[Ovmsdev] Integration of Simcom 7670 and changes to Simcom Powering
Info
info at zeitnitz.eu
Sun Mar 30 18:02:54 HKT 2025
OK, thanks Michael.
At least this was an easy fix.
Had a look at the NMEA code and I screwed up the istringstream object
when checking for the CGNSSINFO string.
Fixed it and I hope this works now as well.
Best regards
Christian
Am 29.03.2025 um 18:42 schrieb Michael Balzer via OvmsDev:
> Christian,
> the GSM/PPP part now works smoothly with all standard situations
> tested so far.
> But the GPS part doesn't work. It looks like the NMEA sentences are
> received in the MUX channel, but not forwarded to the NMEA module.
> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (794230) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> These should be the NMEA sentences, but there are no corresponding log
> entries from gsm-nmea.
> New logs attached.
> Am 29.03.25 um 15:13 schrieb Info via OvmsDev:
>> Hi Michael,
>> thanks for testing.
>> The results look odd, so I went back to the schematics of OVMS
>> modules and realized, that I was mistaken. The PWRKEY pin is actually
>> inverted in the modules as well. This definetly explains the strange
>> behaviour.
>> I changed now the logic in simcom_powering.h and the inverted PWRKEY
>> level is now the default.
>> Could you please run another test?
>> Best regards
>> Christian
>> Am 29.03.2025 um 09:25 schrieb Michael Balzer via OvmsDev:
>>> Christian,
>>> well done on the 7670 support :-)
>>> I've just done some first tests of your branch on the 7600, which
>>> turned up some issues. Logs attached:
>>> * Cold boot failed in 2 of 3 test boots, with the driver getting
>>> stuck in a loop (poweredon / identify / muxstart)
>>> * Regular shutdown fails to power down the modem in time -- for a
>>> deep sleep phase, this would mean the modem will remain powered on
>>> * After a crash, the modem driver gets somehow stuck in PowerOffOn
>>> state
>>> It seems the test for reaction ("AT") sometimes gets skipped, even
>>> though the modem isn't ready yet.
>>> On the failed cold boot log, you can see this at the end:
>>> *I (389178) cellular-modem-auto: Power Cycle*
>>> I (389178) Simcom: Power Cycle - T_off 2500 ms - T_on 200 ms
>>> D (389178) events: Signal(system.modem.poweringon)
>>> D (389188) events: Signal(egpio.output.0.low)
>>> D (391678) events: Signal(egpio.output.0.high)
>>> D (396678) events: Signal(egpio.output.0.low)
>>> D (396878) events: Signal(egpio.output.0.high)
>>> *I (396878) cellular: State: Enter Identify state
>>> D (396978) cellular: tx-cmd: AT+CGMM*
>>> I (397008) cellular: Identified cellular modem: SIM7600/Experimental
>>> support for SIMCOM SIM7600
>>> D (397008) cellular: Remove old 'auto' modem driver
>>> I (397008) cellular: Set modem driver to 'SIM7600'
>>> *I (397008) cellular: State: Enter PoweredOn state*
>>> D (397008) events: Signal(system.modem.installed)
>>> D (397008) events: Signal(system.modem.poweredon)
>>> D (406178) cellular: tx-cmd:
>>> AT+CPIN?;+CREG=1;+CGREG=1;+CEREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0;S0=0
>>> D (408178) cellular: tx-cmd: AT+CGMR;+ICCID
>>> D (416178) cellular: tx-cmd: AT+CMUX=0;+CATR=6
>>> D (434808) cellular: mux-rx-line #0 (2/46): OK
>>> *D (434808) cellular: mux-rx-line #0 (3/39): RDY*
>>> D (434808) cellular: mux-rx-line #0 (12/23): +CPIN: READY
>>> D (434808) cellular: mux-rx-line #0 (8/11): SMS DONE
>>> D (434808) cellular: mux-rx-line #0 (7/0): PB DONE
>>> I (434808) cellular: State: Enter MuxStart state
>>> D (434808) events: Signal(system.modem.muxstart)
>>> Am 26.03.25 um 13:13 schrieb Info Zeitnitz via OvmsDev:
>>>> Dear all,
>>>> I finished to integrate the Simcom 7670 modem into the OVMS code.
>>>> See
>>>> https://github.com/zbchristian/Open-Vehicle-Monitoring-System-3.git
>>>> branch update_cellular.
>>>> Modem Powering
>>>> I had problems to get the 7670 working with the current code. The
>>>> modem was stuck in a power cycle loop.
>>>> I checked the Simcom documentation for the 4 models 5360, 7000
>>>> series, 7600, 7670 and the powering procedure via the PWRKEY pin is
>>>> the same, but with different on/off timing. Depending on the
>>>> hardware, the PWRKEY can be inverted as well. This is the case for
>>>> my Lilygo TCall board, but I think not for the OVMS HW versions. At
>>>> least version 3.1 connects the corresponding MAX7317 pin directly
>>>> to the modem.
>>>> Assuming, that all hardware versions use the PWRKEY procedure for
>>>> powering, I streamlined the code and moved the corresponding
>>>> functions into separate files (simcom_powering.cpp and
>>>> simcom_powering.h). This avoids the duplication of the code.
>>>> All this leads to substantial changes in ovms_cellular and
>>>> ovms_cellular_modem_driver as well.
>>>> The code works now perfectly for the 7670, but testing is required
>>>> for all other models.
>>>> If my assumptions about the OVMS HW versions are not correct, or
>>>> the modems do not work as documented, some modifications might be
>>>> needed.
>>>> GNSS Location
>>>> The 7670 no longer accepts the currently used AT commands to obtain
>>>> the location as a GRMC sentence. So, I added code to the new 7670
>>>> class to request the location via the AT+CGNSSINFO command.
>>>> Since this has to be send explicitly again and again, I
>>>> implemented a corresponding call in the StatusPoller of the 7670.
>>>> All the NMEA related code has been adapted to handle the
>>>> corresponding CGNSSINFO response.
>>>> In conclusion, before doing a pull request, it would make sense
>>>> that the code is tested with the other hardware and modem models.
>>>> So, tell me what you think and if the general strategy of the mods
>>>> make sense to you.
>>>> Best regards
>>>> Christian
>>>> OvmsDev mailing list
>>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>>> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250330/8770f2a6/attachment.htm>
