I've pushed an update to enable saving crash data over a reset and automatically send that to the server using the history record "*-OVM-DebugCrash". Note: you will need to pull the esp-idf as well. As the support for exception handlers was insufficient for our needs, I have added a separate error handler registration that catches all three kinds of crashes (exceptions, panics and aborts). Crash reason, registers (if available) and backtrace are available via "boot status", with "make monitor" automatically mapping the addresses: OVMS# boot status Last boot was 16 second(s) ago This is reset #1 since last power cycle Detected boot reason: Crash Crash counters: 1 total, 0 early CPU#0 boot reason was 12 CPU#1 boot reason was 12 Last crash: abort() was called on core 1 Backtrace: 0x4008f698 0x4008f86f 0x400e7027 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937 0x401cb613 0x400e3f49 0x400e82e5 0x400e84d1 0x400e3df5 0x400e3e04 0x400e69dd 0x4008f698: invoke_abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669 0x4008f86f: abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669 0x400e7027: module_fault(int, OvmsWriter*, OvmsCommand*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:823 0x400edb76: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edc8d: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edc7f: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edcb5: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400e3908: Execute(microrl*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:47 0x400f11c9: new_line_handler at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:620 0x400f1230: microrl_insert_char at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:668 0x400e3937: OvmsShell::ProcessChar(char) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:70 0x401cb613: OvmsShell::ProcessChars(char const*, int) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:77 (discriminator 2) 0x400e3f49: ConsoleAsync::HandleDeviceEvent(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:169 0x400e82e5: OvmsConsole::Poll(unsigned int, void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:152 0x400e84d1: OvmsConsole::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:132 (discriminator 1) 0x400e3df5: ConsoleAsync::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:80 0x400e3e04: non-virtual thunk to ConsoleAsync::Service() at ??:? 0x400e69dd: TaskBase::Task(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./task_base.cpp:156 The "*-OVM-DebugCrash" record has this structure: // H type "*-OVM-DebugCrash" // ,<firmware_version> // ,<bootcount>,<bootreason_name>,<bootreason_cpu0>,<bootreason_cpu1> // ,<crashcnt>,<earlycrashcnt>,<crashtype>,<crashcore>,<registers>,<backtrace> …with registers and backtraces separated by spaces. Example: *-OVM-DebugCrash,0,2592000,3.1.003-11-g37c5f4b/factory/main (build idf v3.1-dev-453-g0f978bcb-dirty Apr 8 2018 14:42:07),1,Crash,12,12,1,0,abort(),1,,0x4008f698 0x4008f86f 0x400e7027 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937 0x401cb613 0x400e3f49 0x400e82e5 0x400e84d1 0x400e3df5 0x400e3e04 0x400e69dd To decode the backtrace, feed it to addr2line: balzer@leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> xtensa-esp32-elf-addr2line -pfiaC -e build/ovms3.elf 0x4008f698 0x4008f86f 0x400e7027 0x400edb76 0x400edc8d 0x400edc7f 0x400edcb5 0x400e3908 0x400f11c9 0x400f1230 0x400e3937 0x401cb613 0x400e3f49 0x400e82e5 0x400e84d1 0x400e3df5 0x400e3e04 0x400e69dd 0x4008f698: invoke_abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669 0x4008f86f: abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:669 0x400e7027: module_fault(int, OvmsWriter*, OvmsCommand*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:823 0x400edb76: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edc8d: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edc7f: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400edcb5: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94 0x400e3908: Execute(microrl*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:47 0x400f11c9: new_line_handler at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:620 0x400f1230: microrl_insert_char at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:668 0x400e3937: OvmsShell::ProcessChar(char) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:70 0x401cb613: OvmsShell::ProcessChars(char const*, int) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:77 (discriminator 2) 0x400e3f49: ConsoleAsync::HandleDeviceEvent(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:169 0x400e82e5: OvmsConsole::Poll(unsigned int, void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:152 0x400e84d1: OvmsConsole::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:132 (discriminator 1) 0x400e3df5: ConsoleAsync::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:80 0x400e3e04: non-virtual thunk to ConsoleAsync::Service() at ??:? 0x400e69dd: TaskBase::Task(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./task_base.cpp:156 There is also an option to write core dumps in esp-idf, but a core has 64K, and crashes are still too many. I think the backtrace is sufficient in most situations. We should keep a central archive of .elf files for the releases rolled out, so we don't need to recompile for debugging. Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Michael, Neat. I agree that the stack track is normally sufficient. I’ve started to store the production PUSH firmwares in a standardised way. You can find them at: http://api.openvehicles.com/firmware/ota/ <http://api.openvehicles.com/firmware/ota/>(v3.0|v3.1)/main/ <http://api.openvehicles.com/firmware/ota/v3.0/main/> <ver>.ovms3.bin <ver>.ovms3.elf <ver>.ovms3.map Where <ver> is the version in format ‘major.minor.sequence' such as 3.1.003. So, for example: http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.003.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.003.ovms3.elf> Regards, Mark
On 8 Apr 2018, at 8:56 PM, Michael Balzer <dexter@expeedo.de <mailto:dexter@expeedo.de>> wrote:
Example:
