >> ssid matches? But it doesn't check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is connected, >> and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I'm missing something? > The state ticker does not check yet if it can abort a scheduled timeout. So it doesn't do the test as soon as GetSSID() returns the network. > > The test is done fixed 20 seconds after StartAccessPointClientMode(). That is normally plenty of time for everything to settle. In my runs, the client > network was normally fully functional in ~10 seconds. > > How long does your APClient switch take? You can try raising the 20 second timeout in line 226. > > Regards, > Michael > > >> Regards, Mark >> >>> On 12 May 2018, at 11:14 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>> >>> >>> Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson: >>>> Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event >>>> delivery queue was full so ticker.1 messages couldn't be delivered). I guess it is doing the wifi connectivity test in the main event task? >>> Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my tests... >>> >>>> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn't seem to work properly, so I lose connection to the station. Also, my >>>> iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks. >>> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some >>> commit a few days before. >>> >>> CONFIG_LWIP_SO_REUSE=y >>> CONFIG_LWIP_SO_REUSE_RXTOALL=y >>> >>> If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT. >>> >>> The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is >>> fast enough to keep them on the AP. >>> >>> Regards, >>> Michael >>> >>> >>>> I'll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode >>>> (which is what I did with my alternative approach before). >>>> >>>> Regards, Mark. >>>> >>>>> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>> >>>>> Added another fix. >>>>> >>>>> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I >>>>> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the >>>>> javascript code in that case. >>>>> >>>>> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5 >>>>> seconds. >>>>> >>>>> Regards, >>>>> Michael >>>>> >>>>> >>>>> Am 11.05.2018 um 18:19 schrieb Michael Balzer: >>>>>> OK. I really should wait for config.mounted before reading from MyConfig. >>>>>> >>>>>> Fix is pushed, please try. >>>>>> >>>>>> >>>>>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson: >>>>>>> I tried a restart. Here is what I get: >>>>>>> >>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main >>>>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 >>>>>>> >>>>>>> I (1465) webserver: Launching Web Server >>>>>>> I (1465) ssh: Launching SSH Server >>>>>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2 >>>>>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1 >>>>>>> I (4945) wifi: state: init -> auth (b0) >>>>>>> I (4945) wifi: state: auth -> assoc (0) >>>>>>> I (4955) wifi: state: assoc -> run (10) >>>>>>> I (5055) wifi: connected with HIGHWAYS, channel 6 >>>>>>> I (5375) sdcard: SD CARD has been inserted >>>>>>> I (5465) sdcard: mount done >>>>>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it. >>>>>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it. >>>>>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6 >>>>>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20 >>>>>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4 >>>>>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64) >>>>>>> I (9455) netmanager: Set DNS#0 10.10.40.64 >>>>>>> I (9455) netmanager: Set DNS#1 0.0.0.0 >>>>>>> I (9455) netmanager: Set DNS#2 0.0.0.0 >>>>>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client >>>>>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64 >>>>>>> I (9455) time: Starting SNTP client >>>>>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608) >>>>>>> I (13565) webserver: HTTP GET / >>>>>>> I (13575) webserver: HTTP GET /cfg/init >>>>>>> I (14825) webserver: HTTP GET / >>>>>>> I (15135) webserver: HTTP GET /cfg/init >>>>>>> I (15375) simcom: State timeout, transition to 13 >>>>>>> I (15375) simcom: State: Enter PoweredOff state >>>>>>> I (15375) gsm-mux: Stop MUX >>>>>>> I (16695) webserver: HTTP GET / >>>>>>> I (16705) webserver: HTTP GET /cfg/init >>>>>>> I (16735) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (16905) webserver: HTTP GET /assets/style.css >>>>>>> I (16905) webserver: HTTP GET /assets/script.js >>>>>>> I (17345) webserver: HTTP GET /cfg/init >>>>>>> I (28045) webserver: HTTP POST /cfg/init >>>>>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574 >>>>>>> I (28085) webserver: HTTP GET /cfg/init >>>>>>> I (28085) webserver: CfgInit enter 2.test.connect >>>>>>> I (28085) webserver: HTTP GET /menu >>>>>>> I (40025) webserver: HTTP GET / >>>>>>> I (40035) webserver: HTTP GET /cfg/init >>>>>>> I (40035) webserver: CfgInit enter 2.test.connect >>>>>>> I (40045) webserver: HTTP GET / >>>>>>> I (40075) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (40085) webserver: HTTP GET /assets/style.css >>>>>>> I (40185) webserver: HTTP GET /assets/script.js >>>>>>> I (40355) webserver: HTTP GET /cfg/init >>>>>>> I (40355) webserver: CfgInit enter 2.test.connect >>>>>>> OVMS> enable >>>>>>> Password: >>>>>>> Secure mode >>>>>>> >>>>>>> I (50425) webserver: HTTP GET / >>>>>>> I (50425) webserver: HTTP GET /cfg/init >>>>>>> I (50425) webserver: CfgInit enter 2.test.connect >>>>>>> I (50465) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (50475) webserver: HTTP GET /assets/style.css >>>>>>> I (50555) webserver: HTTP GET /assets/script.js >>>>>>> I (50675) webserver: HTTP GET /cfg/init >>>>>>> I (50675) webserver: CfgInit enter 2.test.connect >>>>>>> OVMS# ota status >>>>>>> Running partition: ota_0 >>>>>>> Boot partition: ota_0 >>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>>> Server Available: 3.1.005 >>>>>>> >>>>>>> OTA release providing minor improvements and fixes. >>>>>>> >>>>>>> - Vehicle: 12V battery monitoring >>>>>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference >>>>>>> - OTA: automatic daily firmware updates (wifi only) >>>>>>> auto [ota] = yes Enable/disable >>>>>>> ota [auto.hour] = 2 Hour for daily check >>>>>>> - Logging: persistent configuration, file cycling, web config UI: >>>>>>> log [file.enable] = no Enable/disable file logging >>>>>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling >>>>>>> log [file.path] = "" Log path, if on /sd watches sd.mounted >>>>>>> log [level] Default level >>>>>>> log [level.<tag>] Component levels >>>>>>> - Reverse Engineering Tools enhancements >>>>>>> - Tesla Roadster CAC support >>>>>>> - Miscellaneous bug fixes and enhancements >>>>>>> >>>>>>> I (61705) webserver: HTTP GET / >>>>>>> I (61715) webserver: HTTP GET /cfg/init >>>>>>> I (61715) webserver: CfgInit enter 2.test.connect >>>>>>> I (61745) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (61755) webserver: HTTP GET /assets/style.css >>>>>>> I (61845) webserver: HTTP GET /assets/script.js >>>>>>> I (61965) webserver: HTTP GET /cfg/init >>>>>>> I (61965) webserver: CfgInit enter 2.test.connect >>>>>>> I (72035) webserver: HTTP GET / >>>>>>> I (72045) webserver: HTTP GET /cfg/init >>>>>>> I (72045) webserver: CfgInit enter 2.test.connect >>>>>>> I (72085) webserver: HTTP GET /apple-touch-icon.png >>>>>>> I (72095) webserver: HTTP GET /assets/style.css >>>>>>> I (72175) webserver: HTTP GET /assets/script.js >>>>>>> I (73485) webserver: HTTP GET /cfg/init >>>>>>> I (73495) webserver: CfgInit enter 2.test.connect >>>>>>> >>>>>>> OVMS# config list auto >>>>>>> auto (readable writeable) >>>>>>> wifi.mode: apclient >>>>>>> wifi.ssid.ap: DEVBENCH >>>>>>> wifi.ssid.client: HIGHWAYS >>>>>>> >>>>>>> OVMS# config list module >>>>>>> module (readable writeable) >>>>>>> init: 2.test.connect >>>>>>> >>>>>>> >>>>>>> Regards, Mark >>>>>>> >>>>>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote: >>>>>>>> >>>>>>>> Do you have the earlier log, especially of the CfgInit ticker messages? >>>>>>>> >>>>>>>> Is the auto config correct and matching the "HIGHWAY" network? >>>>>>>> >>>>>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed. >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson: >>>>>>>>> Trying the new web setup, but not getting very far... >>>>>>>>> >>>>>>>>> I (503580) webserver: HTTP GET / >>>>>>>>> I (503590) webserver: HTTP GET /cfg/init >>>>>>>>> I (503590) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (503610) webserver: HTTP GET /assets/style.css >>>>>>>>> I (503730) webserver: HTTP GET /assets/script.js >>>>>>>>> I (503880) webserver: HTTP GET /cfg/init >>>>>>>>> I (503880) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (513960) webserver: HTTP GET /cfg/init >>>>>>>>> I (513960) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (513960) webserver: HTTP GET / >>>>>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (514000) webserver: HTTP GET /assets/style.css >>>>>>>>> I (514090) webserver: HTTP GET /assets/script.js >>>>>>>>> I (514220) webserver: HTTP GET /cfg/init >>>>>>>>> I (514220) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (524280) webserver: HTTP GET / >>>>>>>>> I (524290) webserver: HTTP GET /cfg/init >>>>>>>>> I (524290) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (524340) webserver: HTTP GET /assets/style.css >>>>>>>>> I (524420) webserver: HTTP GET /assets/script.js >>>>>>>>> I (524590) webserver: HTTP GET /cfg/init >>>>>>>>> I (524590) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (534620) webserver: HTTP GET / >>>>>>>>> I (534630) webserver: HTTP GET /cfg/init >>>>>>>>> I (534630) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (534660) webserver: HTTP GET /assets/style.css >>>>>>>>> I (534760) webserver: HTTP GET /assets/script.js >>>>>>>>> I (534890) webserver: HTTP GET /cfg/init >>>>>>>>> I (534890) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (544940) webserver: HTTP GET / >>>>>>>>> I (544950) webserver: HTTP GET /cfg/init >>>>>>>>> I (544950) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (544980) webserver: HTTP GET /assets/style.css >>>>>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (545080) webserver: HTTP GET /assets/script.js >>>>>>>>> I (545250) webserver: HTTP GET /cfg/init >>>>>>>>> I (545250) webserver: CfgInit enter 2.test.connect >>>>>>>>> >>>>>>>>> OVMS# wifi status >>>>>>>>> WiFi >>>>>>>>> Power: on >>>>>>>>> Mode: Access-Point + Client mode >>>>>>>>> >>>>>>>>> STA SSID: HIGHWAYS >>>>>>>>> MAC: 30:ae:a4:43:92:c4 >>>>>>>>> IP: 10.10.41.203/255.255.248.0 >>>>>>>>> GW: 10.10.40.64 >>>>>>>>> >>>>>>>>> AP SSID: DEVBENCH >>>>>>>>> MAC: 30:ae:a4:43:92:c5 >>>>>>>>> IP: 192.168.4.1 >>>>>>>>> AP Stations: 1 >>>>>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2 >>>>>>>>> >>>>>>>>> OVMS# ota status >>>>>>>>> Running partition: ota_0 >>>>>>>>> Boot partition: ota_0 >>>>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05) >>>>>>>>> Server Available: 3.1.005 >>>>>>>>> >>>>>>>>> ... >>>>>>>>> >>>>>>>>> I (1141850) webserver: HTTP GET / >>>>>>>>> I (1141860) webserver: HTTP GET /cfg/init >>>>>>>>> I (1141860) webserver: CfgInit enter 2.test.connect >>>>>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png >>>>>>>>> I (1141890) webserver: HTTP GET /assets/style.css >>>>>>>>> I (1141990) webserver: HTTP GET /assets/script.js >>>>>>>>> I (1142120) webserver: HTTP GET /cfg/init >>>>>>>>> I (1142120) webserver: CfgInit enter 2.test.connect >>>>>>>>> >>>>>>>>> >>>>>>>>> Can't get out of that 2.test.connect. >>>>>>>>> >>>>>>>>> Any ideas? >>>>>>>>> >>>>>>>>> Regards, Mark. >>>>>>>>> >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OvmsDev mailing list >>>>>>>>> OvmsDev@lists.openvehicles.com >>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>>> -- >>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>>>>> _______________________________________________ >>>>>>>> OvmsDev mailing list >>>>>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>>> >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OvmsDev mailing list >>>>>>> OvmsDev@lists.openvehicles.com >>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>>> -- >>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>>> >>>>>> >>>>>> _______________________________________________ >>>>>> OvmsDev mailing list >>>>>> OvmsDev@lists.openvehicles.com >>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>>> -- >>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>>>> _______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> -- >>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal >>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 >>> _______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > -- > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Greg D. -
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner
