A suggestion for the changes.txt: I thought and now suggest this file is intended as an extract of high level changes, i.e. changes that extend or change the user interface and/or features of the system, but not bug fixes or internal reworks. A log of all changes can be created automatically from the git log, no need to do that manually. git log --oneline --no-merges 3.1.000.. If we add all commits, users will stop reading this file. If we reduce it to high level entries, it becomes a valuable info for users. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Regards, Michael
Yes, that is the intention. For v2, I generally did this for each firmware release by doing a ‘git lola’ (like your 'git log --oneline --no-merges’), going through the changelog, and updating the changes.txt with non technical translations of core functionality changes. Trivial changes were not recorded in changes.txt. I just reviewed the latest, and this is what I came up with: $ git log --oneline --no-merges 3.1.003 master aeb7728 (HEAD -> master) Tesla Model S: Refinements for v.e.handbrake and Mph/Kph support 52e8214 (origin/master, origin/HEAD) Web shell: touch keyboard optimization 2eab5d3 Provide configurable parameters for sdcard: sdcard [maxfreq.khz] = 16000 sdcard [automount] = yes a2804b8 Add ovms_utils.h for FormatHexDump. 343ad45 Reimplement setting console prompt for secure mode 09f6f6b Tesla Model S: Use 32bit arithmetic for data decoding ed4d700 Tesla Model S: Use 32bit arithmetic for data decoding 6f732b2 Improve hexdump of 're list' to show ascii printable characters. 82cccc7 Tesla Model S: Gear selector - on/awake 3e0d5b1 TeslaModelS: v.bat.soc and v.pos.speed metrics e898c1b TeslaModelS: Fix for metric v.bat.soc c5bc34a TeslaModelS: Fix for metric v.pos.speed ad46fb2 Clone data passed to SignalEvent ed32467 Default production config support for ESP IDF panic stub b38b0ef Mutex protect fsync function call, on logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 37c5f4b Boot: store & send crash debug info (*-OVM-DebugCrash records) Note: needs esp-idf update (daef4b5c11a646b7149bf3534e338f3070ae3abf) 1bcbef9 Clone data passed to SignalEvent d9931cb Changelog update be39917 Run SD CARD automount in Events task context, not Timer. f0969a3 Refactor housekeeping/events tasks to use Events task for signal dispatch and housekeeping. 97775cf OVMS task naming cleanup 90c00b8 Enable watchdog reset for production builds fde6d8d OVMS task naming cleanup f6a8de5 changes.txt update 7ea18b4 Server v2: Delay 50ms on cmd #16 (between setting mode and current) 21e4110 Increase wifi scan responsiveness Becomes: ????-??-?? ??? ??????? OTA release - Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan) - Server v2: Introduce a 50ms delay between setting charge mode and current in same command - Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions to the event task (removing housekeeping task) - Core: Enable watchdogs for production builds - SD CARD: Reliability improvements to SD CARD auto-mounting on insertion - SD CARD: Provide configurable sdcard parameters: sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus sdcard [automount] = yes Automatically mount SD CARD on insertion - Boot: store & send crash debug info (*-OVM-DebugCrash records) - Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 - Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics This process is helped if people can include full information in their commit messages - in particular for changes that impact features, usage, provide new options, etc - anything that is going to affect or be visible to the user. Currently, the firmware download server has a file (http://api.openvehicles.com/firmware/ota/[v3.0|v3.1]/<tag>/ovms3.ver <http://api.openvehicles.com/firmware/ota/%5Bv3.0%7Cv3.1%5D/%3Ctag%3E/ovms3.ver>) that stores a one-line ‘current version’. I plan to change that to include the last few releases for changes.txt (as well as the version). That way, ‘ota status’ can show the changes in the latest version as well as the version number itself). Regards, Mark.
