I've just released to testflightapp another preview of the upcoming 1.2.5 iOS App. This is build 20120506. Testflightapp testers registered for the OVMS project can get it in the usual place. We're getting close now. The basics are working and the last thing to do is the configuration features/parameters/advanced screens. Regards, Mark. Open Vehicle 1.2.5 (20120506) Team: Open Vehicles What's New: v1.2.5 preview (20120506) - Retina vehicle images - Current weather situation indicator - Location vehicle animations - Location lock-to-my-car feature - Location Groups support (preliminary) - UI revamp - App version shown in vehicle info display - Move Control button to car detail screen - Move Info button to car selection screen - Move GSM signal bars to car selection screen - Show car direction on location map - Support display and control of a timer-delayed charge - Use pump status for temp stale - Charge port animations - Stale indicators for ambient, pem, motor, battery and toms - Various minor bug-fixes and stability enhancements Size: 7.6 MB
mark, first THANKS it looks great. just a couple of questions. where and how is the timed charge supported?? also was wondering if you are planning on looking at the on off switches etc for ease of use of the functions such as CAN write mode etc, that we had discussed or you will leave that for now....? thanks again for all your hard work felix b. Sent from somewhere in our beautiful universe. On 6 May, 2012, at 21:27, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
<Icon.png> Open Vehicle 1.2.5 (20120506) Team: Open Vehicles What's New: v1.2.5 preview (20120506) - Retina vehicle images - Current weather situation indicator - Location vehicle animations - Location lock-to-my-car feature - Location Groups support (preliminary) - UI revamp - App version shown in vehicle info display - Move Control button to car detail screen - Move Info button to car selection screen - Move GSM signal bars to car selection screen - Show car direction on location map - Support display and control of a timer-delayed charge - Use pump status for temp stale - Charge port animations - Stale indicators for ambient, pem, motor, battery and toms - Various minor bug-fixes and stability enhancements
Size: 7.6 MB _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Felix,
Currently, I've added support to the App to show the charging is delayed by timer. It shows in the plug graphic with a switch slid to the left and the words "TIMED CHARGE". Sliding the switch to the right will start the charge immediately (overriding the timer delay). It looks almost identical to the normal "SLIDE TO CHARGE" mechanism, just with different wording. I want to add support to the car module for (a) sending current charge delay mode (charge on plugin or charge on timer) and time, and (b) support changing the mode from the App. But, that is going to require a firmware change to the car firmware which I'm doing in the current set of updates. So, full App support will come later. I think in the App, this can go on the current battery-tap screen that sets current limit and mode.
Yes, I want to do this. That is almost the last thing pending on this version, before we should be good to release. The other minor thing is the graphic for the car with groups. I'm going to add a global "Settings" control to allow opt-out of sending the chosen car image name up to the server for distribution to people who subscribe to the groups. It will default on, but can be disabled. If on, the app will tell the server (when logging in) what car color choice has been made by the user, and the server will send that information along with the group messages. This will allow us to display the correct car colors on the groups map. Not too big a change, but needs to be co-ordinated with the Android release. Regards, Mark. On 7 May, 2012, at 3:15 AM, felix bonnier wrote:
mark,
felix b.
also: what does, use pump status for temp stale, mean??? best felix b. Sent from somewhere in our beautiful universe. On 6 May, 2012, at 21:27, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
In the current car firmware, we try to determine if values are 'stale' or not. If the car no longer sends the value for some time, then we make it as stale as we want to let the user know this is an old value that is not being updated, as opposed to a value that is updated in real-time. Examples are temperatures and toms values. In the car firmware, the logic is that if we don't see the message on the can bus for some time, we mark it as stale. Seems to work well, except for temperatures. It appears that the car continues to transmit the temperature can messages long after it stops updating the temperatures :-( The best guess is that the car subsystem that provides that data is powered down, but the VMS keeps sending out the old data. However, we think that "that little pump" in the boot of the car is on the same circuit as the temperature systems. When the car is asleep, the pump stops and the temperatures are not updated. So, for the moment I have changed the App to treat temperatures as stale if _either_ the car firmware tells us they are _or_ the pump is off (i.e.; the car is asleep). It is a workaround, and the next firmware upgrade will directly use the pump status as an input to whether temperatures are stale or not. By the way, while here I would like to bring attention to the great work Felix is doing on this. A lot of this is off-list, so you don't get to hear about it, but Felix is the guy working with us on the iOS App design and graphics. He is making all these amazing retina graphics, and (more importantly IMHO) providing a user perspective to the design and workflow of the app. We've probably done about 2/3rds of what he has suggested, with the last bit being the settings for Features and Parameters coming soon, but I hope you can all see how much better it is now. We're quite an unusual project in that the iOS and Android Apps are two completely separate development streams. But, what works out well is the way the Apps independently develop features, see what works, then borrow from each other to come up with the best approach for each platform. A survival-of-the-fittest kind of approach. Regards, Mark On 7 May, 2012, at 3:17 AM, felix bonnier wrote:
best
felix b.
mark, thanks a lot for the very thorough explanation of what my questions were. I understand perfectly now. looking forward to the new goodies coming to the app, server and car software/firmware /fb Sent from my iPad somewhere in our beautiful universe....... On 7 May, 2012, at 10:16, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
best
felix b.
felix bonnier -
