Now i change the sd card to a smaller, and formatted to fat32 (16Gb), but on reboot is crashing. Now connect a computer to the usb port, and create a log in verbose, attached to the email. -- Üdvözlettel: Kovács Tamás
The log shows it actually crashes during the shutdown process -- but @Michael, I'm pretty sure this is an old issue, turning up now only by chance. This looks like a race condition between event handler invocation and deregistration: Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited).Exception was unhandled. … Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60 0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00 → Crash at *0x41000000* (invalid address), called from: 0x401208ed is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_events.cpp:310). 305 { 306 for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc) 307 { 308 m_current_started = monotonictime; 309 m_current_callback = *itc; *310 m_current_callback->m_callback(m_current_event, msg->body.signal.data);* 311 m_current_callback = NULL; 312 } 313 } 314 } From there it then enters a crash loop from the crash handler somehow running into an illegal address when trying to access the RTC boot_data object (?). I think, when introducing the separate event handling task, we missed adding a lock to make manipulations & accesses to the event handler list atomic. The log shows, the event queue grew significantly due to duktape/scripts lagging during shutdown (as seen in the log), so the task was quite busy. So probably a `DeregisterEvent()` call from the shutdown process came in, invalidating a callback entry just while the event task was processing that callback list. Solving this may need some additional thoughts & measures: locking the whole event registry with handlers lagging like this could lead to a deadlock… probably at least the Duktape component needs to cleanly abort/reject all pending events before/while deregistering. Michael, if you'd like to have a look at this, go ahead. Regards, Michael Am 01.01.25 um 11:47 schrieb Tamás Kovács via OvmsDev:
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Michael Balzer * Am Rahmen 5 * D-58313 Herdecke Fon 02330 9104094 * Handy 0176 20698926
Tamás, I've got a test build that should fix your reboot issue, if my diagnosis was correct. Can you please test this firmware image? http://ovms.dexters-web.de/f/firmware/test/ovms3.bin The build works in my test & live module. The changes are not yet checked in, patch attached. This consists of a) delegating registry changes to the event task and b) invalidating callbacks in the list on deregistration before actually deleting them, so the list processing cannot run into deleted entries, when deregistration is done from within a callback execution. The changes need another mutex and a larger event queue. I had queue size 40 before, minimum now is 80, build uses 100 to be on the safe side. That means another 720 bytes of 8-bit RAM are used for the queue unfortunately, but that shouldn't be a problem yet. I also again needed to power off my module for the reboot, but with the new firmware, the reboot works. So chances are, this issue is now hit more often than before, probably because of more stuff going on in the shutdown. Regards, Michael Am 02.01.25 um 15:25 schrieb Michael Balzer via OvmsDev:
Regards, Michael
Everyone, I've just checked in my changes, so this is now included in the edge build (3.3.004-331-g4a7b966d, already available on dexters-web). I had no issues with my modules, but depending on the vehicle & configuration, we may need to raise the new default queue size beyond 100. Please test & report. If the queue is too small, the module will crash with a "queue overflow" log entry. Regards, Michael Am 06.01.25 um 20:49 schrieb Michael Balzer via OvmsDev:
Tamás,
Regards, Michael
Regards, Michael
Now i use after send to me, i restarted the modul many times and no problem. Michael Balzer via OvmsDev <ovmsdev@lists.openvehicles.com> ezt írta (időpont: 2025. jan. 8., Sze, 8:29):
Everyone,
Regards, Michael
Tamás,
Regards, Michael
Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited). Exception was unhandled. … Backtrace: 0x41000000:0x3ffc8c30 0x401208ed:0x3ffc8c60 0x401209d4:0x3ffc8cc0 0x40120a5d:0x3ffc8d00
Regards, Michael
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
I compiled and installed 3.3.004-331-g4a7b966d The initial reboot after the update crashed (as expected). Now rebooting works again. Thanx! Chris Am Mittwoch, dem 08.01.2025 um 19:42 +0100 schrieb Tamás Kovács via OvmsDev:
Everyone,
I've just checked in my changes, so this is now included in the edge build (3.3.004-331-g4a7b966d, already available on dexters- web).
Regards, Michael
Tamás,
Regards, Michael
The log shows it actually crashes during the shutdown process - - but @Michael, I'm pretty sure this is an old issue, turning up now only by chance.
→ Crash at 0x41000000 (invalid address), called from:
0x401208ed is in OvmsEvents::HandleQueueSignalEvent(event_queue_t*) (/home/balzer/esp/Open-Vehicle-Monitoring-System- 3/vehicle/OVMS.V3/main/ovms_events.cpp:310). 305 { 306 for (EventCallbackList::iterator itc=el->begin(); itc!=el->end(); ++itc) 307 { 308 m_current_started = monotonictime; 309 m_current_callback = *itc; 310 m_current_callback->m_callback(m_current_event, msg->body.signal.data); 311 m_current_callback = NULL; 312 } 313 } 314 }
Regards, Michael
Chris van der Meijden -
Michael Balzer -
Tamás Kovács
