Hi folks, Ok, so the new code seems to be working half-way decently. But I think there's a memory issue with the webserver. After poking at home and status a couple of times, my browser (chrome or Firefox) drop from a nicely formatted screen to something very text-like. Links and words, no buttons. Then another poke or two and the module crashed. I've done it a few times, and the crash usually seem to be with the Status button, which, looking at the console, seems to have an auto-repeat on it. I managed to get the repeated "job queue overflow" once, followed after hitting home a few times, a similar crash as below. This was one of the quicker crashes (browser didn't get to the text-mode state), using AP mode wifi. Browser in this case was Chrome. I have a suspicion that the issue with the text-mode stuff is a leak somewhere triggered by Firefox, with its CSS fetches. Greg OVMS> OVMS> I (12641) housekeeping: System considered stable (free: 35212 bytes) I (17331) simcom: State: Enter PoweredOn state I (30481) wifi: n:1 0, o:1 1, ap:1 1, sta:1 0, prof:1 I (30491) wifi: station: 40:4e:36:8a:44:c0 join, AID=1, g, 20 I (30491) esp32wifi: AP station connected: id: 1, MAC: 40:4e:36:8a:44:c0 I (37121) webserver: HTTP GET /home I (37371) simcom: State: Enter MuxStart state I (37371) gsm-mux: Start MUX I (40411) webserver: HTTP GET /status I (47611) webserver: HTTP GET /shell I (51031) webserver: HTTP GET /home I (53891) webserver: HTTP GET /status I (59031) webserver: HTTP GET /home I (61581) webserver: HTTP GET / I (61661) webserver: HTTP GET /home I (63511) webserver: HTTP GET /home I (65971) webserver: HTTP GET /status OVMS> abort() was called at PC 0x400db927 on core 1 Backtrace: 0x4008f0b8:0x3ffeb8b0 0x4008f28f:0x3ffeb8d0 0x400db927:0x3ffeb8f0 0x4014880c:0x3ffeb910 0x40154899:0x3ffeb930 0x40154a9f:0x3ffeb950 0x40126564:0x3ffeb980 0x401267c7:0x3ffeb9e0 0x40126846:0x3ffeba00 0x4012841f:0x3ffeba50 0x400f6aff:0x3ffebb10 0x400f7262:0x3ffebb40 0x400f6aff:0x3ffebb60 0x400f7c8e:0x3ffebb90 0x400f7d3f:0x3ffebbc0 0x400f80eb:0x3ffebbf0 0x400f834d:0x3ffebc30 0x400f4b2d:0x3ffebc80 0x400e749a:0x3ffebca0 0x400e74d9:0x3ffebcf0 Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 156795334, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:4560 ho 0 tail 12 room 4 load:0x40078000,len:0 load:0x40078000,len:13176 entry 0x40078d38 I (647) cpu_start: Pro cpu up. I (648) cpu_start: Starting app cpu, entry point is 0x40081300 I (632) cpu_start: App cpu up. I (651) heap_init: Initializing. RAM available for dynamic allocation: I (658) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (664) heap_init: At 3FFBBAC0 len 00024540 (145 KiB): DRAM I (670) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM I (676) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (684) heap_init: At 40091FDC len 0000E024 (56 KiB): IRAM I (689) cpu_start: Pro cpu start user code I (35) ovms_main: Set default logging level for * to INFO I (36) command: Initialising COMMAND (1000) I (36) boot: Initialising BOOT (1100) I (40) boot: Boot #4 reasons for CPU0=12 and CPU1=12 E (46) boot: Crash #4 detected I (49) events: Initialising EVENTS (1200) I (54) config: Initialising CONFIG (1400) I (59) time: Initialising TIME (1500) I (64) script: Initialising SCRIPTS (1600) I (68) script: Using DUKTAPE javascript engine I (74) metrics: Initialising METRICS (1810) I (78) metrics: Expanding DUKTAPE javascript engine I (88) notify: Initialising NOTIFICATIONS (1820) I (89) notify: Registered notification type info I (94) notify: Registered notification type error I (99) notify: Registered notification type alert I (105) notify: Registered notification type data I (110) location: Initialising LOCATIONS (1900) I (116) location: Expanding DUKTAPE javascript engine I (121) vehicle: Initialising VEHICLE Factory (2000) I (127) pcp: Initialising POWER (4000) I (131) max7317: Initialising MAX7317 EGPIO (4200) I (137) sdcard: Initialising SD CARD (4400) I (142) ota: Initialising OTA (4400) I (146) can: Initialising CAN (4500) I (151) simcom: Initialising SIMCOM (4600) I (155) test: Initialising TEST (5000) I (159) ovms-module: Initialising MODULE (5100) I (165) vfs: Initialising VFS (5200) I (169) ovms-server: Initialising OVMS Server (6000) I (174) ovms-server-v2: Initialising OVMS V2 Server (6100) I (181) ovms-server-v3: Initialising OVMS V3 Server (6200) I (187) obd2ecu: Initialising OBD2ECU (7000) I (192) canopen: Initialising CANopen (7000) I (197) esp32wifi: Initialising ESP32WIFI (8000) I (202) ovms-mdns: Initialising MDNS (8100) I (207) webserver: