[Ovmsdev] Adding support for eGolf
Erick Fuentes fuentes.erick at gmail.com
Thu Feb 5 19:53:27 HKT 2026
Michael - Thank you for the feedback. I'll work on getting things into
better shape. I asked Mikus for a harness and it should arrive in about a
week, so in the meantime, I'll be working at my desk. I don't think I saw
any, but is there any infrastructure for unit testing?
Chris - Michael mentioned your previous attempt. I took a quick look and it
seems like you got pretty far. Do you remember what was left to do? I found
the following in the docs folder, but I wasn't sure if it was up to date. I
understand if you can't remember, I don't even remember what I had for
breakfast yesterday, let alone what I was doing a few years ago.
Regardless, Mikus and I will add some documentation.
Thank you,
Erick
Function                    Support Status
Hardware                    Any OVMS v3 (or later) module.
Vehicle Cable               Comfort CAN / OBD Gateway
GSM Antenna                 T4AC - R205 with fakra_sma adapter cable or
1000500 Open Vehicles OVMS GSM Antenna (or any compatible antenna)
GPS Antenna                 T4AC - R50 with fakra_sma adapter cable or
1020200 Universal GPS Antenna (or any compatible antenna)
SOC Display                 Yes
Range Display               Yes
Cabin Pre-heat/cool Control Yes
GPS Location                Yes (from modem module GPS)
Speed Display               Yes
Temperature Display         Yes (see list of metrics below)
BMS v+t Display             Yes
TPMS Display                tba
Charge Status Display       Yes
Charge Interruption Alerts  Yes (per notification on the charging state)
Charge Control              tba
Lock/Unlock Vehicle         No
Valet Mode Control          No
On Thu, Feb 5, 2026 at 2:47 AM Chris van der Meijden via OvmsDev <
> Hi Erick,
> good to see that you have started to get the e-Golf up and running with
> OVMS.
> I have tried it a few years ago too based on my expierences with the e-UP.
> Though I have to say without very much success. The e-Golf and e-UP behave
> in great parts different on the CAN-bus. But there seems to be more insight
> on the e-Golf nowadays, so a new approach seems to be more promissing now.
> Could you create a "docs" folder with an "index.rst" like in the
> "vehicle_demo"?
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_demo/docs/index.rst
> This will make the progress steps clearer to those following your progress
> with the project.
> Regards
> Chris
> Am Montag, dem 02.02.2026 um 16:27 +0100 schrieb Michael Balzer via
> OvmsDev:
> Erick, welcome :)
> An initial PR for the initial vehicle support is OK.
> For later extensions, try to keep each PR concentrating on a specific
> feature/extension.
> Split up further on any critical change that may need to be quickly
> revertable.
> Keep framework and vehicle specific changes strictly separate, only
> include vehicle changes in framework commits if they need to be changed
> for the framework change.
> Use concise but clear commit messages.
> Do not submit unvalidated AI results.
> More:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3?tab=readme-ov-file#development-and-contributions
> Am 02.02.26 um 04:23 schrieb Erick Fuentes via OvmsDev:
> Hello!
> I recently bought a 2019 eGolf and I'm interested in getting support
> for it in the project. Some folks on the OVMS Discord server have code
> that appears to work and I've volunteered to try to merge it. I've yet
> to run the code myself (I'm still waiting on a harness), but I thought
> I'd ask what the process might look like. Do you want small pull
> requests where each one covers a single, small feature? Are you okay
> with merging everything at once, provided it doesn't break other vehicles?
> Erick
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260205/0b8a81b0/attachment.htm>
