Sun Jan 19 19:48:47 HKT 2025
Regarding CAN timing, our ESP32CAN/SJA1000 configuration is mostly
according to the SAE/CiA recommendations, with one exception: we
generally enable multi (triple) sampling, regardless of the bus speed:
esp32can::InitController():
   /* Set sampling
    * 1 -> triple; the bus is sampled three times; recommended for
low/medium speed buses     (class A and B) where filtering spikes on the
bus line is beneficial
    * 0 -> single; the bus is sampled once; recommended for high speed
buses (SAE class C)*/
   MODULE_ESP32CAN->BTR1.B.SAM=0x1;
SAE defines "high speed" (class C) as speeds >= 125 kbit/s. See SAE
J2284-1, -2 & -3, section 6.10.8 Data Sample Mode: "The data sampling
shall always be set to single sample mode."
If setting SAM=0 for 500 kbit/s, our timing setup is exactly as
recommended by two tested SJA1000 timing calculators on the web.
Maybe we should give that a try? I.e.
   MODULE_ESP32CAN->BTR1.B.SAM = (MyESP32can->m_speed <
CAN_SPEED_125KBPS) ? 1 : 0;
Simon, can you try if that helps?
But as you also use can2, I wouldn't rule out a timing issue with the
MCP2515 configuration. At which speed do you have can2, and did you have
some indication from the vehicle error codes regarding a specific bus?
Am 17.01.25 um 17:49 schrieb Michael Balzer via OvmsDev:
> OK, I've got a new idea: CAN timing.
> Comparing our esp32can bit timing to the esp-idf driver's, there seem
> to be some differences:
> https://github.com/espressif/esp-idf/blob/master/components/hal/include/hal/twai_types_deprecated.h#L75
> Transceivers are normally tolerant to small timing offsets. Maybe
> being off a little bit has no effect under normal conditions, but it
> has when the transceiver has to cope with a filled RX queue. That
> could be causing the transceiver to slide just out of sync. If the
> timing gets garbled, the transceiver would signal errors in the
> packets to the bus, possibly so many the vehicle ECUs decide to raise
> an error condition.
> Is that plausible?
> On why the new poller could be causing this (in combination with too
> slow processing by the vehicle): as mentioned, the standard CAN
> listener mechanism doesn't care about queue overflows. The poller
> does. `OvmsPollers::Queue_PollerFrame()` does a log call when Tx/Rx
> tracing is enabled, that could even block, but tracing is optional and
> only meant for debugging. Not optional is the overflow counting using
> an atomic uint32.
> The atomic types are said to be fast, but I never checked their actual
> implementation on the ESP32. Maybe they can block as well?
> @Simon: it would be an option to try commenting out the overflow
> counting, to see if that's causing the issue.
> Am 17.01.25 um 15:37 schrieb Chris Box via OvmsDev:
>> Yes, I can confirm I've had one experience of the Leaf switching to
>> Neutral while driving, with a yellow warning symbol on the dash. It
>> refused to reselect Drive until I had switched the car off and back
>> on. Derek wasn't so lucky and he need to clear fault codes before the
>> car would work.
>> On returning home, I found OVMS was not accessible over a network. I
>> didn't try a USB cable. Unplugging and reinserting the OBD cable
>> caused OVMS to rejoin Wi-Fi. However the SD logs showed nothing from
>> the time of the event. CAN writes are enabled, so it can perform SOC
>> limiting.
>> My car has been using this firmware since 21st November, based on the
>> git master of that day. As a relatively new user of OVMS (only since
>> October) I don't have much experience of older firmware.
>> Perhaps a safeguard should be implemented before releasing a new
>> stable firmware that will be automatically downloaded by Leaf owners.
>> But I don't have the expertise to know what that safeguard should be.
>> Derek's suggestion of 'only CAN write when parked' appears to be a
>> good idea.
>> Chris
>> On 2025-01-15 18:18, Derek Caudwell via OvmsDev wrote:
>>> Since the following email I have high confidence the issue on the
>>> Leaf is related/caused by the poller as there has been no further
>>> occurrence and Chris has also experienced the car going to neutral
>>> on the new poller firmware.
>>> I haven't ruled out it being a fault with my car yet. Shortly after
>>> it faulted the car was run into so has been off the road for
>>> sometime, my first step was to replace 12V battery. The ovms unit is
>>> now unplugged and if it does not fault over the next month while
>>> driving I'll be reasonably confident it's ovms related.
>>> Not sure which firmware version the poller updates were included in
>>> but it was only after upgrading to it that the errors occurred
>>> (which could be coincidental however it has faulted twice more both
>>> on version 3.3.004-141-gf729d82c). For periods where I reverted to
>>> 3.3.003 it was fine.
>>> It might be useful to have an extra option on the enable can write
>>> to only enable it when the car is parked/charging.
> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
> Fon 02330 9104094 * Handy 0176 20698926
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/5dd75b8f/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/5dd75b8f/attachment.sig>
