[Ovmsdev] Firmware size approaching 4 MB limit
Wed Feb 25 06:00:07 HKT 2026
Tested, works like a charm -- test log below.
Only thing that was a bit odd: "ota" still showed the old layout
directly after "ota partitions upgrade" (before the reboot). Probably
cached, "ota partitions list" showed the new layout.
I then tried rebooting into the old build to see if doing an OTA update
from there would show any issues -- nope, works perfectly, installs to
the other OTA partition and boots from there. So even after the upgrade,
people can still run older firmware versions and perform normal OTA
updates, the partitions are identified and located correctly by their label.
Only thing odd with that was: "ota boot factory" failed correctly (did
nothing), but did so without any error output. Not really a situation
that will occur with normal users, so not really an issue.
AFAICT "ota partitions upgrade" currently does not verify the system has
booted from "factory" before allowing the operation -- I think that
should be added as a safety measure.
I can take care of the web UI modifications if you like.
Regarding the product version 3.5 to distinguish 6MB capable modules, I
think that's a neat & simple solution.
> P.S. There is a possibility to do this another way to make even more
> flash space available, but that would mean moving the store partition
> right to the end of the 16MB flash, which is not so simple. Is 6MB
> really enough? Probably so if we can move to javascript vehicle
> modules, otherwise probably not (long-term).
I see what you mean… I wasn't aware there is so much space left unused
now. Like this, if partition alignment constraints allow?
Label Type Subtype Address Size
nvs data nvs 0x00009000 16 KB
otadata data ota 0x0000d000 8 KB
phy_init data phy 0x0000f000 4 KB
ota_0 app ota_0 0x00010000 7.46875 MB (0x778000 bytes)
ota_1 app ota_1 0x00788000 7.46875 MB(0x778000 bytes)
store data fat 0x00f00000 1 MB
OK, that's substantially more.
Another option would be to allocate say 7 MB to each OTA partition (or
even keep them at 6 MB) and add the remaining free capacity to store.
Performing a config restore currently already fails due to lack of space
when not done from a freshly cleared config, especially with some
scripts & plugins installed.
With custom JS vehicles being installed to /store, that will get a bit
more tight yet, and maybe JS vehicles want to use /store for some
extended data storage as well. So more capacity for /store would make
sense, heading in that direction.
OVMS# ota
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Firmware: 3.3.005-711-g4feca695d/factory/edge (build idf
v3.3.4-854-g9063c8662c Feb 24 2026 21:17:07)
Partition type: v3-f12 (factory, ota1, ota2)
Partition table: 0x8000
Running partition: factory
Boot partition: factory
Factory image: 3.3.005-711-g4feca695d
OTA_O image: 3.3.005-711-g4feca695d
OTA_1 image: 3.3.005-704-g6a1fed98
OVMS# ota partitions list
Partition table:
factory app factory 0x00010000 4 MB
ota_0 app ota_0 0x00410000 4 MB
ota_1 app ota_1 0x00810000 4 MB
store data fat 0x00c10000 1 MB
Digest: cfe36765a6bfe1b802a2abd4ec9f6851 pass
OVMS# ota partitions upgrade
Upgrade partition table to new format (y/n): y
0x00009000 Skipping over data/nvs partition
0x0000d000 Skipping over data/ota partition
0x0000f000 Skipping over data/phy partition
0x00010000 Converted factory partition to 6MB OTA 0
0x00610000 Converted OTA 0 partition to 6MB OTA 1
0x00c10000 Moved data/fat partition up one position
Recalculated MD5 checksum
Clearing trailing old MD5 checksum record
Erasing old partition table (4096 bytes at 0x00008000)...
Writing new partition table (4096 bytes at 0x00008000)...
Partition table upgraded successfully - reboot required
OVMS# ota
Partition table:
ota_0 app ota_0 0x00010000 6 MB
ota_1 app ota_1 0x00610000 6 MB
Digest: a0d94b1efa7f6d8852b44150db218e8d pass
OVMS# module reset
Resetting system...
OVMS# ota
Firmware: 3.3.005-711-g4feca695d/ota_0/edge (build idf
Partition type: v3-12 (ota1, ota2, no factory)
Running partition: ota_0
Boot partition: ota_0
Partition table:
OVMS# ota boot ?
Usage: ota boot ota_0|ota_1
ota_0 Boot from ota_0 image
ota_1 Boot from ota_1 image
OVMS# ota copy ?
Usage: ota copy ota_0|ota_1
ota_0 OTA copy ota_0 <to>
ota_1 OTA copy ota_1 <to>
OVMS# ota erase ?
Usage: ota erase ota_0|ota_1
ota_0 Erase ota_0 image
ota_1 Erase ota_1 image
Am 24.02.26 um 13:40 schrieb Mark Webb-Johnson:
> OK, I have just committed this. The two new commands are:
> * ota partitions list
> * ota partitions upgrade [-noconfirm]
> Rollback is via:
> * wget http://api.openvehicles.com/firmware/ota/v3.1/main/partitions.bin
> * esptool.py -p <path-to-usb> write_flash 0x8000 partitions.bin
> General approach to manual upgrade:
> 1. Upgrade to firmware supporting this feature (3.3.005-711-g4feca695
> or later)
> 2. Copy running ota firmware to factory
> 3. Set to boot from flash and reboot
> 4. Use ‘ota partitions upgrade’ to upgrade
> 5. Reboot
> Items still to be addressed:
> * Documentation (including rollback procedure).
> * Modify partitions.csv to use this new format (when ready for
> production).
> * Web interface (in particular concept of factory vs ota), if
> necessary (haven’t checked this).
> * OTA flash builds. We will need a way to support 6MB builds for
> those that can use them. I suggest to change GetOVMSProduct() to
> return v3.5 for these modules that are running this new 6MB
> capable partition table. Then on server we can build a production
> release final 4MB firmware including this support, and then use
> v3.5 tree to build future 6MB only builds. The ‘ota flash’ system
> would automatically support that and give people time to upgrade
> (as well as new users with 4MB partition modules for many months).
> * Investigate any simple way to make this a simple one-command
> (current ota->factory, boot factory, reboot, partitions upgrade,
> reboot).
> For the moment, please try this out and let me know if you find any
> problems. We can then decide on the items still to be addressed.
>> On Feb 23, 2026, at 12:27 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Awesome :-)
>> We need to update the user manual's firmware rescue guide
>> (https://docs.openvehicles.com/en/latest/userguide/factory.html#flash-factory-firmware-via-usb)
>> accordingly, so in case anything goes wrong, users can help
>> themselves or get local help.
>> The 4KB RAM overhead shouldn't be an issue I think, but we could add
>> a free memory check and recommend switching to the "NONE" vehicle
>> while performing the operation, if memory is too tight.
>>> P.S. OVMS v2 had to fit in 96KB of flash ;-)
>> …and 3328 bytes of RAM in total… so much for the "overhead" ;-)
>> Am 22.02.26 um 16:00 schrieb Mark Webb-Johnson:
>>> I’ve made some progress with this:
>>> OVMS# ota status nocheck
>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
>>> Firmware: 3.3.005-704-g6a1fed98-dirty/factory/edge (build idf
>>> v3.3.4-854-g9063c8662-dirty Feb 22 2026 22:28:00)
>>> Factory image: 3.3.005-704-g6a1fed98-dirty
>>> OTA_O image: 3.3.005-662-g1f318f04
>>> OTA_1 image: 3.3.005-643-gdbec4a13
>>> Partition table:
>>> ## Before upgrade, user needs to copy current OTA to FACTORY,
>>> set boot partition to FACTORY, then reboot
>>> ## The upgrade process checks this and will refuse to upgrade
>>> unless that is the case
>>> Partition table:
>>> This is mostly implemented in a new ovms_partitions.{h,cpp} in
>>> ovms_ota component, with only minor extensions to ovms_ota itself. I
>>> have removed the ‘factory’ commands from ovms_ota if the new
>>> partition layout is detected at boot.
>>> One big ‘gotcha’ I found was that we need to
>>> set CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORT=
>>> and CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=y in our
>>> sdkconfig - otherwise the partition table cannot be re-flashed.
>>> The partition table must also be held in internal (not external SPI)
>>> RAM - which is about a 4KB overhead just for these checks.
>>> The usual app-flash still works (and now targets the first OTA at
>>> 0x0010000, rather than factory), so this approach seems feasible and
>>> workable now. Once we are happy with this, and have a production
>>> firmware supporting this layout, I can also provide a new
>>> partitions.bin to the factory for new units to ship with.
>>> I have a few minor enhancements to make: (a) add a ‘yes/no’ (like
>>> factory reset), (b) an option to load partition table in
>>> internal/external ram (internal only at the moment), and (c) some
>>> minor tidy-ups. I suggest then to just check it in with this basic
>>> manual functionality that can be experimented with. Absent any
>>> comments / suggestions, I should be able to commit this early in the
>>> coming week.
>>>> On Jan 21, 2026, at 11:12 AM, Mark Webb-Johnson
>>>> <mark at webb-johnson.net> wrote:
>>>> Michael,
>>>> The links are very helpful.
>>>> I have some time, and inclination to handle this (now that my new
>>>> home build host is up and running and a make of OVMS from clean,
>>>> with 32 cores and a fast SSD, is under 25 seconds).
>>>> real0m24.642s
>>>> user5m50.376s
>>>> sys0m38.276s
>>>> We’ve already got the ‘ota copy’ command, so I will start with
>>>> trying to work on manipulation of the partition table and improving
>>>> the ‘ota status’ command to show partition table format and sizes.
>>>> Regards, Mark.
>>>>> On 11 Jan 2026, at 5:34 PM, Michael Balzer via OvmsDev
>>>>> <ovmsdev at lists.openvehicles.com> wrote:
>>>>> Signed PGP part
>>>>> On the migration tool for changing the partition table from a
>>>>> running application, we're (of course) not the first having that
>>>>> issue.
>>>>> If we're about to go that way, here is an implementation of the
>>>>> process:
>>>>> * Explanation:https://johnmu.com/2024-esp32-partition-update/
>>>>> * Source:https://github.com/softplus/Esp32Repartition
>>>>> It's written for the Arduino IDE with the PlatformIO lib to create
>>>>> a UI, but the core function is straight forward and should be
>>>>> adaptable for us.
>>>>> The implementation allows for direct manipulations of the
>>>>> partition table, i.e. doesn't need a prepared table blob to flash.
>>>>> Using a prepared blob should be even more simple, basically just a
>>>>> matter of `spi_flash_erase_range()` & `spi_flash_write()`
>>>>> (→https://github.com/softplus/Esp32Repartition/blob/main/src/part_mgr.cpp#L297).
>>>>> We probably don't even need `getPartitionTableAddr()`, as our
>>>>> table is fixed at 0x8000.
>>>>> The code needed is small. When using a blob, the table in theory
>>>>> uses a full flash sector of 4096 bytes, but probably doesn't fill
>>>>> the whole sector.
>>>>> Regards,
>>>>> Michael
>>>>> Am 08.12.25 um 07:01 schrieb Mark Webb-Johnson via OvmsDev:
>>>>>> Michael, Carsten,
>>>>>> I think that if targeting things to cull, we would need to be
>>>>>> balance size vs importance. For example, the RE tools mentioned
>>>>>> is just 10KB total size. By comparison TPMS is 9KB, and web
>>>>>> server is 538KB.
>>>>>> We learned with OVMS v2 that the biggest culprits in the long-run
>>>>>> are always the vehicle modules. The core system stays pretty
>>>>>> stable, but the space required for *all* vehicle modules grows
>>>>>> with the number of vehicles supported.