Initialising WEBSERVER (8200) I (213) telnet: Initialising Telnet (8300) I (217) ssh: Initialising SSH (8300) I (221) re: Initialising RE Tools (8800) I (226) netmanager: Initialising NETMANAGER (8999) I (233) v-track: Registering Vehicle: TRACK (9000) I (237) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000) I (243) v-teslamodels: Registering Vehicle: Tesla Model S (9000) I (250) v-obdii: Registering Vehicle: OBDII (9000) I (256) v-none: Registering Vehicle: NONE (9000) I (261) v-demo: Registering Vehicle: DEMO (9000) I (266) version: Initialising Versioning (9900) I (275) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (321) ovms_main: Executing on CPU core 0 I (321) ovms_main: Mounting CONFIG... W (371) webserver: UpdateGlobalAuthFile: no password set => no auth for web console I (381) ovms_main: Registering default configs... I (381) ovms_main: Starting HOUSEKEEPING... I (381) housekeeping: Initialising HOUSEKEEPING Framework... I (441) housekeeping: Executing on CPU core 1 I (441) housekeeping: reset_reason: cpu0=12, cpu1=12 I (441) housekeeping: Starting PERIPHERALS... I (451) peripherals: Initialising OVMS Peripherals... I (451) peripherals: TCP/IP Adaptor I (461) peripherals: ESP32 system I (461) peripherals: SPI bus I (461) peripherals: MAX7317 I/O Expander I (471) peripherals: ESP32 CAN I (471) peripherals: ESP32 WIFI I (481) peripherals: ESP32 BLUETOOTH I (481) peripherals: ESP32 ADC I (481) peripherals: MCP2515 CAN 1/2 I (501) peripherals: MCP2515 CAN 2/2 I (511) peripherals: SD CARD I (511) peripherals: SIMCOM MODEM I (511) gpio: GPIO[16]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (521) gpio: GPIO[17]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 I (531) uart: queue free spaces: 10 I (531) ext12v: Powering off external 12V devices I (541) housekeeping: Auto init ext12v (free: 112712 bytes) I (541) ext12v: Powering on external 12V devices I (551) housekeeping: Auto init wifi (free: 112712 bytes) I (551) wifi: wifi firmware version: ebd3e5d I (561) wifi: config NVS flash: enabled I (561) wifi: config nano formating: disabled I (561) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (571) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (601) wifi: Init dynamic tx buffer num: 16 I (601) wifi: Init data frame dynamic rx buffer num: 16 I (601) wifi: Init management frame dynamic rx buffer num: 16 I (601) wifi: wifi driver task: 3ffe60f0, prio:23, stack:4096 I (611) wifi: Init static rx buffer num: 4 I (611) wifi: Init dynamic rx buffer num: 16 I (611) wifi: wifi power manager task: 0x3ffe8888 prio: 21 stack: 2560 I (1341) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0 I (1341) wifi: mode : sta (30:ae:a4:37:1b:64) + softAP (30:ae:a4:37:1b:65) I (1351) housekeeping: Auto init modem (free: 90568 bytes) I (1351) simcom: State: Enter PoweringOn state I (1351) simcom: Power Cycle I (1361) netmanager: WIFI access point is up I (1361) webserver: Launching Web Server I (1371) esp32wifi: AP started with SSID: ovms, MAC: 30:ae:a4:37:1b:65, IP: 192.168.4.1 I (1371) telnet: Launching Telnet Server I (1381) ssh: Launching SSH Server I (1441) simcom: State: Enter PoweredOn state I (2361) housekeeping: Auto init vehicle (free: 78820 bytes) I (2361) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module I (2371) housekeeping: Auto init obd2ecu (free: 73088 bytes) I (2571) housekeeping: Auto init server v2 (free: 64432 bytes) I (2571) ovms-server-v2: OVMS Server V2 registered metric modifier is #1 I (2581) ovms-server-v2: Status: Starting I (2581) ovms-server-v2: OVMS Server v2 running I (2591) housekeeping: Auto init server v3 (free: 60120 bytes) I (2591) housekeeping: Auto init done (free: 60120 bytes) I (2601) housekeeping: Starting USB console... I (2601) uart: queue free spaces: 30 I (2611) ovms-mdns: Starting MDNS Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console I (2651) version: Set version I (4181) wifi: n:1 1, o:1 0, ap:1 1, sta:1 0, prof:1 I (4841) wifi: state: init -> auth (b0) I (4841) wifi: state: auth -> auth (4a0) OVMS>
Seems to be ok for me. But I have 48KB RAM free (OVMS v3.0) which gives a bit more breathing room. I’ve been doing a lot of bringing up and down wifi and modem links, and switching between ap, apclient, client, and off wifi modes. It seems that the network manager is behaving better now (at least on my desk). That bug of taking down mongoose would have caused unpredictable behaviour and weird errors everywhere. I’m going to put it in my car now, and leave it running this afternoon (and for my drive home). Regards, Mark.
On 20 Mar 2018, at 12:53 PM, Greg D. <gregd2350@gmail.com> wrote:
Hi folks,
Greg
Ok, interesting. Am I seeing an out-of-memory crash? I can't tell... It seems like the webserver status button is the worst offender, probably because it's doing a lot of work and building a big payload. Very often hangs for a while before responding, and if so, usually results in the job queue overflow. If I catch it quick enough and hit home or some other shorter task, the overflow will drain and I'll get the new screen; otherwise a crash. Sometimes there will be a timeout mixed in. I'm wondering if our little squirrel in the ESP32 just can't pedal hard enough... I did some tests going between wifi and modem, and it seems to be better than yesterday. I am still having a lot of trouble with modem framing errors. I get only an update or two (25-35 frames), if that, before they start mounting, eventually relying on the 3 minute timer to reset things. Thought last night that perhaps it was electrical interference, since there's a 2.4 ghz transmitter screaming right under the modem board. But turning off wifi altogether (mode and power) didn't change the framing errors, so that can't be it. Perhaps I'm just in a bad (RF) neighborhood. The webserver status page (when I can get it) is reporting -95 to -97 dBm for the signal. Seems a bit low, but I don't have a lot of experience in that department. I'm just using an antenna off my portable ham radio. Supposed to be good to over a ghz, but not ideal, to be sure. There are a lot of "netmanager: interface priority is pp3" messages when running the modem. Is that netmanager offering encouragement to the modem, or an indication of some status that might be bad? I've switched over to the home wifi, and will let it run for the night, but can load another build before heading to bed in an hour or so, if there is one. Greg Mark Webb-Johnson wrote:
Hi folks,
Greg
I’m a little worried by 30KB RAM free. That is tight, and it doesn’t take much temporary buffers for output to cause it to run out of ram. I did try it just now in my car, and it seemed ok for me - but I was accessing it via AP from my iPhone. Anyway, Michael knows the webserver, so best to let him try it now. Framing errors would be indicative of a mux issue, not really RF signal. Are you sure the modem is not browning out from lack of power? Are you seeing any ..START.. messages in the log (which is a modem restart)? I was getting a lot of these until I switched to a powered USB hub. How are you powering this - 5v usb or 12v? Don’t worry about the net manager interface priority messages. Those are there because the wifi stack keeps screwing with the default interface, so I work around it by re-setting the default interface pretty much every time there is wifi ap/sta event. For example: Start and Access Point + Station Start a modem Wait for everything to connect. Netmanager priority will be Station. Shutdown access point and station. Netmanager will switch to modem. Start a Station. Netmanager will switch to station. (at this point, everything is fine - but network status shows a ‘dead’ AP interface left lying around unused) Stop the station. Netmanager will switch to modem. A second or so later, the wifi stack will shutdown the station interface, and say ‘oh look, there is an AP interface, let’s switch to that’. Server v2 can’t connect any more. Now, with my new code, Netmanager will pick up on this and switch to modem. If I have time, I might change the Netmanager code to only output the priority message if it actually has to change the interface. I don’t have any plans for changes in the next few hours. At work now, lunch time over, and day job beckons. Regards, Mark.