Regards, Michael
Mark, I would reduce this much further to: ????-??-?? ??? ??????? OTA release - Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics This is IMO the only change from the current log a normal user needs to know about. The SD card configuration is on the edge, I would remove that entry from the user info as well, as a normal user will (should) not need to touch these configs: - SD CARD: Provide configurable sdcard parameters: sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus sdcard [automount] = yes Automatically mount SD CARD on insertion The DebugCrash records info is also on the edge, I would now also remove that from the changes file as no normal user can make use of that info: - Boot: store & send crash debug info (*-OVM-DebugCrash records) The remaining changes are bug fixes or internal stuff no user needs to know, only developers: - Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan) - Server v2: Introduce a 50ms delay between setting charge mode and current in same command - Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions to the event task (removing housekeeping task) - Core: Enable watchdogs for production builds - SD CARD: Reliability improvements to SD CARD auto-mounting on insertion - Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 All this can be reduced to a single line "lots of bug fixes and optimizations". Am I too radical on this? Regards, Michael Am 11.04.2018 um 02:06 schrieb Mark Webb-Johnson:
Becomes:
On 11 Apr 2018, at 5:31 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Michael, Your position may be a bit too radical. What you propose is good for the "cover letter", like the short paragraph that that Apple provides with updates to MacOS. But it always annoys me that there isn't a second-level bug fix list with more detail that I can reference to tell if a problem that I experienced has been fixed. For OVMS you are right that (most) anyone can run a command to get a list of commits, but very often it is helpful to users to have an interpretation of those commit messages by an expert who has enough context to understand the significance of the commit. -- Steve On Wed, 11 Apr 2018, Michael Balzer wrote:
Mark,
Regards, Michael
Yes, that is the intention. For v2, I generally did this for each firmware release by doing a 'git lola' (like your 'git log --oneline --no-merges'), going through the changelog, and updating the changes.txt with non technical translations of core functionality changes. Trivial changes were not recorded in changes.txt.
Becomes:
Currently, the firmware download server has a file (http://api.openvehicles.com/firmware/ota/[v3.0|v3.1]/<tag>/ovms3.ver <http://api.openvehicles.com/firmware/ota/%5Bv3.0%7Cv3.1%5D/%3Ctag%3E/ovms3.ver>) that stores a one-line 'current version'. I plan to change that to include the last few releases for changes.txt (as well as the version). That way, 'ota status' can show the changes in the latest version as well as the version number itself).
Regards, Michael
Taking into account Steve and Greg feedback, perhaps we need to define the criteria for what should be in there? I think we need to focus on what is useful to the user. In particular things that we’ve done that may impact his usage experience. I suggest a short one or two line summary headline. Then, individual points to cover: User visible changes Changes to functionality that could impact users Enhancements and new features that would be of benefit to users Github reported issues addressed I am not sure about #4. Should we be reporting ALL github issues, or just those that meet the first three criteria? Looking at the example, and what @Michael suggests removing, I think that would keep: Wifi scan responsiveness The “Server v2: 50 ms delay …” should probably be a github reported issue. Watchdogs (included because it could impact users if they suddenly start to see random reboots, but I agree that this is borderline for inclusion) I don’t think the SD CARD issue meets the above inclusion criteria. But, somebody who had been having issues with his SD CARD would probably be interested in knowing we have made changes to try to make it better. Does that work? Regards, Mark.