>>>>>> I don’t think we can simply switch to 32MB flash, as that would
>>>>>> abandon the existing users. We would also need to source a
>>>>>> standard certified 32MB module (which I don’t think Espressif
>>>>>> offer themselves).
>>>>>> Looking at the partition table:
>>>>>> # OVMS 16MB flash ESP32 Partition Table
>>>>>> # Name, Type, SubType, Offset, Size
>>>>>> nvs, data, nvs, 0x9000, 0x4000
>>>>>> otadata, data, ota, 0xd000, 0x2000
>>>>>> phy_init, data, phy, 0xf000, 0x1000
>>>>>> factory, app, factory, 0x10000, 4M
>>>>>> ota_0, app, ota_0, , 4M
>>>>>> ota_1, app, ota_1, , 4M
>>>>>> store, data, fat, , 1M
>>>>>> Assuming we could (and that is a big assumption given our older
>>>>>> SDK) change that at runtime, then a possible migration path could be:
>>>>>> 1. Have our code support both old and new partition table
>>>>>> formats, and refuse to update to old format if firmware >
>>>>>> 4MB. Get that code out into the hands of users.
>>>>>> 2. Provide a migration tool for partition table:
>>>>>> 1. Copy running code to factory (from ota_0 or ota_1,
>>>>>> whichever is current).
>>>>>> 2. Reboot
>>>>>> 3. Change partition table (most likely replacing the entire
>>>>>> table with a binary blob of the new format)
>>>>>> 1. factory 4MB -> ota_0 same offset, 6MB size
>>>>>> 2. ota_0 -> ota_1 6MB offset, 6MB size
>>>>>> 4. Change boot to ota_0.
>>>>>> 5. Reboot
>>>>>> 3. Liase with factory so new modules use new partition format
>>>>>> (and ship with firmware that supports it).
>>>>>> 4. Wait a reasonable time for users to update before releasing
>>>>>> any firmware > 4MB.
>>>>>> That would work more similarly to other more modern ESP
>>>>>> frameworks which don’t bother with ‘factory’. It would allow us
>>>>>> another 50% expansion. But it does run the risk of bricking
>>>>>> (requiring espflash to recover) during the process.
>>>>>> But longer-term, the solution to me seems to be to allow the
>>>>>> vehicle module code to overlay - so only the single vehicle you
>>>>>> choose is loaded. And (absent any dynamic linking of modular code
>>>>>> in freertos), the only straightforward way of doing that I know
>>>>>> of is migrating vehicle support to Javascript (which comes along
>>>>>> with a host of other advantages - most notably not having to be a
>>>>>> C++ embedded developer to add/refine vehicle support).
>>>>>> Regards, Mark.
>>>>>>> On 7 Dec 2025, at 4:39 PM, Carsten Schmiemann via
>>>>>>> OvmsDev<ovmsdev at lists.openvehicles.com>wrote:
>>>>>>> Hi Michael,
>>>>>>> It was to be expected that we would eventually run out of flash
>>>>>>> storage. That’s why I would immediately question whether we
>>>>>>> should detach ourselves from components that aren’t really being
>>>>>>> used. We could even start a survey or something like that.
>>>>>>> For example, the RE tools — the idea behind them is great, but
>>>>>>> without documentation they’re not easy to use, and every time I
>>>>>>> tried to work with them, it just resulted in crashes.
>>>>>>> Then there’s the question of who actually uses Telnet, SSH, the
>>>>>>> Duktape framework, the DBC parser, OBD2ECU, or CANopen (yes, the
>>>>>>> Twizy integration is the only one that uses it).
>>>>>>> All great ideas, but in the end, how many users really make use
>>>>>>> of them?
>>>>>>> The fewer active components we have to maintain, the ‘easier’ it
>>>>>>> would also be to port the code to a more current ESP-IDF version
>>>>>>> — and that would bring significant benefits such as improved
>>>>>>> networking features, including firewall capabilities and a much
>>>>>>> more stable switching between LTE and Wi-Fi. I’ve looked at
>>>>>>> llanges attempts and it’s extremely tough.
>>>>>>> As an example, in my own custom firmware builds, I don’t enable
>>>>>>> the components (and of course not all vehicles, so not 100
>>>>>>> percent representative) mentioned above. This requires small
>>>>>>> modifications in the code because, for example, the ESP logger
>>>>>>> is missing but referenced in another file, etc. But my firmware
>>>>>>> file is only about 2.8 MB.
>>>>>>> Just my 2 cents
>>>>>>> Carsten
>>>>>>>> Am 07.12.2025 um 08:57 schrieb Michael Balzer via
>>>>>>>> OvmsDev<ovmsdev at lists.openvehicles.com>:
>>>>>>>> FYI: use `make size-components` to create a report on all
>>>>>>>> component sizes (`make size-files` for source file level).
>>>>>>>> Unsurprisingly the webserver is on top, even with all assets
>>>>>>>> precompressed already.
>>>>>>>> *_Top 10 components:_*
>>>>>>>> Per-archive contributions to ELF file:
>>>>>>>> Archive File DRAM .data & .bss IRAM Flash code & rodata Total
>>>>>>>> libovms_webserver.a 0 255 0 134342 399846 534443
>>>>>>>> libstdc++.a 149 5640 0 141045 72513 219347
>>>>>>>> libmain.a 15 2104 0 139216 40086 181421
>>>>>>>> libduktape.a 0 0 0 141641 20367 162008
>>>>>>>> libvehicle_renaulttwizy. 0 29 0 86517
>>>>>>>> 75357 161903
>>>>>>>> libc-psram-workaround.a 1854 66 18391 118283
>>>>>>>> 10943 149537
>>>>>>>> liblwip.a 17 3873 0 118366 16722 138978
>>>>>>>> libnet80211.a 938 9042 10475 92339 21900 134694
>>>>>>>> libmbedtls.a 100 560 76 107079 26785 134600
>>>>>>>> libvehicle_vweup.a 8 8 0 60846 43432 104294
>>>>>>>> *_Vehicles:_*
>>>>>>>> 75357 161903
>>>>>>>> libvehicle_mgev.a 156 26 0 47756 33998 81936
>>>>>>>> libvehicle_smarteq.a 82 15 0 59267 19527 78891
>>>>>>>> libvehicle_smarted.a 0 9 0 48481 28801 77291
>>>>>>>> libvehicle_renaultzoe_ph 4 10 0 44622
>>>>>>>> 29564 74200
>>>>>>>> libvehicle.a 0 68 0 57735 12062 69865
>>>>>>>> libvehicle_bmwi3.a 0 2 0 33370 14357 47729
>>>>>>>> libvehicle_minise.a 9432 2 0 35360 2210 47004
>>>>>>>> libvehicle_hyundai_ioniq 176 7 0 32921
>>>>>>>> 13425 46529
>>>>>>>> libvehicle_nissanleaf.a 0 3 0 35491
>>>>>>>> 8941 44435
>>>>>>>> libvehicle_kiasoulev.a 240 9 0 32508 5473
>>>>>>>> 38230
>>>>>>>> libvehicle_kianiroev.a 108 7 0 24070 4006
>>>>>>>> 28191
>>>>>>>> libvehicle_mitsubishi.a 0 5 0 21645
>>>>>>>> 3893 25543
>>>>>>>> libvehicle_boltev.a 0 5 0 15999 7864 23868
>>>>>>>> libvehicle_niu_gtevo.a 4 12 0 18248 3733
>>>>>>>> 21997
>>>>>>>> libvehicle_maxus_edelive 156 3 0 10713
>>>>>>>> 7477 18349
>>>>>>>> libvehicle_renaultzoe.a 0 6 0 14828
>>>>>>>> 2859 17693
>>>>>>>> libvehicle_maxus_euniq56 156 3 0 8363
>>>>>>>> 6840 15362
>>>>>>>> libvehicle_voltampera.a 0 5 0 13221
>>>>>>>> 1932 15158
>>>>>>>> libvehicle_hyundai_ioniq 0 3 0 11081
>>>>>>>> 3191 14275
>>>>>>>> libvehicle_teslaroadster 0 6 0 10367
>>>>>>>> 2238 12611
>>>>>>>> libvehicle_thinkcity.a 0 3 0 6114 3449
>>>>>>>> 9566
>>>>>>>> libvehicle_jaguaripace.a 0 8 0 5445
>>>>>>>> 3941 9394
>>>>>>>> libvehicle_fiatedoblo.a 0 2 0 4262
>>>>>>>> 2126 6390
>>>>>>>> libvehicle_teslamodels.a 0 2 0 5361
>>>>>>>> 948 6311
>>>>>>>> libvehicle_toyotarav4ev. 0 2 0 5023
>>>>>>>> 1255 6280
>>>>>>>> libvehicle_maxus_t90.a 0 3 0 2567 2204
>>>>>>>> 4774
>>>>>>>> libvehicle_byd_atto3.a 0 2 0 3503 947
>>>>>>>> 4452
>>>>>>>> libvehicle_energica.a 0 1 0 3319 880 4200
>>>>>>>> libvehicle_demo.a 0 2 0 3205 795 4002
>>>>>>>> libvehicle_maxus_euniq6. 0 2 0 2470
>>>>>>>> 1182 3654
>>>>>>>> libvehicle_fiat500.a 0 2 0 2838 732 3572
>>>>>>>> libvehicle_zombie_vcu.a 0 4 0 1882
>>>>>>>> 1259 3145
>>>>>>>> libvehicle_mercedesb250e 0 2 0 2113
>>>>>>>> 955 3070
>>>>>>>> libvehicle_zeva.a 0 2 0 2209 688 2899
>>>>>>>> libvehicle_dbc.a 0 2 0 1278 1395 2675
>>>>>>>> libvehicle_cadillac_c2_c 0 7 0 1293
>>>>>>>> 1105 2405
>>>>>>>> libvehicle_maple60s.a 0 2 0 1416 698 2116
>>>>>>>> libvehicle_chevrolet_c6_ 0 2 0 1053
>>>>>>>> 1049 2104
>>>>>>>> libvehicle_obdii.a 0 2 0 957 1007 1966
>>>>>>>> libvehicle_teslamodel3.a 0 2 0 458
>>>>>>>> 713 1173
>>>>>>>> libvehicle_none.a 0 2 0 418 684 1104
>>>>>>>> libvehicle_track.a 0 2 0 416 680 1098
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 06.12.25 um 10:33 schrieb Michael Balzer via OvmsDev:
>>>>>>>>> Everyone,
>>>>>>>>> with the latest vehicle additions, the firmware size has now
>>>>>>>>> grown to 4,015,328 bytes in build 3.3.005-485-gc4664881.
>>>>>>>>> Our flash partitioning scheme is currently designed to provide
>>>>>>>>> three firmware partitions (factory, ota_0 & ota_1) of 4MB =
>>>>>>>>> 4,194,304 bytes each.
>>>>>>>>> So we've now got 178,976 bytes = ~4% left.
>>>>>>>>> Options beyond the 4 MB limit:
>>>>>>>>> a) split features, e.g. vehicle support, into two or more builds
>>>>>>>>> b) repartition into two firmware partitions of 6 MB each,
>>>>>>>>> reusing the factory partition for OTA
>>>>>>>>> c) switch to an ESP32 WROOM module with 32 MB flash (possible?)
>>>>>>>>> We've got some time left, new vehicles normally don't need
>>>>>>>>> that much space, I just wanted to raise awareness.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>>>>>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260224/3937fde5/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260224/3937fde5/attachment-0001.sig>