Greg
Hi folks,
Greg
Ha, interesting. I've been running the module mostly from the high power port on my laptop, with 12v applied only when I was driving the external CAN bus dongle things. I don't recall framing errors being a problem in the past, but I connected the 12v and it appears that the framing errors have stopped. I'll let it run the night, and see what happens by morning. Greg Mark Webb-Johnson wrote:
I mostly get it when using AP + CLIENT + MODEM, and everything transmitting. Regards, Mark.
Greg
Yes, RAM on hw3.0 is very tight now. Greg, you can save around 7 KB by not inserting an SD card. My normal free RAM is around 22 KB after mounting an SD card, which normally still works if I take care not to stress it by additional web / telnet sessions. Greg, if you enable debug log level for "webserver" and "webcommand" you will get free RAM log entries on pages and command calls. I'll try the latest changes as soon as I get home. Regards, Michael Am 20.03.2018 um 07:10 schrieb Mark Webb-Johnson:
1. Start and Access Point + Station 2. Start a modem 3. Wait for everything to connect. Netmanager priority will be Station. 4. Shutdown access point and station. Netmanager will switch to modem. 5. Start a Station. Netmanager will switch to station. 6. (at this point, everything is fine - but network status shows a ‘dead’ AP interface left lying around unused) 7. Stop the station. Netmanager will switch to modem. 8. A second or so later, the wifi stack will shutdown the station interface, and say ‘oh look, there is an AP interface, let’s switch to that’. Server v2 can’t connect any more. 9. Now, with my new code, Netmanager will pick up on this and switch to modem.
On 20 Mar 2018, at 1:47 PM, Greg D. <gregd2350@gmail.com <mailto:gregd2350@gmail.com>> wrote:
Greg
On 20 Mar 2018, at 12:53 PM, Greg D. <gregd2350@gmail.com <mailto:gregd2350@gmail.com>> wrote:
Hi folks,
Greg
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Commit a9bfcc761e8853a5ad1e7cee4b966d012fc33895 …every (!) mode is working now! :-) Wifi client, ap, apclient, also with MDNS enabled, switching networks, using the webserver via any net and using the MDNS name -- everything works. RAM is as tight as before, had one out of memory crash in apclient mode with MDNS, but I also still have memory debugging enabled. MDNS has a memory overhead of 3-8 KB depending on the wifi mode, so I also consider disabling it again for my 3.0 module. I also haven't seen any strange things in the task list or memory leak during the test. This looks very good. Regards, Michael Am 20.03.2018 um 08:49 schrieb Michael Balzer:
Regards, Michael
Gonna give that a shot :-) I love apclient mode, too bad it needs an SSID set (I thought there where limitations, like channel selection for instance which could have been logic, but I don’t really see any reason in fact)
Could this be switched off parametrically (and on the fly) ? (I don’t have any uses cases for it and could easily live without for instance and still have a bit of headroom for other things like having the SD card mounted :) )
Regards, Michael
Regards, Julien PS: the spare OBD cable was badly cabled, used the one on the v2: no more Christmas lights, even with RT module, though even at home it seems it won’t stick stable on GSM anymore (it registers but PPP goes away (just AP mode on wifi))
Regards, Michael
Set apclient, so wifi comes online pretty fast … But getting crash looped very fast (I usually have time to "config set” stuff) https://pastebin.com/ricmTJf7 I did manage to enable and server v3 stop (as it seems to either get disconnected from mqtt then crash after a handful of seconds, or crash during mqtt publishing) and now it sits still. GSM looks dead on the other hand and wifi has hiccups (‘wifi' knows it’s IP, ‘network' doesn’t) :-) OVMS# network Interface#2: ap2 (ifup=1 linkup=1) IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1 Interface#1: st1 (ifup=1 linkup=1) IPv4: 10.33.92.20/255.255.255.0 gateway 10.33.92.1 Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 10.33.33.251 10.33.33.252 Default Interface: st1 (10.33.92.20/255.255.255.0 gateway 10.33.92.1) I (171010) simcom: State timeout, transition to 2 I (171010) simcom: State: Enter PoweringOn state I (171010) simcom: Power Cycle I (174670) simcom: State: Enter PoweredOn state I (194010) simcom: State: Enter MuxStart state I (194010) gsm-mux: Start MUX I (194020) gsm-mux: Channel #0 is open I (194030) gsm-mux: Channel #1 is open I (194030) gsm-mux: Channel #2 is open I (194040) gsm-mux: Channel #3 is open I (194040) gsm-mux: Channel #4 is open I (195010) simcom: State: Enter NetWait state I (195010) gsm-nmea: Startup I (199990) wifi: bcn_timout,ap_probe_send_start I (202490) wifi: ap_probe_send over, resett wifi status to disassoc I (202490) wifi: state: run -> init (1) I (202500) wifi: n:9 0, o:9 0, ap:9 2, sta:9 0, prof:9 I (202500) netmanager: WIFI client down (with MODEM down): network connectivity has been lost I (202500) time: Stopping SNTP client I (203010) ovms-server-v2: Status: Server is ready to start I (205030) simcom: CREG Network Registration: RegisteredHome I (206010) simcom: State: Enter NetStart state I (207050) simcom: PPP Connection is ready to start I (208010) simcom: State: Enter NetMode state I (208010) gsm-ppp: Initialising... E (208010) gsm-ppp: Error init pppos <<< bummer OVMS# simcom SIMCOM Network Registration: RegisteredHome State: NetMode Ticker: 92 User Data: 0 Mux Status: up Open Channels: 4 Framing Errors: 0 Last RX frame: 1 sec(s) ago RX frames: 219 TX frames: 11 PPP Not Connected Last Error: Undefined GPS Status: enabled, required Time: enabled, required NMEA: GPS/GLONASS Connected on channel: #1 OVMS# network Interface#2: ap2 (ifup=1 linkup=1) IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1 Interface#1: st1 (ifup=0 linkup=1) IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 <<<<<< bye bye Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 10.33.33.251 10.33.33.252 Default Interface: ap2 (192.168.4.1/255.255.255.0 gateway 192.168.4.1) I (317690) event: station ip lost OVMS# wifi WiFi Power: on Mode: Access-Point + Client mode STA SSID: JaXX MAC: 30:ae:a4:37:25:54 IP: 10.33.92.20/255.255.255.0 <<<<<<< here GW: 10.33.92.1 AP SSID: TwaXX MAC: 30:ae:a4:37:25:55 IP: 192.168.4.1 AP Stations: 0 OVMS# network Interface#2: ap2 (ifup=1 linkup=1) IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1 Interface#1: st1 (ifup=0 linkup=1) IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 <<<<<< not here Interface#0: lo0 (ifup=1 linkup=1) IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1 DNS: 10.33.33.251 10.33.33.252 Default Interface: ap2 (192.168.4.1/255.255.255.0 gateway 192.168.4.1) OVMS# Regards, JaXX./.
Julien, you're loading too much on hw3.0. You cannot start both v2 and v3 server, even if you exclude optional components. See here: 1. I (7011) ovms-server-v3: Tx(all) metric ovms/TWAXXV3/m/m.freeram=14284 2. …you've barely booted and your RAM is already gone. You've also enabled the wolfssh stuff and the obd2ecu component, I recommend disabling both to save RAM. I also have disabled every car except Twizy, but I think that doesn't make much difference on RAM usage. Also, did you disable the FATFS per file cache? Regards, Michael Am 20.03.2018 um 19:39 schrieb Julien “JaXX” Banchet:
Regards, JaXX./.
On 20 Mar 2018 at 19:54 +0100, Michael Balzer <dexter@expeedo.de>, wrote:
Julien,
See here:
1. > I (7011) ovms-server-v3: Tx(all) metric ovms/TWAXXV3/m/m.freeram=14284 2.
Damn, that’s me seeing light and getting all enthusiastic :) (yeah, didn’t think of that, and the localised crash mislead me)
They were defaulted to =y, took out obd2ecu, most vehicles, and the FATFS cache I probably will take ssh out eventually The build lost some weight and leaves 46/48kB of ram, can run v2 and v3 at the same time (but I’ll stick to one at a time atm) Rock solid and PPP comes up quick (dunno if it was related or just a transient local cell network issue) Just need a passive gps antenna now and it will more durably be living in the car ! Thanks !
Regards, Michael
Regards, JaXX./.
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
We could refactor it to be PSP derived. It could then be started/stopped with a power control command and brought into the ‘auto’ system. Not hard to do. Regards, Mark.
Regards, Michael
Regards, Julien
Regards, Michael
Wouldn't that be confusing what "power" means? -- Steve On Wed, 21 Mar 2018, Mark Webb-Johnson wrote:
Not hard to do.
