[Ovmsdev] Firmware size approaching 4 MB limit
Wed Feb 25 15:59:42 HKT 2026
@Craig: nice find!
Am 25.02.26 um 02:58 schrieb Mark Webb-Johnson:
> Michael,
>> AFAICT "ota partitions upgrade" currently does not verify the system
>> has booted from "factory" before allowing the operation -- I think
>> that should be added as a safety measure.
> I thought it did that check. Maybe not working?
No, you're right, should be OK that way. But as Craig's result shows, I
still should test it ;-)
> Here are the three partition table options:
> Original (f12):
> Label Type Subtype Offset (Hex) Size (Hex) Next (Hex) Offset
> (Dec) Size (Dec)
> bootloader bootloader bootloader 0x0000 0x8000 8000 0 32768
> partition_table partition_table partition_table 0x8000 0x1000
> 9000 32768 4096
> nvs data nvs 0x9000 0x4000 D000 36864 16384
> otadata data ota 0xD000 0x2000 F000 53248 8192
> phy_init data phy 0xF000 0x1000 10000 61440 4096
> factory app factory 0x10000 0x400000 410000 65536 4194304
> ota_0 app ota_0 0x410000 0x400000 810000 4259840 4194304
> ota_1 app ota_1 0x810000 0x400000 C10000 8454144 4194304
> store data fat 0xC10000 0x100000 D10000 12648448 1048576
> *unused*
> 0xD10000 0x2F0000 1000000 13697024 3080192
> Current (12):
> (Dec) Size (Dec)
> 9000 32768 4096
> ota_0 app ota_0 0x10000 0x600000 610000 65536 6291456
> ota_1 app ota_1 0x610000 0x600000 C10000 6356992 6291456
> *unused*
> Suggested (12, 7MB code, more store):
> (Dec) Size (Dec)
> 9000 32768 4096
> ota_0 app ota_0 0x10000 0x700000 710000 65536 7340032
> ota_1 app ota_1 0x710000 0x700000 E10000 7405568 7340032
> store data fat 0xE10000 0x1F0000 1000000 14745600 2031616
> It would make sense to resize store *now* if we are going to do it,
> but I am wary of requiring a factory reset. Also need to double check
> that the unused space at the end is truly unused. I am assuming the
> boot loader is in the first 32KB, but haven’t actually checked.
> Looking at the third (resize store) arrangement, it would be moving
> 0xC10000-0xD0FFFF to 0xE10000-0xFFFFFF, which doesn’t seem to overlap.
> I wonder what simply copy that partition over (without reformatting
> flash) would do? Either corrupt the filesystem, ignore the extra
> space, or magically have the new space available to FAT? I suspect
> corruption. So, there is another (more complex) alternative:
> 1. Create a 2nd fat store partition (0xE10000-0xFFFFFF)
> 2. Format and mount that as FAT
> 3. Copy files from old to new
> 4. Unmount and drop the old store
> 5. Finish the rest of the partition upgrade
> I suspect #3 would be the most complex step.
> Or the store move and resize could be done first as a separate step.
> Thoughts? Much more complex and risky...
There's the fatresize tool, didn't check the code, but given we can
simply create the new partition cleanly and copy the files there, we
should go that way.
I second the store resize should be the first upgrade step:
Unmounting /store while running may be risky, that was never needed and
up to now only occurrs during shutdown as a final step.
I suggest we just relable the old "store" partition and do a reboot
instead. esp_vfs_fat_spiflash_mount() searches for the partition by
name, so the system should automatically mount & use the new "store" on
boot.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260225/c5681faf/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260225/c5681faf/attachment-0001.sig>
