Åter-: Re: Mitsubishi logging problem
I can change the code so the CarOn=1 only when that particular message (the 412) is received. But I still need to set it to 0 when the car is not on and charging. The current code is setting the CarOn=0 when CANBUS communication is missing for 60 seconds, so If I park the car, and plug it without switching off the CarOn is going to stay 1. Maybe a timer on the 412 message? So if not received within 10 seconds I can set CarOn to 0? Nikolay ------------------------------ Den sön 8 jun 2014 10:44 EEST skrev Thomas Bergo:
From what i remember this should be a easy fix.
The car_speed and car_odometer @ PID 412 is only updated when ignition is ON. So setting the car_doors1bits.CarOn = 1 when PID 412 is received should fix this issue. Setting car_doors1bits.CarOn = 0 when no CANBUS activity is already implemented in the code.
Regards, Thomas
2014-06-08 7:51 GMT+02:00 Tom Saxton <tom@idleloop.com>:
It sounds like the Mitsubishi code is setting the car_doors1bits.CarON incorrectly. That bit should only be set if the car is turned on. Perhaps it needs to be more discerning as to which CAN messages indicate the car is on.
Tom
On 6/7/14, 2:32 PM, "Nikolay Shishkov" <nshishkov@yahoo.com> wrote:
I have been testing the logging for the mitsubishi and noticed a problem with it - no matter if I was charging or driving the log was always showing driving. I have been looking at the code and I think I found the problem. If I understand this correctly in vehicle_mitsubishi_ticker1 function in vehicle_mitsubishi.c file the car_doors1bits.CarON is set depending on wheather there is CAN bus communication. This is unfortunate since the car_doors1bits.CarON (via CAR_IS_ON) is used in the logging.c to determine if the car is "driving"... and if it is, then it is not "charging".
I am not sure what the best solution would be: - to set the car_doors1bits.CarON to 0 if the car is charging or - to refactore the logging code to prefer the CAR_IS_CHARGING and test for it first in the various if/else statements.
I have not been able to build and test any of this yet.
Any comments, ideas, suggestions on how to solve this?
Nikolay
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Spec for this is: unsigned char car_doors1 [bit 7] A bit used to signal whether the car is turned on or off. Set to 1 if the car ignition switch is ON, otherwise 0. The correct approach is to set CarOn=1 only when the ignition switch is on. There are quite a few things that use that (not just logging, but also ACC and the code to speed-up reporting if the car is driving/charging). Regards, Mark. On 9 Jun, 2014, at 12:15 am, Nikolay Shishkov <nshishkov@yahoo.com> wrote:
Nikolay
Regards, Thomas
Tom
Nikolay
Mark Webb-Johnson -
Nikolay Shishkov