On 12 Apr 2018, at 12:13 AM, Michael Balzer <dexter@expeedo.de> wrote:
Mark,
- Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan) - Server v2: Introduce a 50ms delay between setting charge mode and current in same command - Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions to the event task (removing housekeeping task) - Core: Enable watchdogs for production builds - SD CARD: Reliability improvements to SD CARD auto-mounting on insertion - Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 <https://github.com/espressif/esp-idf/issues/1837>
Regards, Michael
$ git log --oneline --no-merges 3.1.003 master aeb7728 (HEAD -> master) Tesla Model S: Refinements for v.e.handbrake and Mph/Kph support 52e8214 (origin/master, origin/HEAD) Web shell: touch keyboard optimization 2eab5d3 Provide configurable parameters for sdcard: sdcard [maxfreq.khz] = 16000 sdcard [automount] = yes a2804b8 Add ovms_utils.h for FormatHexDump. 343ad45 Reimplement setting console prompt for secure mode 09f6f6b Tesla Model S: Use 32bit arithmetic for data decoding ed4d700 Tesla Model S: Use 32bit arithmetic for data decoding 6f732b2 Improve hexdump of 're list' to show ascii printable characters. 82cccc7 Tesla Model S: Gear selector - on/awake 3e0d5b1 TeslaModelS: v.bat.soc and v.pos.speed metrics e898c1b TeslaModelS: Fix for metric v.bat.soc c5bc34a TeslaModelS: Fix for metric v.pos.speed ad46fb2 Clone data passed to SignalEvent ed32467 Default production config support for ESP IDF panic stub b38b0ef Mutex protect fsync function call, on logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 <https://github.com/espressif/esp-idf/issues/1837> 37c5f4b Boot: store & send crash debug info (*-OVM-DebugCrash records) Note: needs esp-idf update (daef4b5c11a646b7149bf3534e338f3070ae3abf) 1bcbef9 Clone data passed to SignalEvent d9931cb Changelog update be39917 Run SD CARD automount in Events task context, not Timer. f0969a3 Refactor housekeeping/events tasks to use Events task for signal dispatch and housekeeping. 97775cf OVMS task naming cleanup 90c00b8 Enable watchdog reset for production builds fde6d8d OVMS task naming cleanup f6a8de5 changes.txt update 7ea18b4 Server v2: Delay 50ms on cmd #16 (between setting mode and current) 21e4110 Increase wifi scan responsiveness
Becomes:
????-??-?? ??? ??????? OTA release - Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan) - Server v2: Introduce a 50ms delay between setting charge mode and current in same command - Core: Changes to housekeeping and events tasks to move event delivery and housekeeping actions to the event task (removing housekeeping task) - Core: Enable watchdogs for production builds - SD CARD: Reliability improvements to SD CARD auto-mounting on insertion - SD CARD: Provide configurable sdcard parameters: sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus sdcard [automount] = yes Automatically mount SD CARD on insertion - Boot: store & send crash debug info (*-OVM-DebugCrash records) - Core: Introduce protection for thread safety while logging, to workaround ESP IDF bug https://github.com/espressif/esp-idf/issues/1837 <https://github.com/espressif/esp-idf/issues/1837> - Tesla Model S: Support v.bat.soc, v.pos.speed and park/drive status metrics
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
To make looking up all fixes easier for users we can include a git log as a second file. Github reported issues will be discussed on github so people involved will already be informed. So I think we should apply rules 1-3 for their inclusion in the general changes report. I think that will work well. Regards, Michael Am 12.04.2018 um 08:06 schrieb Mark Webb-Johnson:
1. User visible changes 2. Changes to functionality that could impact users 3. Enhancements and new features that would be of benefit to users 4. Github reported issues addressed
* Wifi scan responsiveness * The “Server v2: 50 ms delay …” should probably be a github reported issue. * Watchdogs (included because it could impact users if they suddenly start to see random reboots, but I agree that this is borderline for inclusion)
Does that work?
On 12 Apr 2018, at 12:13 AM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Mark,
Regards, Michael
Becomes:
Regards, Michael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
OK. Criteria: User visible changes Changes to functionality that could impact users Enhancements and new features that would be of benefit to users That gives: ????-??-?? ??? ??????? OTA release OTA release providing minor improvements and fixes. - Tesla Model S: Add support for v.bat.soc, v.pos.speed and park/drive status metrics - SD CARD: Provide configurable sdcard parameters: sdcard [maxfreq.khz] = 16000 Maximum frequency (in kHz) of SD CARD bus sdcard [automount] = yes Automatically mount SD CARD on insertion - Boot: store & send crash debug info (*-OVM-DebugCrash records) - Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan) - Miscellaneous bug fixes and enhancements Regards, Mark
Regards, Michael
Does that work?
Mark,
Regards, Michael
Becomes:
Regards, Michael
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Greg D. -
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner
