    Mon Jan 20 23:15:46 HKT 2025
DFJ,
a) what do you mean by "it works fine" if no data gets through?
b) what do you mean by "now sends tx commands" when can2 has "txpkt=0"?
Also, the log errors indicate can2 had nearly 300000 frames received
when the module had been running for just 186 seconds -- that's ~1,600
frames per second, is that an expected/plausible volume for can2 on the
Leaf?
errflags=0x23401c01 translates to "all RX buffers full", i.e. the CAN
driver could not drain the MCP2515 receive buffers fast enough.
The leaf polls both can1 and can2, can2 only every 900 seconds, but you
should still see a TX count in the can status.
Could try & compare to the Arduino MCP_CAN timing as suggested by Mark?
Am 19.01.25 um 23:17 schrieb Developer From Jokela via OvmsDev:
> Hi.
> Tried setting Remember, the SAE/CiA recommendation is SJW=2, Sample 1x @87.5%. That
>>> would translate to:
>>>   PROP=5, PS1=8, PS2=2, SJW=2, Sample 1x @87.5% =
>     cnf1=0x40; cnf2=0xbc; cnf3=0x81; on leaf and it works fine. But, queue gets full and no data from can2 gets through.
> CAN1 no errors, CAN2:
> E (186415) can: can2: intr=294497 rxpkt=296913 txpkt=0 errflags=0x22401c02 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
> E (186425) can: can2: intr=294498 rxpkt=296914 txpkt=0 errflags=0x23401c01 rxerr=0 txerr=0 rxinval=0 rxovr=0 txovr=0 txdelay=0 txfail=0 wdgreset=0 errreset=0
> After this change poller now sends tx commands, compared to before when it did not.
> - DFJ
>> ovmsdev-request at lists.openvehicles.com kirjoitti 19.1.2025 kello 21.47:
>> Am 19.01.25 um 12:48 schrieb Michael Balzer via OvmsDev:
>>> Maybe we should give that a try? I.e.
>>> ? MODULE_ESP32CAN->BTR1.B.SAM = (MyESP32can->m_speed <
>>> CAN_SPEED_125KBPS) ? 1 : 0;
>> This change works flawlessly on my UpMiiGo (running can1 at 500 kbit/s).
>> Michael Balzer * Am Rahmen 5 * D-58313 Herdecke
>> Fon 02330 9104094 * Handy 0176 20698926
>> -------------- next part --------------
>> A non-text attachment was scrubbed...
>> Type: application/pgp-signature
>> Desc: OpenPGP digital signature
>> URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250119/9d47cbb2/attachment-0001.sig>
>> Message: 2
>> Date: Mon, 20 Jan 2025 08:47:07 +1300
>> From: Derek Caudwell <d.caudwell at gmail.com>
>> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
>> Subject: Re: [Ovmsdev] OVMS Poller module/singleton
>> Message-ID:
>> 	<CAKUcfWEY-F4CiY9J1DmAHZgzSXEMfHO-0mW_b=k-4eXjf4TcVw at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Thanks Michael
>> I can't recall testing a later version but I think Chris can confirm he was
>> on a later version when his Leaf had a similar problem.
>> The Leaf is now my wife's daily drive so I won't be able to take a look at
>> making the suggested changes for a couple of weeks at least.
>> On Mon, 20 Jan 2025, 8:31 am Michael Balzer via OvmsDev, <
>> ovmsdev at lists.openvehicles.com> wrote:
>>> Derek,
>>> Am 03.05.24 um 12:53 schrieb Derek Caudwell via OvmsDev:
>>> When running *firmware  **3.3.004-74-gbd4e7196* on my Nissan Leaf I
>>> suspect (but can't be 100% sure as it's only been 24h without fault) the
>>> new poller caused the car to throw the attached faults from overloading the
>>> can bus whilst driving. The fault was sufficient to send the car into limp
>>> mode and could not be driven until cleared with LeafSpy.
>>> Build 3.3.004-74 (released 2024-04-30) did not yet include the poller
>>> tracing control, i.e. it did lots of logging for frames, significantly
>>> affecting overall performance.
>>> Poller tracing control was introduced in
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/7e4046042a99339d0212aac8f874cc8f780e634e
>>> on May 12.
>>> That commit was first included in build 3.3.004-103-g11fddbf6 released
>>> 2024-05-25. Do you remember testing that build or a later one?
>>> But as I still don't understand how a software queue overflow could cause
>>> a bus crash, I've also checked the 500 kbit timing for the MCP2515 and
>>> found that may have the same issue as the 125 kbit timing:
>>> Our timing is:
>>>   case CAN_SPEED_500KBPS:
>>>     cnf1=0x00; cnf2=0xf0; cnf3=0x86;
>>>   = PROP=1, PS1=7, PS2=7, SJW=1, Sample 3x @56.3%
>>> would translate to:
>>> I also checked the Arduino MCP_CAN lib, and that uses:
>>>     cnf1=0x40; cnf2=0xe5; cnf3=0x83;
>>>   = PROP=6, PS1=5, PS2=4, SJW=2, Sample 3x @75%
>>> So our timing for 500 kbit/s on the MCP buses also isn't as recommended.
>>> Derek, could you test the SAE/CiA recommendation and the MCP_CAN config as
>>> shown? Or anyone else with a live can2/can3 bus at 500 kbit?
>>> If these work, the question is which is the more general setup we should
>>> adopt. Apparently the MCP_CAN lib also does not follow the CiA
>>> recommendation, I wonder if the MCP_CAN config is a compromise for
>>> compatibility.
>>> Am 19.01.25 um 19:07 schrieb Derek Caudwell via OvmsDev:
>>> Hi Michael
>>> I just used the firmware stock with no changes to the poller settings.
>>> The Leaf is using high speeds on both buses:
>>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>>   RegisterCanBus(2,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>> On Sun, 19 Jan 2025, 10:15 pm Michael Balzer via OvmsDev, <
>>>> Michael,
>>>> I suggest adding a standard bool member variable to reflect if any filter
>>>> is defined, so `PollerRxCallback()` can just skip the filter test while
>>>> that is false. A mutex has some overhead, even if used non-blocking, and a
>>>> bool variable only read there will be sufficient to signal "apply
>>>> filtering" to the callback. With the simple bool test, all vehicles that
>>>> don't need filtering (i.e. most vehicles) will have a neglectible impact
>>>> from this.