Regards, Michael
Regards, Julien
Regards, Michael
Am 20.03.2018 um 06:47 schrieb Greg D.:
Most crashes now are related to lack of free memory. Regarding the status page I just hit the page 10 times: OVMS# mo m Free 8-bit 27264/283200, 32-bit 27544/55820, SPIRAM 0/0 I (784440) webserver: HTTP GET /status D (785010) webserver: Serve /status: 6068 bytes used, 21200 free I (787240) webserver: HTTP GET /status D (787830) webserver: Serve /status: 6064 bytes used, 21168 free I (788720) webserver: HTTP GET /status D (789290) webserver: Serve /status: 6104 bytes used, 21164 free I (790110) webserver: HTTP GET /status D (790700) webserver: Serve /status: 6100 bytes used, 21164 free I (791530) webserver: HTTP GET /status D (792120) webserver: Serve /status: 6068 bytes used, 21200 free I (792980) webserver: HTTP GET /status D (793550) webserver: Serve /status: 6100 bytes used, 21164 free I (794400) webserver: HTTP GET /status D (794980) webserver: Serve /status: 6068 bytes used, 21200 free I (795860) webserver: HTTP GET /status D (796730) webserver: Serve /status: 6100 bytes used, 21164 free I (797160) webserver: HTTP GET /status D (797740) webserver: Serve /status: 6064 bytes used, 21168 free I (798430) webserver: HTTP GET /status D (799020) webserver: Serve /status: 6060 bytes used, 21200 free OVMS# mo m Free 8-bit 27264/283200, 32-bit 27544/55820, SPIRAM 0/0 So no memory loss and no crashes. The 6K is just the buffer usage after processing. The commands executed for the status page need additional RAM, but above 20 K free, the page normally has no problems. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
With 3.1, here is what I get on a clean boot: OVMS# module memory Free 8-bit 133180/282048, 32-bit 8164/24420, SPIRAM 4148396/4194252 And, again with 3.1, here it is after starting SIMCOM modem, wifi in APCLIENT mode, TR vehicle module, and Server v2: OVMS# module memory Free 8-bit 79520/282048, 32-bit 8164/24420, SPIRAM 4136036/4194252 OVMS# module tasks Number of Tasks = 18 Stack: Now Max Total Heap 32-bit SPIRAM Task 3FFAEB34 1 esp_timer 392 648 6656 55140 644 0 Task 3FFAF7E0 2 eventTask 444 3116 4608 7620 0 0 Task 3FFC3F68 3 CanRxTask 420 420 4096 0 0 0 Task 3FFC8060 4 ipc0 396 444 1024 10848 0 0 Task 3FFC8660 5 ipc1 396 444 1024 12 0 0 Task 3FFCA488 8 IDLE 356 484 1024 0 0 0 Task 3FFCAA1C 9 IDLE 360 488 1024 0 0 0 Task 3FFCC3B0 10 Tmr Svc 396 3276 6144 7816 0 0 Task 3FFCF8F0 14 Housekeeping 364 2716 6144 53420 0 0 Task 3FFC8AB0 16 tiT 496 2752 6144 7112 0 0 Task 3FFD79C8 17 SIMCOMTask 452 2260 4096 4404 0 0 Task 3FFDB8C8 18 AsyncConsole 756 4964 5120 45864 15488 0 Task 3FFDCD84 19 mdns 416 1736 4096 108 0 0 Task 3FFE147C 20 wifi 424 2296 4096 5180 0 0 Task 3FFE3D74 21 pmT 416 464 2560 0 0 0 Task 3FFE6C30 22 NetManTask 732 2556 7168 2488 0 0 Task 3FFEAB08 23 Vrx Task 452 452 4096 0 0 0 Task 3FFEAD0C 24 OBDII ECU Task 424 424 6144 0 0 0 I think something got broken with a recent build of ESP-IDF so that our ‘module memory’ and ‘module tasks’ is not showing SPIRAM usage correctly. But, it is definitely used and certainly helps ease the stress: OVMS# module memory Free 8-bit 133032/282048, 32-bit 8164/24420, SPIRAM 4148396/4194252 OVMS# obdii ecu start can3 OBDII ECU has been started OVMS# module memory Free 8-bit 125000/282048, 32-bit 8164/24420, SPIRAM 4147772/4194252 --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM AsyncConsole 13896 6144 15488 0 +1876 +6144 +0 +0 We are far from perfect, but I think good enough for some factory firmware. Anything else will come as OTA. Regards, Mark.
Regards, Michael
Let me see if I can figure that out. It may be that I did not set the right capabilities mask in the user-level code. Unfortunately, I don't have v3.1 to test. -- Steve
Greg D. -
Julien “JaXX” Banchet -
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner
