[Ovmsdev] Adding support for eGolf
Chris van der Meijden
chris at arachnon.de
Thu Feb 5 15:47:39 HKT 2026
Hi Erick,
good to see that you have started to get the e-Golf up and running with
OVMS.
I have tried it a few years ago too based on my expierences with the e-
UP. Though I have to say without very much success. The e-Golf and e-UP
behave in great parts different on the CAN-bus. But there seems to be
more insight on the e-Golf nowadays, so a new approach seems to be more
promissing now.
Could you create a "docs" folder with an "index.rst" like in the
"vehicle_demo"?
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_demo/docs/index.rst
This will make the progress steps clearer to those following your
progress with the project.
Regards
Chris
Am Montag, dem 02.02.2026 um 16:27 +0100 schrieb Michael Balzer via
OvmsDev:
> Erick, welcome :)
> An initial PR for the initial vehicle support is OK.
> For later extensions, try to keep each PR concentrating on a specific
> feature/extension.
> Split up further on any critical change that may need to be quickly
> revertable.
> Keep framework and vehicle specific changes strictly separate, only
> include vehicle changes in framework commits if they need to be
> changed
> for the framework change.
> Use concise but clear commit messages.
> Do not submit unvalidated AI results.
> More:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3?tab=readme-ov-file#development-and-contributions
> Am 02.02.26 um 04:23 schrieb Erick Fuentes via OvmsDev:
> > Hello!
> > I recently bought a 2019 eGolf and I'm interested in getting
> > support
> > for it in the project. Some folks on the OVMS Discord server have
> > code
> > that appears to work and I've volunteered to try to merge it. I've
> > yet
> > to run the code myself (I'm still waiting on a harness), but I
> > thought
> > I'd ask what the process might look like. Do you want small pull
> > requests where each one covers a single, small feature? Are you
> > okay
> > with merging everything at once, provided it doesn't break other
> > vehicles?
> > Erick
> > OvmsDev mailing list
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20260205/f0135714/attachment.htm>