>>>> Regarding the overhead: the GCC atomic implementation should use the
>>>> xtensa CPU builtin atomic support (SCOMPARE1 register & S32C1I
>>>> instruction), so should be pretty fast and not use any interrupt disabling,
>>>> see:
>>>>    - https://gcc.gnu.org/wiki/Atomic (xtensa atomic support since gcc
>>>>    4.4.0)
>>>>    https://www.cadence.com/content/dam/cadence-www/global/en_US/documents/tools/silicon-solutions/compute-ip/isa-summary.pdf
>>>>    (section 4.3.13)
>>>> So I still doubt the queue overflow is the real culprit.
>>>> But having the filter option doesn't hurt (with my suggestion above), and
>>>> your changes to the queue processing look promising as well.
>>>> @Derek: what was your poller tracing & timing setup when you had the bus
>>>> issue on the Leaf? I still think that was something related to your car or
>>>> setup. There are currently 11 Leafs on my server running "edge" releases
>>>> including the new poller, all without (reported) issues.
>>>> Regards,
>>>> Michael
>>>> Am 19.01.25 um 04:26 schrieb Michael Geddes:
>>>> P/R Created
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/1100
>>>> Let me know if you want me to split it up or ANY changes and I'll get
>>>> onto it asap.
>>>> Maybe somebody could grab the code and check it out in the context of
>>>> specifying some filters.  This will prevent those messages from coming to
>>>> the vehicle implementation at all.. and even from going through the poller
>>>> queue.  It is non-blocking meaning that the filter is briefly
>>>> inopperational while the filter is being modified.
>>>> On Sun, 19 Jan 2025 at 11:02, Michael Geddes <frog at bunyip.wheelycreek.net>
>>>> wrote:
>>>>> On Sat, 18 Jan 2025 at 17:08, Michael Balzer via OvmsDev <
>>>>>> I have commented out the line with the Atomic_Increment statement. Now
>>>>>> I no longer receive any messages with ?RX Task Queue Overflow Run?
>>>>>> Here is the output of poller times status:
>>>>>> The main question is if you still get the CAN bus crash (vehicle
>>>>>> running into issues) with that modification in active mode. Timing
>>>>>> statistics were not expected to change.
>>>>> I have a feeling that the atomic operations are along the lines of:
>>>>> * Set Interrupts off
>>>>> * atomic operation
>>>>> * Set interrupts on
>>>>> Which means no real 'blocking' .. just not allowing interrupts and
>>>>> therefor task switching for a couple of instructions.
>>>>>> Nearly 2800 frames per second is quite a lot, and most is on can1 with
>>>>>> many frame periods at 20 ms. Yet the total processing time averages at
>>>>>> 30-40 ms, so there is no actual CPU capacity issue for that amount of
>>>>>> frames.
>>>>>> @Derek: can you please supply these statistics for the Leaf in drive
>>>>>> mode as well?
>>>>>> Am 18.01.25 um 02:42 schrieb Michael Geddes via OvmsDev:
>>>>>> Maybe try setting CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE = 160   and see
>>>>>> if that reduces the overflow?
>>>>>> Simons car sends at least 91 process data frame IDs on can1 and 84 on
>>>>>> can2. Worst case would be these come all in within the shortest possible
>>>>>> time span, that would mean the queue needs to be able to hold 175 frames.
>>>>>> I'd add some headroom and round up to 200.
>>>>>> But keep in mind, if the Incoming processing actually occasionally gets
>>>>>> blocked for up to 60 ms -- as indicated by Simons statistics --, the queue
>>>>>> may need to be twice as large.
>>>>>> I was thinking that the frame filter would be here:
>>>>>> void OvmsPollers::PollerRxCallback(const CAN_frame_t* frame, bool
>>>>>> success)
>>>>>>   Queue_PollerFrame(*frame, success, false);
>>>>>> which I guess is executed in  the task handling the CAN queue.  (we
>>>>>> don't know how many frames get dropped there).
>>>>>> Actually we do know that, or at least have some indication, as we count
>>>>>> the CAN transceiver queue overruns. That info is included as "Rx overflw"
>>>>>> in the can status output & as "rxovr" in the logs.
>>>>>> Adding a filter before queueing the frame would exclude the filtered
>>>>>> IDs from all vehicle processing. I meant adding a filter just to exclude
>>>>>> IDs from the timing statistics, assuming those are the culprits, as Simon
>>>>>> wrote the issue only appears after enabling the timing statistics and
>>>>>> printing them. That's why I asked if printing might need to lock the
>>>>>> statistics for too long in case of such a long list.
>>>>>> Completely blocking ID ranges from processing by the vehicle should
>>>>>> normally not be necessary, unless the Incoming handler is written very
>>>>>> poorly.
>>>>>> Yet, if we add that, a mutex in the CAN RX callback must be avoided, or
>>>>>> would need to be non-blocking:
>>>>>> The only real concern is thread safety between checking and adding to
>>>>>> the filter - so the check itself might have to be mutexed.
>>>>>> success)
>>>>>>   // Check filter
>>>>>>   OvmsRecMutexLock lock(&m_filter_mutex);
>>>>>>     if (! m_filter->IsFiltered(frame))
>>>>>>       return;
>>>>>> A mutex like that could block the CAN task, which must be avoided at
>>>>>> all cost. I introduced CAN callbacks for vehicles & applications that need
>>>>>> to react to certain frames as fast as possible, e.g. to maintain control
>>>>>> precedence, so cannot use the standard CAN listener mechanism (frame
>>>>>> queueing).
>>>>>> The current poller callback use is OK, if (!) the atomic type really
>>>>>> isn't the culprit, ie doesn't block.
>>>>>> So if (!) an ID filter needs to be added before queueing, it needs to
>>>>>> be done in a way that needs no mutex. But I don't see an issue with the
>>>>>> vehicle passing a fixed filter when registering with the poller/buses. The
>>>>>> filter doesn't need to by mutable on the fly.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 17.01.25 um 19:42 schrieb Simon Ehlen via OvmsDev:
>>>>>> The poller statistics can help you track this down, but you need to
>>>>>> have at least 10 seconds of statistics, the more the better. Rule of thumb:
>>>>>> PRI average at 0.0/second means you don't have enough data yet.
>>>>>> There were again many messages with ?RX Task Queue Overflow Run?.
>>>>>> Here are the statistics of poller times status:
>>>>>> OVMS# poll times status
>>>>>> Poller timing is: on
>>>>>> Type           | count  | Utlztn | Time
>>>>>>                | per s  | [%]    | [ms]
>>>>>> Poll:PRI    Avg|    1.00|  0.0043|    0.004
>>>>>>            Peak|        |  0.0043|    0.052
>>>>>> RxCan1[010] Avg|   34.26|  1.6741|    0.015
>>>>>>            Peak|        |  1.6741|    1.182
>>>>>> RxCan1[030] Avg|   34.06|  1.7085|    0.020
>>>>>>            Peak|        |  1.7085|    1.390
>>>>>> RxCan1[041] Avg|   49.89|  0.8109|    0.016
>>>>>>            Peak|        |  0.8541|    1.098
>>>>>> RxCan1[049] Avg|   50.00|  1.5970|    0.019
>>>>>>            Peak|        |  1.7154|   32.233
>>>>>> RxCan1[04c] Avg|   49.92|  0.8340|    0.014
>>>>>>            Peak|        |  0.8933|    1.995
>>>>>> RxCan1[04d] Avg|   34.43|  1.6211|    0.014
>>>>>>            Peak|        |  1.6756|    1.318
>>>>>> RxCan1[076] Avg|   50.00|  0.8362|    0.024
>>>>>>            Peak|        |  0.8784|    2.185
>>>>>> RxCan1[077] Avg|   50.00|  0.7837|    0.014
>>>>>>            Peak|        |  0.8083|    1.156
>>>>>> RxCan1[07a] Avg|   34.31|  2.1870|    0.017
>>>>>>            Peak|        |  2.3252|    1.888
>>>>>> RxCan1[07d] Avg|   50.00|  0.8001|    0.013
>>>>>>            Peak|        |  0.8434|    1.150
>>>>>> RxCan1[0c8] Avg|   49.96|  0.8359|    0.013
>>>>>>            Peak|        |  0.8715|    1.171
>>>>>> RxCan1[11a] Avg|   34.35|  1.6701|    0.020
>>>>>>            Peak|        |  1.6981|    1.273
>>>>>> RxCan1[130] Avg|   50.00|  0.7902|    0.018
>>>>>>            Peak|        |  0.8513|    0.980
>>>>>> RxCan1[139] Avg|   49.92|  0.7872|    0.013
>>>>>>            Peak|        |  0.8219|    0.795
>>>>>> RxCan1[156] Avg|   10.00|  0.1620|    0.014
>>>>>>            Peak|        |  0.1729|    0.919
>>>>>> RxCan1[160] Avg|   50.04|  0.7977|    0.014
>>>>>>            Peak|        |  0.8232|    1.495
>>>>>> RxCan1[165] Avg|   49.85|  0.7976|    0.014
>>>>>>            Peak|        |  0.8486|    1.015
>>>>>> RxCan1[167] Avg|   34.39|  1.6025|    0.016
>>>>>>            Peak|        |  1.6888|    1.354
>>>>>> RxCan1[171] Avg|   50.00|  0.8150|    0.017
>>>>>>            Peak|        |  0.8488|    1.091
>>>>>> RxCan1[178] Avg|   10.00|  0.1614|    0.014
>>>>>>            Peak|        |  0.1702|    0.903
>>>>>> RxCan1[179] Avg|   10.00|  0.1630|    0.017
>>>>>>            Peak|        |  0.1663|    1.336
>>>>>> RxCan1[180] Avg|   50.00|  0.8137|    0.014
>>>>>>            Peak|        |  0.8605|    1.566
>>>>>> RxCan1[185] Avg|   50.04|  0.8033|    0.013
>>>>>>            Peak|        |  0.8393|    1.126
>>>>>> RxCan1[1a0] Avg|   49.92|  0.7748|    0.013
>>>>>>            Peak|        |  0.8169|    1.184
>>>>>> RxCan1[1e0] Avg|   49.92|  0.7738|    0.014
>>>>>>            Peak|        |  0.8028|    1.049
>>>>>> RxCan1[1e4] Avg|   49.89|  0.9692|    0.018
>>>>>>            Peak|        |  1.0096|    1.332
>>>>>> RxCan1[1f0] Avg|   33.22|  0.5544|    0.014
>>>>>>            Peak|        |  0.5855|    0.848
>>>>>> RxCan1[200] Avg|   49.92|  0.7879|    0.015
>>>>>>            Peak|        |  0.8345|    1.206
>>>>>> RxCan1[202] Avg|   34.28|  1.7075|    0.016
>>>>>>            Peak|        |  1.7874|    1.218
>>>>>> RxCan1[204] Avg|   34.35|  1.5641|    0.013
>>>>>>            Peak|        |  1.6427|    1.235
>>>>>> RxCan1[213] Avg|   49.89|  0.7814|    0.015
>>>>>>            Peak|        |  0.8232|    0.910
>>>>>> RxCan1[214] Avg|   49.92|  0.7736|    0.014
>>>>>>            Peak|        |  0.8216|    0.800
>>>>>> RxCan1[217] Avg|   34.31|  1.6294|    0.014
>>>>>>            Peak|        |  1.7165|    1.153
>>>>>> RxCan1[218] Avg|   49.86|  0.7877|    0.013
>>>>>>            Peak|        |  0.8290|    1.068
>>>>>> RxCan1[230] Avg|   50.00|  0.7596|    0.014
>>>>>>            Peak|        |  0.7660|    1.021
>>>>>> RxCan1[240] Avg|   10.00|  0.1669|    0.013
>>>>>>            Peak|        |  0.1835|    0.887
>>>>>> RxCan1[242] Avg|   24.96|  0.4764|    0.020
>>>>>>            Peak|        |  0.4963|    1.501
>>>>>> RxCan1[24a] Avg|    9.89|  0.1789|    0.015
>>>>>>            Peak|        |  0.2009|    0.874
>>>>>> RxCan1[24b] Avg|    9.89|  0.1702|    0.014
>>>>>>            Peak|        |  0.1870|    1.195
>>>>>> RxCan1[24c] Avg|    9.89|  0.2146|    0.019
>>>>>>            Peak|        |  0.2187|    1.242
>>>>>> RxCan1[25a] Avg|   10.00|  0.1603|    0.013
>>>>>>            Peak|        |  0.1667|    0.720
>>>>>> RxCan1[25b] Avg|   49.94|  0.7918|    0.017
>>>>>>            Peak|        |  0.8454|    1.666
>>>>>> RxCan1[25c] Avg|   34.24|  1.5331|    0.013
>>>>>>            Peak|        |  1.5997|    1.538
>>>>>> RxCan1[260] Avg|   10.00|  0.1626|    0.014
>>>>>>            Peak|        |  0.1682|    0.718
>>>>>> RxCan1[270] Avg|   49.90|  0.8120|    0.014
>>>>>>            Peak|        |  0.8460|    1.671
>>>>>> RxCan1[280] Avg|   49.92|  0.7777|    0.019
>>>>>>            Peak|        |  0.8447|    1.157
>>>>>> RxCan1[2e4] Avg|   19.89|  0.5778|    0.032
>>>>>>            Peak|        |  0.6648|    2.226
>>>>>> RxCan1[2ec] Avg|   10.00|  0.1701|    0.014
>>>>>>            Peak|        |  0.1755|    0.928
>>>>>> RxCan1[2ed] Avg|   10.00|  0.1650|    0.013
>>>>>>            Peak|        |  0.1747|    0.917
>>>>>> RxCan1[2ee] Avg|    9.98|  0.1544|    0.013
>>>>>>            Peak|        |  0.1588|    1.312
>>>>>> RxCan1[312] Avg|   10.00|  0.1648|    0.017
>>>>>>            Peak|        |  0.1690|    0.922
>>>>>> RxCan1[326] Avg|    9.89|  0.1603|    0.015
>>>>>>            Peak|        |  0.1833|    1.230
>>>>>> RxCan1[336] Avg|    1.00|  0.0146|    0.015
>>>>>>            Peak|        |  0.0150|    0.349
>>>>>> RxCan1[352] Avg|    6.66|  0.1223|    0.022
>>>>>>            Peak|        |  0.1338|    1.015
>>>>>> RxCan1[355] Avg|    2.00|  0.0424|    0.019
>>>>>>            Peak|        |  0.0431|    0.786
>>>>>> RxCan1[35e] Avg|    9.96|  0.1570|    0.013
>>>>>>            Peak|        |  0.1644|    0.579
>>>>>> RxCan1[365] Avg|   10.00|  0.1600|    0.014
>>>>>>            Peak|        |  0.1653|    0.961
>>>>>> RxCan1[366] Avg|   10.00|  0.1716|    0.013
>>>>>>            Peak|        |  0.1890|    0.987
>>>>>> RxCan1[367] Avg|    9.93|  0.1793|    0.015
>>>>>>            Peak|        |  0.1864|    0.984
>>>>>> RxCan1[368] Avg|   10.00|  0.1645|    0.014
>>>>>>            Peak|        |  0.1778|    0.768
>>>>>> RxCan1[369] Avg|   10.00|  0.1562|    0.016
>>>>>>            Peak|        |  0.1606|    0.724
>>>>>> RxCan1[380] Avg|   10.00|  0.1619|    0.014
>>>>>>            Peak|        |  0.1644|    0.605
>>>>>> RxCan1[38b] Avg|   25.00|  0.3991|    0.016
>>>>>>            Peak|        |  0.4280|    1.448
>>>>>> RxCan1[3b3] Avg|   10.00|  0.1537|    0.013
>>>>>>            Peak|        |  0.1610|    0.380
>>>>>> RxCan1[400] Avg|    4.00|  0.0626|    0.014
>>>>>>            Peak|        |  0.0626|    0.251
>>>>>> RxCan1[405] Avg|    3.90|  0.1019|    0.028
>>>>>>            Peak|        |  0.1019|    0.781
>>>>>> RxCan1[40a] Avg|    7.90|  0.1256|    0.020
>>>>>>            Peak|        |  0.1256|    0.991
>>>>>> RxCan1[410] Avg|   10.00|  0.1643|    0.016
>>>>>>            Peak|        |  0.1839|    1.634
>>>>>> RxCan1[411] Avg|   10.00|  0.1532|    0.013
>>>>>>            Peak|        |  0.1645|    0.824
>>>>>> RxCan1[416] Avg|   10.00|  0.1516|    0.016
>>>>>>            Peak|        |  0.1582|    0.807
>>>>>> RxCan1[421] Avg|   10.00|  0.1648|    0.013
>>>>>>            Peak|        |  0.1740|    0.839
>>>>>> RxCan1[42d] Avg|   10.00|  0.1548|    0.014
>>>>>>            Peak|        |  0.1658|    0.741
>>>>>> RxCan1[42f] Avg|   10.00|  0.1527|    0.013
>>>>>>            Peak|        |  0.1578|    0.667
>>>>>> RxCan1[430] Avg|   10.00|  0.1730|    0.016
>>>>>>            Peak|        |  0.1880|    1.209
>>>>>> RxCan1[434] Avg|   10.00|  0.1620|    0.021
>>>>>>            Peak|        |  0.1712|    1.140
>>>>>> RxCan1[435] Avg|    6.66|  0.1104|    0.014
>>>>>>            Peak|        |  0.1121|    1.011
>>>>>> RxCan1[43e] Avg|   20.00|  0.3194|    0.013
>>>>>>            Peak|        |  0.3434|    1.212
>>>>>> RxCan1[440] Avg|    1.00|  0.0160|    0.014
>>>>>>            Peak|        |  0.0175|    0.315
>>>>>> RxCan1[465] Avg|    1.00|  0.0172|    0.015
>>>>>>            Peak|        |  0.0194|    0.404
>>>>>> RxCan1[466] Avg|    1.00|  0.0198|    0.015
>>>>>>            Peak|        |  0.0252|    0.890
>>>>>> RxCan1[467] Avg|    1.00|  0.0152|    0.014
>>>>>>            Peak|        |  0.0160|    0.217
>>>>>> RxCan1[472] Avg|    0.70|  0.0533|    0.075
>>>>>>            Peak|        |  0.0546|    0.990
>>>>>> RxCan1[473] Avg|    0.65|  0.0325|    0.051
>>>>>>            Peak|        |  0.0361|    0.774
>>>>>> RxCan1[474] Avg|    1.00|  0.0146|    0.014
>>>>>>            Peak|        |  0.0151|    0.189
>>>>>> RxCan1[475] Avg|    2.00|  0.0332|    0.015
>>>>>>            Peak|        |  0.0362|    0.513
>>>>>> RxCan1[476] Avg|    2.00|  0.0305|    0.014
>>>>>>            Peak|        |  0.0307|    0.249
>>>>>> RxCan1[477] Avg|    2.00|  0.0309|    0.014
>>>>>>            Peak|        |  0.0311|    0.438
>>>>>> RxCan1[595] Avg|    1.00|  0.0151|    0.014
>>>>>>            Peak|        |  0.0160|    0.230
>>>>>> RxCan1[59e] Avg|    1.00|  0.0179|    0.015
>>>>>>            Peak|        |  0.0209|    0.716
>>>>>> RxCan1[5a2] Avg|    1.00|  0.0154|    0.016
>>>>>>            Peak|        |  0.0184|    0.699
>>>>>> RxCan1[5ba] Avg|    1.00|  0.0159|    0.017
>>>>>>            Peak|        |  0.0174|    0.485
>>>>>> RxCan2[010] Avg|    0.00|  0.0000|    0.015
>>>>>>            Peak|        |  0.0000|    0.146
>>>>>> RxCan2[020] Avg|   31.10|  0.5159|    0.015
>>>>>>            Peak|        |  0.5730|    0.992
>>>>>> RxCan2[030] Avg|   20.70|  0.3506|    0.016
>>>>>>            Peak|        |  0.3956|    1.055
>>>>>> RxCan2[03a] Avg|   18.65|  0.3157|    0.014
>>>>>>            Peak|        |  0.3292|    0.702
>>>>>> RxCan2[040] Avg|   18.60|  0.3111|    0.015
>>>>>>            Peak|        |  0.3474|    0.953
>>>>>> RxCan2[060] Avg|   18.60|  0.3182|    0.014
>>>>>>            Peak|        |  0.3569|    0.694
>>>>>> RxCan2[070] Avg|   15.55|  0.4581|    0.017
>>>>>>            Peak|        |  0.6859|   39.212
>>>>>> RxCan2[080] Avg|   15.50|  0.5041|    0.029
>>>>>>            Peak|        |  0.5414|    1.555
>>>>>> RxCan2[083] Avg|   18.70|  0.3083|    0.014
>>>>>>            Peak|        |  0.3325|    0.557
>>>>>> RxCan2[090] Avg|   23.40|  0.3961|    0.014
>>>>>>            Peak|        |  0.4445|    1.218
>>>>>> RxCan2[0a0] Avg|   15.55|  0.2734|    0.014
>>>>>>            Peak|        |  0.3144|    1.062
>>>>>> RxCan2[100] Avg|   15.50|  0.2645|    0.016
>>>>>>            Peak|        |  0.2875|    1.021
>>>>>> RxCan2[108] Avg|   23.40|  0.4231|    0.016
>>>>>>            Peak|        |  0.4680|    1.297
>>>>>> RxCan2[110] Avg|   15.55|  0.2467|    0.014
>>>>>>            Peak|        |  0.2684|    0.475
>>>>>> RxCan2[130] Avg|   13.30|  0.2231|    0.014
>>>>>>            Peak|        |  0.2447|    0.512
>>>>>> RxCan2[150] Avg|   15.50|  0.2533|    0.015
>>>>>>            Peak|        |  0.2836|    0.823
>>>>>> RxCan2[160] Avg|    4.70|  0.0784|    0.014
>>>>>>            Peak|        |  0.0863|    0.608
>>>>>> RxCan2[180] Avg|   15.55|  0.2713|    0.015
>>>>>>            Peak|        |  0.2841|    0.884
>>>>>> RxCan2[190] Avg|   15.50|  0.2596|    0.014
>>>>>>            Peak|        |  0.2825|    0.743
>>>>>> RxCan2[1a0] Avg|    0.95|  0.0164|    0.015
>>>>>>            Peak|        |  0.0164|    0.346
>>>>>> RxCan2[1a4] Avg|   18.65|  0.3232|    0.015
>>>>>>            Peak|        |  0.3515|    0.989
>>>>>> RxCan2[1a8] Avg|   11.60|  0.1911|    0.016
>>>>>>            Peak|        |  0.2012|    0.757
>>>>>> RxCan2[1b0] Avg|    9.35|  0.1558|    0.016
>>>>>>            Peak|        |  0.1641|    0.795
>>>>>> RxCan2[1b4] Avg|    9.35|  0.1543|    0.015
>>>>>>            Peak|        |  0.1617|    1.217
>>>>>> RxCan2[1b8] Avg|   11.65|  0.2003|    0.014
>>>>>>            Peak|        |  0.2236|    1.549
>>>>>> RxCan2[1c0] Avg|    9.40|  0.1532|    0.016
>>>>>>            Peak|        |  0.1673|    0.955
>>>>>> RxCan2[1e0] Avg|    9.30|  0.1582|    0.015
>>>>>>            Peak|        |  0.1708|    0.661
>>>>>> RxCan2[215] Avg|    7.80|  0.1409|    0.016
>>>>>>            Peak|        |  0.1531|    0.660
>>>>>> RxCan2[217] Avg|    7.80|  0.1239|    0.014
>>>>>>            Peak|        |  0.1333|    0.520
>>>>>> RxCan2[220] Avg|    6.20|  0.1041|    0.015
>>>>>>            Peak|        |  0.1094|    0.652
>>>>>> RxCan2[225] Avg|   23.40|  0.4648|    0.015
>>>>>>            Peak|        |  0.4696|    4.288
>>>>>> RxCan2[230] Avg|    6.20|  0.3120|    0.048
>>>>>>            Peak|        |  0.3377|    1.065
>>>>>> RxCan2[240] Avg|    7.70|  0.1248|    0.014
>>>>>>            Peak|        |  0.1364|    0.635
>>>>>> RxCan2[241] Avg|   18.60|  0.3258|    0.014
>>>>>>            Peak|        |  0.3343|    1.288
>>>>>> RxCan2[250] Avg|    4.70|  0.0761|    0.014
>>>>>>            Peak|        |  0.0809|    0.322
>>>>>> RxCan2[255] Avg|   11.75|  0.2058|    0.014
>>>>>>            Peak|        |  0.2283|    0.937
>>>>>> RxCan2[265] Avg|   11.65|  0.1964|    0.014
>>>>>>            Peak|        |  0.2068|    0.965
>>>>>> RxCan2[270] Avg|    4.70|  0.0808|    0.016
>>>>>>            Peak|        |  0.0949|    0.729
>>>>>> RxCan2[290] Avg|    3.15|  0.0498|    0.015
>>>>>>            Peak|        |  0.0504|    0.449
>>>>>> RxCan2[295] Avg|    6.25|  0.1019|    0.014
>>>>>>            Peak|        |  0.1094|    0.859
>>>>>> RxCan2[2a0] Avg|    3.15|  0.0550|    0.014
>>>>>>            Peak|        |  0.0551|    0.779
>>>>>> RxCan2[2a7] Avg|   11.65|  0.1929|    0.014
>>>>>>            Peak|        |  0.2080|    0.775
>>>>>> RxCan2[2b0] Avg|    3.00|  0.0497|    0.015
>>>>>>            Peak|        |  0.0562|    0.528
>>>>>> RxCan2[2c0] Avg|    3.10|  0.0534|    0.016
>>>>>>            Peak|        |  0.0592|    0.501
>>>>>> RxCan2[2e0] Avg|    1.55|  0.0247|    0.014
>>>>>>            Peak|        |  0.0289|    0.319
>>>>>> RxCan2[2f0] Avg|    1.55|  0.0244|    0.014
>>>>>>            Peak|        |  0.0273|    0.192
>>>>>> RxCan2[2f5] Avg|   11.65|  0.2078|    0.016
>>>>>>            Peak|        |  0.2333|    0.879
>>>>>> RxCan2[300] Avg|    1.60|  0.0266|    0.018
>>>>>>            Peak|        |  0.0278|    0.724
>>>>>> RxCan2[310] Avg|    1.55|  0.0276|    0.016
>>>>>>            Peak|        |  0.0285|    0.759
>>>>>> RxCan2[320] Avg|    1.60|  0.0240|    0.014
>>>>>>            Peak|        |  0.0258|    0.179
>>>>>> RxCan2[326] Avg|    9.30|  0.1550|    0.014
>>>>>>            Peak|        |  0.1582|    0.850
>>>>>> RxCan2[330] Avg|   29.95|  0.5311|    0.015
>>>>>>            Peak|        |  0.5565|    4.522
>>>>>> RxCan2[340] Avg|    7.75|  0.1693|    0.024
>>>>>>            Peak|        |  0.1868|    1.148
>>>>>> RxCan2[345] Avg|    1.60|  0.0292|    0.016
>>>>>>            Peak|        |  0.0316|    0.471
>>>>>> RxCan2[350] Avg|    0.00|  0.0000|    0.019
>>>>>>            Peak|        |  0.0000|    0.188
>>>>>> RxCan2[35e] Avg|    4.70|  0.0851|    0.019
>>>>>>            Peak|        |  0.0911|    1.023
>>>>>> RxCan2[360] Avg|    1.60|  0.0258|    0.015
>>>>>>            Peak|        |  0.0284|    0.306
>>>>>> RxCan2[361] Avg|    7.75|  0.1341|    0.017
>>>>>>            Peak|        |  0.1487|    0.761
>>>>>> RxCan2[363] Avg|    1.20|  0.0203|    0.016
>>>>>>            Peak|        |  0.0220|    0.421
>>>>>> RxCan2[370] Avg|    0.85|  0.0140|    0.016
>>>>>>            Peak|        |  0.0162|    0.354
>>>>>> RxCan2[381] Avg|    3.15|  0.0512|    0.016
>>>>>>            Peak|        |  0.0546|    0.416
>>>>>> RxCan2[3a0] Avg|   15.60|  0.2548|    0.015
>>>>>>            Peak|        |  0.2890|    0.976
>>>>>> RxCan2[3d0] Avg|    9.35|  0.1553|    0.019
>>>>>>            Peak|        |  0.1612|    1.115
>>>>>> RxCan2[3d5] Avg|    5.15|  0.0836|    0.016
>>>>>>            Peak|        |  0.0867|    0.479
>>>>>> RxCan2[3e0] Avg|    0.00|  0.0000|    0.014
>>>>>>            Peak|        |  0.0000|    0.142
>>>>>> RxCan2[400] Avg|    3.55|  0.0613|    0.017
>>>>>>            Peak|        |  0.0695|    0.501
>>>>>> RxCan2[405] Avg|    3.50|  0.0584|    0.018
>>>>>>            Peak|        |  0.0626|    0.686
>>>>>> RxCan2[40a] Avg|    7.10|  0.1278|    0.017
>>>>>>            Peak|        |  0.1389|    1.244
>>>>>> RxCan2[415] Avg|    1.60|  0.0258|    0.014
>>>>>>            Peak|        |  0.0287|    0.266
>>>>>> RxCan2[435] Avg|    0.85|  0.0165|    0.019
>>>>>>            Peak|        |  0.0167|    0.367
>>>>>> RxCan2[440] Avg|    0.85|  0.0128|    0.019
>>>>>>            Peak|        |  0.0141|    0.885
>>>>>> RxCan2[465] Avg|    0.95|  0.0177|    0.016
>>>>>>            Peak|        |  0.0195|    0.721
>>>>>> RxCan2[466] Avg|    0.95|  0.0147|    0.014
>>>>>>            Peak|        |  0.0160|    0.184
>>>>>> RxCan2[467] Avg|    0.95|  0.0172|    0.017
>>>>>>            Peak|        |  0.0188|    0.391
>>>>>> RxCan2[501] Avg|    1.45|  0.0273|    0.016
>>>>>>            Peak|        |  0.0327|    0.996
>>>>>> RxCan2[503] Avg|    1.45|  0.0288|    0.020
>>>>>>            Peak|        |  0.0338|    0.970
>>>>>> RxCan2[504] Avg|    1.40|  0.0241|    0.015
>>>>>>            Peak|        |  0.0263|    0.609
>>>>>> RxCan2[505] Avg|    1.40|  0.0255|    0.015
>>>>>>            Peak|        |  0.0296|    0.866
>>>>>> RxCan2[508] Avg|    1.35|  0.0237|    0.017
>>>>>>            Peak|        |  0.0237|    0.384
>>>>>> RxCan2[511] Avg|    1.35|  0.0226|    0.016
>>>>>>            Peak|        |  0.0228|    0.426
>>>>>> RxCan2[51e] Avg|    1.40|  0.0221|    0.014
>>>>>>            Peak|        |  0.0245|    0.211
>>>>>> RxCan2[581] Avg|    0.80|  0.0189|    0.019
>>>>>>            Peak|        |  0.0290|    1.217
>>>>>> RxCan2[606] Avg|    0.00|  0.0000|    0.014
>>>>>> RxCan2[657] Avg|    0.00|  0.0000|    0.014
>>>>>>            Peak|        |  0.0000|    0.137
>>>>>> Cmd:State   Avg|    0.00|  0.0000|    0.002
>>>>>>            Peak|        |  0.0000|    0.024
>>>>>>       Total Avg| 2748.42| 58.3344|   28.718
>>>>>> @Simon: it would be an option to try commenting out the overflow
>>>>>> counting, to see if that's causing the issue.
>>>>>> OVMS# poll time status
>>>>>>                | per s  | [%]    | [ms]
>>>>>> Poll:PRI    Avg|    1.00|  0.0045|    0.004
>>>>>>            Peak|        |  0.0046|    0.064
>>>>>> RxCan1[010] Avg|   34.26|  2.2574|    0.021
>>>>>>            Peak|        |  2.2574|    4.609
>>>>>> RxCan1[030] Avg|   34.26|  2.3820|    0.021
>>>>>>            Peak|        |  2.3820|    1.135
>>>>>> RxCan1[041] Avg|   49.89|  1.2059|    0.021
>>>>>>            Peak|        |  1.2295|    5.331
>>>>>> RxCan1[049] Avg|   49.96|  1.2400|    0.030
>>>>>>            Peak|        |  1.2699|    1.402
>>>>>> RxCan1[04c] Avg|   49.92|  1.1752|    0.021
>>>>>>            Peak|        |  1.2072|    4.502
>>>>>> RxCan1[04d] Avg|   34.31|  2.4433|    0.022
>>>>>>            Peak|        |  2.4773|    1.368
>>>>>> RxCan1[076] Avg|   49.96|  1.2071|    0.024
>>>>>>            Peak|        |  1.2554|    2.007
>>>>>> RxCan1[077] Avg|   49.96|  1.2012|    0.022
>>>>>>            Peak|        |  1.2492|    1.955
>>>>>> RxCan1[07a] Avg|   34.35|  2.9251|    0.030
>>>>>>            Peak|        |  3.1103|    1.829
>>>>>> RxCan1[07d] Avg|   49.96|  1.1954|    0.022
>>>>>>            Peak|        |  1.2282|    1.074
>>>>>> RxCan1[0c8] Avg|   49.89|  1.2491|    0.021
>>>>>>            Peak|        |  1.3169|    1.181
>>>>>> RxCan1[11a] Avg|   34.39|  2.4423|    0.024
>>>>>>            Peak|        |  2.5693|    1.491
>>>>>> RxCan1[130] Avg|   49.95|  1.1312|    0.020
>>>>>>            Peak|        |  1.1684|    1.218
>>>>>> RxCan1[139] Avg|   49.92|  1.1547|    0.021
>>>>>>            Peak|        |  1.1778|    1.199
>>>>>> RxCan1[156] Avg|    9.96|  0.2391|    0.023
>>>>>>            Peak|        |  0.2591|    1.943
>>>>>> RxCan1[160] Avg|   49.96|  1.1657|    0.031
>>>>>>            Peak|        |  1.2017|    2.158
>>>>>> RxCan1[165] Avg|   49.96|  1.1257|    0.021
>>>>>>            Peak|        |  1.1652|    1.471
>>>>>> RxCan1[167] Avg|   34.31|  2.2871|    0.021
>>>>>>            Peak|        |  2.3374|    1.776
>>>>>> RxCan1[171] Avg|   49.96|  1.1879|    0.023
>>>>>>            Peak|        |  1.2268|    1.166
>>>>>> RxCan1[178] Avg|   10.00|  0.2371|    0.029
>>>>>>            Peak|        |  0.2459|    1.516
>>>>>> RxCan1[179] Avg|   10.00|  0.2196|    0.021
>>>>>>            Peak|        |  0.2260|    0.758
>>>>>> RxCan1[180] Avg|   49.96|  1.1703|    0.022
>>>>>>            Peak|        |  1.2103|    1.481
>>>>>> RxCan1[185] Avg|   49.95|  1.1127|    0.020
>>>>>>            Peak|        |  1.1636|    1.292
>>>>>> RxCan1[1a0] Avg|   49.96|  1.1009|    0.020
>>>>>>            Peak|        |  1.1468|    1.060
>>>>>> RxCan1[1e0] Avg|   49.96|  1.1744|    0.021
>>>>>>            Peak|        |  1.2027|    1.240
>>>>>> RxCan1[1e4] Avg|   49.96|  1.3733|    0.032
>>>>>>            Peak|        |  1.4085|    1.523
>>>>>> RxCan1[1f0] Avg|   33.30|  0.7625|    0.023
>>>>>>            Peak|        |  0.8004|    3.349
>>>>>> RxCan1[200] Avg|   49.92|  1.1462|    0.021
>>>>>>            Peak|        |  1.1809|    1.254
>>>>>> RxCan1[202] Avg|   34.39|  2.4034|    0.028
>>>>>>            Peak|        |  2.5611|    1.472
>>>>>> RxCan1[204] Avg|   34.30|  2.2541|    0.022
>>>>>>            Peak|        |  2.2924|    2.015
>>>>>> RxCan1[213] Avg|   49.96|  1.1599|    0.027
>>>>>>            Peak|        |  1.1794|    1.714
>>>>>> RxCan1[214] Avg|   49.96|  1.1537|    0.022
>>>>>>            Peak|        |  1.1941|    1.439
>>>>>> RxCan1[217] Avg|   34.39|  2.2490|    0.020
>>>>>>            Peak|        |  2.2856|    3.766
>>>>>> RxCan1[218] Avg|   49.96|  1.1291|    0.021
>>>>>>            Peak|        |  1.1646|    1.547
>>>>>> RxCan1[230] Avg|   49.96|  1.1272|    0.020
>>>>>>            Peak|        |  1.2237|    1.295
>>>>>> RxCan1[240] Avg|   10.00|  0.2191|    0.021
>>>>>>            Peak|        |  0.2226|    1.067
>>>>>> RxCan1[242] Avg|   24.96|  0.6911|    0.024
>>>>>>            Peak|        |  0.7161|    1.180
>>>>>> RxCan1[24a] Avg|    9.96|  0.2345|    0.024
>>>>>>            Peak|        |  0.2535|    0.779
>>>>>> RxCan1[24b] Avg|    9.96|  0.2433|    0.023
>>>>>>            Peak|        |  0.2697|    2.085
>>>>>> RxCan1[24c] Avg|    9.96|  0.3103|    0.029
>>>>>>            Peak|        |  0.3203|    0.809
>>>>>> RxCan1[25a] Avg|   10.00|  0.2346|    0.022
>>>>>>            Peak|        |  0.2405|    1.223
>>>>>> RxCan1[25b] Avg|   49.89|  1.2121|    0.020
>>>>>>            Peak|        |  1.3659|   19.523
>>>>>> RxCan1[25c] Avg|   34.31|  2.4193|    0.019
>>>>>>            Peak|        |  2.8022|   58.153
>>>>>> RxCan1[260] Avg|    9.93|  0.2149|    0.024
>>>>>>            Peak|        |  0.2174|    1.096
>>>>>> RxCan1[270] Avg|   49.96|  1.2042|    0.026
>>>>>>            Peak|        |  1.2755|   20.612
>>>>>> RxCan1[280] Avg|   49.96|  1.0922|    0.020
>>>>>>            Peak|        |  1.1312|    1.266
>>>>>> RxCan1[2e4] Avg|   19.96|  0.6942|    0.044
>>>>>>            Peak|        |  0.8604|    1.533
>>>>>> RxCan1[2ec] Avg|   10.00|  0.3727|    0.025
>>>>>>            Peak|        |  0.5154|   28.819
>>>>>> RxCan1[2ed] Avg|   10.00|  0.2298|    0.023
>>>>>>            Peak|        |  0.2378|    1.345
>>>>>> RxCan1[2ee] Avg|    9.96|  0.2172|    0.019
>>>>>>            Peak|        |  0.2210|    1.058
>>>>>> RxCan1[312] Avg|   10.00|  0.2206|    0.020
>>>>>>            Peak|        |  0.2396|    1.060
>>>>>> RxCan1[326] Avg|    9.96|  0.2099|    0.020
>>>>>>            Peak|        |  0.2158|    0.507
>>>>>> RxCan1[336] Avg|    1.00|  0.0212|    0.020
>>>>>>            Peak|        |  0.0233|    0.315
>>>>>> RxCan1[352] Avg|    6.64|  0.1675|    0.024
>>>>>>            Peak|        |  0.1818|    1.048
>>>>>> RxCan1[355] Avg|    2.00|  0.0540|    0.027
>>>>>>            Peak|        |  0.0619|    1.209
>>>>>> RxCan1[35e] Avg|    9.98|  0.2221|    0.021
>>>>>>            Peak|        |  0.2284|    1.186
>>>>>> RxCan1[365] Avg|   10.00|  0.2282|    0.023
>>>>>>            Peak|        |  0.2335|    0.769
>>>>>> RxCan1[366] Avg|   10.00|  0.3163|    0.022
>>>>>>            Peak|        |  0.6330|   23.587
>>>>>> RxCan1[367] Avg|   10.00|  0.2417|    0.021
>>>>>>            Peak|        |  0.2568|    1.417
>>>>>> RxCan1[368] Avg|    9.96|  0.2187|    0.019
>>>>>>            Peak|        |  0.2250|    1.135
>>>>>> RxCan1[369] Avg|    9.99|  0.2277|    0.021
>>>>>>            Peak|        |  0.2334|    0.667
>>>>>> RxCan1[380] Avg|    9.96|  0.2133|    0.020
>>>>>>            Peak|        |  0.2161|    0.560
>>>>>> RxCan1[38b] Avg|   24.92|  0.5622|    0.022
>>>>>>            Peak|        |  0.5716|    1.618
>>>>>> RxCan1[3b3] Avg|   10.00|  0.2132|    0.023
>>>>>>            Peak|        |  0.2194|    1.106
>>>>>> RxCan1[400] Avg|    4.00|  0.0885|    0.019
>>>>>>            Peak|        |  0.0885|    0.570
>>>>>> RxCan1[405] Avg|    3.70|  0.1414|    0.036
>>>>>>            Peak|        |  0.1414|    0.710
>>>>>> RxCan1[40a] Avg|    8.00|  0.1887|    0.021
>>>>>>            Peak|        |  0.1887|    1.027
>>>>>> RxCan1[410] Avg|   10.00|  0.2141|    0.023
>>>>>>            Peak|        |  0.2188|    0.984
>>>>>> RxCan1[411] Avg|   10.00|  0.2325|    0.023
>>>>>>            Peak|        |  0.2447|    0.660
>>>>>> RxCan1[416] Avg|   10.00|  0.2326|    0.022
>>>>>>            Peak|        |  0.2389|    0.774
>>>>>> RxCan1[421] Avg|   10.00|  0.2245|    0.021
>>>>>>            Peak|        |  0.2271|    1.160
>>>>>> RxCan1[42d] Avg|   10.00|  0.2315|    0.021
>>>>>>            Peak|        |  0.2411|    0.677
>>>>>> RxCan1[42f] Avg|   10.00|  0.2480|    0.020
>>>>>>            Peak|        |  0.2975|    8.093
>>>>>> RxCan1[430] Avg|   10.00|  0.2203|    0.019
>>>>>>            Peak|        |  0.2302|    0.847
>>>>>> RxCan1[434] Avg|   10.00|  0.2331|    0.019
>>>>>>            Peak|        |  0.2620|    1.150
>>>>>> RxCan1[435] Avg|    6.68|  0.1445|    0.020
>>>>>>            Peak|        |  0.1486|    1.063
>>>>>> RxCan1[43e] Avg|   20.00|  0.4515|    0.021
>>>>>>            Peak|        |  0.4632|    1.013
>>>>>> RxCan1[440] Avg|    1.00|  0.0210|    0.019
>>>>>>            Peak|        |  0.0218|    0.294
>>>>>> RxCan1[465] Avg|    0.95|  0.0214|    0.023
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20250120/a9ad8fb0/attachment-0001.sig>
