    Chris Box
    chris8086 at ee.eclipse1.net
    Thu Jan 23 19:48:53 HKT 2025
On 2025-01-23 08:19, Michael Balzer wrote:
> did you take the can status outputs _before_ unplugging the OVMS when
> the car wouldn't enter drive ready?
No, unfortunately at the time I was only thinking of wanting to get the
car working again.
> Also, did you use the new poller firmware before without issues, i.e.
> can you confirm the issue only turns up with the new bus timing test?
> That would confirm it's a timing issue, and it would mean the new
> timing makes it worse.
Previously I was using git master firmware from 19th November. I covered
800 miles in two months using this firmware and only experienced one
issue (drive going to neutral).
As this firmware gave me an issue on the same day I flashed it, this
morning I've reverted the bus timing back to how it was before. But I've
kept the single sampling change:
MODULE_ESP32CAN->BTR1.B.SAM = (MyESP32can->m_speed < CAN_SPEED_125KBPS)
? 1 : 0;
So we'll see how this one goes.
>> How would I look for changes in can error frequency in the log?
> Basically by counting the error log entries for each bus to see if they
> generally increase or decrease, in more detail by also taking the error
> types logged into account. Some errors log entries are normal, may even
> occur frequently.
Could I do this by looking at these counters? e.g.
delays/overflow/fails/err/invalid/resets.
OVMS# can can1 status
CAN:       can1
Mode:      Active
Speed:     500000
DBC:       none
Interrupts:             6752500
Rx pkt:                 6752388
Rx ovrflw:                    1
Tx pkt:                     737
Tx delays:                    0
Tx ovrflw:                    0
Tx fails:                     0
Err flags: 0x00000000
Rx err:                       0
Tx err:                       0
Rx invalid:                   0
Wdg Resets:                   0
Wdg Timer:                    0 sec(s)
Err Resets:                   0
The above set was taken before charging.
After charging (and soc limit applied):
CAN:       can1
Mode:      Active
Speed:     500000
DBC:       none
Interrupts:             7294918
Rx pkt:                 7294172
Rx ovrflw:                    1
Tx pkt:                    1103
Tx delays:                   50
Tx ovrflw:                    0
Tx fails:                   144
Err flags: 0x008040d9
Rx err:                       0
Tx err:                     128
Rx invalid:                   0
Wdg Resets:                   0
Wdg Timer:                    2 sec(s)
Err Resets:                   0
> So I suggest first isolating this by selectively putting one bus into
> listen mode and testing if the issue then still turns up.
> Use the "can <bus> start" command to switch the mode, e.g.: can can1
> start listen 500000
I think I'll first give this new firmware a couple of days to see if
it's free of issues.
If it is, then I could reapply the bus timing changes and then set can1
into listen mode. And see how that goes.
Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250123/ac9b62ee/attachment-0001.htm>
