Everyone, by request of Henri Bachmann on the german GoingElectric forum, I've added the Hyundai Ioniq vFL (28 kWh). The implementation is based on the reverse engineering data published by the EVNotify project: https://github.com/EVNotify/EVNotiPi/blob/master/car/ioniq_bev.py Module Documentation: https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/... Henri has tested the module, but more tests from other Ioniq drivers are welcome. One of the PIDs needs more data/logs: the "driveMotorSpeed" didn't match the actual speed on Henri's tests. That PID isn't used by the EVNotify system so may be wrong, or could be RPM. If you can help with logs on this, enable file logging and do a test drive with level verbose on module v-hyundaivfl. Try to maintain a fixed maximum speed for 20 seconds for reference. Send me the logs and the max speed. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
This is great news! I am happy to contribute. I am a newbie in OVMS with Huyndai Ioniq 28 kWh (2017). I haven't yet received the hardware, but I have bluetooth OBD-II dongle an EVNotify installed in my s artphone. What exactly should I do to help? Regards, Kirmo On Wed, Mar 17, 2021 at 10:47 PM Michael Balzer <dexter@expeedo.de> wrote:
Everyone,
Regards, Michael
Kirmo, welcome :-) Henri was mostly interested in the SOC, which works for him. The other metrics and the state management could use some more testing. To help with the speed decoding:
If you later want to explore and add more PIDs, I can show you how do reverse engineering and PID monitoring, and how to integrate more PIDs into the code. Regards, Michael Am 24.03.21 um 16:27 schrieb Kirmo Uusitalo:
Regards, Kirmo
On Wed, Mar 17, 2021 at 10:47 PM Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Everyone,
The implementation is based on the reverse engineering data published by the EVNotify project: https://github.com/EVNotify/EVNotiPi/blob/master/car/ioniq_bev.py <https://github.com/EVNotify/EVNotiPi/blob/master/car/ioniq_bev.py>
Module Documentation: https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/... <https://docs.openvehicles.com/en/latest/components/vehicle_hyundai_ioniqvfl/docs/index.html>
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
Kirmo Uusitalo -