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Att: addr2line reports wrong line numbers. That's a known issue: https://github.com/jcmvbkbc/binutils-gdb-xtensa/issues/5 Workaround is using gdb. I've made a little bash script named "a2l" for this: #!/bin/bash elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf for adr in $* ; do cmd+=" -ex 'l *$adr'" ; done cmd+=" -ex 'q'" eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null | grep " is in " You can also leave out the final grep if you want to see the source context. 80% of the crashes I have recorded today have been out of memory issues. The remaining 20% have all been along this path: 0x400f8432 is in mg_send_dns_query (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:11168). 0x400f85d9 is in mg_resolve_async_eh (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:11628). 0x400f644b is in mg_call (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2277). 0x400f6536 is in mg_if_poll (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2318). 0x400f7a56 is in mg_mgr_handle_conn (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:3729). 0x400f7ca9 is in mg_socket_if_poll (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:3916). 0x400f4471 is in mg_mgr_poll (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mongoose/mongoose/mongoose.c:2446). 0x400eb9e6 is in OvmsNetManager::MongooseTask() (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_netmanager.cpp:382). 0x400eba25 is in MongooseRawTask(void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_netmanager.cpp:370). …which is what Greg reported as "webserver status crash" but also occurs without user interaction. This is related to network changes, for example losing contact to a wifi station quite often triggers this. It looks like mongoose continues to use some object that has been deleted by another task, but I need to have a closer look tomorrow. Regards, Michael Am 08.04.2018 um 16:11 schrieb Mark Webb-Johnson:
Michael,
http://api.openvehicles.com/firmware/ota/(v3.0|v3.1)/main/ <http://api.openvehicles.com/firmware/ota/v3.0/main/>
So, for example:
Regards, Mark
Example:
Regards, Michael
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
gdb is better, but also not exact. Line numbers reported are usually around 2-5 lines too low. I'm pretty sure now the crashes in mg_send_dns_query() are also memory related, it looks like MG_CALLOC() fails. I think this happens because we still buffer notifications in RAM. The Twizy firmware sends a lot of data notifications which may add up on a temporary loss of connection. I'm looking forward to testing with the v3.1 module. The first has arrived in germany, mine has been routed to the customs department… let's see what happens next… Regards, Michael Am 09.04.2018 um 00:27 schrieb Michael Balzer:
Regards, Michael
Michael,
So, for example:
Regards, Mark
Example:
Regards, Michael
Michael, I just took a quick look at the diff. There are many lines changed because trailing whitespace was removed, presumably as an automatic action by your editor. Is that something you can configure it not to do? I noticed the same phenomenon on some of Mark's recent commits as well, when the files being committed were ones that he had created/edited before, so perhaps you and he are using a new editor or its policy has changed. I don't like trailing whitespace, and I am careful to avoid it as I write code. However, I also take extra effort to avoid removing any existing trailing whitespace (or make other unrelated changes like comment fixes) as part of committing a change, especially for source that isn't mine. I sometimes make separate commits with just those nonfunctional changes. This is to keep the annotation log meaningful. I don't mean this as a major criticism, just a question. -- Steve
Stephen, I don't care about trailing whitespace, but I know what you mean. I usually set my diff options to "-b" and "core.whitespace" to "-trailing-space" so git also doesn't care. My editor is set to "do not remove trailing whitespace", but you're right, somehow the trailing ws in Kconfig and xtensa_api.h have been removed. Strange, I can't explain that… maybe a git feature I don't know about? Regards, Michael Am 08.04.2018 um 18:35 schrieb Stephen Casner:
Michael,
-- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I use Atom, which ships by default with the ‘whitespace’ package. That removes trailing whitespaces. Did a quick check in our project, and we have it in 10 files in main/ - mostly whitespace on blank lines (which my editor is set to NOT remove - but I think it should). In our own project, I think we should in general remove this. But, as Steven says, better to do it as a separate commit. Mea culpa. Regards, Mark.
On 9 Apr 2018, at 1:20 AM, Michael Balzer <dexter@expeedo.de> wrote:
Stephen,
Regards, Michael
Michael,
Mystery solved: there is a .editorconfig file in the esp-idf root directory which my editor (kate) automatically uses, sadly without telling me or showing in the config menu. Obviously, the last one who worked on the two files affected used an editor that doesn't use that scheme. Regards, Michael Am 09.04.2018 um 04:23 schrieb Mark Webb-Johnson:
Regards, Mark.
Stephen,
Regards, Michael
Michael,
-- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Michael, That's very interesting. That possible cause had not occurred to me because I don't use EditorConfig. I looked into it briefly a while back, but didn't explore what is necessary to use it with Emacs. In the past I have used Emacs' own mechanism, which puts the settings in comments at the top of the file being edited, but I don't have the freedom to do that in this project so I manually set a profile each time I open a file. That is tolerable because I rarely reboot my Mac and I leave Emacs running. But it might be worthwhile to consider using .editorconfig in our project. -- Steve On Mon, 9 Apr 2018, Michael Balzer wrote:
Regards, Michael
I use Atom, which ships by default with the 'whitespace' package. That removes trailing whitespaces.
Regards, Mark.
Stephen,
My editor is set to "do not remove trailing whitespace", but you're right, somehow the trailing ws in Kconfig and xtensa_api.h have been removed. Strange, I can't explain that... maybe a git feature I don't know about?
Regards, Michael
Michael,
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner
